POV-Ray : Newsgroups : povray.binaries.images : Isosurface problem - how to create real ridges? Server Time
31 Jan 2025 01:58:33 EST (-0500)
  Isosurface problem - how to create real ridges? (Message 1 to 3 of 3)
Subject: Isosurface problem - how to create real ridges?
Date: 10 Feb 2018 07:31:59
Message: <5a7ee63f@news.povray.org>
Hi(gh)!
Returning to my "Whatmough" project from 2011, I now tried to create the
entire planet Whatmough as an isosurface in the first place - by
gleaning parameters from the heightfield generator software "Wilbur",
which also uses the ridged multifractal function.
But something is strange: the ridges form grooves in the surface rather
than sticking out as mountain ranges, as you can see in the attached
image, I tried several combinations of positive and negative function
parameters, but did not succeed in getting rid of this...
Here is the code:
#include "functions.inc"
#declare sc = 10000; // universal scaling factor
#declare T_Whatmough_Solid =
texture
   pigment { color rgb <0, 0.8, 0> }
   finish { ambient 0.05 diffuse 1 brilliance 1.5 }
#declare S =
function { x*x + y*y + z*z -1 } // spherical isosurface
#declare Whatmough_Terrain_Function =
function { S(x, y, z) +  f_ridged_mf(-x, -y, -z, 1, 1.9, 7, 1, 2, 1)/50 }
#declare Whatmough =
isosurface
   function { Whatmough_Terrain_Function(x,y,z)/2 }
   contained_by
     sphere { 0, 1.2 }
   max_gradient 20
   accuracy 0.00000001
   double_illuminate
   texture { T_Whatmough_Solid }
   scale 5902.45/sc
light_source
   0
   color rgb 1
   looks_like
     sphere // HD 28185
       0, 723528/sc
       pigment { color rgb 1 }
       finish { ambient 1 }
sphere // HD 28185 glow
   0, 1
   hollow
   texture
     pigment { color rgbft <1, 1, 1, 0.5, 0.5> }
   interior
     media
       emission rgb <1, 1, 0.82>/(723528*7/sc)
       density
         spherical
         poly_wave 4
   scale 723528*7/sc
#declare HD_28185_b =
sphere
   0, 1
   texture
     pigment { color rgb <0.6, 0.6, 0.85> }
     finish { ambient 0.05 diffuse 1 brilliance 0.9 }
   scale <68332, 67045, 68332>/sc
#declare HD_28185_b_Dist = 154200000/sc;
#declare HD_28185_b_AngPos = 156;
#declare HD_28185_b_Pos =
HD_28185_b_Dist*<sin(radians(HD_28185_b_AngPos)), 0,
cos(radians(HD_28185_b_AngPos))>;
#declare Whatmough_Dist = 912580/sc;
#declare Whatmough_AngPos = 254;
#declare Whatmough_Pos = HD_28185_b_Pos +
Whatmough_Dist*<sin(radians(Whatmough_AngPos)), 0,
cos(radians(Whatmough_AngPos))>;
#declare camDist = 30000/sc;
#declare cam_AngPos = 16;
#declare camPos = Whatmough_Pos + camDist*<sin(radians(cam_AngPos)), 0,
cos(radians(cam_AngPos))>;
object
   HD_28185_b
   translate HD_28185_b_Pos
object
   Whatmough
   translate Whatmough_Pos
camera
   location camPos
   look_at Whatmough_Pos
   angle 40
Any suggestions?
See you in Khyberspace!
Yadgar
Download '2018-02-10 whatmough, take 1.png' (80 KB)
Preview of image '2018-02-10 whatmough, take 1.png'
Subject: Re: Isosurface problem - how to create real ridges?
Date: 10 Feb 2018 08:10:01
Message: <web.5a7eee0030e961385cafe28e0@news.povray.org>
Sure, just change it to:
function { S(x, y, z) -  f_ridged_mf(-x, -y, -z, 1, 1.9, 7, 1, 2, 1)/50 }
                      ^ minus
Date: 10 Feb 2018 18:46:24
Message: <5a7f8450$1@news.povray.org>
Hi(gh)!
>                        ^ minus
Yes, that's the ticket (as you can see in the attached image... thank you!
After that, I started an animation showing the rotating planet
(technically, it is an almost Earth-sized moon of exoplanet HD 28185 b),
which will be completed this night (CET) and then published on
YouTube... watch out!
Then, I plan to generate cylindrical topographic maps of Whatmough like
I did with Ghurghusht back in 2010, also in very large scales to place
vegetation, buildings and traffic systems on the planet!
Yadgar
Download 'whatmough_planet-.png' (49 KB)
Preview of image 'whatmough_planet-.png'
