Recently, I found a blackbird eggshell and wanted to model its texture.
It gave me the opportunity to play again with some (UberPOV) settings I
like and using subsurface scattering throughout the scene.
So, here we are with all objects showing subsurface scattering.
UberPOV antialiasing set at +am3 +a0.01 +ac0.90 +r3 and using no_cache.
2h20' render time with 6 cores. This would be much longer if using
+ac0.99 of course.
Download 'sslt_test_uber_02.png' (707 KB)
Preview of image 'sslt_test_uber_02.png'
> +ac0.99 of course.
Did you use stochastic rendering? It looks a little bit grainy. Other
than that it is excellent.
+am3 - I see that you did.
Regards
Hi(gh)!
> +ac0.99 of course.
A dragon's egg... and when reading your subject, I initially thought (or
better, hoped!) you tried to render the same-named neutron star of the
cheela!
That would be a cool project... but I would postpone it until I acquired
reliable knowledge of spectral rendering, as to humans, the Egg is
white-hot at about 9000 K, and any features on its surface are only
discernible when viewed through cheela eyes!
See you in Khyberspace!
Yadgar
Now playing: Under the Orangish Sky (Michael Garrison)
>> +ac0.99 of course.
You bet he did.
no_cache and +am+ both enable stochastic rendering. The first in the
radiosity evaluation, the second in antialiasing.
>>> +ac0.99 of course.
> You bet he did.
I don't gamble. At least with anything as trivial as money. ;)
I did not see Thomas's setting until I was about to post.
Thanks, I did not know that. At least the no_cache setting. I don't
normally use radiosity myself.
Does that mean +am1 or +am2 enables stochastic rendering? I thought it
was only +am3 that did that. But then I've only used UberPov when I was
working on Dhalgren with Thomas and he set the quality settings.
I am an egg. :-)
Albeit a thousand-year-old egg. Yum yum.
Regards
On 26-4-2017 15:42, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
>> +ac0.99 of course.
> cheela!
> Yadgar
Only by chance I am afraid. I am not acquainted with Robert Forward's
work so I am out. Still, a nice example of syzygy isn't it?
>>>> +ac0.99 of course.
>> You bet he did.
Only +am3 sets stochastic rendering. I like it but it is much slower imo
when set to high quality like +ac99. However, I may be wrong as I have
not compared renders seriously. Clipka would know ;-) I little bit of
grainy image is not a problem to me although it is difficult to balance
quality versus (acceptable) render time. I am not always that patient.
With Dhalgren, I used +am2, so no stochastic rendering there.
> I am an egg. :-)
Hum... I am a bit reluctant to have a bite :-)
That is the crux of the matter. How long you are willing to wait for the
quality you want.
But I did a couple of runs with +am3 as it was the first time I had used
UberPov.
>> I am an egg. :-)
They are really nice. They are a bit like haggis, in the way the taste
is linked to the way you catch them. ;-)
Regards
> quality you want.
Indeed. I am running a render now with slightly increased quality
(+ac0.95 +r4) which is already more satisfactory. 80% done after 3h23'.
> UberPov.
I am a fan. :-)
>>> I am an egg. :-)
Really? Well, I shall have to taste haggis too then. ;-)
...which completed looks like this.
Download 'sslt_test_uber_03.png' (672 KB)
Preview of image 'sslt_test_uber_03.png'
>> UberPov.
> I am a fan. :-)
I had noticed. :)
I appreciate the speed up more than the other features. I have an 800
frame animation that I am working on. I'll certainly use it for that.
>>>> I am an egg. :-)
If you don't try it before Brexit you will have to catch your own or
import it. ;)
Tatties and neeps are available everywhere. Although not always called
the same thing.
Regards
> ....which completed looks like this.
That does make a positive difference. It is more the dragon that shows
it up. To my eyes it looks as if it hasn't been polished to a high degree.
Regards
> Thomas
The subsurface scattering in the dragon must add to the render time.
http://www.3d-imaging.co.uk
>> Thomas
Yes indeed, and like Stephen said, it mostly shows up on the dragon too.
To answers here stephen's other comment: the reflections have been kept
rather low so the polish is almost absent.
As a comparison, a render without any subsurface scattering.
Download 'sslt_test_uber_noss.png' (682 KB)
Preview of image 'sslt_test_uber_noss.png'
That definitely makes a huge difference with the dragon. It looks like
modeling clay, not jade. But there seems only a slight difference with
the floor, and the egg and cube look the same.
I think I need to explore more the translucency strength for each
object, increasing or decreasing the value. I am not yet done ;-)
In fact, the differences are more subtle. For the cube, compare the
shadows of dragon and egg: their edges show the stone's translucency. In
my next render I hope to show this better.
In this render:
- Dragon: no SSLT
- Floor: no SSLT
- Cube: SSLT with 5*translucency vector (was 2* in earlier example)
- Egg: SSLT with 3*translucency vector (was 2* in earlier example)
The cube is showing markedly more translucency in the shadows cast on
it. I see not much difference in the egg, although if I increase the
translucency exaggeratedly (*100 for instance) the effect becomes distorted.
Question: In the wiki about SSLT it is said: "The effect doesn't scale
with the object". Does this mean that SSLT works in the same way as a
scattering media where the amount of scattering has to be compensated
for the amount of media object's scale? It appears so to me at least
although this is not mentioned in the wiki.
Download 'sslt_test_uber.png' (679 KB)
Preview of image 'sslt_test_uber.png'
> In this render:
> - Dragon: no SSLT
> - Floor: no SSLT
> distorted.
It does work similarly to medias, both emissive, absorbing and scattering.
So, if you scale your scene by 10 and want SSLT to look the same, then
you need to multiply your SSLT vector by 10. Alternately, you can
increase mm_per_unit by the same amount in the global_settings block.
>> In this render:
>> - Dragon: no SSLT
>> - Floor: no SSLT
>> distorted.
OK. Only difference would be that with scattering media (for instance)
you have to /divide/ the scattering vector by the scale of the container
to get the same result, but I get the point indeed.
I am a bit wary about the mm_per_unit and prefer not to touch it too
much, especially if different objects have different scales.
Yes Clipka has put the fear of god into us. :-)
I suppose it depends what you intend by scaling the models.
Regards
Indeed, yes. Take my image as example, the dragon is scaled 0.01, the
egg 0.25, the cube is not scaled, and the floor 0.50. It seems best to
use a standard mm_per_unit and change translucency as needed.
My understanding is that the mm_per_unit is the world/scene scale
And to add to the confusion (on my part at least) meshes can have an
internal scale and an external one. By internal scale I mean the scaling
you can change in PoseRay before exporting and external is how you
change it in PovRay.
In Blender when using the physics engine the scale should be 1.0. So to
scale a mesh. You need to edit it and scale it there. Otherwise you get
unexpected results.
So if the dragon is an ornament. I would scale it down in PoseRay. If it
is a statue scale it up in PoseRay. Keep the mm_per_unit as the default.
Having said that. I have not used SSLT since its RC3. :-(
So what do I know?
Regards
Another thought:
If you use the same material for your three objects. There should be no
difference in the look of the objects. That might be a way to check if I
am talking rubbish or not. And I am talking about meshes not primitives.
Regards
>>>> translucency. In
>>> In this render:
>>> - Dragon: no SSLT
>>> - Floor: no SSLT
>>> distorted.
>> scattering.
You should set it according to the overall scale of your scene.
The default of 10 mean 1 POV unit = 1 cm. Set it to 1000 if your scale
is 1 POV unit = 1 m, and 25.4 for 1 inch = 1 POV unit.
In my suggestion, it would make a scene scalled in cm work in mm. So,
you can change mm_per_unit from it's default of 10 to 1 to reflect the
change in overall scale.
> unexpected results.
> So what do I know?
This all makes a lot of sense indeed. Generally, I do not build a scene
with a particular scale in mind so I just assemble the elements and let
the observer do the rest. Thus, a landscape can very well be built by
either relatively small elements or by big ones, I do not care as I am
only interested in the final effect.
With SSLT it seems I have to be much more careful.... ;-)
On 2-5-2017 5:57, Alain wrote:
[snip]
As I wrote in my answer to Stephen, I am shamefully negligent about
overall scales and just throw together elements to be brewed in the same
pot. I need to be a bit more careful if I want to include SSLT. :-)
Gosh! a first. :-)
I'm the same. I tend to build my scenes small. For some reason I don't
like wasting Pov space. Which means I use a lot of decimals but decimals
are cheap.
I tend to use Poser figures as a reference. Michael is about six feet,
in my mind.
I am sure if Clikpa were about. He would agree. ;-)
Regards
> Gosh! a first. :-)
Really?
> are cheap.
They are indeed. However, I try to avoid too small ones. They are more
difficult to find when they drop to the floor. :-)
> in my mind.
Typically, I scale the figures to the environment they are to live in. :-)
Ah! The Clipka! He seems to have gone on holiday? Shame. He /knows/ he
cannot go without our permission. ;-)
>> Gosh! a first. :-)
> Really?
I meant a first for today.
>> are cheap.
Alt+ LMB + drag scoops them up. :-)
(Bishop3D setting)
>> in my mind.
I was talking my dreams. In truth I scale my scenes by the first object
I create.
As long as he hasn't taken a marching band with him. It is okay. ;-)
Regards
> unexpected results.
> So what do I know?
I have been pondering this a bit. I think that you do achieve the same
(using meshes of course) if you first do basic transforms (in POV-Ray)
and /then/ use that copy of the original object with SSLT. In fact, I do
that exercise quite often:
#declare MyObject =
object {MyMesh_POV_
transform {MyTransforms}
object {MyObject
material {MyMaterial}
rotate {MyRotate}
translate {MyTranslate}
Am 30.04.2017 um 13:05 schrieb Thomas de Groot:
That depends on what you want to achieve.
If you want the object to look like a larger item made of the same
material, scale the object and use the same SSLT parameters.
If you want the object to look exactly the same, but take up a larger
portion on the screen, scale the object and adjust the SSLT parameters.
(Or zoom in on the object ;))
Am 01.05.2017 um 14:06 schrieb Stephen:
Indeed.
Also, I might take the opportunity to re-iterate that it is not an SSLT
setting /per se/. It only just so happens that SSLT is currently the
only feature that makes use of it.
Am 02.05.2017 um 08:51 schrieb Thomas de Groot:
> [snip]
Technically, you only need to be careful if you intend to re-use (or
have others re-use) your SSLT stuff in any other scene.
For instance, if you've concocted a convincing ivory material, that
ivory material will only look convincing in other scenes if both your
original scene and the new scene have proper mm_per_unit settings (or if
both have the mm_per_unit setting screwed up by the same factor).
> Indeed.
Yet? :-)
Regards
Am 02.05.2017 um 10:03 schrieb Stephen:
Nah, no marching band for me yet.
But eight bells for someone dear.
Sorry to hear that. :-(
Regards
Well, I am very sorry to hear that, Christoph. You have my sincere support.
Hmmm... yes, that is well put. I guess I have to ponder this a bit and
add it to my own little reminders.
Thanks a lot!
>> [snip]
Yes, that was what I thought indeed.
As far as I am concerned, the final version. I streamlined the code for
better reproducibility, made an area_light of the spotlight, and
increased the translucency of the cube. Using: +am3 +a0.01 +ac0.95 +r4
Download 'sslt_test_uber_final.png' (673 KB)
Preview of image 'sslt_test_uber_final.png'
Excellent job.
Regards
> Excellent job.
Thanks indeed. For the curious, I am going to put the material macros
used in p.t.scene-files.
