POV-Ray : Newsgroups : povray.binaries.images : Testing ... Server Time
21 Oct 2025 22:24:09 EDT (-0400)
  Testing ... (Message 1 to 9 of 9)
Subject: Testing ...
Date: 11 Apr 2017 08:28:30
Message: <58eccbee@news.povray.org>
... these 3.7.1 features. All materials have the finish level fresnel.
The key light uses the new light fading model. Used type 7 image map
with the hdr probe surrounding everything and last but not least tau is
used to position the camera and light source.
Download 'flowers.png' (664 KB)
Preview of image 'flowers.png'
Subject: Re: Testing ...
Date: 12 Apr 2017 02:56:35
Message: <58edcfa3$1@news.povray.org>
Interesting, although I miss a bit of highlights on leaves and petals.
They seem a bit flat.
Date: 12 Apr 2017 07:10:50
Message: <58ee0b3a$1@news.povray.org>
yeah i know what you mean ... it's the fresnel. perhaps a misuse for
those materials. this is still a wip and i ran out of time.
Date: 12 Apr 2017 15:39:46
Message: <58ee8282@news.povray.org>
What's the ior of your flower?
Remember that fresnel really always need an ior, or it just don't work
at all.
My guess for the ior needed would be somewhere between 1.3 and 1.4.
Close to that of water.
Date: 13 Apr 2017 02:48:08
Message: <58ef1f28$1@news.povray.org>
In any case, what I forgot to say, I believe such images would do very
well in any future Insert Menu for the used features.
Date: 13 Apr 2017 07:40:28
Message: <58ef63ac$1@news.povray.org>
> at all.
yep using 1.3 (water) and hollow on as well. fresnel is angle dependent
(lighting and/or viewing) right? maybe that's where i'm missing the bus.
also (not /entirely/ unrelated) regarding variable reflection. it seems
a bit threshold-ish ... that is: reflection { 0, 0.2 fresnel } doesn't
give exactly what i'd expect but reflection { any-small-none-zero-value,
0.2 fresnel } does
Date: 13 Apr 2017 13:18:40
Message: <58efb2f0$1@news.povray.org>
Am 13.04.2017 um 13:40 schrieb Jim Holsenback:
> 0.2 fresnel } does
Sounds odd to me. Can you post an example?
Theoretically, a polished surface should work best with
    finish {
      diffuse albedo 1
      specular albedo 1 roughness VERY_SMALL
      fresnel
      reflection { 0, 1 fresnel }
      conserve_energy
and it should be possible to shorten `reflection { 0, 1 fresnel }` to
`reflection { 1 fresnel }`.
Date: 16 Apr 2017 09:32:55
Message: <58f37287@news.povray.org>
>> 0.2 fresnel } does
>      finish {
>        diffuse albedo 1
>        fresnel
>        conserve_energy
i withdraw my threshold-ish comment after playing around with things a
bit however i now have these observations:
in the attached image the object on the left has finish level fresnel
/only/ and the object on the right the same but with fresnel off in the
reflection block. all other finish attributes are identical for both
objects. i was under the impression that specifying finish level fresnel
/did not/ enable reflection level fresnel until specified!
Download 'fresneltest.png' (675 KB)
Preview of image 'fresneltest.png'
Date: 17 Apr 2017 09:19:42
Message: <58f4c0ee$1@news.povray.org>
Am 16.04.2017 um 15:32 schrieb Jim Holsenback:
I confess that this would have been my ad-hoc recollection, too -- but
looking at the source code and wiki I find that's neither how I
implemented it nor how it has been documented (quoting from
http://wiki.povray.org/content/Reference:Finish):
"Setting finish-level fresnel will automatically activate (if set to a
non-zero value) or deactivate (if set to zero) the reflection-level
fresnel parameter. This can be overridden by specifying the reflection
parameters after the finish-level fresnel parameter. [...]"
This is consistent with the implementation.
