POV-Ray : Newsgroups : povray.binaries.images : Isosurface intersection artifacts Server Time
22 Oct 2025 07:44:40 EDT (-0400)
  Isosurface intersection artifacts (Message 1 to 8 of 8)
Subject: Isosurface intersection artifacts
Date: 25 Nov 2016 11:51:06
Message: <58386bfa$1@news.povray.org>
You can see in the image there is a jagged line where the isosurface
intersects the cylinder. Is it possible to get rid of this completely?
I have set accuracy very low to 0.0001 and max gradient very high to
10000, but I'm afraid it will never go away completely.
Thanks.
Mike
Download 'cielch_color_solid_cylinder_isosurface_backup_05.png' (24 KB)
Preview of image 'cielch_color_solid_cylinder_isosurface_backup_05.png'
Subject: Re: Isosurface intersection artifacts
Date: 25 Nov 2016 12:03:13
Message: <58386ed1$1@news.povray.org>
Am 25.11.2016 um 17:51 schrieb Mike Horvath:
You might try changing the overall scale of the entire scene.
An overly high max_gradient will not help at all, and will only increase
render time.
Date: 25 Nov 2016 22:00:00
Message: <web.5838f9774532f3c8e8ae267f0@news.povray.org>
This is probably the same problem I had in this thread:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.48cd3df6832f1b9885de7b680%40news.povray.org%3E/
Date: 26 Nov 2016 07:54:26
Message: <58398602$1@news.povray.org>
Excellent! That did the trick I think.
Mike
Date: 26 Nov 2016 13:12:18
Message: <787526097.501876608.045297.gdsHYPHENentropyAThotmaolDOTcom@news.povray.org>
> render time.
Out of curiosity, how close to "as good as it gets" is isosurface
performance? I love the things but they are prohibitively slow most of the
time...at least for the things I do with them, which is probably all sorts
of backwards and wrong to begin with. :)
Ian
Date: 26 Nov 2016 14:28:52
Message: <5839e274$1@news.povray.org>
Am 26.11.2016 um 19:12 schrieb [GDS|Entropy]:
>> render time.
There are certainly still ways to optimize, at least for special cases.
One such example would be functions whith lots of subexpressions, each
of which affect the result only in a well-defined region of space, like
the components in a blob.
Other approaches would involve preprocessing the isosurface prior to
rendering -- whether it is conversion to a mesh, pre-computing of
samples in a spatial tree (with the extreme being conversion to voxel
data), or other such fancy stuff.
And last not least there's the execution speed of the user-defined
functions. At present they are executed by a homegrown virtual machine,
which is quite simple and therefore presumably quite fast, but most
certainly no match for just-in-time-compiled code.
Date: 26 Nov 2016 17:51:26
Message: <583a11ee$1@news.povray.org>
>> render time.
> Ian
Set your max_gradient value as low as you can without degrading the object.
In some cases, using evaluate instead of max_gradient can improve your
performance. I've seen cases where the improvement was prety good.
Using pow() instead of multipliyng a variable by itself can help,
especialy in the case of a cube or higher power.
If your equation(s) can be writen in several ways, it's possible that
some of those ways to be more effecient. Try it if possible.
Make the container as tight as possible. It reduce the sampling needed
and often help in reducing the max_gradient.
In case of artefacts around areas where the isosurface intersect another
surface, try increasing the overall scale of the scene. This also work
with blobs.
Date: 27 Nov 2016 07:46:11
Message: <1368151571.501943393.962224.gdsHYPHENentropyAThotmaolDOTcom@news.povray.org>
> with blobs.
Thanks man I will give that a shot! :)
Ian
