POV-Ray : Newsgroups : povray.binaries.images : On thing leads to another Server Time
22 Nov 2026 10:53:08 EST (-0500)
  On thing leads to another (Message 1 to 49 of 49)
Subject: On thing leads to another
Date: 6 Oct 2016 10:58:47
Message: <57f666a7@news.povray.org>
This started out as just an alcove ... but the test object turned out
pretty cool so I decided to post.
Download 'spinner.png' (542 KB)
Preview of image 'spinner.png'
Subject: Re: On thing leads to another
Date: 6 Oct 2016 15:00:01
Message: <web.57f69f2f63e93b5fb488d9aa0@news.povray.org>
Nice - is that a double Witch of Agnesi?
Date: 7 Oct 2016 03:22:35
Message: <57f74d3b@news.povray.org>
Beautiful metallic texture indeed, as are the ceramic tiles by the way.
(What is that background reflection...? always fascinating to try to
decode the invisible...)
Date: 7 Oct 2016 06:16:00
Message: <57f775e0$1@news.povray.org>
thanks ... yes it is. top one has +y and bottom has -y (two different
spikes sizes) then csg'ed away the leftovers. used trace to get close
(some minor tweaking needed afterwards) with torus parameters then union
Date: 7 Oct 2016 06:21:58
Message: <57f77746$1@news.povray.org>
danke ...
for the large tile's (and floor) i used sam's odd tiles macro, and
tiling pattern 27 for the accent (penrose) tiles ... chrome material
uses a touch of irid
the background is one of my favorite hdr images ... an abandoned paper mill
Date: 10 Oct 2016 06:14:35
Message: <57fb6a0b$1@news.povray.org>
Jim Holsenback wrote on 06/10/2016 16:58:
A really nice image.
Paolo
Date: 11 Oct 2016 05:53:24
Message: <57fcb694$1@news.povray.org>
> Paolo
Date: 26 Oct 2016 22:18:06
Message: <581163de@news.povray.org>
found a couple of light leaks in the alcove when i used radiosity ...
grout needed a nudge. since i like where this is going i think i'll
spend a bit more time on the subsurface with this one before i do a
beauty run ... i'm shooting for porcelain
Download 'torusknot.png' (405 KB)
Preview of image 'torusknot.png'
Date: 27 Oct 2016 03:00:35
Message: <5811a613$1@news.povray.org>
Looking good.
Regards
Date: 2 Nov 2016 06:18:11
Message: <5819bd63@news.povray.org>
how about jade instead ...
Download 'jadeknot.png' (470 KB)
Preview of image 'jadeknot.png'
Date: 2 Nov 2016 07:06:17
Message: <5819c8a9$1@news.povray.org>
I like it. :)
How about a bit more colour variation? (I know I am a pleb with cheap
tastes ;) )
Regards
Date: 2 Nov 2016 08:00:52
Message: <5819d574$1@news.povray.org>
> I like it. :)
there already is a gradient y (4 color) but 18hrs later (subsurface)
it's not as apparent as i would have liked ... maybe i should throw some
yellow into the mix
Date: 2 Nov 2016 12:10:00
Message: <web.581a0f8363e93b5fb488d9aa0@news.povray.org>
Oh, take the bull by the horns already and just do a nice procedural opal.
:D
Date: 3 Nov 2016 00:10:00
Message: <web.581ab77b63e93b5f9c5d6c810@news.povray.org>
> > I like it. :)
> yellow into the mix
Probably more to do with the usual perfection problem, most jade I've seen tends
to have inclusions or variations. I like these knots regardless of that,
especially since I'm attracted to clean appearing perfection.
On that note I could find a tiny black crescent thing right at the left side of
the platform which doesn't seem to belong, so I couldn't help myself mentioning
that.
On the subject of jade... I have been trying the "baked map" textures from Jaime
Vives Piqueres 4 years ago. First time I've been doing so, and wanted to try
jade for the dragon mesh. Picture posted here. I simply put a small turbulent
and skew scaled granite color_map on it and let subsurface scattering do the
rest. Also has a thick layer of dark dust.
Reason I'm showing this one of mine here is because jade varies so much. I'm not
sure how homogeneous some real objects are but apparently some can be without
much of any variation in color or substance. My attempt was to get small changes
throughout, except maybe it looks too plastic...?
Enjoyed looking at your scenes here anyhow.
Download 'jade dragon.png' (167 KB)
Preview of image 'jade dragon.png'
Date: 4 Nov 2016 06:49:22
Message: <581c67b2$1@news.povray.org>
>> I like it. :)
> yellow into the mix
It is difficult. I did a nice one of Lucy, the grave monument, with one
of the early SSLT betas. I have not used it much since.
Regards
Date: 19 Nov 2016 10:48:15
Message: <5830743f@news.povray.org>
> I like it. :)
> tastes ;) )
mo betta? ... also changed the pose a bit and darkened it some as in
"after hours"
Download 'jadeknot.png' (706 KB)
Date: 19 Nov 2016 11:58:04
Message: <5830849c$1@news.povray.org>
>> I like it. :)
>> tastes ;) )
> "after hours"
Yes, I like that. :)
> "after hours"
? ^_^
Regards
Date: 20 Nov 2016 03:15:01
Message: <web.58315b6563e93b5f9c5d6c810@news.povray.org>
> "after hours"
Only problem now is that I imagine it doing twisting motions and the patterned
tiles rotating... animation possible? Or is that asking too much? :}
The image along with my imagination does okay enough if you can't do that so
don't feel pressured.
Date: 20 Nov 2016 08:20:05
Message: <5831a305$1@news.povray.org>
>>> I like it. :)
>>> tastes ;) )
>> "after hours"
>> "after hours"
> ? ^_^
like in a gallery after it's closed. i'm also working on a monochrome
version with scattering media.
Date: 20 Nov 2016 08:31:26
Message: <5831a5ae$1@news.povray.org>
>> "after hours"
lol don't worry i won't ... area lights + subsurface pushed the render
time into the 10 hr range on my machine, so i can't see any animations
happening on this one
Date: 20 Nov 2016 09:14:34
Message: <5831afca$1@news.povray.org>
>>>> I like it. :)
>>>> tastes ;) )
>>> "after hours"
>>> "after hours"
>> ? ^_^
Of course. Adjusting the gamma in an editor didn't cross my mind.
<Whistling> <blush>
I would not mind seeing that when it has finished rendering.
Regards
Date: 20 Nov 2016 09:15:34
Message: <5831b006$1@news.povray.org>
>>> "after hours"
>> patterned
>> that so
I chuckled when I read it. :)
Regards
Date: 20 Nov 2016 10:55:00
Message: <web.5831c6ac63e93b5f9c5d6c810@news.povray.org>
> >> that so
Can't let it churn something out over the next month that would only be a second
or two of animation? LOL
Come to think of it I haven't animated anything with subsurface scattering yet,
probably because I almost always use radiosity together with it. And you're not
kidding about the slowness of area lights, makes me reduce SSS samples and light
grid number out of desperation.
Will be watching, and waiting, for the monochrome version.
Date: 20 Nov 2016 11:16:05
Message: <5831cc45$1@news.povray.org>
Am 20.11.2016 um 16:52 schrieb omniverse:
>>>> that so
Have you considered trying UberPOV? It does include some mechanisms that
might trim down render times considerably when multiple oversampling
effects (e.g. focal blur, SSS, area lights, anti-aliasing) are combined.
Date: 20 Nov 2016 17:35:18
Message: <58322526@news.povray.org>
>> I like it. :)
>> tastes ;) )
> "after hours"
Very good. My only complain would be about those area_light artefacts in
the left anf right shadowed areas. Try increasing the adaptive value by
1, it should help, but it will obviously take longer to render.
Date: 20 Nov 2016 18:20:01
Message: <web.58322ef763e93b5f9c5d6c810@news.povray.org>
I'm using UberPOV mostly for the things specific to it so haven't really
compared until now.
Checking on that I found good news and bad news. The bad first.
Shadows from area light looks like jitter is always on even though that keyword
is left out.
The good news is it can be very fast.
More bad news, because even when attempting to equal the shadow appearances (and
they won't for whatever reason unknown to me) the subsurface scattering gets
worse not better. This with everything the same other than changing area_light
adaptive. Can only guess SSS requires more sampling when adaptive is increased,
just not tried yet.
Sorry Jim, for not starting a new topic. Will do so here in image group to show
the comparison.
Date: 21 Nov 2016 07:02:47
Message: <5832e267$1@news.povray.org>
not lately ... although in tinkering around i've gained some render
speed regarding area lights. i'd been using area_illumination on
Date: 21 Nov 2016 07:04:21
Message: <5832e2c5$1@news.povray.org>
ah ... thanks for jogging my memory on that i was wondering how to
address that issue
Date: 21 Nov 2016 07:16:53
Message: <5832e5b5$1@news.povray.org>
sa-weeeet ... increasing adaptive to 2 fixed it
Date: 21 Nov 2016 18:50:24
Message: <58338840$1@news.povray.org>
Good :)
Remember:
adaptive 0 = start with only the 4 corners of the area_light.
adaptive 1 = start with 1 subdivision, or a 3*3 array.
adaptive 2 = start with 2 subdivisions, or a 5*5 array.
Date: 1 Dec 2016 18:35:41
Message: <5840b3cd@news.povray.org>
On 11/20/2016 8:20 AM, Jim Holsenback wrote:
> i'm also working on a monochrome version with scattering media.
i reworked the material a bit ... gave blend_mode and blend_gamma a test
drive. i have a cool purple one but like this jade-ish version the best.
type 5 scattering media turned out ok too. i don't dare release the
kraken (area lights) on this one ... wondering if there is a chance of a
new subsurface option? ignore area lights for finish (subsurface) but
use with object (shadows)
Download 'jadeknot.png' (326 KB)
Date: 1 Dec 2016 19:04:46
Message: <5840ba9e$1@news.povray.org>
Am 02.12.2016 um 00:35 schrieb Jim Holsenback:
Unfortunately that's not possible for technical reasons: Shadow handling
is too deeply intertwined with the subsurface light transport algorithm
to be done separately.
Date: 2 Dec 2016 06:23:10
Message: <5841599e$1@news.povray.org>
we can already opt /not/ to use area lights in scenes (generally
speaking) and by extension subsurface ... that is good subsurface
results aren't depended on area lights or is it?
Date: 2 Dec 2016 13:19:06
Message: <5841bb1a$1@news.povray.org>
just tried uberpov 3.7.1-x.colour.8871403 and compared it to pov
3.7.1-alpha.8889454
did a subsurface and scattering comparison (no area lights):
subsurface only: pov 34.315 min  uber 47.6 min  pov 38% faster
scattering only: pov 16.1 min  uber 15.8 min toss up
why the big difference in render time for subsurface!!! not leading me
to expect any pay off by adding more than one effect or area lights into
the mix
absolutely no changes to sdl file other than #version 3.7;  -vs-
#version unofficial patch 3.7;
Date: 2 Dec 2016 15:02:01
Message: <5841d339$1@news.povray.org>
Am 02.12.2016 um 19:19 schrieb Jim Holsenback:
> 3.7.1-alpha.8889454
Can't say off the top of my head. It probably has to do with subsurface
light transport being inherently based on numerical integration (read:
it needs to shoot rays in lots of directions to do its job), which needs
to be shoehorned in to POV-Ray by brute force, while UberPOV provides a
dedicated framework for such numerical integration stuff. Maybe that
framework adds some unexpected overhead, or maybe it causes some
implicit increase in the number of rays short when default settings are
used.
Or maybe it's some entirely unrelated overhead unexpectedly introduced
with one of the other UberPOV features.
> not leading me
> the mix
Go ahead and try.
The crucial thing here is that in official POV-Ray, when both subsurface
light transport and area lights are used, the computational effort
doesn't simply add - it multiplies instead. This shouldn't be the case
with UberPOV's special framework.
Date: 3 Dec 2016 06:46:06
Message: <5842b07e$1@news.povray.org>
Me like. :)
Regards
Date: 4 Dec 2016 05:15:43
Message: <5843eccf$1@news.povray.org>
On 12/2/2016 3:01 PM, clipka wrote:
> Go ahead and try.
hmmm ... with uber subsurface + area lights render was > 14 hrs. pov is
/still/ ~ 38 % faster
Date: 4 Dec 2016 08:55:01
Message: <web.58441fd263e93b5f9c5d6c810@news.povray.org>
> > Go ahead and try.
That's a curious thing because I found subsurface together with area lights and
radiosity to be faster in most recent UberPOV versus the 3.7.1.1-alpha.
Same scene file was able to get a fraction, about 15%, of the render done while
the "alpha" was still doing the radiosity pretrace. Around 5 minutes to complete
pretrace versus about 25 minutes.
Date: 4 Dec 2016 12:10:54
Message: <58444e1e$1@news.povray.org>
>>> Go ahead and try.
maybe it was edge of that blackhole gravity well that passed through our
sector last evening
Date: 4 Dec 2016 13:55:00
Message: <web.5844655f63e93b5f9c5d6c810@news.povray.org>
> >>> Go ahead and try.
> sector last evening
Could be. :) Rendering with POV and its variations takes more scientific methods
than I'm usually capable of. The seldom mentioned findings like yours (and mine)
is very little to go on I'm sure. I'm always making guesses about what or why
something is so different regarding render times.
Funny thing about that. Just a while ago I mistakenly had 2 sets of scene
objects occupying the same space, and I couldn't understand why a slowdown and
strange artifacts was happening. Not typical coincident surfaces I'm used to
seeing, more like box shadows. Possibly the subsurface scattering causing the
change in appearance. Won't really ever know I guess, unless I encounter that
enough times to learn why.
Date: 10 Dec 2016 06:29:56
Message: <584be734@news.povray.org>
a change in test object ... best so far!!!!
Download 'chromeknot.png' (811 KB)
Preview of image 'chromeknot.png'
Date: 10 Dec 2016 06:31:57
Message: <584be7ad$1@news.povray.org>
render time:
Download 'time.png' (1 KB)
Preview of image 'time.png'
Date: 10 Dec 2016 07:10:08
Message: <584bf0a0$1@news.povray.org>
I love this one.
Date: 10 Dec 2016 07:21:01
Message: <584bf32d$1@news.povray.org>
> I love this one.
thanks ... can't take credit for model:
http://www.thingiverse.com/thing:1263333
it's in .stl format ... blender was able to import (no cleanup needed)
and i believe Jerome's pov branch can handle .stl
Date: 11 Dec 2016 08:37:27
Message: <584d5697$1@news.povray.org>
Yes indeed! This one has a great look.
Bill P.
Date: 12 Dec 2016 04:10:00
Message: <web.584e68a263e93b5f16086ed00@news.povray.org>
> render time:
That render time is depressing.
Date: 12 Dec 2016 06:50:01
Message: <web.584e8ec463e93b5fb1eb18a80@news.povray.org>
nice metal material
But the room is too dark, my opinion.
Date: 12 Dec 2016 07:30:10
Message: <584e9852$1@news.povray.org>
> nice metal material
thanks ...
perhaps ... room not as important as scattering media and object.
Date: 12 Dec 2016 07:32:29
Message: <584e98dd$1@news.povray.org>
>> render time:
well i suppose to be fair about it my system wasn't exclusive on the
render all the times ... maybe some gains from decreasing area light
density but then scattering and shadows suffer
