POV-Ray : Newsgroups : povray.binaries.images : Ringworld (continued) Server Time
15 Oct 2026 16:44:49 EDT (-0400)
  Ringworld (continued) (Message 1 to 50 of 81)
Goto Latest 50 Messages Next 31 Messages >>>
Subject: Ringworld (continued)
Date: 6 Aug 2018 17:15:23
Message: <5b68ba6b@news.povray.org>
An old scene, but I've been sprucing it up in preparation toward
uploading it to the Object Collection. I can't remember if it's to
proper scale however. Also I'm thinking there may be a little too much
cloud cover.
Mike
Download 'ringworld_fullscale_save_04.png' (533 KB)
Preview of image 'ringworld_fullscale_save_04.png'
Subject: Re: Ringworld (continued)
Date: 6 Aug 2018 17:34:46
Message: <5b68bef6$1@news.povray.org>
> cloud cover.
> Mike
Also, due to the sun being an area light, the unlit regions are much too
small.
Mike
Date: 7 Aug 2018 02:22:49
Message: <5b693ab9$1@news.povray.org>
>> cloud cover.
>> Mike
> small.
I got similar results when I tried it. I suspect Larry Niven got his
maths wrong. I had to move the shadow plates closer to the Ringworld to
get the day/night cycle equal.
Regards
Date: 7 Aug 2018 02:42:33
Message: <5b693f59$1@news.povray.org>
>>> much cloud cover.
>>> Mike
>> too small.
That, or scale down the area_light's effective surface. At this
planetary scale the area effect would be hardly noticeable imo.
Date: 7 Aug 2018 04:20:07
Message: <5b695637$1@news.povray.org>
>>>> much cloud cover.
>>>> Mike
>>> too small.
>> to get the day/night cycle equal.
He is not the only one who got his maths wrong. Of course I meant closer
to the star.
A point light gives the same result.
Regards
Date: 7 Aug 2018 05:02:36
Message: <5b69602c$1@news.povray.org>
>>>>> much cloud cover.
>>>>> Mike
>>>> too small.
> to the star.
Right. I would suggest then to test with a point light, following
Stephen's maths, then try some area_light until it fits.
Date: 7 Aug 2018 06:29:48
Message: <5b69749c@news.povray.org>
>>>>>> much cloud cover.
>>>>>> Mike
>>>>> much too small.
>> closer to the star.
No, don't follow my maths.
Using the data from this site. I did a quick model.
http://www.alcyone.com/max/reference/scifi/ringworld.html
I adjusted the Shadow square ring radius until the day/night cycle
looked equal.(multiplied the radius by 0.587587699)
Regards
Download 'ring_3_0000.png' (14 KB)
Preview of image 'ring_3_0000.png'
Date: 7 Aug 2018 06:33:04
Message: <5b697560$1@news.povray.org>
A close up of the terminator on the Ringworld.
The area light does make a difference.
Using
  light_source {  // Light_Source2
   < 0.000000, 0.000000, 0.000000 >, colour rgb <1.000,1.000,1.000>*1.500
   area_light <3.400000,0.000000,0.000000>,
<0.000000,3.400000,0.000000>, 23, 23
   circular
   orient
   adaptive 5
Regards
Download 'ring_2bm2_0000.png' (9 KB)
Preview of image 'ring_2bm2_0000.png'
Date: 7 Aug 2018 06:51:15
Message: <5b6979a3$1@news.povray.org>
Am 07.08.2018 um 12:33 schrieb Stephen:
> Using
>   area_light <3.400000,0.000000,0.000000>, <0.000000,3.400000,0.000000>,
> 23, 23
>   circular
>   orient
>   adaptive 5
And it better does. You don't want the light to blink off
instantaneously - you do want some twilight time.
Date: 7 Aug 2018 07:07:49
Message: <5b697d85$1@news.povray.org>
>> Using
>> 23, 23
>>    circular
>>    orient
>>    adaptive 5
I agree. What I meant earlier was that, with the camera at /planetary/
distances from the ring, the penumbra would hardly be visible. Up close,
and more so on the ring surface, of course the penumbra matters.
However, if the area_light is set while the camera is at a /planetary/
distance, it will most probably be grossly exaggerated because otherwise
you would not be able to see it properly in a render.
Date: 7 Aug 2018 07:09:07
Message: <5b697dd3$1@news.povray.org>
>> Using
>> 23, 23
>>    circular
>>    orient
>>    adaptive 5
That is the whole idea, I believe. ;)
As for maths the area_light axis vectors should be doubled to 6.8 not 3.4
I was thinking radius as opposed to diameter.
Regards
Date: 7 Aug 2018 07:23:24
Message: <5b69812c$1@news.povray.org>
>>> Using
>>> 23, 23
>>>    circular
>>>    orient
>>>    adaptive 5
Do you mean that the penumbra would need to be exaggerated so it can be
seen?
I thought that too but when I created two big sticks located at opposite
sides of the star and clipping the same edge of a shadow square. The
divergence at the ring was quite large.
I might try moving the shadow square radius back to the quoted radius
and adjust the length of the shadow square to get equal day/night.
This image was taken from slightly beyond the other side of the ring and
above a bit.
Regards
Download 'ring_3c_0000.png' (17 KB)
Preview of image 'ring_3c_0000.png'
Date: 7 Aug 2018 08:01:39
Message: <5b698a23$1@news.povray.org>
As threatened. :-)
Twilight is less obvious.
Regards
Download 'ring_4_0000.png' (14 KB)
Preview of image 'ring_4_0000.png'
Date: 7 Aug 2018 10:31:57
Message: <5b69ad5d@news.povray.org>
> Using
>    circular
>    orient
>    adaptive 5
The 23, 23  get bumped up to 33, 33
adaptive 5 mean start at subdivision 5, or start with 33, 33 samples.
This effectively disable the adaptive optimization.
In the present case, adaptive 0 is good.
adaptive 0 start at 2 by 2
adaptive 1 start at 3 by 3
adaptive 2 start at 5 by 5
adaptive 3 start at 9 by 9
adaptive 4 start at 17 by 17
adaptive 5 start at 33 by 33
adaptive 6 start at 65 by 65
You need a number of samples at least 2 step up to get some appreciable
benefit. For adaptive 0, use at least 5 by 5, and 9 by 9 or more in most
cases.
For adaptive 1, better to start around 17 by 17.
For adaptive 5, you start to see an improvement around 129 by 129...
Date: 7 Aug 2018 11:20:32
Message: <5b69b8c0@news.povray.org>
>> Using
>>    circular
>>    orient
>>    adaptive 5
> cases.
Thanks Alain, I seldom use area lights and this is the first time I have
used adaptive.
When you said samples is that what the offline help names Size_1 &
Size_2, in the line;
AXIS_1_VECTOR, AXIS_2_VECTOR, Size_1, Size_2?
Regards
Date: 7 Aug 2018 15:22:10
Message: <5b69f162$1@news.povray.org>
I tried a point light, and the day/night cycles were equal. But Niven
did specify the size of the star, and I checked my other numbers against
his and they match.
Mike
Date: 7 Aug 2018 15:28:48
Message: <5b69f2f0$1@news.povray.org>
You just reminded me that I used the sun radius instead of diameter for
the area light axes.
When instead using the diameter, I get some fuzziness but no real "night".
Sorry, Niven. Your math is bad.
Mike
Date: 7 Aug 2018 17:52:59
Message: <5b6a14bb$1@news.povray.org>
I now feel better. ;)
You don't have an "ambient" in there? (Before Clipka says anything. ;) )
Funnily enough, I did not notice that when I read the books. ;)
It is PovRay's fault. It is too realistic. :)
I think it is better to bring the shadow shields nearer the sun, for the
data I found.
This last image (I promise) using Alain's settings, has a stary
background to show that the night part of the ring is occluding the stars.
BTW Thanks for starting the thread. It has been a distraction for me
when I don't feel up to starting a new project.
Regards
Download 'ring_3d_0000.png' (16 KB)
Preview of image 'ring_3d_0000.png'
Date: 7 Aug 2018 18:39:51
Message: <5b6a1fb7$1@news.povray.org>
> data I found.
Hold on. I just noticed I wasn't using the correct sizes for the shadow
squares. And I had 40 of them instead of 20. I will need to redo them.
Mike
Date: 8 Aug 2018 02:22:44
Message: <5b6a8c34$1@news.povray.org>
> As threatened. :-)
Yes, but I think it is looking natural from that distance. On the ring,
twilight would be gradual, as expected.
Date: 8 Aug 2018 03:34:51
Message: <5b6a9d1b$1@news.povray.org>
>> As threatened. :-)
I think so too. The image I posted yesterday at 22:52, my time. Does
show the gradual darkening. The render did take an hour and a half to
complete.
Regards
Date: 8 Aug 2018 03:36:12
Message: <5b6a9d6c$1@news.povray.org>
>> the data I found.
>> stars.
The way of the world. :)
Regards
Date: 8 Aug 2018 07:08:27
Message: <5b6acf2b$1@news.povray.org>
>>>> radius and adjust the length of the shadow square to get equal
>>>> day/night.
>>> As threatened. :-)
>> ring, twilight would be gradual, as expected.
> complete.
I often need to take stock again and again of the gigantic distances and
sizes we are dealing with in a planetary system. It is something quite
difficult to grasp, and rendering things like the Ringworld makes us
forget them, reducing them to simple rings to be taken into our hands ;-)
Date: 8 Aug 2018 10:08:38
Message: <5b6af966$1@news.povray.org>
Okay, I uploaded my scene to here:
http://lib.povray.org/searchcollection/index2.php?objectName=Ringworld&version=2.0&contributorTag=SharkD
I also attached my latest render to this post. The shadow squares'
widths now match what was apparently stated in the books. The shadowed
regions on the ring look much better now.
However, I had to double the height of the shadow squares in order to
block out the sun. See the parameter `RWorld_Shadow_Square_Width`. I'm
not sure why this was necessary, as the original height was equal to the
sun's diameter, and should have fully blocked its light.
Oh well.
Mike
Download 'ringworld_foggy_save_03.png' (99 KB)
Preview of image 'ringworld_foggy_save_03.png'
Date: 8 Aug 2018 13:05:24
Message: <5b6b22d4$1@news.povray.org>
Do the two area_light vectors <Axis_1> and <Axis_2> extend beyond the
star's volume?
> Oh well.
I like the image especially the shadows cast by the shadow squares in
the solar wind. :)
Unfortunately I don't have CIE.inc or lightsys.inc installed. :(
Regards
Date: 8 Aug 2018 15:35:01
Message: <web.5b6b44f994c089801b6c6b3a0@news.povray.org>
Yay for more Ringworld! Nice image.
I don't remember any of the details any more, but I remember spending time going
through the book for measurements and descriptions when I last tried this (some
years ago now), and I don't recall any issues like you describe. Someone
mentioned ambient in the foregoing discussion - of course, the lit areas of the
Ring would cast secondary light onto the night areas. I'm sure Niven mentioned
arch-light in place of moonlight somewhere...
And of course his maths was bad - he had to write an entire sequel novel just to
deal with the Ringworld's intrinsic instability ;-)
Bill
Date: 8 Aug 2018 16:17:18
Message: <5b6b4fce$1@news.povray.org>
There is a link on this site. ;)
http://www.infradead.org/~wmp/proj_rings.html
He did, I had forgotten.
Regards
Date: 8 Aug 2018 16:57:50
Message: <5b6b594e$1@news.povray.org>
Thanks!
> Bill
I am using the stats from Niven's website:
http://news.larryniven.net/concordance/content.asp?page=Ringworld%20Appendix#Params
Mike
Date: 8 Aug 2018 17:02:17
Message: <5b6b5a59@news.povray.org>
>> the sun's diameter, and should have fully blocked its light.
> star's volume?
1. the axis lengths are equal to the sun's diameter
2. the area light is circular and oriented
3. the sun's diameter should be equal to the shadow squares' height
according to Niven's website
4. an array of point lights in the shape of a sphere does not suffer
from the issues I'm experiencing
>> Oh well.
> the solar wind. :)
Thanks!
I use them in nearly everything. Not sure why. Probably just habit.
Mike
Date: 8 Aug 2018 17:12:27
Message: <5b6b5cbb$1@news.povray.org>
> used adaptive.
Yes, Size_1 and Size_2.
AXIS_1_VECTOR and AXIS_2_VECTOR set the extent of the area_light.
Size_1 and Size_2 set the number of components, or samples, in the
area_light.
When using orient, the pairs need to be of the same size. The
AXIS_n_VECTORs need to have the same length and be perpendicular.
And, you need Size_1 = Size_2.
When using adaptive, always start with adaptive 0 and only increase if
you really need to.
Date: 8 Aug 2018 17:35:33
Message: <5b6b6225$1@news.povray.org>
>>> shadowed regions on the ring look much better now.
>>> I'm not sure why this was necessary, as the original height was equal
>>> to the sun's diameter, and should have fully blocked its light.
>> star's volume?
Just a check list.
I just noticed that the data I was looking at was from the game. Oops.
How do you do that without them clustering at the poles?
>>> Oh well.
>> the solar wind. :)
> Thanks!
Probably a good habit to have.
Regards
Date: 8 Aug 2018 17:36:54
Message: <5b6b6276$1@news.povray.org>
>> have used adaptive.
> area_light.
> you really need to.
Thanks for the advice Alain
Regards
Date: 8 Aug 2018 19:32:18
Message: <5b6b7d82@news.povray.org>
I am dumb. Instead of specifying the area light's axis vectors in the
form of:
     x * foo, y * foo
I was instead simply using:
     foo, foo
which is the same as:
     <foo,foo,foo>, <foo,foo,foo>
which is too long.
I fixed that and things are fine now. Doing another really big render at
the moment. It might take over a day to render.
Mike
Date: 8 Aug 2018 19:37:18
Message: <5b6b7eae$1@news.povray.org>
>>>> to block out the sun. See the parameter
>>>> `RWorld_Shadow_Square_Width`. I'm not sure why this was necessary,
>>>> as the original height was equal to the sun's diameter, and should
>>> star's volume?
Oops! I screwed up here. See my other post. They're fixed now.
> Just a check list.
Here's a scan from the game:
https://img.fireden.net/tg/image/1464/06/1464060167901.jpg
The shadow squares seem much smaller than they should be.
I don't. They do cluster! I should investigate a "good enough" sphere
packing formula.
>>>> Oh well.
>>> the solar wind. :)
>> Thanks!
Date: 9 Aug 2018 02:07:25
Message: <5b6bda1d@news.povray.org>
Here's a partial render.
I would like to make the edge of the sun a bit sharper, and also make
the sun smaller while keeping the haze generally the same. Here is the
sphere I use for this:
#declare RWorld_Corona_Radius			= 95000*4;
#declare RWorld_Corona_Object = sphere
     0, RWorld_Corona_Radius
     hollow
     material
         texture
             pigment {rgbt 1}
         interior
             media
                 scattering {1, RWorld_Light_Point_Color/2000}
                 density
                     function {1/(x*x + y*y + z*z)/RWorld_Corona_Radius}
                     density_map
                         [0.0 rgb 0]
                         [1.0 rgb 1]
                     scale RWorld_Corona_Radius
Any idea on how I can accomplish this?
Download 'sdsadasdsa.png' (273 KB)
Preview of image 'sdsadasdsa.png'
Date: 9 Aug 2018 02:40:48
Message: <5b6be1f0$1@news.povray.org>
>      hollow
>      material
>          texture
>              pigment {rgbt 1}
>          interior
>              media
>                  density
>                      density_map
>                          [0.0 rgb 0]
>                          [1.0 rgb 1]
I would suggest to play with the settings of the density_map. Not
tested, but something like:
density_map {
   [0.00 rgb 0.0]
   [0.90 rgb 0.9]
   [0.90 rgb 1.0]
Date: 9 Aug 2018 04:10:48
Message: <5b6bf708@news.povray.org>
> density_map {
>    [0.00 rgb 0.0]
>    [0.90 rgb 0.9]
>    [0.90 rgb 1.0]
Yeah, I thought of that too, but haven't been successful.
I also tried changing the formula so that x y and z are cubed instead of
squared, but it turned the whole image black!
Meh.
Mike
Date: 9 Aug 2018 07:11:56
Message: <5b6c217c$1@news.povray.org>
Translating from the mind's eye to reality is always a problem with
planetary scales.
I wonder if it is possible to use a log rather than a linear scale along
the axis.
Regards
Date: 9 Aug 2018 07:32:44
Message: <5b6c265c$1@news.povray.org>
>> density_map {
>>    [0.00 rgb 0.0]
>>    [0.90 rgb 0.9]
>>    [0.90 rgb 1.0]
> Meh.
> Mike
I tested this and it looks acceptable to me:
#local MyScale = 10;
sphere {
   0, 1
   hollow
   texture {pigment {rgbt 1}}
   interior {
     media {
       emission 3/MyScale
       density{
         spherical
         density_map {
           [0.10 rgb <0.0, 0, 0.0>]
           [0.95 rgb <1.0, 1.0, 1.0>*0.2]
           [0.95 rgb <1.0, 1.0, 1.0>]
   scale MyScale
Instead of 'spherical', you may need something else more appropriate. I
have problems with the function you use for the density map.
Date: 9 Aug 2018 07:41:49
Message: <5b6c287d$1@news.povray.org>
>> and sizes we are dealing with in a planetary system. It is something
>> quite difficult to grasp, and rendering things like the Ringworld
>> makes us forget them, reducing them to simple rings to be taken into
>> our hands ;-)
> planetary scales.
Indeed. It is not just a matter of scaling up or scaling down the model.
More is involved.
> the axis.
I'll leave that to my betters, but it might be an interesting and
worthwhile experiment.
Date: 9 Aug 2018 10:15:01
Message: <web.5b6c4b6a94c08980c437ac910@news.povray.org>
the sun smaller
Draw out the graph of the density you want, and then add those functions
together.  Make use of select() if you have to.
I think there is a way to use splines in functions as well.
Date: 9 Aug 2018 13:15:27
Message: <5b6c76af$1@news.povray.org>
>>>> the star's volume?
>> Just a check list.
It looks deliberate to give unequal day night cycles.
I can't remember what the book said.
> packing formula.
 From my reading. There is no general solution for placing equidistant
points on a sphere. :(
I have managed to extract the coords of a Blender Icosphere which is
made up of equilateral triangles. 42 points, a bit on the high side for
lights. If it is any use here they are.
BTW Blender used Z up coords.
         <0.000000, 0.000000, -1.000000>,
         <0.723607, -0.525725, -0.447220>,
         <-0.276388, -0.850649, -0.447220>,
         <-0.894426, 0.000000, -0.447216>,
         <-0.276388, 0.850649, -0.447220>,
         <0.723607, 0.525725, -0.447220>,
         <0.276388, -0.850649, 0.447220>,
         <-0.723607, -0.525725, 0.447220>,
         <-0.723607, 0.525725, 0.447220>,
         <0.276388, 0.850649, 0.447220>,
         <0.894426, 0.000000, 0.447216>,
         <0.000000, 0.000000, 1.000000>,
         <-0.162456, -0.499995, -0.850654>,
         <0.425323, -0.309011, -0.850654>,
         <0.262869, -0.809012, -0.525738>,
         <0.850648, 0.000000, -0.525736>,
         <0.425323, 0.309011, -0.850654>,
         <-0.525730, 0.000000, -0.850652>,
         <-0.688189, -0.499997, -0.525736>,
         <-0.162456, 0.499995, -0.850654>,
         <-0.688189, 0.499997, -0.525736>,
         <0.262869, 0.809012, -0.525738>,
         <0.951058, -0.309013, 0.000000>,
         <0.951058, 0.309013, 0.000000>,
         <0.000000, -1.000000, 0.000000>,
         <0.587786, -0.809017, 0.000000>,
         <-0.951058, -0.309013, 0.000000>,
         <-0.587786, -0.809017, 0.000000>,
         <-0.587786, 0.809017, 0.000000>,
         <-0.951058, 0.309013, 0.000000>,
         <0.587786, 0.809017, 0.000000>,
         <0.000000, 1.000000, 0.000000>,
         <0.688189, -0.499997, 0.525736>,
         <-0.262869, -0.809012, 0.525738>,
         <-0.850648, 0.000000, 0.525736>,
         <-0.262869, 0.809012, 0.525738>,
         <0.688189, 0.499997, 0.525736>,
         <0.162456, -0.499995, 0.850654>,
         <0.525730, 0.000000, 0.850652>,
         <-0.425323, -0.309011, 0.850654>,
         <-0.425323, 0.309011, 0.850654>,
         <0.162456, 0.499995, 0.850654>
Regards
Date: 9 Aug 2018 14:30:03
Message: <web.5b6c881294c089801b6c6b3a0@news.povray.org>
Ha, that's me told. I'd forgotten that page was still up! I keep meaning to
redesign the site, it looks nice but could do with being a little more
minimalistic methinks...
Bill
Date: 9 Aug 2018 15:05:18
Message: <5b6c906e$1@news.povray.org>
> Ha, that's me told.
That's me. Stevie Subtly McAvoy. ;)
Anything to get you involved again. :)
In your own time.
Regards
Date: 9 Aug 2018 16:15:00
Message: <web.5b6c9fa494c089801b6c6b3a0@news.povray.org>
> > Ha, that's me told.
I'm still around, lurking! Too many small children afoot for sustained povraying
at the moment. I can never resist a Ringworld tho :D
> In your own time.
I made a start a few years back, but never got around to the main site.
Something like this:
http://www.infradead.org/~wmp/polyhedra/poly_index.html
Date: 10 Aug 2018 01:36:05
Message: <5b6d2445@news.povray.org>
Latest render. Took roughly a whole day to render. I think I'm done with
this scene for the time being.
Mike
Download 'ringworld_regular_save_09.png' (653 KB)
Preview of image 'ringworld_regular_save_09.png'
Date: 10 Aug 2018 02:23:47
Message: <5b6d2f73$1@news.povray.org>
> Mike
Well, that looks good, doesn't it? Well done.
Date: 10 Aug 2018 03:09:29
Message: <5b6d3a29$1@news.povray.org>
>> with this scene for the time being.
>> Mike
I would go as far as saying very good. :D
Regards
Date: 10 Aug 2018 17:29:32
Message: <5b6e03bc$1@news.povray.org>
>>> Mike
THANK YOU!!!
Date: 16 Aug 2018 06:53:42
Message: <5b7557b6$1@news.povray.org>
>>> Ha, that's me told.
> at the moment.
o_O
^_^
I wish we had made a "Ringworld from the surface" round in TC-RTC. But I
suppose that it would have been too hard. I certainly found the scales
very difficult to work with.
>> In your own time.
Tease! No code. :(
They look good. I like the settings.
Regards
