POV-Ray : Newsgroups : povray.binaries.images : QUESTION: Bump not showing? Server Time
22 Nov 2026 10:19:02 EST (-0500)
  QUESTION: Bump not showing? (Message 1 to 50 of 91)
Goto Latest 50 Messages Next 41 Messages >>>
Subject: QUESTION: Bump not showing?
Date: 15 Jul 2017 20:40:24
Message: <596ab5f8@news.povray.org>
I never actually used bump_maps before. Now I try to use one, but not
seeing any effect. Can someone assist me?
The scene contains a stratosphere helium balloon, and the bump_map
should have created the typical balloon surface. However, I don't see
the surface changed. Before posting any images, I show you the scene
file. is there any error the way I do it?
#version 3.7;
#include "kolors.inc"
#include "finish.inc"
#include "textures.inc"
#declare MyRadiosity = off;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
 subsurface        {}
 adc_bailout       0.0039
 ambient_light     rgb < 0.000, 0.000, 0.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 location < -000.0, 400.0, -500.0 >
 look_at < 0.0, -200.0, 0.0 >
 right 1.77*x
light_source
 < 2500.0, 2500.0, 5000.0 >
 rgb < 0.72265625, 0.8046875, 0.80859375 > *10.0
#declare MyRadius = 200.0;
#declare MyOuterBalloonFinish = finish
// reflection   0.00
 crand        0.10
#declare MyInnerBalloonFinish = finish
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
#declare MyOuterBalloonTexture = texture
 pigment
  image_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher
- Balloon - Type 001 - Moon Runnings - Balloon Texture.png" }
  translate -0.5
  rotate < 90.0, 0.0, 0.0 >
  scale MyRadius*2
 normal
  bump_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher -
Balloon - Type 001 - Moon Runnings - Balloon BumpMap.png" gamma 1.8
bump_size 150.0 }
  translate -0.5
  scale MyRadius*2
 finish { MyOuterBalloonFinish }
#declare MyInnerBalloonTexture = texture
 pigment { color rgb < 0.7686275,  0.7607843,  0.7333333 > }
 finish { MyInnerBalloonFinish }
#declare UpperBalloonShape = torus     // Balloon Radius: 175 m /
Launcher Radius: 10 m
 95.0, 105.0
 scale < 1.0, 0.5, 1.0 >
#declare LowerBalloonShape = difference
 sphere { < 0.0, 0.0, 0.0 > MyRadius }
 cylinder { < 0.0, 0.0, 0.0 > < 0.0, 175.001, 0.0 > MyRadius+0.001 }
 scale < 1.0, 1.5, 1.0 >
#declare MyBalloonHullOutside = union
 object { UpperBalloonShape }
 object { LowerBalloonShape }
 texture { MyOuterBalloonTexture }
#declare MyBalloonHull = difference
 object { MyBalloonHullOutside }
 object
  scale 0.99999
  texture { MyInnerBalloonTexture }
 cylinder  // Launcher Openings
  < 0.0, -((MyRadius*1.5)+0.001), 0.0 > < 0.0, (MyRadius+0.001), 0.0 > 3.5
#declare Launcher = difference
 union
  #declare MyLength = 10.0;
  #declare MyHeight = 0.0;
  #declare MyTop = 35.0;
  cylinder { < 0.0, -((MyRadius*1.5)+30.0), 0.0 > < 0.0, MyTop, 0.0 >
3.5 }
  box { < MyLength, -MyHeight, -0.1 > < -MyLength, MyTop, 0.1 > rotate <
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
 cylinder { < 0.0, -((MyRadius*1.5)+30.001), 0.0 > < 0.0, MyTop+0.001,
0.0 > 3.3 }
 pigment { color rgb 1.0 }
#declare DoublePositionLight = union
 union
  cylinder { < 0.0, 0.0,  2.5 > < 10.0, 0.0,  2.5 > 0.20 }
  cylinder { < 0.0, 0.0, -2.5 > < 10.0, 0.0, -2.5 > 0.20 }
  pigment { color rgb < 0.05, 0.05, 0.05 > }
 union
  sphere { < 10.0, 0.0, 2.5 > 0.35 }
  sphere { < 10.0, 0.0, -2.5 > 0.35 }
  pigment { color rgbf < 1.0, 0.0, 0.0, 0.5 > }
  finish { ambient rgb < 0.3, 0.1, 0.1 > }
 union
  light_source
   < 10.0, 0.0, 2.5 >
   rgb < 0.7, 0.0, 0.0 > *10.0
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   rgb < 0.7, 0.0, 0.0 > *1.0
   fade_distance 50.0
   fade_power 4
#declare PositionLights = union
 #declare MyDistance = MyRadius-0.1;
 object { DoublePositionLight translate < MyDistance, 0.0, 0.0 > rotate
< 0.0, 000.0, 0.0 > }
< 0.0, 045.0, 0.0 > }
< 0.0, 090.0, 0.0 > }
< 0.0, 135.0, 0.0 > }
< 0.0, 180.0, 0.0 > }
< 0.0, 225.0, 0.0 > }
< 0.0, 270.0, 0.0 > }
< 0.0, 315.0, 0.0 > }
union
 object { MyBalloonHull }
 object { Launcher }
 object { PositionLights }
background { rgb < 0.02392157,  0.03490196,  0.04627451 > }
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: QUESTION: Bump not showing?
Date: 16 Jul 2017 16:10:38
Message: <596bc83e$1@news.povray.org>
Am 16.07.2017 um 01:40 schrieb Sven Littkowski:
I don't see you adapting the texture to the shape of the balloon (such
as by the use of `map_type`, spherical warp, or UV mapping).
Date: 24 Jul 2017 01:50:03
Message: <web.59758a1a9f453b979c5d6c810@news.povray.org>
Here's what I managed to do with it, changed many things so your scene file will
look different. See whole scene file text below.
I discovered something, caught me by surprise, when using a planar mapping for a
bump map the opposite side will invert the normal. Well, not too surprising if
on a plane {y,0} for example, but I didn't think about the inversion for a
spherical shape like your balloon.
That might not be so much a problem, because I easily solved that by using
opposite scale (as you will see in SDL changes). The real problem I encountered
is how the vertical portions of balloon lose bumpiness. I realize it could be
dealt with by using a non-planar mapping, or maybe warp (that I was unsuccessful
with), but the image file is not usable as such.
Someone else might be able to alter it but I didn't try more than applying
spherical and cylindrical warp {} to the planar image/bump map.
Including enhanced image file here too. It was indeed low contrast before, which
can be bad for this kind of thing. You should be able to see how the bumpiness
is shown now, mainly for upper and lower parts of balloon, yet flattens out on
the sides as I said.
Remember I changed things like lights, textures, too so you are going to need to
do whatever changes you want to this. At least I think you should see the
bumpiness anyhow.
#version 3.7;
//#include "colors.inc"
//#include "finish.inc"
//#include "textures.inc"
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   normal on // added
   pretrace_start 0.08
   pretrace_end   0.02
   count 123
   error_bound 0.75
   recursion_limit 2
 //subsurface        {}
 //adc_bailout       0.0039
 ambient_light     0.06//rgb < 0.000, 0.000, 0.000 >
 assumed_gamma     1
 max_trace_level   4
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 location < 0.0, 200.0, -500.0 >
 look_at < 0.0, -150.0, 0.0 >
 right image_width/image_height*x
light_source
 < 12500.0, 1500.0, -500.0 >,
 rgb < 0.72265625, 0.8046875, 0.80859375 > // *10.0
plane {y,-1000 pigment {rgb <0.9,0.95,1>}}
 brilliance   1.50
 phong albedo 0.05
 phong_size 5
 specular 0.5
 roughness 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   {0.050,0.15}
 brilliance   1.50
 phong albedo 0.05
 phong_size 5
 specular 0.5
 roughness 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
#declare PositiveBump=
normal {
bump_map {
 png "spaceballoon2bumpmap" map_type 0 interpolate 2
bump_size 0.1
 translate -0.5
 scale MyRadius*2
#declare NegativeBump=
normal {
bump_map {
bump_size 0.1
 translate -0.5
 scale -MyRadius*2
 pigment
  image_map { png "spaceballoon2bumpmap" gamma 1
    map_type 0 interpolate 2 once transmit all 0.5}
  translate -0.5
  scale MyRadius*2
 normal { gradient y
 normal_map {
   [0.5 PositiveBump]
   [0.5 NegativeBump]
 } // end normal_map
 scale <1,MyRadius*2,1>
} // end normal
 pigment { color rgb < 0.7686275, 0.7607843, 0.7333333 > transmit 0.5 }
 normal { gradient y
 normal_map {
   [0.5 PositiveBump]
   [0.5 NegativeBump]
   } // end normal_map
} // end normal
//Launcher Radius: 10 m
 95.0, 105.0
 sphere { < 0.0, 0.0, 0.0 >, MyRadius }
 cylinder { < 0.0, 0.0, 0.0 >, < 0.0, MyRadius+0.001, 0.0 >, MyRadius+0.001 }
 object
  scale 0.99999
  < 0.0, -((MyRadius*1.5)+0.001), 0.0 >, < 0.0, (MyRadius+0.001), 0.0 >, 3.5
 union
  cylinder { < 0.0, -((MyRadius*1.5)+30.0), 0.0 >, < 0.0, MyTop, 0.0 >, 3.5 }
  box { < MyLength, -MyHeight, -0.1 >, < -MyLength, MyTop, 0.1 >
rotate <0.0, 000.0, 0.0 > }
rotate <0.0, 045.0, 0.0 > }
rotate <0.0, 090.0, 0.0 > }
rotate <0.0, 135.0, 0.0 > }
rotate <0.0, 180.0, 0.0 > }
rotate <0.0, 225.0, 0.0 > }
rotate <0.0, 270.0, 0.0 > }
rotate <0.0, 315.0, 0.0 > }
 cylinder { < 0.0, -((MyRadius*1.5)+30.001), 0.0 >,
< 0.0, MyTop+0.001, 0.0 >, 3.3 }
 union
  cylinder { < 0.0, 0.0,  2.5 >, < 10, 0.0,  2.5 >, 0.20 }
  cylinder { < 0.0, 0.0, -2.5 >, < 10, 0.0, -2.5 >, 0.20 }
 union
  sphere { < 10.0, 0.0, 2.5 >, 0.35 }
  sphere { < 10.0, 0.0, -2.5 >, 0.35 }
  finish { emission rgb < 0.3, 0.1, 0.1 > }
 union
  light_source
   < 10.25, 0.0, 2.5 >,
   rgb 1//< 0.7, 0.0, 0.0 > // *10.0
   fade_distance 15.0
   fade_power 2
  light_source
   < 10.25, 0.0, -2.5 >,
   rgb 1//< 0.7, 0.0, 0.0 > // *1.0
   fade_distance 15.0
   fade_power 2
rotate < 0.0, 000.0, 0.0 > }
rotate < 0.0, 045.0, 0.0 > }
rotate < 0.0, 090.0, 0.0 > }
rotate < 0.0, 135.0, 0.0 > }
rotate < 0.0, 180.0, 0.0 > }
rotate < 0.0, 225.0, 0.0 > }
rotate < 0.0, 270.0, 0.0 > }
rotate < 0.0, 315.0, 0.0 > }
union
 object { Launcher }
// object { PositionLights }
Download 'spaceballoon2bumpmap.png' (3960 KB)
Preview of image 'spaceballoon2bumpmap.png'
Date: 24 Jul 2017 03:50:00
Message: <web.5975a1d69f453b979c5d6c810@news.povray.org>
"omniverse" <omn### [at] charternet> wrote:
>  normal { gradient y
>  normal_map {
>    [0.5 PositiveBump]
>    [0.5 NegativeBump]
>  } // end normal_map
> } // end normal
Mistakes... And wouldn't surprise me if it's still wrong somehow. I get confused
easily.  ;)
Replace both normal statements for outer and inner textures with this:
 normal { gradient y
 normal_map { /* 0.175 equates to 105/2 or balloon top (torus half vertical
scale) height from 0 */
   [0.175 PositiveBump]
   [0.175 NegativeBump]
 } // end normal_map
 scale <1,1.5*MyRadius,1> // rescale only y to fit whole balloon
And maybe it will be right. I neglected to see the 1.5 times rescale later on
for the balloon object.
And that flattened torus top (scale <1,0.5,1>) was simply being overlooked
because I was only thinking in terms of the gradient y
going upward and downward from 0, or starting at the max width part of balloon,
and not about actual distances for the gradient.
BTW, the gamma 1 for image file was arbitrarily chosen to brighten it for the
sake of seeing the bump map. You may have also noticed I changed the original
light source from 10 times to 1.5 times.
Date: 24 Jul 2017 19:38:16
Message: <597684e8@news.povray.org>
On 24.07.2017 03:46, omniverse wrote:
> normal_map {
>    [0.5 PositiveBump]
>    [0.5 NegativeBump]
>  } // end normal_map
Hi. Now I am irritated, I admit. :-)
Did you see the bump images I added to the GENERAL group (same topic there)
However, someone else mentioned I should size down the bump image and
increase the contrast between bright and dark areas, and also to make it
16bit. I now did all this, still no success.
Please have a look to the attached bump image, this might help you to
know more about my problem and errors I do. Lots of thanks for your help!
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (314 KB)
Preview of image 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png'
Date: 24 Jul 2017 19:41:23
Message: <597685a3@news.povray.org>
Thanks a lot for your assistance, so far. But I admit, I am now irritated.
Did you see the bump image I posted inside the other group (GENERAL)
with the same topic? Someone there told me to reduce the image size,
make it 16bit, and increase the contrast between dark and bright areas
there. I did that all. Still - no success.
I attached the new bump image, please have a look. It should give you a
better understanding of what I want to achieve (and maybe what I am
doing wrong).
Sven
http://www.avg.com
Date: 24 Jul 2017 19:47:53
Message: <59768729$1@news.povray.org>
Another problem: The same thread exists inside the GENERAL section. I
posted here at first before making up my mind that it might be a GENERAL
topic. Now we have two identical threads. I think, we all should just
use the GENERAL thread there, not this one.
http://www.avg.com
Date: 24 Jul 2017 20:30:01
Message: <web.597690689f453b979c5d6c810@news.povray.org>
From general group message:
> Here's the updated bump image. I reduced its size, made it 16bit, and
> increased the contrast between dark and bright areas. Still - no
> success.   :-(
> Another problem: The same thread exists inside the IMAGE section. I
> posted there at first before making up my mind that it might be a
> GENERAL topic. Now we have two identical threads. I think, we all should
> just use THIS thread here, inside GENERAL.
I was avoiding general group because of image uploads not being accepted there,
so I'm not sure how you were able to do that.
Showing the render here that I was able to make using *your updated* bump_map
file, along with the SDL I posted here before (including fixed normal
statements).
And I regret uploading my version of the bump_map in PNG while leaving the
resolution size large, made almost 4 MB download file. Sorry!
I did not use reflection and radiosity, and also removed the image_map to use
only color rgb 1 which allows seeing only the bumpiness without any other visual
effects other than light source shadowing.
If you could show your resulting render here, to compare with this, it might
help figure out why you can't get "success". Must be an answer anyhow.
Download 'test-bump_map-balloon.jpg' (34 KB)
Preview of image 'test-bump_map-balloon.jpg'
Date: 25 Jul 2017 00:28:50
Message: <5976c902$1@news.povray.org>
Am 25.07.2017 um 01:42 schrieb Sven Littkowski:
> My e-mail client seems to ignore if I try to stop an unfinished posting.
> Please ignore the above posting with the wrong contents.
Select the posting in question, then open the "Nachricht" menu (Alt-N),
and choose "Beitrag zurückziehen" (Alt-Z).
Date: 25 Jul 2017 00:34:05
Message: <5976ca3d$1@news.povray.org>
Am 25.07.2017 um 01:41 schrieb Sven Littkowski:
I hope you're just "confused" ("irritiert"), not "irritated" ("verärgert").
Date: 25 Jul 2017 00:43:45
Message: <5976cc81$1@news.povray.org>
> statements).
> normal { gradient y
> normal_map { /* 0.175 equates to 105/2 or balloon top (torus half vertical scale)
height from 0 */
> } // end normal_map
> scale <1,1.5*MyRadius,1> // rescale only y to fit whole balloon>
Hi, thanks. I am seeing your two bump_map declarations, but not that you
specified the bump image. I tried to incorporate everything, but still
fail (now with error message):
 normal
  gradient y
  normal_map
   [ 0.175 PositiveBump ]
   [ 0.175 NegativeBump ]
Balloon - Type 001 - Moon Runnings - Balloon BumpMap.png" map_type 1
once bump_size 150.0 }
  scale < 1.0, 1.5*MyRadius, 1.0 >
http://www.avg.com
Date: 25 Jul 2017 01:06:19
Message: <5976d1cb@news.povray.org>
I'm not sure what you are doing there. With the new bump map and using
the scene from your original post, the attached image is what I get
(after repairing broken comments and replacing the image_map with a
plain white pigment).
That looks like bumps to me. (Excessively strong ones, actually; try
`bump_size 10` or lower.)
You still have some residual issues:
- Contrary to my recommendation, you apparently did not re-generate the
image with higher contrast and bit depth, but rather just converted the
old image and blurred it a bit. This still leaves you with artefacts
from the original color banding.
- You are using `gamma 1.8` in a bump map. This indicates to me that
/something/ regarding gamma is not quite right: Either you didn't
understand what you were doing, or your bump map uses a poor encoding
scheme that gives you more precision in black areas than it does in
white areas. (To tell which of the two is the case, I'd have to know
more about how you created the bump map in the first place.)
- Your radiosity block does not contain a `normal on` statement. As a
consequence, if you turn on radiosity, you will not see any bumps in
areas that are lit only indirectly.
Download 'test.png' (90 KB)
Preview of image 'test.png'
Date: 25 Jul 2017 01:10:17
Message: <5976d2b9$1@news.povray.org>
Am 25.07.2017 um 07:06 schrieb clipka:
Oops, attached the wrong image: This one was generated with radiosity
enabled (and a `nornal on` statement). Without radiosity the image looks
pretty similar though.
Date: 25 Jul 2017 01:30:00
Message: <web.5976d66f9f453b979c5d6c810@news.povray.org>
> > statements).
> > normal { gradient y
height from 0 */
> > } // end normal_map
>  normal
>   gradient y
>   normal_map
Oh. Yeah, you missed that from the whole SDL I posted at:
http://news.povray.org/web.59758a1a9f453b979c5d6c810%40news.povray.org
It's in the #declare statements for PositiveBump and NegativeBump before that
part.
I used my own file name so only that would need to be changed, otherwise you
have the correct 0.175 and 1.5*MyRadius in there.
You must remove your map_type 1 and bump_size 150.0 or else it will be
completely wrong for the way I did it. Reason why, the scale drastically
increases the surface normal deformation. You will notice I used only bump_size
0.1 so the object scale won't affect it as much.
Well, I say "correct" but I'm still wondering if I got it exactly right as
possible, or not.
And later I changed the torus to be taller because I thought it just looked
shaped better to me, not that you must change anything, by making scale
<1,0.5*1.5,1> (same as scale 0.75*y)
and changing to:
   [0.175*1.5 PositiveBump] // refit to rescaled torus height
   [0.175*1.5 NegativeBump]
 } // end normal_map
 scale <1,1.75*MyRadius,1> // rescale only y to fit whole balloon
in the two gradient y normal statements.
Date: 25 Jul 2017 02:01:41
Message: <5976dec5$1@news.povray.org>
Cool! Thanks! Learned something new...
http://www.avg.com
Date: 25 Jul 2017 02:02:16
Message: <5976dee8$1@news.povray.org>
Yes, confused. :-D
http://www.avg.com
Date: 25 Jul 2017 02:06:32
Message: <5976dfe8$1@news.povray.org>
Thanks. Meanwhile, I actually applied many changes, with the effect that
scene parsing ends with an error. I tried to incorporate all advises,
but still miss something.
I am going to post the changed scene code at the very end of this
thread, to keep you all updated.
http://www.avg.com
Date: 25 Jul 2017 02:26:44
Message: <5976e4a4$1@news.povray.org>
UPDATE
Latest Scene Code
(I managed to change the balloon to a gray apple)   :-(
#version 3.7;
//#declare MyBackground = "SL_Space_Scene_003"; // Wormhole /
SL_Space_Scene_003 /
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 subsurface        {}
 adc_bailout       0.0039
 assumed_gamma     1.000
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
#declare LightDiameter =     10000.0;
#declare LightDistanceX =  -500000.0; // X = Left - Right
#declare LightDistanceY =  1000000.0; // Y = Up - Down
#declare LightDistanceZ =  -100000.0; // Z = Front - Back
#declare LightRotate =          36.0;
#declare MyLight =             0.125;
camera
 right 1.77*x
light_source
 rgb < 0.72265625, 0.8046875, 0.80859375 > *1.5
light_source
 < -50.0, 50.0, 0.0 >
 rgb < 0.3, 0.4, 0.8 > *1.1
#declare MyLight = light_source
 < -1000.0, 1000.0, 1000.0 >
 rgb < 0.72265625, 0.8046875, 0.80859375 > *0.25
// spotlight
// point_at < 0.0, 25.0, 100.0 >
// falloff 100.0
// radius 10.0
// fade_distance 50.0
// fade_power 4
union
 object { MyLight rotate < 0.0, 000.0, 0.0 > }
 object { MyLight rotate < 0.0, 036.0, 0.0 > }
 object { MyLight rotate < 0.0, 072.0, 0.0 > }
 object { MyLight rotate < 0.0, 108.0, 0.0 > }
 object { MyLight rotate < 0.0, 144.0, 0.0 > }
 object { MyLight rotate < 0.0, 180.0, 0.0 > }
 object { MyLight rotate < 0.0, 216.0, 0.0 > }
 object { MyLight rotate < 0.0, 252.0, 0.0 > }
 object { MyLight rotate < 0.0, 288.0, 0.0 > }
 object { MyLight rotate < 0.0, 324.0, 0.0 > }
 translate < -1000.0, 0000.0, -1000.0 >
#declare PositiveBump = normal
 bump_map
  png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher - Balloon -
 bump_size 0.1
 translate -0.5
 scale MyRadius*2
#declare NegativeBump = normal
Balloon - Type 001 - Moon Runnings - Balloon BumpMap.png" map_type 0
interpolate 2 }
 bump_size 0.1
 translate -0.5
 scale -MyRadius*2
// reflection   0.00
 crand        0.10
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
 pigment
  image_map
   gamma 1
   map_type 0
   interpolate 2
   once
   transmit all 0.5
  translate -0.5
  scale MyRadius*2
 normal
  gradient y
  normal_map
   [ 0.175 PositiveBump]
   [ 0.175 NegativeBump]
 normal
  gradient y
  normal_map
 95.0, 105.0
 object
  scale 0.99999
 union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
 union
 union
 union
  light_source
   < 10.0, 0.0, 2.5 >
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   fade_distance 50.0
   fade_power 4
union
 object { Launcher }
http://www.avg.com
Date: 25 Jul 2017 03:11:25
Message: <5976ef1d$1@news.povray.org>
Do the changes one at a time and test if they work before going on to
the next. Otherwise it is like trying to find two matching ends in a
plate of spaghetti. :)
Regards
Date: 25 Jul 2017 04:45:00
Message: <web.597704e29f453b979c5d6c810@news.povray.org>
I like that description, and spaghetti.
I didn't get any errors after making sure all lines of SDL are commented, mostly
the several
however, that's with my own image/bump file.
Probably need to use forward slashes, not back slashes since those are also
escape characters.
Rendering with a more distant camera I see the parachute piece again, that's
because in the LowerBalloonShape the cylinder being differenced away from the
sphere doesn't encompass the entire upper half.
Which is why I used:
instead of 175.001 for y.
Only my opinion but I still think the torus balloon top has a better look if
making it
scale <1, 0.75, 1> instead of the flattened <1, 0.5, 1>
but that's all up to you.
Although, if doing like I did, those bump_map entries are required to be either
0.175*1.5 or the equivalent of just 0.2625.
Anyway, I'm sure you get the idea how to rescale the gradient if making any
changes to the object scale.
And once again, I'll say the widest part of the balloon gets smooth with this
way of going about using a map_type 0 (planar) mapping. But to do it with
map_type 1 (spherical) you need an entirely different image, one that isn't
patterned radially. Something with vertical features.
Date: 25 Jul 2017 05:00:36
Message: <597708b4$1@news.povray.org>
> Well, too late now. :-)
It should never be too late. Any sort of version control is better than
none.
I assume you pressed the wrong button
BTW Put more tobacco in them. ;)
Regards
Date: 25 Jul 2017 05:14:52
Message: <59770c0c$1@news.povray.org>
I've learned my lessons the hard way.
And it is Tuesday, traditionally pasta night.
> the several
/* That is why
I put my comments tile this. Even if it is only one line. */
Not that I do a lot of coding but I modify machine written SDL a lot.
Regards
Date: 25 Jul 2017 05:15:00
Message: <web.59770bba9f453b979c5d6c810@news.povray.org>
Yoiks! Forgot to say what I was going to tell about before starting to write
that last reply.
I blame Stephen for making me lose my train of thought with that perfect
metaphor about finding errors.  LOL
Sooo... bump_size 0.1, apparently that's too much. I tried 0.01 instead and
think it looks better. I realized the scale in the normal statement being
MyRadius*2 is probably the equivalent of bump_size 4 even if starting with 0.01.
Don't want to go into all that here but I recall many discussions long ago about
attempts to keep things such as normal and media from scaling up or down with
object sizes after placing the texture. Or just to be aware of the possible
ramifications when scaling.
That aside, please be sure to read my previous reply about the other things.
Date: 25 Jul 2017 05:16:06
Message: <59770c56$1@news.povray.org>
commented, mostly
 > the several
/* That is why
I put my comments like this. Even if it is only one line. */
Regards
Date: 25 Jul 2017 13:16:05
Message: <59777cd5@news.povray.org>
Hi, did you all see the latest code?
http://www.avg.com
Date: 25 Jul 2017 13:19:40
Message: <59777dac$1@news.povray.org>
ite
> that last reply.
nd
h 0.01.
o about
with
le
gs.
> Bob
Ho, can you publish here the entire scene code of your version of the
scene? That would help me better to see the differences and to understand.
I admit, another problem I have, is based on the English language. Yes,
i understand it well, I even live in an English-speaking country now.
But I am not natively English-speaking. Reading all that English here,
causes a concentration problem for me, and I am always missing a lot of
things, not capturing them somehow. That is why I want to ask you all
here, to be patient with me. :-)
http://www.avg.com
Date: 25 Jul 2017 14:51:03
Message: <59779317$1@news.povray.org>
Jamaican English is an ittsy bitsy bit different from Standard English.
In case you hadn't noticed.
Regards
Date: 25 Jul 2017 16:00:00
Message: <web.5977a2619f453b979c5d6c810@news.povray.org>
Hope this doesn't suffer in translation.  ;)
There's some dark splotches on the lower left side, maybe reflection? I didn't
check, wanted to go ahead and post this.
#version 3.7;
#declare MyRadiosity = on; // fast enough, but faster without
/*#declare MyBackground = "SL_Space_Scene_003"; // Wormhole /SL_Space_Scene_003
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.02
   count 100
   error_bound 0.75
   recursion_limit 1
   normal on
 subsurface        {}
 adc_bailout       0.0039
 assumed_gamma     1.000
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 location < -000.0, 400.0/2, -500.0 > /* < -000.0, 400.0, -500.0 > */
 look_at < 0.0, -200.0, 0.0 >/2 /* < 0.0, -200.0, 0.0 > */
 right 1.77*x
light_source
 < 2500.0, 2500.0, 500.0 > //< 2500.0, 2500.0, 5000.0 >
 rgb < 0.72265625, 0.8046875, 0.80859375 > *1.5 // bright!?
 area_light x*100,z*100,5,5 circular orient
 area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
// simulate Earth below
plane {y,-9999 pigment {rgb <0.4,0.7,1>}}
 bump_map
 { // use your file name
 png "balloon2bump"
 map_type 0 interpolate 2 }
 translate -0.5
 scale MyRadius*2 // 200*2=400, multiply by bump_size
 bump_size 0.02 // this equates to 8 after scale
#declare NegativeBump = normal // invert surface normal
 bump_map
  png "balloon2bump"
 translate -0.5
 scale -MyRadius*2 // 200*2=400, multiply by bump_size
 bump_size 0.04 // this equates to 16 after scale
 reflection   0.1 // I'm guessing here
 //crand        0.10 // grainy near shadows! Is it needed??
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50 // this much needed? or not?
 pigment
  image_map
   png "balloon2bump"
   gamma 1
   map_type 0
   interpolate 2
   once
   transmit all 0.4 /* added to make partially transparent, change or remove? */
  translate -0.5
  scale MyRadius*2
 normal
  gradient y
  normal_map
  { /* index number is based on balloon size, upper part height */
   [ 0.2625 PositiveBump] // top
   [ 0.2625 NegativeBump] // bottom
  scale <1,1.5*MyRadius,1> // set to balloon height
  transmit 0.4 /* added to make partially transparent, change or remove? */
 normal
  gradient y
  normal_map
  { /* set index values to 0.175 if torus scale <1,0.5,1>, same above */
/* Balloon Radius: 175 m /Launcher Radius: 10 m */
 95.0, 105.0
 scale < 1.0, 0.75, 1.0 >
 /* if 0.5*y, use normal_map 0.175 not 0.2625 (0.175*1.5, 0.5*1.5=0.75) */
} /* I changed that to get tall fat appearance, not required
but must change everything back again if not used this way */
 cylinder { < 0.0, 0.0, 0.0 >, < 0.0, /*175.001*/MyRadius+0.001, 0.0 >,
MyRadius+0.001 }
#declare MyBalloonHullOutside = merge // union causes artefacts??
 object
  scale 0.99999 // causing artefacts??
// plane {z,0} // only to see inside
 union
  cylinder {
 cylinder {
 union
 union
 union
  light_source
   < 10.0, 0.0, 2.5 >
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   fade_distance 50.0
   fade_power 4
union
 object { Launcher }
// object { PositionLights } // slow, fast if commented out
Date: 25 Jul 2017 18:54:18
Message: <5977cc1a$1@news.povray.org>
But how different is German to English? :-)
http://www.avg.com
Date: 25 Jul 2017 19:16:03
Message: <5977d133$1@news.povray.org>
How long have you lived there?
And English is a Germanic language.
https://en.wikipedia.org/wiki/English_language
https://de.wikipedia.org/wiki/Englische_Sprache
Regards
Date: 25 Jul 2017 19:31:21
Message: <5977d4c9$1@news.povray.org>
d.
It seems, with my graphic program I can work only with one layer, if it
comes to 16bit. Cannot create any additional layers when in 16bit, and I
would need, in order to crate a similar pattern.
I use Photoshop v7.0. That is the reason, why I could not create the
image you suggested (and I agree on).   :-(
Will create a new bump image, but it will be again 8bit. But I create it
as a smaller version. Hoping for the best.
http://www.avg.com
Date: 25 Jul 2017 20:01:32
Message: <5977dbdc@news.povray.org>
Latest Scene Code, Latest Bump, Latest Result
(still no bumps)
#version 3.7;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 subsurface        {}
 adc_bailout       0.0039
 assumed_gamma     1.000
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 right 1.77*x
light_source
 area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
 bump_map
 translate -0.5
 scale MyRadius*2
 bump_size 0.02
interpolate 2 }
 translate -0.5
 scale -MyRadius*2
 bump_size 0.04
// reflection   0.00
 crand        0.10
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
 pigment
  image_map
   gamma 1
   map_type 0
   interpolate 2
   once
  translate -0.5
  scale MyRadius*2
 normal
  gradient y
  normal_map
 normal
  gradient y
  normal_map
 95.0, 105.0
 object { MyBalloonHullOutside hollow }
 union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
 union
 union
 union
  light_source
   < 10.0, 0.0, 2.5 >
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   fade_distance 50.0
   fade_power 4
union
 object { Launcher }
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (201 KB) Download 'space - launcher - balloon - type 001 - moon runnings.png' (171 KB)
Preview of image 'space - launcher - balloon - type 001 - moon runnings.png'
Date: 25 Jul 2017 20:07:26
Message: <5977dd3e@news.povray.org>
Clipka, I created a new, more contrasting bump image. I dream to get
something like your result. My Photoshop 7 does not allow to work with
multiple layers if the mode is 16bit, thus I had to create it again
(sadly) in 8bit.
Please have a look at my latest scene code, I also tried to incorporate
the changed scene code of Omniverse, too:
#version 3.7;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 subsurface        {}
 adc_bailout       0.0039
 assumed_gamma     1.000
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 right 1.77*x
light_source
 area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
 bump_map
 translate -0.5
 scale MyRadius*2
 bump_size 0.02
interpolate 2 }
 translate -0.5
 scale -MyRadius*2
 bump_size 0.04
// reflection   0.00
 crand        0.10
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
 pigment
  image_map
   gamma 1
   map_type 0
   interpolate 2
   once
  translate -0.5
  scale MyRadius*2
 normal
  gradient y
  normal_map
 normal
  gradient y
  normal_map
 95.0, 105.0
 union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
 union
 union
 union
  light_source
   < 10.0, 0.0, 2.5 >
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   fade_distance 50.0
   fade_power 4
union
 object { Launcher }
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings.png' (171 KB) Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (201 KB)
Date: 25 Jul 2017 20:12:51
Message: <5977de83$1@news.povray.org>
Well, quite some time. Speaking English is the easiest for me. Listening
to English takes on a bit more concentration, but I can manage. But
reading in English takes on the most concentration, if I read too much,
i lose the contents and nothing reaches my understanding anymore, after
some time. That is how i would try to describe it.
English and German are not really similar, even if the modern English
has some of its roots in the Germanic language of the Saxons. Some parts
are Celtic, some parts are French, and some are even Latin (beside
French a 2nd Romanic language). But that is not so important. Important
is, how similar languages are. Not enough for me, to avoid this problem. :-
http://www.avg.com
Date: 26 Jul 2017 00:40:00
Message: <web.59781c979f453b979c5d6c810@news.povray.org>
All I can say is I can render your exact scene using your bump map file and see
how it should be.
However, there is trouble with the image_map. You say a "texture" name for that
one, yet didn't give another, so I used the same bump_map file for the texture
too.
I can see the shadowing on the surface, but the contrast is now so much I lose
sight of it in the darkest areas.
What I tried, again, is remove that image_map from pigment statement and
replaced with a simple:
color rgb 1 // plain white
Rendering posted.
And I was confused at first about the rounded shadow seen on the top left side
of balloon.
That was once again the 'parachute' piece, you don't actually see it until
moving camera farther away; I got rid of it before by replacing 175.001 with
MyRadius+0.001 in the SDL part:
 cylinder {
  < 0.0, 0.0, 0.0 >,
  < 0.0, MyRadius+001, 0.0 >, MyRadius+0.001 } // instead of y*175.001
Date: 26 Jul 2017 03:31:13
Message: <59784541@news.povray.org>
nd see
> how it should be.
r that
xture
> too.
 lose
> Rendering posted.
 side
> of balloon.
l
ith
>  cylinder {
>   < 0.0, 0.0, 0.0 >,
I made the balloon HOLLOW (instead of a difference). And removed the
TRANSMIT keyword. Looks better. But not getting any bumps. Made also the
top a bit flatter again 8as it was before).
Are you able to reproduce anything that looks like Clipka's balloon image?
Complete Scene Code:
#version 3.7;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 subsurface        {}
 adc_bailout       0.0039
 assumed_gamma     1.000
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 right 1.77*x
light_source
 area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
 bump_map
 translate -0.5
 scale MyRadius*2
 bump_size 0.02
interpolate 2 }
 translate -0.5
 scale -MyRadius*2
 bump_size 0.04
// reflection   0.00
 crand        0.10
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
 pigment
  image_map
   gamma 1
   map_type 0
   interpolate 2
   once
  translate -0.5
  scale MyRadius*2
 normal
  gradient y
  normal_map
 normal
  gradient y
  normal_map
 95.0, 105.0
 union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
 union
 union
 union
  light_source
   < 10.0, 0.0, 2.5 >
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   fade_distance 50.0
   fade_power 4
union
 object { Launcher }
http://www.avg.com
Date: 26 Jul 2017 07:20:42
Message: <59787b0a@news.povray.org>
> (still no bumps)
I didn't change anything to your code and used the bump map provided,
and this is what I get: bumps *are* visible!
Download 'sl_balloon.png' (87 KB)
Preview of image 'sl_balloon.png'
Date: 26 Jul 2017 07:28:32
Message: <59787ce0$1@news.povray.org>
>> (still no bumps)
Not entirely true ;-)
I added:
global_settings {
   assumed_gamma 1.0
which was demanded by your kolors.inc (and for obvious reasons when
using version 3.7) and I provided a uniform red colour texture for the
balloon (as an image_map).
Date: 26 Jul 2017 07:50:01
Message: <web.597880ca9f453b97c437ac910@news.povray.org>
> > (still no bumps)
> Thomas
This whole thing really reminds me of:
http://1.bp.blogspot.com/-IFTXBJQc0UU/VIHkNM5jKkI/AAAAAAAA2F8/yyWnsQBHmO4/s1600/gah1.jpg
Since it's from the 80's, maybe Yadgar will join this thread  ;)   :D
Date: 26 Jul 2017 07:55:48
Message: <59788344$1@news.povray.org>
>>> (still no bumps)
>> Thomas
Close Encounters of the Third(?) Kind? :-)
Date: 26 Jul 2017 08:20:56
Message: <59788928$1@news.povray.org>
>>>> (still no bumps)
>>> Thomas
That's what I was thinking.
I thought that they would be earlier than the 80's.
Regards
Date: 26 Jul 2017 10:00:01
Message: <web.59789ff89f453b97c437ac910@news.povray.org>
Close.  "The Greatest American Hero"
(With Robert Culp from I Spy (!) :O )
Yes, but only slightly. 1977
Date: 26 Jul 2017 10:44:32
Message: <5978aad0$1@news.povray.org>
Whoosh! That went completely over my head. Not only have I never heard
of the movie. The image looked like a neon tube mounted in an old
fashioned lampshade.
Regards
Date: 26 Jul 2017 10:47:23
Message: <5978ab7b$1@news.povray.org>
Am 26.07.2017 um 16:44 schrieb Stephen:
Given the state-of-the-art special effects back then, maybe it /was/ a
neon tube mounted in an old fashioned lampshade after all ;)
Date: 26 Jul 2017 11:42:35
Message: <5978b86b@news.povray.org>
>>> (still no bumps)
> I added:
> global_settings {
>   assumed_gamma 1.0
I am not understanding this. I added the assumed gamma (but kept the
texture as it is), and still nothing of the bump shows! I really want to
use an images as texture. Please try my scene with the assumed gama, and
post the resulting image.
I am attaching the scene code, the bump image, and the resulting scene
image.
#version 3.7;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 assumed_gamma 1.0
 subsurface        {}
 adc_bailout       0.0039
 assumed_gamma     1.000
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 right 1.77*x
light_source
 area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
 bump_map
 translate -0.5
 scale MyRadius*2
 bump_size 0.02
interpolate 2 }
 translate -0.5
 scale -MyRadius*2
 bump_size 0.04
// reflection   0.00
 crand        0.10
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
 pigment
  image_map
   gamma 1
   map_type 0
   interpolate 2
   once
  translate -0.5
  scale MyRadius*2
 normal
  gradient y
  normal_map
 normal
  gradient y
  normal_map
 95.0, 105.0
 union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
 union
 union
 union
  light_source
   < 10.0, 0.0, 2.5 >
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   fade_distance 50.0
   fade_power 4
union
 object { Launcher }
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings.png' (172 KB) Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (201 KB)
Date: 26 Jul 2017 11:46:29
Message: <5978b955@news.povray.org>
Coming back into the cinemas. Alas they did not add the latest effects
and spaceship designs to that great movie. I've seen the original movie.
Great movie.
Still not getting any bumps, feeling very frustrated now. I want to keep
my texture image file, not replacing it with a single color.
Attached are scene code, bump image, and resulting bump-less scene
image. Are you people getting bumps the way it is?
#version 3.7;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 assumed_gamma 1.0
 subsurface        {}
 adc_bailout       0.0039
 assumed_gamma     1.000
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 right 1.77*x
light_source
 area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
 bump_map
 translate -0.5
 scale MyRadius*2
 bump_size 0.02
interpolate 2 }
 translate -0.5
 scale -MyRadius*2
 bump_size 0.04
// reflection   0.00
 crand        0.10
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
 pigment
  image_map
   gamma 1
   map_type 0
   interpolate 2
   once
  translate -0.5
  scale MyRadius*2
 normal
  gradient y
  normal_map
 normal
  gradient y
  normal_map
 95.0, 105.0
 union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
 union
 union
 union
  light_source
   < 10.0, 0.0, 2.5 >
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   fade_distance 50.0
   fade_power 4
union
 object { Launcher }
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (201 KB) Download 'space - launcher - balloon - type 001 - moon runnings.png' (172 KB)
Date: 26 Jul 2017 12:40:00
Message: <web.5978c52e9f453b97c437ac910@news.povray.org>
https://en.wikipedia.org/wiki/The_Greatest_American_Hero
Pretty sure it was lights on the bottom of a hot air balloon, which is why this
reminds me so much of it.
https://www.youtube.com/watch?v=e9Q3orQhEcA
Maybe Sven needs to add some light sources to the scene...   :D
Date: 26 Jul 2017 15:04:30
Message: <5978e7be$1@news.povray.org>
Am 26.07.2017 um 17:46 schrieb Sven Littkowski:
> Great movie.
At the moment, all seems to point at the pigment definition as the
culprit, as that's the only relevant thing we've always changed. You
should at least /try/ it with a plain pigment, to either confirm or
refute this theory.
If you can confirm it, we know that's what we have to examine further;
in that case you'll probably want to post the image map at last, so that
we can see what might be so special about it.
Otherwise we can be sure that it's a red herring, and that we have to
dig someplace else.
Date: 26 Jul 2017 15:17:58
Message: <5978eae6$1@news.povray.org>
Am 26.07.2017 um 18:37 schrieb Bald Eagle:
You know you'll be going straight to The Hague for posting this, right?
Date: 26 Jul 2017 21:20:01
Message: <web.59793eee9f453b97e85ccd120@news.povray.org>
I believe what's going on is your image map is too dark and there's no specular
highlight or phone home and load in your outer finish statement.
I'm not home to test that theory out.
