POV-Ray : Newsgroups : povray.binaries.images : Ringworld (continued) Server Time
10 Apr 2026 06:03:09 EDT (-0400)
  Ringworld (continued) (Message 1 to 10 of 81)
Subject: Ringworld (continued)
Date: 6 Aug 2018 17:15:23
Message: <5b68ba6b@news.povray.org>
An old scene, but I've been sprucing it up in preparation toward
uploading it to the Object Collection. I can't remember if it's to
proper scale however. Also I'm thinking there may be a little too much
cloud cover.
Mike
Download 'ringworld_fullscale_save_04.png' (533 KB)
Preview of image 'ringworld_fullscale_save_04.png'
Subject: Re: Ringworld (continued)
Date: 6 Aug 2018 17:34:46
Message: <5b68bef6$1@news.povray.org>
> cloud cover.
> Mike
Also, due to the sun being an area light, the unlit regions are much too
small.
Mike
Date: 7 Aug 2018 02:22:49
Message: <5b693ab9$1@news.povray.org>
>> cloud cover.
>> Mike
> small.
I got similar results when I tried it. I suspect Larry Niven got his
maths wrong. I had to move the shadow plates closer to the Ringworld to
get the day/night cycle equal.
Regards
Date: 7 Aug 2018 02:42:33
Message: <5b693f59$1@news.povray.org>
>>> much cloud cover.
>>> Mike
>> too small.
That, or scale down the area_light's effective surface. At this
planetary scale the area effect would be hardly noticeable imo.
Date: 7 Aug 2018 04:20:07
Message: <5b695637$1@news.povray.org>
>>>> much cloud cover.
>>>> Mike
>>> too small.
>> to get the day/night cycle equal.
He is not the only one who got his maths wrong. Of course I meant closer
to the star.
A point light gives the same result.
Regards
Date: 7 Aug 2018 05:02:36
Message: <5b69602c$1@news.povray.org>
>>>>> much cloud cover.
>>>>> Mike
>>>> too small.
> to the star.
Right. I would suggest then to test with a point light, following
Stephen's maths, then try some area_light until it fits.
Date: 7 Aug 2018 06:29:48
Message: <5b69749c@news.povray.org>
>>>>>> much cloud cover.
>>>>>> Mike
>>>>> much too small.
>> closer to the star.
No, don't follow my maths.
Using the data from this site. I did a quick model.
http://www.alcyone.com/max/reference/scifi/ringworld.html
I adjusted the Shadow square ring radius until the day/night cycle
looked equal.(multiplied the radius by 0.587587699)
Regards
Download 'ring_3_0000.png' (14 KB)
Preview of image 'ring_3_0000.png'
Date: 7 Aug 2018 06:33:04
Message: <5b697560$1@news.povray.org>
A close up of the terminator on the Ringworld.
The area light does make a difference.
Using
  light_source {  // Light_Source2
   < 0.000000, 0.000000, 0.000000 >, colour rgb <1.000,1.000,1.000>*1.500
   area_light <3.400000,0.000000,0.000000>,
<0.000000,3.400000,0.000000>, 23, 23
   circular
   orient
   adaptive 5
Regards
Download 'ring_2bm2_0000.png' (9 KB)
Preview of image 'ring_2bm2_0000.png'
Date: 7 Aug 2018 06:51:15
Message: <5b6979a3$1@news.povray.org>
Am 07.08.2018 um 12:33 schrieb Stephen:
> Using
>   area_light <3.400000,0.000000,0.000000>, <0.000000,3.400000,0.000000>,
> 23, 23
>   circular
>   orient
>   adaptive 5
And it better does. You don't want the light to blink off
instantaneously - you do want some twilight time.
Date: 7 Aug 2018 07:07:49
Message: <5b697d85$1@news.povray.org>
>> Using
>> 23, 23
>>    circular
>>    orient
>>    adaptive 5
I agree. What I meant earlier was that, with the camera at /planetary/
distances from the ring, the penumbra would hardly be visible. Up close,
and more so on the ring surface, of course the penumbra matters.
However, if the area_light is set while the camera is at a /planetary/
distance, it will most probably be grossly exaggerated because otherwise
you would not be able to see it properly in a render.
