POV-Ray : Newsgroups : povray.binaries.images : hard_object, soft_object pattern 3.7.2 patch branch. Server Time
15 Oct 2026 20:46:01 EDT (-0400)
  hard_object, soft_object pattern 3.7.2 patch branch. (Message 1 to 22 of 22)
Subject: hard_object, soft_object pattern 3.7.2 patch branch.
Date: 3 Mar 2017 05:43:15
Message: <58b948c3$1@news.povray.org>
The three attached images were created using two new patterns called
hard_object and soft_object. They can be found in the patch branch off
master (3.7.2) at:
https://github.com/wfpokorny/povray/tree/feature/soft_objectAndhard_objectPatterns
Associated demo scenes can be found in the scenes/textures/patterns
directory of the branch. Both new patterns are aimed first at making the
object to isosurface-object path easier. However, both work as pure
patterns too with gradual 0 to 1 value changes from the object surface
inward.
The hard_object pattern is a more complete implementation of the
ObjectAsIso idea I was playing with - mostly in SDL - back in 2008 or
2009. Hard because the method replicates an input object's sharp features.
The soft_object pattern is based upon a subset of the density file
pattern updates and ideas I was playing with last year. See:
http://wiki.povray.org/content/User:Wfpokorny/DensityFile. Soft because
the method uses exponential blobbing. In this implementation a virtual
"df3 grid" is created on the fly.
The essential sdl for hard_object looks like:
  #declare FnHardObj = function {
     pattern { hard_object { ObjectText }
         radius 0.08
         recursion_limit 10
         samples 22
         warp { turbulence VarTurb octaves 3 lambda 3 }
and for soft_object it looks like :
#declare FnSoftObj = function {
     pattern { soft_object { ObjectText }
               spacing 0.009
               strength 1.00
               warp { turbulence VarTurb lambda 5 }
If you'd like to give these patterns a try, feel free to grab the branch
off github. I'm still seeing what they can do - and not do - myself.
Bill P.
Further notes.
- Both patterns are sampling based.
- The hard_object demo uses one text object ("Water") for simplicity.
The soft_object demo is made faster making each letter was its own
isosurface due bounding and inside object test efficiency. Both methods
are sensitive to how quickly the inside object tests can be done.
- Objects used must have a defined inside.
- Further documentation on the options can be found in the associated
git commit messages.
- If using as a pattern the soft_object is often faster than hard_object
for a smooth result. The reverse tends to be true if using the patterns
in an isosurface.
- When using hard_object in a pattern low recursion_limit values and
high samples are usually best. If using the hard_object pattern in an
isosurface low samples and higher recursion tends to be better.
- The hard_object method works exceptionally well with convex,
outwardly-pointy object features. The method struggles with concave,
inward-crevasse portions of the object - though where samples high
enough the distance from surface measure is decent. As the spherical
sampling moves further inside the original object fewer and fewer of the
spherical samples are usable in estimating the distance within - and
results get noisy. Such noisiness is both shown and used for effect in
this TinaCHeP image:
http://www.tc-rtc.co.uk/imagenewdisplay/stills/754/10.html
- Aggressive AA settings in combination with these patterns should be
avoided until final renders. The relative slowness of the patterns
compounds with AA.
Download 'hard_object.jpg' (65 KB) Download 'hard_objecta.jpg' (129 KB) Download 'soft_object.jpg' (81 KB)
Preview of image 'hard_object.jpg'
Preview of image 'hard_objecta.jpg'
Preview of image 'soft_object.jpg'
Subject: Re: hard_object, soft_object pattern 3.7.2 patch branch.
Date: 3 Mar 2017 09:00:36
Message: <58b97704$1@news.povray.org>
Am 03.03.2017 um 11:43 schrieb William F Pokorny:
> master (3.7.2) at:
Sounds to me like an extension of the mechanism could be used for
proximity patterns.
I find the names `hard_object` and `soft_object` rather nondescriptive.
Also, I wonder whether it would be more user-friendly to syntactically
include these patterns into the `object` pattern, using one additional
parameter to enable "fuzzyness" of the pattern and choose a mode to
achieve that "fuzzyness", plus mode-specific parameters (though ideally
the modes should use the same set of parameters where possible).
How I would like to use such a pattern would be by specifying:
- Whether the pattern slope should be outside the surface, inside the
surface, or across the surface (given a flat surface of course). (Note
however that the latter might be sufficient to create the other two by
"postprocessing".)
- A falloff rule, e.g. linear, power-law or exponential-ish. (Note
however that the waveform pattern parameter might be sufficient for this.)
- A parameter to control the falloff distance.
- One or more parameters to control the quality of the computations.
Maybe it would also be useful to implement a caching mechanism for some
modes.
Also, ideally some parameterization of the whole smash should combine
neatly with blob potential patterns.
Date: 3 Mar 2017 10:20:01
Message: <web.58b988852105b4c1c437ac910@news.povray.org>
Hmmm -
I'm watching this right now and you may also find this to be of interest:
https://www.youtube.com/watch?v=r18Gi8lSkfM
especially around the 12:00 mark
IIRC from another tutorial I saw a while back, there may be some utility here in
selecting round vs sharp corners - I'll have to track down the demonstration of
that.  Might be useful for other folks playing around with scanning, meshes,
isosurfaces, fillets, etc.
Looks like Thies Heidecke was working in the forward direction in 2002.
http://news.povray.org/povray.binaries.images/message/%3C3c7bb095%40news.povray.org%3E/#%3C3c7bb095%40news.povray.org%3
E
So much to learn, so many approaches to every problem!
Date: 4 Mar 2017 10:32:00
Message: <58baddf0$1@news.povray.org>
>> master (3.7.2) at:
> proximity patterns.
Yes, a variation of the hard_object method would essentially be what
many here have called proximity patterns - that are really local
density-of-object(s) patterns. Jérôme has this:
http://wiki.povray.org/content/User:Le_Forgeron#proximity_pattern and
several have done things in SDL(1).
I think any real proximity pattern would shoot sample rays outward from
any sample point in space. Meaning it would be valid at a distance from
objects, perhaps even in a way not associated with particular objects at
all.
(1) - Including me. Somewhere I have a local density of object(s)
pattern written with functions for which performance was pretty good in
my use. I'll see if I can find it.
Not a big fan of these myself, but in the moment it's what I came up with.
A good idea - but one which is hampered by my near-amateur c++ skills...
> "postprocessing".)
Agree & thought of 'some' of these use desires myself. Tried one or two
variations working from outside the object, but failed to come up with
anything that worked.
By 'worked' here remember we are, performance wise, playing out at the
edge of practicality. Especially, given the primary intended use is in
another performance challenged area in functions and isosurfaces.
Yes, poly_wave is the intended method.
This is somewhat there given the hard_object->radius and
soft_object->spacing & soft_object->strength affect the falloff. Might
be hard to get the right trade offs though without an explicit falloff
value... If we can figure out a just outside value field capability an
explicit falloff distance - as a maximum - becomes more useful I think.
I'll think about it...
Not completely sure what you mean here. hard_object->samples is one I
guess. As you perhaps saw from the previous df3 blobbing modes, there
are some known tricks for faster much less accurate exp emulation used
in the soft_object which might be OK for pure pattern use - they were in
experimentation not useful with isosurfaces.
The very latest intel processors have AVX512 8x double exp capability,
which in the soft_object method might lead to a significant performance
boost. The code would have to be restructured I think to make it
practical by hand coding or compiler optimization. (I also do not own
such a processor & most other users won't have them near term...)
> modes.
Yes, possible. For the soft_object form I have little immediate
interest in code work given the new df3 3,4 & 5 interpolation modes are
just such a cache with the added benefit I can tune the strengths used
in the df3-grid to get much better looking soft/blobbed results.
I've played a little with caching ideas for the hard_object method
without success. My limited C++ skills are likely in the way.
What I found myself wishing for was a simple to use fixed thread
associated, array storage. Something I could index by thread number
(ThreadData->ThreadNumber).
There is a thread id in the boost pthread implementations, but no by
render-thread 'integer' I could find which might be the basis for such
caching. Did I miss something or might we create such an render-thread
index integer ourselves as we spin the render-threads off? For caching
to benefit performance-wise it is my belief we cannot be doing much -
perhaps any - memory management. Thinking of caching created on pattern
creation and then fixed thereafter during pattern evaluation could
likely help.
I looked at the crackle and isosurface caching, but in addition to not
really understanding completely how it all works - just adding more
overhead to the by thread threaddata looked undesirable. Especially
given our recent thread stack size issues.
Yes, this thought popped into my head too, but I'm well off having any
clear view on how it might all work.
Thanks for the feedback!
Bill P.
Date: 4 Mar 2017 10:41:49
Message: <58bae03d$1@news.povray.org>
> Hmmm -
> E
Thanks for the pointers and yes, agree. Lots of ways to come at things.
I've noted your recent FFT posts. Who knows maybe they can play some
part here, but I've never worked directly with FFT code or libraries.
Bill P.
Date: 4 Mar 2017 13:22:23
Message: <58bb05df$1@news.povray.org>
>> proximity patterns.
> all.
I've posted the full code for an example to p.b.scene-files. The
resultant image is attached. It shows too some of the shortcomings of
density-based vs what a real proximity pattern might do.
FYI - In finding the code again, the functions could I think be
encapsulated in a macro for a general local-density capability. I
defined a radius variable and a falloff variable.
In this implementation the starting radius with a relatively few samples
is shrunk by a falloff - (currentRadius/falloff) for each step - from
the starting radius smaller for 22 steps. The sampling vectors  were
randomly rotated at each step. The number of samples inside of all the
samples is then normalized to a 0-1 value as the final functional result.
Bill P.
Download 'denfnctexample.jpg' (34 KB)
Preview of image 'denfnctexample.jpg'
Date: 5 Mar 2017 13:27:30
Message: <58bc5892$1@news.povray.org>
I'll admit, I have no idea what "short comings" I am looking at, since,
this looks really neat. Like, someone painted the thing blue, then
yellow, then bright pink, then it spent enough time in some sort of
abrasive conditions so as to strip the paint, except where well
protected, back to yellow, then finally the original blue, along the
much more exposed edges.
Commander Vimes: "You take a bunch of people who don't seem any
different from you and me, but when you add them all together you get
this sort of huge raving maniac with national borders and an anthem."
Date: 6 Mar 2017 02:51:24
Message: <58bd14fc$1@news.povray.org>
I was thinking the same and that this image even seems to show some
improvements over current proximity pattern use.
Date: 6 Mar 2017 09:49:41
Message: <58bd7705$1@news.povray.org>
Patrick & Thomas, Thanks & thanks for making me think more about this.
I've had it in my head a real proximity pattern would stop at the first
surface of the surrounding object(s) - which would create a smoother
result than seen - in addition to working with objects having no
interior(1).
Suppose though, rays shot outward from a proximity pattern don't have to
stop at the first surface... ;-)
Perhaps relatively obvious, but the posted density function example
doesn't need to be object based. In other words it's input function can
be another pattern or any other function. I'm attaching another image
using the cells pattern as the input. I've played very little with other
than object based function inputs with this local density method.
Bill P.
(1) - A really rough idea for use I've had rattling around in my head
for a first-surface (best aligned to surface normal, min found, other?)
proximity pattern is using such a pattern as an aid in placing objects.
Or, moving objects around in a scene in an environmentally aware way.
Especially meshes and objects in relation to meshes. Mesh camera looking
outward from each face toward objects(s) whose pigment is an emitted
color which corresponds to proximity not to itself but back to the
mesh... Similar things can be done with trace, but at the speed of SDL...
Download 'denfnctexample2.jpg' (51 KB)
Preview of image 'denfnctexample2.jpg'
Date: 6 Mar 2017 13:20:07
Message: <58bda857$1@news.povray.org>
Am 06.03.2017 um 15:49 schrieb William F Pokorny:
> interior(1).
I would consider that an implementation detail of a proximity pattern --
just a different mode, if you will.
Date: 7 Mar 2017 08:12:36
Message: <58beb1c4$1@news.povray.org>
> master (3.7.2) at:
One of my goals with the hard_object pattern was to get to where we
could pass an object with a defined inside to some macro and have it
create a peeling paint (PP) (or other surface-skin) isosurface for that
object without the need for extra outside steps.
While obviously not a complete/correct PP implementation, using a
superellipsoid - as Thomas did in his original peeling paint texture
postings - kinda functions. See the attached image.
The bad news is I don't think the performance is tolerable - except
perhaps to those with 32 or more fast, real cores willing to endure some
long renders...
Suspect part of the issue is in doing everything on the fly necessarily
puts the crackle pattern into the overall function being evaluated where
it was previously a separate 2D-in-evaluation outside step. Often the
case with isosurfaces; Put a handful of slightly slow things together in
a function, stick it in an isosurface and you get glacially slow. :-)
Anyway, off to do some performance profiling to see if I can nudge the
technique into the practical realm.
Bill P.
Download 'peelingpaintb.jpg' (82 KB)
Preview of image 'peelingpaintb.jpg'
Date: 8 Mar 2017 02:42:47
Message: <58bfb5f7$1@news.povray.org>
Very nice indeed! I am following this work in progress with strong interest.
Date: 29 Mar 2017 04:25:44
Message: <58db6f88$1@news.povray.org>
Hi(gh)!
Apologizing for joining the thread only now...
Am I right to assume that with the soft_object pattern, gradients
controlled by objects can be generated? If so, this would be a finally
solved issue for me!
See you in Khyberspace!
Yadgar
Now playing: A Victory of Love (Alphaville)
Date: 29 Mar 2017 09:17:07
Message: <58dbb3d3$1@news.povray.org>
On 03/29/2017 04:25 AM, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
> Yadgar
Yes, if I'm understanding your question. Gradients are generated from
objects with both the hard_* and soft_* pattern variants. Objects like
box, sphere, mesh etc so long as they have a defined inside.
The gradients generated behave differently & the image posted to
TinaCHeP shows the hard_object pattern as a pigment on a plane. Attached
is an example of the soft_object variant where I back way down on the
strength parameter so that the individual df3 like virtual grid can be
seen; We essentially get many small sphere gradients at the virtual
voxel centers. The containing object here is a 9 point star mesh
compliments of some code posted by "Mike the Elder" a while back.
For soft_object at strong strengths - giving better overall rounding -
most of the interior has a value of 1.0 and only the near surface
regions of the mesh have the 0-1 gradient.
Both the hard and soft variants normally tend toward 1.0 well inside the
shape. The hard variant stops at 1.0 by nature of the method used, the
soft method internally goes to well over a 1.0 value, but is currently
clamped to 1.0 as all, but the new potential pattern, are presently.
Bill P.
Download 'soft_objectweakstrengthaspigm.jpg' (143 KB)
Preview of image 'soft_objectweakstrengthaspigm.jpg'
Date: 29 Mar 2017 10:15:01
Message: <web.58dbc1212105b4c1c437ac910@news.povray.org>
"One of my goals with the hard_object pattern was to get to where we
create ... ( ... surface-skin) isosurface for that
object without the need for extra outside steps."
Yes, this is something I think would be very useful indeed.
I think a lot of us dabbling with fillets and meshifying primitives and Bezier
patches and isosurfaces have at some point eyed that as a goal - to "somehow"
skin-over an object or union of objects.
It would be especially useful, I think, because I'm guessing that a pattern or
texture might be able to be "wrapped" in x/y/z so as to cover all of the "faces"
of the result.
This can be a real pain with CSG and standard procedural textures.
This is a very interesting project, and I hope you keep at it and make some more
excellent progress!   :)
Date: 31 Mar 2017 15:15:00
Message: <web.58deaa102105b4c1883fb31c0@news.povray.org>
All of this is quite fascinating.
I must have missed Thomas's posting. Anyone have a link to it?
Date: 31 Mar 2017 19:50:01
Message: <web.58deeab32105b4c180403a200@news.povray.org>
http://news.povray.org/povray.binaries.images/thread/%3C537db33d%40news.povray.org%3E/?ttop=414962&toff=450
Date: 31 Mar 2017 23:58:47
Message: <58df2577$1@news.povray.org>
> master (3.7.2) at:
How long did those take to render? Isosurfaces are usually very slow.
Mike
Date: 1 Apr 2017 00:30:01
Message: <web.58df2bee2105b4c19c5d6c810@news.povray.org>
Cool stuff, missed it before too. Missed a whole lot those few, to many, years
ago.
Thought I replied here earlier, too, these new object patterns are intriguing.
Date: 1 Apr 2017 03:08:21
Message: <58df51e5$1@news.povray.org>
> ago.
> Bob
And I forgot about that nice grunge texture by Paolo, at the end of that
same post. ;-)
Date: 1 Apr 2017 12:26:14
Message: <58dfd4a6$1@news.povray.org>
>> master (3.7.2) at:
> Mike
Rendered just now, 900x600 +A0.3, in a 3.72 branch without the recent
performance improvements of 3.71's, the demo soft_object takes 3 minutes
and the demo hard_object 1m 45s wall clock on my 2 core, 4 thread, I3.
Bill P.
Date: 1 Apr 2017 12:45:07
Message: <58dfd913$1@news.povray.org>
>> Mike
> Bill P.
I forgot I posted a hard_objectA.jpg image too - using warp turbulence
values I don't recall. More turbulence usually drives up the time so
probably 2-3x the hard_object time as a guess.
Bill P.
