POV-Ray : Newsgroups : povray.binaries.images : Differencing a cubic sphere sweep - artifact problem! Server Time
10 Oct 2026 11:21:02 EDT (-0400)
  Differencing a cubic sphere sweep - artifact problem! (Message 1 to 15 of 15)
Subject: Differencing a cubic sphere sweep - artifact problem!
Date: 29 Apr 2017 20:05:07
Message: <59052a33@news.povray.org>
Hi(gh)!
I started to model the building blocks of a Swiss-made marble lane
system... when I came to an elongated block with a serpentine-shaped
marble track on top, I chose to use a cubic sphere to create the
hollow... but it resulted in heavy artifacts (object on the extreme
right of the scene attached). I tried various tolerance values - but
nothing removed those artifacts! Here is the code:
#declare T_Beech =
texture
   pigment { color rgb <0.6, 0.55, 0.45> }
   finish { ambient 0.1 diffuse 1 brilliance 0.4 }
#declare Cube =
box
   0, 0.05
   texture { T_Beech }
#declare HalfCube =
object
   Cube
   scale <1, 0.5, 1>
#declare HalfCube_Triple =
object { HalfCube scale <1, 1, 3> }
#declare Serpentine =
sphere_sweep
   cubic_spline
   8
   <0.025, 0.025, -0.02>, 0.05/6
   <0.025, 0.025, 0>, 0.05/6
   <0.021, 0.025, 0.02>, 0.05/6
   <0.012, 0.025, 0.05>, 0.05/6
   <0.038, 0.025, 0.10>, 0.05/6
   <0.029, 0.025, 0.13>, 0.05/6
   <0.025,  0.025, 0.15>, 0.05/6
   <0.025, 0.025,  0.17>, 0.05/6
   texture { T_Beech }
#declare KL =
difference
   object { HalfCube_Triple }
   object { Serpentine }
See you in Khyberspace!
Yadgar
Download '2017-04-30 cugolino, take 1.jpg' (41 KB)
Preview of image '2017-04-30 cugolino, take 1.jpg'
Subject: Re: Differencing a cubic sphere sweep - artifact problem!
Date: 29 Apr 2017 23:20:01
Message: <web.590554a3ecb34136883fb31c0@news.povray.org>
I tried all sorts of tricks to try and eliminate the problem, but no luck:
Scaling both cube and sphere-sweep (both before and after they are created), as
well as the sphere radii; changing the sphere-sweep 'tolerance' value by orders
of magnitude up and down (which seems to have no effect at all); rotating only
the sphere-sweep in space; changing the number of entries in the sphere-sweep;
even moving the camera around. Adding commas after the 'sweep entries (as
recommended in the docs) has no effect either.
Using a b_spline instead of cubic also shows the problem.
Using union (or merge!) instead of difference results in NO problem; those
operations work OK.
I assume that this is your only sphere-sweep that uses a CUBIC spline?
Date: 29 Apr 2017 23:30:00
Message: <web.59055a1aecb34136883fb31c0@news.povray.org>
Oops, I was thinking of your closest block in the image, the one with the curved
indent. That's probably a differenced torus shape, not a sphere-sweep.
Date: 30 Apr 2017 00:06:51
Message: <590562db$1@news.povray.org>
On 2017-04-29 08:05 PM (-4), Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
It is for just such a reason that I created the SphereSweep module in
the Object Collection:
http://lib.povray.org/searchcollection/index2.php?objectName=SphereSweep&contributorTag=Cousin%20Ricky
Date: 30 Apr 2017 07:23:54
Message: <5905c94a$1@news.povray.org>
Hi(gh)!
Am 30.04.2017 um 06:06 schrieb Cousin Ricky:
Very good, I will try this out!
Yadgar
Date: 30 Apr 2017 11:06:35
Message: <5905fd7b$1@news.povray.org>
On 04/29/2017 08:05 PM, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
Thanks for posting code. I've opened a github issue for this:
https://github.com/POV-Ray/povray/issues/287
given it seems to render correctly in 3.6.1.
Bill P.
Date: 30 Apr 2017 11:45:01
Message: <web.590602c4ecb34136883fb31c0@news.povray.org>
> I tried all sorts of tricks to try and eliminate the problem, but no luck...
I ran the scene in the latest(?) 3.7.1 beta 5, as well as in my original 3.70
install; same problems in both.
IIRC, sphere_sweeps using a cubic spline have been problematic for a *long*
time. If it were possible to do, I would suggest adding the 'natural_spline'
type to the sphere_sweep code. I don't know the math differences between natural
and cubic splines (or if one is mathematically 'simpler' than the other) but it
might give us at least one way to make curvy sphere_sweeps that can be
CSG-differenced from another object.
Date: 1 May 2017 03:44:08
Message: <5906e748@news.povray.org>
Hi(gh)!
Am 30.04.2017 um 13:23 schrieb Jörg "Yadgar" Bleimann:
> Hi(gh)!
Now it looks correct: see attachment!
Yadgar
Download '2017-04-30 cugolino, take 2.jpg' (31 KB)
Preview of image '2017-04-30 cugolino, take 2.jpg'
Date: 1 May 2017 08:00:01
Message: <web.590722b8ecb34136c437ac910@news.povray.org>
> time.
I was unaware of this.
Maybe for the time being you could use:
http://www.econym.demon.co.uk/isotut/splines.htm
it may be slower, but would give good end results straightaway.
Date: 1 May 2017 12:19:57
Message: <5907602d@news.povray.org>
>> Hi(gh)!
> Bill P.
Thanks for logging.
I tested with hg-povray and it is fine there (at least the tmp372.pov file)
Actually, it is also ok on my master head, but both stable and official
master have problem.
Which leads me to conclude: read the note about the patch of my master,
for sphere_sweep:
* sphere sweep: less noise under some angles
* sphere sweep: UV mapping
* sphere sweep: removed the preliminary workaround for FS#81 (not
effective, was adding noise)
* sphere sweep: added the suggested fix for FS#243 (negative uniform
scaling of untransformed object should have effect on radius as absolute
factor)
From what I would keep in the sphsweep.cpp, previously in
source/backend/shape (now spheresweep.cpp in source/core/shape ):
const DBL ZERO_TOLERANCE        = 1.0e-1;// less noise when near 1 than
near 0 [JG]
instead of
const DBL ZERO_TOLERANCE        = 1.0e-4;
Good luck.
Download 'offmaster.png' (51 KB) Download 'hg.png' (52 KB) Download 'master.png' (52 KB) Download 'stable.png' (51 KB)
Preview of image 'offmaster.png'
Preview of image 'hg.png'
Preview of image 'master.png'
Preview of image 'stable.png'
Date: 1 May 2017 12:35:43
Message: <590763df$1@news.povray.org>
And also, REMOVE THAT FS#81 PATCH which do no good.
Date: 2 May 2017 13:00:41
Message: <5908bb39$1@news.povray.org>
Am 30.04.2017 um 17:42 schrieb Kenneth:
Mathematically, "natural splines" are only marginally different from
what POV-Ray calls "cubic splines": Both are 3rd order polynomial
splines, i.e. piecewise defined functions mapping a single scalar
parameter to a point in N-dimensional space, with each piece having the form
    F(t) = A[3] * t^3 + A[2] * t^2 + A[1] * t + A[0]
with A[i] being N-dimensional constants (N=3 in the case of POV-Ray's
splines).
I would therefore not expect "natural splines" to have any advantage
over the so-called "cubic splines" (except possibly being more intuitive
to control, depending on user and use case). To the contrary, "natural
splines" have fewer degrees of freedom, allowing less control over the
direction and curvature at the start and end of the spline.
Technically speaking, all 3rd order polynomial splines are cubic
splines. This also includes POV-Ray's "bezier splines", which behind the
scenes differ from the other types only in that they provide even more
degrees of freedom, allowing for sudden changes in both direction and
curvature between the pieces of the spline.
Date: 2 May 2017 14:26:31
Message: <5908cf57$1@news.povray.org>
Am 01.05.2017 um 18:35 schrieb Le_Forgeron:
I was about to press "send" on a passionate defense of that patch just
now, when something crossed my mind.
Can you confirm my hunch that all use cases where the patch negatively
impacts quality are cases where we see the sphere sweep's inside?
Other than that, I'm at a loss how the patch could possibly have any
negative impact.
Date: 2 May 2017 17:05:00
Message: <web.5908f2f5ecb34136883fb31c0@news.povray.org>
> splines... [snip]
Thinking back to the v3.62 days, I'm ashamed to admit that you probably
explained this long ago-- and probably in response to a similar post by me! Mea
culpa.
I've been looking at Wikipedia's entries on 'spline interpolation' and 'cubic
Hermite splines', in a (poor) attempt to understand them. But I'm trying! ;-)
My mention of using a 'natural spline' is simply based on its well-behaved use
in other parts of POV-Ray (without knowing its mathematical differences vs.
POV-ray's 'cubic splines'.) I had assumed that a 'natural spline' was somehow
better behaved mathematically than a cubic one... or maybe that it wasn't 3-rd
order...
Since both 'natural splines' and 'cubic splines' ARE both 3-rd order, I'm
willing to guess(!) that the problem is not in POV-ray's mathematical
implementation of the cubic spline, but rather in some kind of co-dependent
problem with the 'difference-ing' operation. Based on nothing but my nutty
intuition ;-)
Date: 3 May 2017 11:08:13
Message: <5909f25d$1@news.povray.org>
Am 02.05.2017 um 22:58 schrieb Kenneth:
>> splines... [snip]
> culpa.
I'm an explainer by nature. It's difficult to tire me out on
re-iterating stuff I've explained over and over again. Ask me again
tomorrow, and I'll explain once more.
> intuition ;-)
There _is_ (or so I think by now) a fundamental flaw of that infamous
"FS#81 Patch" that specifically screws up difference ops (and other
cases where the interior of the sphere sweep is exposed). However, the
issue the patch was originally intended to fix does hit 3rd order
splines even without a difference op. (In a nutshell, any 3rd order
sphere sweep will be screwed up anywhere the spline runs approximately
perpendicular to the viewing direction.)
