POV-Ray : Newsgroups : povray.binaries.images : assumed_gamma, overlapping textures and transmit. Server Time
10 Oct 2026 12:30:23 EDT (-0400)
  assumed_gamma, overlapping textures and transmit. (Message 1 to 20 of 20)
Subject: assumed_gamma, overlapping textures and transmit.
Date: 18 Oct 2016 12:29:17
Message: <58064ddd@news.povray.org>
With the recent discussions related to gamma handling I thought I'd post
an image comparing how transmit behaves with respect to assumed_gamma in
a texture overlaid upon an image base texture. The behavior of transmit
at an assumed_gamma (ag) of 1.0 is something I like less well than its
behavior at an ag of 2.2.
In the attached image I am comparing ag of 1.0 to an ag of 2.2 in each row.
There is a base image_map texture on a plane. Over the top of that
texture is another with 5 columns of 4 colors (0,0.5,1.0,2.0) where the
5 columns have transmit values of: 0,0.5,1.0,1.5,2.0. One parallel light
source, camera orthographic, ambient 0, diffuse 1.0.
The non-linear behavior of transmit in the ag 2.2 case is often helpful
to the final appearance of layered textures - the gray out region is
tighter. When trying to map a 2.2 texture say from Norbert's collection
into my ag 1.0 working space, I start by converting any rgb colors to
srgb (bottom row), but that is usually not enough if the transmit value
in any part of the texture is not 0.0 or 1.0.
I usually end up thrashing around with colors and transmit values to get
closer, but truth is I'm often not able to match exactly the ag 2.2
look. Might be different if I started from scratch I guess.
Am I missing some technique? Are there proposals in the works - or
better available - which might help?
Aside: I have been wondering for a while about a more probabilistic
pixel based transmit mode for blending overlapping textures. Might such
an approach help with the dulling/graying of overlapping partly
transparent textures...
Bill P.
Download 'comparetransmitgammahandling.jpg' (876 KB)
Preview of image 'comparetransmitgammahandling.jpg'
Subject: Re: assumed_gamma, overlapping textures and transmit.
Date: 18 Oct 2016 14:36:06
Message: <58066b96$1@news.povray.org>
Am 18.10.2016 um 18:29 schrieb William F Pokorny:
Your example uses very unsaturated colours; to get the full picture, you
should also try the same experiment with highly saturated colours. I can
imagine that you'll come to different conclusions there.
What do you mean by "probabilistic pixel based transmit mode"?
Date: 19 Oct 2016 04:11:47
Message: <58072ac3$1@news.povray.org>
Quantum simulation of photons :-)
Date: 19 Oct 2016 06:20:24
Message: <580748e8$1@news.povray.org>
Will put it on the todo list - would suppose I'd notice the greying
transitions less in such an experiment. The image used was one where I'd
struggled with transparent textures and getting a "blend" between
textures that I wanted.
I have in mind some sort of sampling between textures weighted by the
transmit values involved. Suppose somewhat like the blending which
happened in the tilt shift image I posted recently. I admit though, I'm
thinking aloud.
Bill P.
Date: 19 Oct 2016 06:21:31
Message: <5807492b$1@news.povray.org>
:-) With those new quantum computers, it will be easy.
Date: 19 Oct 2016 07:16:14
Message: <580755fe$1@news.povray.org>
On 18-10-2016 18:29, William F Pokorny wrote:
> [snip]
Out of curiosity: what is a transmit value >1.0?
Date: 19 Oct 2016 08:09:35
Message: <5807627f$1@news.povray.org>
>> [snip]
People use >1 sometimes to amplify colors or increase contrast.
I think Norbert used this technique for one of his recent,
http://www.tc-rtc.co.uk/, metal monster images.
It isn't the most stable technique as can be seen in the right part of
the posted images. I'd say use values in the 0 to 1 range as a rule.
Aside: I have a question rattling around in my head as to why the higher
values tend toward black.
Bill P.
Date: 19 Oct 2016 11:15:18
Message: <58078e06$1@news.povray.org>
Is the problem here though is that you're trying to solve this by
tweaking gamma? Maybe it works for this issue, but it's also going to
affect all the other lighting and colours in your scene.
The better approach would be to figure out how to achieve what you want
without changing the scene-wide gamma setting. What if you adjust the
gamma of the image and the "gamma" of your rgbt values (ie don't step in
equal steps for each column)? You might have to sit down and work out
the maths to get what you want without changing assumed_gamma.
Date: 19 Oct 2016 13:18:33
Message: <5807aae9$1@news.povray.org>
Am 19.10.2016 um 12:21 schrieb William F Pokorny:
Such a simulator already exists -- it's called Reality ;)
Date: 19 Oct 2016 13:29:36
Message: <5807ad80@news.povray.org>
Am 19.10.2016 um 12:20 schrieb William F Pokorny:
> thinking aloud.
You mean, something like using the "average" pseudo-pattern to textures,
but with the weight being modulated by the textures' "transmit" channel?
While that sounds interesting, a major drawback would be that the
"transmit" channel couldn't be used for its original purpose, namely
specifying transparency of the texture.
Date: 19 Oct 2016 13:36:16
Message: <5807af10$1@news.povray.org>
Am 19.10.2016 um 14:09 schrieb William F Pokorny:
>>> [snip]
Because transmit not only controls the brightness of the background that
peeps through, but also of the texture itself. The higher the transmit,
the lower the percentage of the texture itself that gets mixed in -- to
the point where a /negative/ percentage is mixed in.
At the same time, more and more background is mixed in, but if it's
darker than the foreground it can't compensate the loss.
Date: 20 Oct 2016 02:58:51
Message: <58086b2b$1@news.povray.org>
>>> [snip]
[snip]
Thanks indeed. This is an unknown effect of /transmit/ to me, in
contrast to /filter/. Going beyond complete transparency (t=1) is not
very intuitive :-)
I suppose that most users are unaware of this and possibly it should be
mentioned in the docs.
Date: 20 Oct 2016 03:32:33
Message: <58087311$1@news.povray.org>
Am 20.10.2016 um 08:58 schrieb Thomas de Groot:
>>>> [snip]
>>>> light
> [snip]
> very intuitive :-)
What -- that transmit+filter>1 can be used for effect? Or that the
effect is non-intuitive?
Date: 20 Oct 2016 04:03:57
Message: <58087a6d$1@news.povray.org>
>>>>> [snip]
>>>>> light
>> [snip]
>> very intuitive :-)
transmit+filter, yes, I understand that; but transmit >1? for me that is
non-intuitive. I cannot conceive something /more/ transparent than
complete transparency ;-)
Date: 20 Oct 2016 09:51:18
Message: <5808cbd6$1@news.povray.org>
>> thinking aloud.
For the base mechanism, yes, this is a good description. On top of which
I was thinking an element of randomness - that probability element - to
add some noise in the blend of textures.
Agree any such a mechanism would have to leave the the current transmit
channel behavior as is. Pretty sure the noise part of it would also not
work well with standard AA - larger images scaled down being the AA
approach instead.
I've been able to play with some elements of the idea using functions
and the wave modifiers, but it hasn't coalesced into a standard
technique for me.
Date: 20 Oct 2016 10:28:26
Message: <5808d48a$1@news.povray.org>
Indeed, you can make adjustments to colors and transmit instead to
mostly get there in the 1.0 space. Inserting additional transmit entries
in the map often helps - sort of a piecewise, linear curve approach.
To be clear, I'm not tweaking assumed_gamma for effect. I use an ag of
1.0 for all my work.
That said, I've spent a fair bit of time working through Norbert's
material collection - mapping them to my own ag 1.0 versions and
variants. I've been doing it as a way to learn from other's texturing
work as much as anything. In my own work, I've hit upon occasions where
I want a less linear and tighter blend between textures. The 2.2 space
offers some of this - I suspect by side effect as much as intent.
With my post I was trying to document a texture layering difference
between the gamma spaces I think real. One that can be a speed bump of
sorts - especially when converting ag 2.2 developed overlapping textures
to an ag of 1.0 working space.
Bill P.
Date: 20 Oct 2016 12:27:08
Message: <5808f05c$1@news.povray.org>
Am 20.10.2016 um 16:28 schrieb William F Pokorny:
Maybe we can introduce a new "blend_gamma" parameter to textures, that
governs how the texture blends with the layer beneath it?
Date: 21 Oct 2016 09:39:24
Message: <580a1a8c$1@news.povray.org>
The idea strikes me as a good one.
Suppose the devil is in the details of implementation and actual use.
Are you thinking initially of:
effective_transmit=pow(T,new_blend_gamma_parm) for each texture with a
blend_gamma parameter?
Something this direct would address much of what I believe I'd like.
If we are going to add such a new control, perhaps the mechanism should
be set up more flexibly than a parameter to a built in function - could
be as much as complete control of the blend by function I guess.
I'm a fan of flexibility, but it's of course not free in terms of
implementation, ease of use and support.
Bill P.
Date: 21 Oct 2016 13:54:24
Message: <580a5650$1@news.povray.org>
Am 21.10.2016 um 15:39 schrieb William F Pokorny:
Pretty much precisely that.
Though, thinking about it, for texture stacks that have semi-transparent
portions this raises the question whether the blending of the lowest
texture in the stack and the background should also be affected.
If that is the case, then all we'd really need to do to achieve that
effect would be to use a pigment that already has the desired effective
transmit value.
For pigments with constant transmit value that would mean simply
adapting the transmit component.
For pigments with non-constant transmit, presumably using a colour_map
or pigment_map, we could just extend the existing blend_mode /
blend_gamma mechanism, for example by introducing additional modes that
also cover the transmit and filter components of the pigment.
If POV-Ray had a multi-channel function feature (which is something on
my todo list but still far from implemented), my suggestion would be to
simply provide some blend_function feature as an alternative for the
blend_mode / blend_gamma, that would take a function with eleven
parameters (the 2x5 channels of the pigment colours to be blended, and
the weight of the first colour) and return five result values (the 5
channels of the resulting pigment colour).
But until then, I am reluctant to implement any function-based solution
to the problem, as that would pose the risk of getting in the way of the
solution I would really want to implement.
Date: 21 Oct 2016 15:20:00
Message: <web.580a6a45fa99a67f700b175c0@news.povray.org>
I hope no one forgets about the alpha channel. although I don't know if that's a
factor in what you're talking about with gamma adjustments, just thought I would
mention it.
