POV-Ray : Newsgroups : povray.binaries.images : Another of Gamma's Smoking Guns Server Time
22 Oct 2025 07:43:07 EDT (-0400)
  Another of Gamma's Smoking Guns (Message 1 to 10 of 13)
Subject: Another of Gamma's Smoking Guns
Date: 24 Dec 2016 04:47:16
Message: <585e4424@news.povray.org>
This is actually much simpler:
#version 3.7;
global_settings { assumed_gamma 2.2 }
  perspective angle 75
  location  <0.0 , 1.0 ,-3.0>
  look_at   <0.0 , 1.0 , 0.0>
light_source { <-3000,3000,-3000> color rgb 1.2 }
plane { y, 0
  pigment { checker srgb 1 srgb 0 }
sphere { y*1, 1
  pigment { color srgb <1,0.5,0> }
  finish {
    diffuse albedo 0.9
    specular albedo 0.1 roughness 0.05
Note how the effective colour of the sphere is shifted in hue towards
yellow by the highlight, when it really should only be shifted in
saturation and brightness towards white.
Download 'gamma_smoking_gun_2.2.png' (78 KB) Download 'gamma_smoking_gun_1.0.png' (85 KB)
Preview of image 'gamma_smoking_gun_2.2.png'
Preview of image 'gamma_smoking_gun_1.0.png'
Subject: Re: Another of Gamma's Smoking Guns
Date: 24 Dec 2016 05:02:07
Message: <585e479f$1@news.povray.org>
That is a more useful illustration for me.
Whilst I could see the differences in your previous examples. They were
just two similar but different images. (Extreme example discounted.)
Regards
Date: 24 Dec 2016 10:25:00
Message: <web.585e928771b7ed6e194284cc0@news.povray.org>
Date: 24 Dec 2016 14:23:31
Message: <585ecb33@news.povray.org>
Am 24.12.2016 um 16:21 schrieb jhu:
I've made no attempt to "un-out-wash" it, so that's not much of a surprise.
Date: 24 Dec 2016 14:36:52
Message: <585ece54@news.povray.org>
Better?
Download 'gamma_smoking_gun.png' (98 KB)
Preview of image 'gamma_smoking_gun.png'
Date: 24 Dec 2016 17:45:00
Message: <web.585ef9d071b7ed6e615a0e20@news.povray.org>
> Better?
Significantly. Radiosity?
Date: 25 Dec 2016 00:25:01
Message: <585f582d$1@news.povray.org>
Am 24.12.2016 um 23:42 schrieb jhu:
>> Better?
That, and gave the light source a realistic inverse-square-law falloff
while moving it closer.
Date: 27 Dec 2016 03:25:00
Message: <web.586223fd71b7ed6e883fb31c0@news.povray.org>
> #version 3.7;
Hello all! I finally have a new computer (well, a used one, with Windows 7
Ultimate, and a dual-core processor. No more Windows XP, sadly-- that one died.)
I've been away from the newsgroups for several months...
But I digress...
I decided to run your test scene with assumed_gamma 1.0 instead of 2.2, and
noticed something about your use of 'rgb' in the light_source. I changed it to
srgb (which I've started doing in all my v3.7xx scenes, to be 'color-consistent'
with all the other srgb colors I use), and noticed that the scene gets
*brighter.* It's an interesting (and unexpected) effect-- unexpected because,
when substituting srgb colors for rgb (under assumed_gamma 1.0), it usually
causes the lighting/colors to be be somewhat *darker* (as expected, due to the
gamma shift of the color components away from linear.) But in this case, the
result is the opposite-- it's brighter!
I assume this is because the light's intensity is greater than 1.0; but I don't
quite understand why. Is it a natural consequence of the srgb 'gamma curve',
affecting color components above 1.0? (Or maybe above a particular
'intermediate' value between 0.0 and 1.0?)
Date: 27 Dec 2016 07:10:39
Message: <58625a3f$1@news.povray.org>
Am 27.12.2016 um 09:21 schrieb Kenneth:
You can think of "srgb C" as (roughly) equivalent to "rgb pow(C,2.2)",
i.e. very roughly squaring the colour value. As you may be aware, the
square of a (positive) value below 1 is an even smaller value, while the
square of a value above 1 is an even larger value.
The sRGB "transfer function" (that's the official technical term) is
indeed designed in such a way that it is neutral for values of 0 and 1,
while adjusting any values in between. Since it was designed for
situations where colours are clipped to this range, no special handling
is provided for larger values, and the effect is reversed there.
BTW, in the nominal region (between 0 and 1) the largest absolute effect
of gamma adjustment is roughly around an sRGB value of 0.5 (a linear
value of about 0.24), while the largest relative effect is near black.
Date: 27 Dec 2016 07:22:55
Message: <58625d1f$1@news.povray.org>
BTW, there's a caveat when using "srgb" in light sources: To modify the
brightness without affecting the hue, you need to use
    colour (srgb <R,G,B>)*Brightness
rather than
    colour srgb <R,G,B>*Brightness
because the latter would be interpreted as
    colour srgb (<R,G,B>*Brightness)
and in the sRGB world multiplying a colour vector by a constant does
/not/ correspond to an even scaling of the corresponding linear colour
components. (That would work for f(x)=pow(x,2.2), but sRGB gamma is more
complicated than that.)
