![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Still with ample room for (technical) improvements, and as yet only the
start of the intended scene.
- The landscape is - as usual - made with GeoControl. As I try to
improve my use of programs from scene to scene (who doesn't?) I opted
here for as large a terrain size as possible (4096x4096) in order to
increase the level of details, the scene itself taking only a small part
of the whole.
- The river water was what the discussion in p.general was about a few
days ago. The surface consist of a height_field based on a grey-scale
stream pattern image_map created in GIMP over an orthographic view of
the landscape. The 'foam' on the water was the feature giving me
problems initially [for completeness sake:
http://news.povray.org/povray.general/thread/%3C5b0d3e84%241%40news.povray.org%3E/
]. It's image_pattern, also a grey-scale image, was also drawn in the
same way but its use inside a texture { } needed some transformations.
The result is pretty good, especially in the background where rapids are
suggested. The foreground is less convincing and I reduced the foam
accordingly. Overall, the tweaking of the different texture settings
took most of the time.
- The rock fall at the base of the cliffs is composed of a randomly
transformed mesh object, altitude- and slope-controlled. In particular,
the rocks become bigger higher on the slopes, as also - in about 20
percent of the cases - below the water surface.
- The clouds are based on a df3 object (thanks to Gilles Tran).
And now, back to the drawing board!
Download 'crossing border_05.jpg' (242 KB)
Preview of image 'crossing border_05.jpg'
![crossing border_05.jpg](/povray.binaries.images/attachment/%3C5b10efd2%40news.povray.org%3E/crossing%20border_05.jpg?ttop=443840&toff=750&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Beautiful landscape!
Being on my side of the Atlantic, when I saw the subject line, I half
expected a rendering of a huge wall and immigration police rounding
people up.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks!
> people up.
You are not wrong, but... ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Thanks!
>> people up.
It is too mountainous for the Irish border. Unless it is metaphorical.
The striations on either side of the valley look different. Is that a
hint to scale?
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Thanks!
>>> people up.
Only partly so. Just wait and see ;-)
> hint to scale?
They are two different things and both are present on both sides, only
in the shadows the finer striation is less pronounced. The colour
banding can be seen as changes of sediment composition over time; the
finer, tabular, striations represent the lithification process of the
sequence, also over time but on an even larger time scale than the former.
As this last striation is a normal, it is less visible in the shadows,
although normal is 'on' in the radiosity block.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> hint to scale?
That's what I thought I was seeing but explained well.
I like the effect as I said. It gives a sense of scale.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am running three slightly different landscapes in parallel. Here is
the third variation which probably will become the principal one. I also
tweaked the rocks and the foam.
Download 'crossing border_3_01.jpg' (252 KB)
Preview of image 'crossing border_3_01.jpg'
![crossing border_3_01.jpg](/povray.binaries.images/attachment/%3C5b152035%40news.povray.org%3E/crossing%20border_3_01.jpg?ttop=443840&toff=750&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
