POV-Ray : Newsgroups : povray.binaries.images : Stranger Moon Server Time
15 Mar 2026 08:43:47 EDT (-0400)
  Stranger Moon (Message 1 to 10 of 36)
Subject: Stranger Moon
Date: 13 Mar 2017 05:00:14
Message: <58c65f9e@news.povray.org>
A scene I have been working on for some time, with different
interruptions. This is a first final version; possibly, some changes
will take place.
The background star field and the landscape are based on Apophysis
images http://apophysis.org/, the first as an .exr file, the second as
basis for the height_field. The scene is a subtle play with different
light_groups.
The vegetation was modelled with Dryad, a little free application from
stanford.edu
http://news.stanford.edu/news/2008/january9/dryad-010908.html that seems
to have disappeared from the net.
Download 'stranger moon_05.jpg' (207 KB)
Preview of image 'stranger moon_05.jpg'
Subject: Re: Stranger Moon
Date: 13 Mar 2017 06:15:01
Message: <web.58c670a1bc728e716086ed00@news.povray.org>
> will take place.
> light_groups.
> stanford.edu
> Thomas
Hello, I feel compelled to criticize to be constructive and always look for
improvement, but I Love the picture, geometric and tonal composition... now to
the nitpicking:
The image works much better in small preview than at a bigger scale. This
reveals a good potential, and lack of some details:
* The tree trunks are too straight
* The trees have not enough color variations (how many different tree models?
maybe changing some of them for a new one with slightly different color would
solve this)
* Though this may be realistic, the water appears too dark , that is probably
because the view angle is too high, with Fresnel not allowing the sky color to
get reflected enough, lowering it might also let us see some of the surface
waves to add some nice detail that probably are already there.
Be careful not to loose that type of background rock you have, it's beautiful
and makes much of the point of the picture.
* isn't scale of the clouds too small? making them bigger would create larger
holes where the "moon" could be let visible and still get some occlusion from
the clouds, because as it is, the moon looks closer than the clouds.
*beaches are too vertical, ideally a small fringe of the terrain with lower
slope would make them less linear, but I guess it must be difficult depending on
how procedurally the height field was generated... If not possible then I would
try to make the sandy yellow line much thinner to make up for that.
Great work and a hard subject to depict !
Date: 13 Mar 2017 08:29:10
Message: <58c69096$1@news.povray.org>
>> will take place.
>> light_groups.
>> stanford.edu
>> Thomas
> the nitpicking:
I am always happy when people nitpick. I like to do it myself too with
others and believe it is to everybody's good :-)
> solve this)
Absolutely true on both points. Those are some of the planned
improvements. Dryad needs a bit of massaging to give better results and
I only used two models here, which of course is way too few.
There is matter for some thoughts here. The water is a media with
absorption and scattering densities. The surface itself has too little
reflection indeed and could be improved.
I was expecting this! ;-) The point is that those as /not/ clouds but a
starscape, maybe somewhere closer to the galaxy's hub. Star clusters and
groupings are supposed to represent this aspect. Of course, the
image_map used of an Apophysis flame is not really star-like nor
realistic but I liked this nonetheless for an alien sky, and why go all
the realistic way after all?
As far as clouds are concerned, there is a scattering media present
which expresses the heat of this planet but no clouds are formed at this
hour of the day.
Thanks!
Date: 13 Mar 2017 10:25:01
Message: <web.58c6aadcbc728e7c437ac910@news.povray.org>
> >> stanford.edu
If it's at all possible, that would be a great application to share with folks,
since vegetation is whole area of its own, that can be a HUGE time sink.  Since
it was being given away for free at the time , I don't know if you need any
other permission from the author to share the version you have.
Indeed.   Constructive nitpicking, like "This here has a problem, which can be
fixed if you do X, Y, or Z...." helps people learn to look at their scenes with
a more discerning and critical eye, and most importantly, LEARN how to avoid and
fix those problems.  This makes for a stronger raytracing community.  :)
Maybe.  They're alien trees.  I'd perhaps say "they're all too uniform /
similar."
> > solve this)
Coding good looking variation is definitely a tremendous skill.
Once again Thomas - great landscape, and a very nice atmosphere.   I always
enjoy looking at your scenes, and have something to learn, and a level of
accomplishment to strive for in my own work.  I really like the higher-contrast,
crisper, clearer foreground to the right which really adds a sense of depth to
the scene.   Perhaps having some of that on the left might help the scene "pop"
more...
Date: 13 Mar 2017 11:23:45
Message: <58c6b981$1@news.povray.org>
On 3/13/2017 2:21 PM, Bald Eagle wrote:
>>>> > >>stanford.edu
But if you use the Wayback machine it can be found here.
https://web.archive.org/web/20090123034022/http://dryad.stanford.edu/download.php?os=windows
There is a Mac version available.
License
Dryad is free for you to use for any purpose, including commercial
applications. However, Dryad is provided entirely "as is" and without
warranties of any kind. Please note that, for our research, we collect
some anonymous usage statistics about Dryad.
Regards
Date: 13 Mar 2017 12:15:00
Message: <web.58c6c462bc728e7c437ac910@news.povray.org>
Thanks Stephen!  :)
And...  "Click on the dice button to get a new tree that is like your current
one but slightly different."
Super useful.
Date: 13 Mar 2017 12:31:42
Message: <58c6c96e$1@news.povray.org>
> Thanks Stephen!  :)
> Super useful.
Selecting a tree and moving the mouse over the RH window is super dooper. :)
Regards
Date: 14 Mar 2017 01:00:00
Message: <web.58c7780cbc728e7194284cc0@news.povray.org>
Image colors look a little washed out and could use some saturation.
Date: 14 Mar 2017 03:47:50
Message: <58c7a026$1@news.povray.org>
That is the atmospheric media.
Date: 14 Mar 2017 03:59:31
Message: <58c7a2e3$1@news.povray.org>
>>>> stanford.edu
I had not thought about the Wayback Machine. Fortunately, I have Stephen
to take care of those details ;-)
I totally agree. I guess that about 70% of my POV-Ray skills come from
the examples and help from others. And my learning curve is still quite
steep.
> similar."
Probably, those trees will remain straight, but there needs to be much
more variation in tree/bush types.
>>> solve this)
I have been lazy (like so often) and postponed that work to phase 2. ;-)
> more...
Thank you very much indeed. :-)
The media at the left of the scene is a bit thicker than on the right.
Partly because the shore is a tiny bit farther away but mostly because
of the turbulence of the media, like mist shrouds thinning out or
thickening locally. It was important to me that at least some part of
the scene were crisper.
