POV-Ray : Newsgroups : povray.binaries.images : Clothed in light. Server Time
22 Nov 2026 10:19:02 EST (-0500)
  Clothed in light. (Message 1 to 35 of 35)
Subject: Clothed in light.
Date: 13 Nov 2017 15:27:50
Message: <5a0a0046@news.povray.org>
The tunic and wings are emissive df3s, made from Poser models.
I think I need a dragon and a rocky scene to complete this. :)
Regards
Download 'studio_vic2cm_0000.png' (726 KB)
Preview of image 'studio_vic2cm_0000.png'
Subject: Re: Clothed in light.
Date: 14 Nov 2017 03:03:45
Message: <5a0aa361$1@news.povray.org>
Yes indeed although I like this ballet school setting with the mirrors.
A couple of things, if I may: (1) the overhead lights should be dimmed -
probably by at least 50 % (if not 25%) also for compensating the light
reflections from the mirrors. (2) Could you merge this scene with your
ballerina animation? That was awesome.
Date: 14 Nov 2017 04:57:32
Message: <5a0abe0c$1@news.povray.org>
It is old enough to have been made in Moray. :-)
The lighting is problematic. The light in the hall of mirrors brightens
when I switch on radiosity. I did not mean this to turn into an
experiment in radiosity but it looks looks like it is going to be. I
have a normal area light in there to even things out.
Hmm! has anyone told you that you have an evil mind, recently?
As if I haven't enough to do. ;-)
It is an interesting challenge though. First I have to find out why when
I create the df3s there is a problem with the handiness. Or more likely
with my set up. Then unless I wanted to make a df3 that coveres the
whole playing area. I would need to work out a method of tracking the
mesh to move the slicing rig there.
On the brighter side. jr is working on a set of utilities for df3s. So
it might be possible in the future.
Regards
Date: 14 Nov 2017 08:57:09
Message: <5a0af635$1@news.povray.org>
Am 14.11.2017 um 10:57 schrieb Stephen:
>> - probably by at least 50 % (if not 25%) also for compensating the
>> light reflections from the mirrors.
Problems with different "quality levels" of illumination are to be
expected here, due to the huge mirrors as well as the glowing wings.
In reality, objects in the room would be lit by...:
(1) Light coming directly from the light sources.
(2a) Light bouncing off diffuse objects.
(2b) Light emitted by glowing stuff.
(3a) Light bouncing off diffuse objects and then the mirrors.
(3b) Light emitted by glowing stuff and bouncing off the mirrors.
(4) Light coming from the light sources and bouncing off the mirrors.
(5) Light bouncing off the mirrors and then diffuse objects.
To simulate (1), "classic" raytracing will do.
To simulate (2) and (3), you need to enable radiosity.
To simulate (4), you need to enable photons.
To simulate (5), you need to enable both radiosity and photons.
If any of these are not simulated, the corresponding portion of
illumination will simply be missing, causing the image to appear darker.
The lack of illumination from (2), (3) and (5) can be compensated for to
some degree, by making use of the "ambient" mechanism.
As far as overall brightness goes, you should ideally use renders with
radiosity and photons as a yardstick, and set up "ambient" accordingly
for fast test renders.
(As a faster alternative to photons for this particular scene, you might
try using mirrored copies of your primary light sources,
`projected_through` the corresponding mirrors. Make sure to properly
account for any dimming effect if your mirrors aren't 100% reflective.)
Date: 14 Nov 2017 16:32:53
Message: <5a0b6105@news.povray.org>
Thanks, they aren't, they are about 95% reflective. But I've ditched the
ordinary light source and am using emissive cubes as light sources.
I was thinking of adding a scattering media container first. Before
trying photons.
Regards
Download 'studio_vic2d_y_901a1_0000.png' (764 KB)
Preview of image 'studio_vic2d_y_901a1_0000.png'
Date: 14 Nov 2017 17:00:00
Message: <web.5a0b663753fdf90589df8d30@news.povray.org>
As the mirror reflections indicate, your dance hall has mirrors on only two
walls. I wonder what would happen re: radiosity and photon complexity if all
four walls were mirrored?! (The 'infinite mirror-reflection' thing.) I have no
idea, but it sounds like an interesting experiment to try. ;-)
Date: 14 Nov 2017 17:05:00
Message: <web.5a0b67b753fdf90589df8d30@news.povray.org>
> `projected_through` the corresponding mirrors...
That's an interesting trick, that I wouldn't have thought of. Thanks.
Date: 14 Nov 2017 17:40:43
Message: <5a0b70eb$1@news.povray.org>
> walls.
Three mirrored walls in fact. I chose the camera position so that I
wouldn't have much of a hall of mirrors, effect.Just a view of three sides.
So you want that I give my machine a stress test? ;)
Of course I'll give it a go. :)
Regards
Date: 14 Nov 2017 19:00:34
Message: <5a0b83a2@news.povray.org>
Not so bad. Less than 6 minutes
No AA nor photons. Max Level 53/64
Regards
Download 'studio_vic2d_y_901a2x_0000.png' (773 KB)
Preview of image 'studio_vic2d_y_901a2x_0000.png'
Date: 15 Nov 2017 02:54:24
Message: <5a0bf2b0$1@news.povray.org>
No. Nobody dares to. ;-)
I knew it was a difficult question, but I am confident in the results :-)
Date: 15 Nov 2017 02:54:48
Message: <5a0bf2c8$1@news.povray.org>
Oh! That is good!
Date: 15 Nov 2017 04:08:52
Message: <5a0c0424$1@news.povray.org>
No one living. I'm sure. ;-)
>> when I create the df3s there is a problem with the handiness. Or more
>> likely with my set up. Then unless I wanted to make a df3 that coveres
>> the whole playing area. I would need to work out a method of tracking
>> the mesh to move the slicing rig there.
It is an interesting problem and a long term one too. Just looking at
the sums. A five second animation @ 25 fps will produce about 180 Gigs
of data in tga and df3s. I reckon that if I can automate the process it
would take about a hundred hours to produce them. So not a project for
the faint hearted.
* Note the correct usage of the at sign. :-)
Regards
Date: 15 Nov 2017 07:10:57
Message: <5a0c2ed1$1@news.povray.org>
>>> coveres the whole playing area. I would need to work out a method of
>>> tracking the mesh to move the slicing rig there.
>>> So it might be possible in the future.
> the faint hearted.
Dear me, yes, I had not really realised this.
Date: 15 Nov 2017 21:25:00
Message: <web.5a0cf6b553fdf9055cafe28e0@news.povray.org>
This is coming along very nicely :)
I like this second version a lot - the camera position just works better I
think.
Enhancements:
Maybe someone can contribute a proximity pattern to add some depth to the skin
texture.   It also looks to me like either she has no pupils, or her eyelids are
closed, depending upon the size of the image...
I'm sure some of us have some slightly richer looking wood floor macros lying
about. ;)
Is there a way to light the room with HDRI?
Maybe just surround the room with one and add no_shadow?
Just throwing out ideas before turning in for the night.
Subject: Re: Not Clothed in light. So partial nudity
Date: 16 Nov 2017 05:24:28
Message: <5a0d675c@news.povray.org>
Thanks but you are not seeing it from this side of the screen. *
> think.
That was just because Kenneth wanted a hall of mirrors.
Remember that this is not an exhibition image but a test image for the
df3s. I placed it in my studio because of the flack I got for Lanya's
dress. ;-)
I'm thinking of using the studio for my test environment because of
getting three additional views of the subject.
> Enhancements:
Here is a close up as changing the eyes in Poser was the only change I
made there.
FYI the female model is a low res one. I don't think it even uses an
image map for the body. So if I wanted more detail I would change it in
Poser. Besides I don't want to get distracted by looking at the model. ;-)
> about. ;)
As I implied to Thomas. The studio is a very old scene. At least ten
years old if I made it in Moray. So any contributions are welcome. :-)
I'm not too keen on that idea. I don't think it would work with three
walls of mirrors. I'm aware of the need for some sort of background.
That is why there are a couple of old chairs and a stack of mats. At one
time I had a table with a stereo and a mop and bucket. Just for interest.
Thanks. I'm flattered over a test image.
* I have no idea why in this image the wings and clothes did not show.
With the render time they should have been there.
But at least you can see that the model is low res and the eyes.
I had two other unexpected results yesterday that has set me back a bit. :-(
Regards
Download 'studio_vic2d_y_903a1_0000.png' (497 KB)
Preview of image 'studio_vic2d_y_903a1_0000.png'
Date: 16 Nov 2017 06:45:01
Message: <web.5a0d79d4967568795cafe28e0@news.povray.org>
Our hidden cameras see EVERYTHING.
Now get back to desk and continue laboring.
> made there.
And the tip of the sword has disappeared - obviously a green screen.
"GIRL WITH WINGS BRANDISHED SWORD IN DANCE STUDIO"
Fake news to forward the agenda to disarm scantily clad females.
> > about. ;)
I'll see what I can isolate from the Secret Passage scene.
You'd think there would be a well developed wood floor macro or include file -
and having had to write the code to make an acceptable wood floor, I can see why
there might not be one.
> walls of mirrors.
I think you miss my point -
I was thinking about using the HDR _only_ as a light source - the image wouldn't
be visible in the scene at all (unless you had windows).
I have very little experience with HDR, so perhaps someone could comment on how
that might best be implemented, if at all.
Because media.
That's why media drives me crazy.
And that's always the case, isn't it - there's always _something_ to start a
cascade of stumbling blocks.
Date: 16 Nov 2017 07:32:02
Message: <5a0d8542$1@news.povray.org>
>> better I
>> think.
> dress. ;-)
In itself, that is a good idea. However, you may come across situations
where mirrors are not really appropriate for a testing environment.
Personally, I am currently working on a "studio lighting" test scene for
objects like sculptures, with three light sources (and a dim hdri).
To be sure, the object/texture determines what kind of environment it
needs best for testing.
>> Enhancements:
[snip]
>> macros lying
>> about. ;)
I have a macro, modified from work by Dan Hentschel in 2004. I shall put
it in p.b.utilities.
Hm... is the camera very close to the model? maybe there is some
interference...
Date: 16 Nov 2017 08:21:17
Message: <5a0d90cd$1@news.povray.org>
How did you know that I'm a card carrying member of the Labour party? :-P
>> made there.
White out I assume.
A variation on the traditional "Dirk Dance, for the Elder Races".
She is actually facing down a Kelpie.
There is a lot of talk about that in the news atm. I am aware of it and
approve, if the truth be told. But since we have become a gentleman's
club again. I don't suppose anyone will notice.
>>> about. ;)
There is one to lay cobblestones/bricks in regular patterns but not for
floors. As far as I know.
I think I would want parquet flooring for my dance studio. None of those
big planks with gaps and splinters. :P
"Stand up for your feet and your feet will stand up for you." One of my
maxims in life. :)
>> walls of mirrors.
I still don't see it for an inside scene. Not going from the HDR images
I've seen. But if you can find what looks like a suitable one. I'll give
it a go.
Since you gave me the idea for my next masterpiece. ;) I will use HDR in
"Dirk Dance, for the Elder Races". I have a couple of ideas for the Kelpie.
> Because media.
I have to relearn it every time I stop using it. It will stick one of
these days.
This is making me doubt my sanity. I'll strip the scene down to it's
essentials and see what's going on.
Regards
Date: 16 Nov 2017 09:13:41
Message: <5a0d9d15$1@news.povray.org>
Am 16.11.2017 um 12:43 schrieb Bald Eagle:
HDRI illumination is just a poor man's substitute for a proper scene. So
if you already have a complete room, there's no point in using HDRI for
illumination. (As a matter of fact it would be counter-productive, as it
would illuminate the objects in a way that wouldn't match the scenes.)
Date: 16 Nov 2017 10:10:00
Message: <web.5a0daa1896756879c437ac910@news.povray.org>
Indeed - but so many of us are poor - we have pockets empty of silver, jingling
round-tuits.
> So
> illumination.
Well...
I might not go that far - I thought that the whole idea with a light probe was
the high dynamic range.
Perhaps there's a way to achieve the same effect with a "proper scene" - but I'd
probably need a tutorial.
True, but I was thinking that there were warehouse HDRI's out there that might
be roughly equivalent to the dance studio.
Also - some of the best images are often the least "realistic".
Date: 16 Nov 2017 13:17:49
Message: <5a0dd64d$1@news.povray.org>
That's my gut feeling in English.
Regards
Date: 16 Nov 2017 14:20:01
Message: <web.5a0de49e9675687923dc70330@news.povray.org>
Nice. In the back mirror the wings seems to appear under the hairs...
How did you make this red hair? Meshes?
Date: 16 Nov 2017 15:04:21
Message: <5a0def45@news.povray.org>
Am 16.11.2017 um 16:09 schrieb Bald Eagle:
>> So
>> illumination.
> Well...
Actually, the primary idea in "high dynamic range light probe" is the
light probe part -- having something for your objects to reflect and be
illuminated by, without having to actually model that something. The
"high dynamic range" part merely solves a bottleneck that limited the
usefulness of light probes, namely the quality at which they could be
stored in image files.
That bottleneck does not exist when your backdrop and illumination
source is a genuine scene rather than just a fancy picture.
As a matter of fact, you're benefiting from POV-Ray's internal high
dynamic range capabilities each time you use a classic light source with
a brightness value above 1. (Or even values below that, if you're using
the "albedo" syntax for specular highlights.)
Date: 16 Nov 2017 15:59:48
Message: <5a0dfc44$1@news.povray.org>
Yes a standard Poser hair mesh. It takes no account of intersecting with
other meshes,
Regards
Date: 16 Nov 2017 17:55:01
Message: <web.5a0e15d09675687989df8d30@news.povray.org>
> >> walls of mirrors.
> > image wouldn't be visible in the scene at all (unless you had windows).
> it a go.
Clipka wrote...
I'm still a virgin when it comes to trying out HDRI... but Clipka's comments
raise some questions for me (or else/maybe they clarify something that I've
always wondered about.)
My assumption of HDRI has always been that it's basically meant to take the
place of scene lights-- and that it's *most* useful for Sun-lit scenes-- i.e., a
light probe image with the Sun actually visible. (OR, something like an indoor
light probe with several candles as the only illumination.) And that the
rendered scene uses the MUCH-brighter Sun (or small candle flames) *as* the
*distinct* light source(s)-- those sources naturally casting scene-object
shadows as if they are actual bright lights-- and with the rest of the light
probe image functioning more or less as a straight environnment map, for the
remaining soft lighting. (Like typical radiosity results when using a
low-dynamic range image on a large sphere.) In other words, the only real reason
for an HDRI light probe would be for its VERY bright lights, relative to the
rest of its image.
That's my own naive understanding, anyway.
For an enclosed room like the dance hall, it seems to me that a typical LDR
image-plus-radiosity would give equally realistic results (unless the room
contained a SUPER-bright light somewhere.)
Date: 17 Nov 2017 00:00:47
Message: <5a0e6cff$1@news.povray.org>
Am 11/16/2017 03:59 PM, also sprach Stephen:
> other meshes,
That hair looks phenomenal from a distance. I thought you had
photoshopped it in for a second. ;)
dik
Date: 17 Nov 2017 02:54:00
Message: <5a0e9598@news.povray.org>
>>> Enhancements:
> [snip]
>>> macros lying
>>> about. ;)
This is what it does.
Download 'dh_woodfloor_2.png' (495 KB)
Preview of image 'dh_woodfloor_2.png'
Date: 17 Nov 2017 05:43:57
Message: <5a0ebd6d$1@news.povray.org>
>>>> Enhancements:
>> [snip]
>>>> macros lying
>>>> about. ;)
>> put it in p.b.utilities.
That looks good.
Regards
Date: 17 Nov 2017 05:56:58
Message: <5a0ec07a$1@news.povray.org>
>>>> walls of mirrors.
>> it a go.
> Clipka wrote...
> rest of its image.
Mine too.
 From what I've seen of studios. They are either at the top of a
building with large windows and maybe two mirrored walls. Or have no
windows and rely totally on artificial light. Giving a even a light as
possible.
I don't think it would work in this scene. But if you find one that
could be appropriate. I'll run it overnight.
Regards
Date: 17 Nov 2017 06:09:39
Message: <5a0ec373$1@news.povray.org>
>> with other meshes,
Yes it does look good. It is a Poser character called Amarseda Hair. I
had to use extreme settings to get it to go back with as few
intersections as possible.
There were several girls in my school with hair that colour. Their
tempers were about the same. ;-)
Regards
Date: 17 Nov 2017 08:00:01
Message: <web.5a0edc2e96756879c437ac910@news.povray.org>
> > > about. ;)
This probably needs to be prettied up to make it generally useful, but see how
this works.   (you may have to translate the floor -y*16*12)
// Planked Hardwood Floor with borders
// Bill Walker "Bald Eagle"  2014
// Some textures based on code supplied by Thomas deGroot
// and Nicolas Rougier
http://news.povray.org/povray.binaries.images/message/%3C54367691%241%40news.povray.org%3E/#%3C54367691%241%40news.povr
ay.org%3E
#version 3.7;
//######################## CONTROL PANEL SETTINGS ##########################
global_settings{
 assumed_gamma 1.0
 ambient_light rgb 0
 max_trace_level 7
 #if (Radiosity)
  radiosity {
   pretrace_start 1 //  0.08
   pretrace_end   1 //  0.04  //  0.01
   count 35    //  150
   nearest_count 5   //  10
   error_bound 1.8  //  0.5
   recursion_limit 2
   low_error_factor 0.5
   gray_threshold 0.0
   minimum_reuse 0.015   //  0.005
   maximum_reuse 0.2
   brightness 1
   adc_bailout 0.01    //  0.005
  }  // end radiosity block
 #else
  }// end global settings
#include "functions.inc"
#include "math.inc"
#include "metals.inc"
#include "rand.inc"
//#include "screen.inc"  //  perspective camera only
#include "shapes.inc"
#include "shapes2.inc"
#include "textures.inc"
#include "transforms.inc"
#include "woods.inc"
#declare Feet = 12;
  #declare Camera_Position = < -1.5*Feet, (18+6)*Feet,  -9*Feet> ;  // front
view
  #declare Camera_Look_At  = <  2*Feet,  16 *  Feet,  18*Feet> ;
  #declare Camera_Angle    =  65 ;
  location Camera_Position
         right    x*image_width/image_height
         angle    Camera_Angle
         look_at  Camera_Look_At
light_source {<1500, 750, -200> color rgb <1, 0.8, 0>*5}  //  Sun
 light_source {<0*Feet, 25*Feet, 4*Feet> color rgb <1, 1, 1>*0.3}
#declare PlankNormal = normal { gradient x 2
    slope_map {
     [0.00 <0, 1>]
     [0.05 <1, 0>]
     [0.95 <1, 0>]
     [1.00 <0,-1>]
    scale 2
#declare Tone = 1;
#declare YRotate = 0;
#declare DarkWood= rgb <71, 35, 1>;
//(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)
(o)
(o)
#declare OakFloor = texture {
   pigment {bozo scale <1, 1, 10>
   color_map {
   //[0.4 rgb <0.9, 0.7, 0.4> * Tone]
   //[0.6 rgb <1.0, 0.8, 0.6> * Tone]
   [0.0 rgb <121/255,  52/255, 13/255> * Tone]
   [0.2 rgb <142/255,  73/255, 18/255> * Tone]
   [0.4 rgb <184/255, 115/255, 48/255> * Tone]
   [0.6 rgb <157/255,  81/255, 23/255> * Tone]
   [0.8 rgb <108/255,  45/255,  4/255> * Tone]
   [1.0 rgb <156/255,  72/255, 26/255> * Tone]
  turbulence 0.5
  scale <1, 1, 10> * 0.5
  rotate y*YRotate
 normal {
  average normal_map {
     [1 PlankNormal]
     [1 wood 0.5
      slope_map {
      [0.0 <0.0, 0>]
      [0.5 <0.5, 1>]
      [1.0 <1.0, 0>]
      }  // end slope map
     turbulence 0.5 scale <1, 1, 10> * 0.5]
    }  // end normal map
    rotate y * YRotate
  }  // end normal
   finish { specular 0.2 reflection 0.1 }  //  finish { specular 0.5 reflection
0.2 }
 }  // end texture
(o)
(o)
#declare Tone = <1.2, 1.2, 0.3>;
#declare OakFloor =
     wood
     color_map {
       [0.0 srgb <121,  52, 13>/255 * Tone]
       [0.2 srgb <142,  73, 18>/255 * Tone]
       [0.4 srgb <184, 115, 48>/255 * Tone]
       [0.6 srgb <157,  81, 23>/255 * Tone]
       [0.8 srgb <108,  45,  4>/255 * Tone]
       [1.0 srgb <156,  72, 26>/255 * Tone]
     warp {turbulence <0.6, 0.1, 0.1>}
     scale <1, 1, 10>*0.5
     scale 0.3
     rotate 1*x
     rotate y*10
(o)
(o)
//============= NR_Wood (2003) =============
#declare NR_wood_grain =
   wood
   warp {cylindrical orientation y dist_exp 1}
   warp {turbulence 1.25}
   scale <0.5, 30, 1>
   warp {turbulence 0.25}
   scale <1, 10, 1>
   warp {
     black_hole <0, 0.5, 0>, 1
     falloff 2
     strength 1.5
     repeat 7
     turbulence 2
     inverse
#declare NR_wood_normal =
function {
     wood
     scale <0.5, 30, 1>
     scale <1, 5, 1>
     color_map {[0 rgb <0, 0, 0>] [1 rgb <1, 1, 1>]}
#declare NR_woodmap =
color_map {
     [0.00 srgb <0.949, 0.792, 0.514 >]
     [0.30 srgb <0.855, 0.651, 0.376 >]
     [0.60 srgb <0.831, 0.596, 0.275 >]
     [0.90 srgb <0.620, 0.447, 0.204 >]
#declare NR_woodmap2 =
     color_map {
       [0.1 srgb <142,  73, 18>/255 * Tone]
       [0.3 srgb <184, 115, 48>/255 * Tone]
       [0.8 srgb <157,  81, 23>/255 * Tone]
       //[0.8 srgb <108,  45,  4>/255 * Tone]
#declare Tone2 = Tone * 1.05;
#declare NR_woodmap3 =
     color_map {
       [0.0 srgb <121,  52, 13>/255 * Tone2]
       [0.1 srgb <142,  73, 18>/255 * Tone2]
       [0.3 srgb <184, 115, 48>/255 * Tone2]
       [0.8 srgb <157,  81, 23>/255 * Tone2]
       //[0.8 srgb <108,  45,  4>/255 * Tone2]
       [1.0 srgb <156,  72, 26>/255 * Tone2]
#declare Tone3 = Tone * 0.95;
#declare NR_woodmap4 =
     color_map {
       [0.0 srgb <121,  52, 13>/255 * Tone3]
       [0.1 srgb <142,  73, 18>/255 * Tone3]
       [0.3 srgb <184, 115, 48>/255 * Tone3]
       [0.8 srgb <157,  81, 23>/255 * Tone3]
       //[0.8 srgb <108,  45,  4>/255 * Tone3]
       [1.0 srgb <156,  72, 26>/255 * Tone3]
#declare FloorNormal = 0.8;
#declare NR_Wood =
   pigment {NR_wood_grain
     color_map {NR_woodmap2}
     ramp_wave
   normal {
     function {NR_wood_normal(x,y,z).grey*FloorNormal
   finish {diffuse 0.6 specular 0.1 roughness 0.005}
#declare NR_Wood2 =
     color_map {NR_woodmap3}
     ramp_wave
   normal {
#declare NR_Wood3 =
     color_map {NR_woodmap4}
     ramp_wave
   normal {
(o)
(o)
//#declare OakFloor = texture {NR_Wood scale 1 rotate <90, 0, 0>};
#declare HalfWidth    =  19.0;
#declare MortarScale  =  0.99;  //  0.995;
#declare TunnelRadius =  1.5;
#declare RoomWidth    =  9.0;
#declare PlankScale   =  1.78;
#declare FloorBorder =
union {
 #declare BorderSize = 2;
 //Left
 box {<-(RoomWidth*Feet)+0, -0.1, -9*Feet>, <-(RoomWidth*Feet)+(2*BorderSize),
2.0, 18*Feet> texture {NR_Wood2 scale 1 rotate <90, 0, 0>}}
 box {<-(RoomWidth*Feet)+(2*BorderSize), -0.1, -9*Feet>,
<-(RoomWidth*Feet)+(6*BorderSize), 2.0, 18*Feet> pigment {srgb <121,  52,
13>/255 * Tone3}}//texture {NR_Wood3 scale 1 rotate <90, 0, 0>}}
 #declare BlockRow = -(9*Feet);
 #declare Alternate = 1;
 #while (BlockRow < (18*Feet))
  #if (Alternate > 0)
   box {<-(RoomWidth*Feet)+(2*BorderSize+0.25), -0.1, BlockRow+0.25>,
<-(RoomWidth*Feet)+(6*BorderSize-0.25), 2.1, BlockRow+1.75> texture {NR_Wood
scale 1 rotate <90, 90, 0>}}
  #else
<-(RoomWidth*Feet)+(6*BorderSize-0.25), 2.1, BlockRow+1.75> texture {NR_Wood2
  #declare BlockRow = BlockRow + (1*BorderSize);
  #declare Alternate = -Alternate;
 box {<-(RoomWidth*Feet)+(6.0*BorderSize), -0.1, -9*Feet>,
<-(RoomWidth*Feet)+(7.5*BorderSize), 2.0, 18*Feet> texture {NR_Wood2 scale 1
rotate <90, 0, 0>}}
 box {<-(RoomWidth*Feet)+(7.5*BorderSize), -0.1, -9*Feet>,
<-(RoomWidth*Feet)+(8.0*BorderSize), 2.0, 18*Feet> pigment {srgb <121,  52,
13>/255 * Tone3}}
 // Right
 box {<(RoomWidth*Feet)-0, -0.1, -9*Feet>, <(RoomWidth*Feet)-(2*BorderSize),
 box {<(RoomWidth*Feet)-(2*BorderSize), -0.1, -9*Feet>,
<(RoomWidth*Feet)-(6*BorderSize), 2.0, 18*Feet> pigment {srgb <121,  52, 13>/255
  #if (Alternate > 0)
   box {<(RoomWidth*Feet)-(2*BorderSize+0.25), -0.1, BlockRow+0.25>,
<(RoomWidth*Feet)-(6*BorderSize-0.25), 2.1, BlockRow+1.75> texture {NR_Wood
  #else
<(RoomWidth*Feet)-(6*BorderSize-0.25), 2.1, BlockRow+1.75> texture {NR_Wood2
 box {<(RoomWidth*Feet)-(6*BorderSize), -0.1, -9*Feet>,
<(RoomWidth*Feet)-(7.5*BorderSize), 2.0, 18*Feet> texture {NR_Wood2 scale 1
rotate <90, 0, 0>}}
 box {<(RoomWidth*Feet)-(7.5*BorderSize), -0.1, -9*Feet>,
<(RoomWidth*Feet)-(8*BorderSize), 2.0, 18*Feet> pigment {srgb <121,  52, 13>/255
* Tone3}}
 // Back
 box {<-(RoomWidth*Feet)+12, -0.1, 18*Feet-0>,
<(RoomWidth*Feet)-12, 2.0, 18*Feet-(2*BorderSize)> texture {NR_Wood2 scale 1
 box {<-(RoomWidth*Feet)+12, -0.1, 18*Feet-(2*BorderSize)>,
<(RoomWidth*Feet)-12, 2.0, 18*Feet-(6*BorderSize)> pigment {srgb <121,  52,
13>/255 * Tone3}}
 #declare BlockRow = -(RoomWidth*Feet)+12;
 #while (BlockRow < (RoomWidth*Feet)-12)
  #if (Alternate > 0)
   box {<BlockRow+0.25, -0.1, 18*Feet-(2*BorderSize+0.25)>, <BlockRow+1.75, 2.1,
18*Feet-(6*BorderSize)-0.25> texture {NR_Wood  scale 1 rotate <90, 0, 0>}}
  #else
18*Feet-(6*BorderSize)-0.25> texture {NR_Wood2 scale 1 rotate <90, 0, 0>}}
 box {<-(RoomWidth*Feet)+12, -0.1, 18*Feet-(6.0*BorderSize)>,
<(RoomWidth*Feet)-12, 2.0, 18*Feet-(7.5*BorderSize)> texture {NR_Wood2 scale 1
 box {<-(RoomWidth*Feet)+12, -0.1, 18*Feet-(7.5*BorderSize)>,
<(RoomWidth*Feet)-12, 2.0, 18*Feet-(8*BorderSize)> pigment {srgb <121,  52,
13>/255 * Tone3}}
 // Front
 box {<-(RoomWidth*Feet)+12, -0.1, -9*Feet+0>, <(RoomWidth*Feet)-12, 2.0,
-9*Feet+4> texture {NR_Wood2 scale 1 rotate <90, 0, 0>}}
 box {<-(RoomWidth*Feet)+12, -0.1, -9*Feet+4>, <(RoomWidth*Feet)-12, 2.0,
-9*Feet+8> texture {NR_Wood3 scale 1 rotate <90, 0, 0>}}
 box {<-(RoomWidth*Feet)+12, -0.1, -9*Feet+8>, <(RoomWidth*Feet)-12, 2.0,
-9*Feet+12> texture {NR_Wood2 scale 1 rotate <90, 0, 0>}}
 translate y*18*Feet
}  // end union
//  Wood Floor building loop
#debug "Building Floor \n"
#declare BL   = seed (113);
#declare Rx   = seed (356);
#declare Ry   = seed (876);
#declare Rz   = seed (159);
#declare Flip = seed (542);
#declare Offset = 10*Feet;
#declare Floor =
union {
 #declare Row = -RoomWidth*Feet;
 #while (Row < RoomWidth*Feet)
  #debug concat("Building Row#", str(Row, 3, 0), " \n")
  //#debug concat("Center: <" vstr (3, Middle, ", ", 0, 1), ">, Radius:",
str(Radius, 3, 4), " \n")
  #declare OverallLength = 0;
  #declare BoardNo = 1;
  #while (OverallLength < 27)
   #declare RotY = SRand(BL)*5;
   #declare Randx = rand(Rx) * Offset;
   #declare Randy = rand(Ry) * Offset;
   #declare Randz = rand(Rz) * Offset;
   #declare BoardLength = (int(rand (BL)*4)+1)*3;
   #if (rand (Flip) > 0.5)
    #declare Amt = 180;
   #else
    #declare Amt = 0;
   #if (rand (Flip) < 0.3)
   #elseif (rand (Flip) > 0.6)
    #declare OakFloor = texture {NR_Wood2 scale 1 rotate <90, 0, 0>};
   #else
    #declare OakFloor = texture {NR_Wood3 scale 1 rotate <90, 0, 0>};
   #debug concat("Board#", str(BoardNo, 3, 0)," | Rotation:", str(Amt+RotY, 3,
0), " | Overall:", str(OverallLength, 3, 0)," \n")
   #declare FloorPlank = box {<Row, 0, (OverallLength-9)*Feet>, <Row+4 -
(rand(Rx)*(1/4)), 1.99, ((OverallLength-9+BoardLength)*Feet) -
(rand(Rz)*(1/8))>}
   object {FloorPlank texture {OakFloor rotate y*RotY translate <Randx, Randy,
Randz>} }
   #declare OverallLength = OverallLength + BoardLength;
   #declare BoardNo = BoardNo + 1;
 #declare Row = Row + 4;
 box {<-RoomWidth*Feet, (18*Feet), -9*Feet>, <RoomWidth*Feet, (18*Feet)+1.99,
18*Feet>
  texture {OakFloor} texture {pigment {rgbt <0, 0, 0, 0.4>}} }  //  Dark cracks
between floorboards
}  // end union
object {Floor translate y*18*Feet}
object {FloorBorder}
Download 'woodfloor.png' (461 KB)
Preview of image 'woodfloor.png'
Date: 17 Nov 2017 08:48:00
Message: <5a0ee890$1@news.povray.org>
Thanks, that looks good. I'll need to modify it a bit as B3D doesn't
handle functions. But that shouldn't be too hard.
Regards
Date: 17 Nov 2017 08:52:58
Message: <5a0ee9ba@news.povray.org>
Oops! the camera was inside the media container.
This is what it was meant to be like. After taking two hours with no AA
nor mirrors. I am posting it. ;-)
Regards
Download 'studio_vic2d_y_903at_1_0000.png' (355 KB)
Preview of image 'studio_vic2d_y_903at_1_0000.png'
Date: 18 Nov 2017 03:12:55
Message: <5a0feb87$1@news.povray.org>
On 17-11-2017 13:55, Bald Eagle wrote:
>>>> about. ;)
So. I /totally/ forgot about this :-O
Well done indeed. I need to update some of my files I believe ;-)
Date: 19 Nov 2017 02:57:15
Message: <5a11395b@news.povray.org>
I managed to look at your code.
I worked my way through it correcting the wrap text/CR-LF errors,
created by T/Bird. Then I substituted the Normals with their fancy
Functions. (B3D cannot handle Functions.)
When I imported the macro into B3D it showed that the scaling of the
studio is all to cock. So I will need to rebuild it before I can use
your macro. That is a shame as the border looks good. For simplicity
I've "borrowed" Warp's code from his "4 tips" tutorial and I've changed
the scale of the model to make it fit in better with the furniture and
props. So this will be the last image in this test.
Regards
Download 'studio_vic2d_y_905a_0000.png' (1109 KB)
Preview of image 'studio_vic2d_y_905a_0000.png'
