POV-Ray : Newsgroups : povray.binaries.images : looks_like Server Time
15 Oct 2026 22:24:03 EDT (-0400)
  looks_like (Message 1 to 16 of 16)
Subject: looks_like
Date: 8 Sep 2016 00:54:14
Message: <57d0eef6@news.povray.org>
Is this the correct way to set up a light_source and attached object?
// Sun
light_source
	Source_Location
	rgb light_color
	looks_like
		sphere
			Source_Location, Source_Radius
			texture
				pigment {color rgb light_color}
				finish
					emission	1
					ambient		0
					diffuse		0
	parallel
Note that the light source and object are both located at
Source_Location. I'm not sure how to test whether I'm doing it right or
wrong.
Mike
Subject: Re: looks_like
Date: 8 Sep 2016 03:57:15
Message: <57d119db$1@news.povray.org>
Am 08.09.2016 um 06:54 schrieb Mike Horvath:
Nope.
A looks_like object needs to be constructed at <0,0,0>, as POV-Ray
automatically adds a translation to the light source's location.
I do agree that this is poorly documented in the official documentation.
Date: 8 Sep 2016 04:00:51
Message: <57d11ab3$1@news.povray.org>
> Nope.
So this is better?
// Sun
light_source
	Source_Location
	rgb light_color
	looks_like
		sphere
			<0,0,0>, Source_Radius
			texture
				finish
					emission	1
					ambient		0
					diffuse		0
	parallel
Date: 8 Sep 2016 04:09:51
Message: <57d11ccf$1@news.povray.org>
Am 08.09.2016 um 10:00 schrieb Mike Horvath:
> So this is better?
Yup.
Date: 12 Sep 2016 03:10:03
Message: <web.57d65443e29f65168ef8a390@news.povray.org>
> Nope.
Date: 12 Sep 2016 03:25:01
Message: <web.57d6580ae29f65168ef8a390@news.povray.org>
> > Nope.
> So this is better?
> // Sun
> light_source
>  Source_Location
>  rgb light_color
>  looks_like
>   sphere
>    texture
>     finish
>      emission 1
>      ambient  0
>      diffuse  0
>  parallel
A more subtle details is that the light_color usually not the same.
the color of POV-Ray light_source describes the color of the illuminated object.
the color of looks_like object describes the color of (sun) itself. The sun
color often much brighter than the object it illuminates.
Date: 12 Sep 2016 04:00:00
Message: <web.57d65fffe29f65168ef8a390@news.povray.org>
I show you the calculation:
The angular diameter of the Sun is about 1/2 degree, so the solid angle of it is
about 0.00006 steradian viewed from Earth. If the luminance of the Sun is
sun_color, than the illuminace of the sun light is sun_color*0.00006, then the
luminance of the reflect surface will be sun_color*0.00006*surface_albedo/pi, so
you should set the color of the POVRay's light_source sun_color*0.00006/pi.
On the other hand, if you set the light_source color A, than the looks_like
color will be A*pi/0.00006 ~= A*52333.
Date: 12 Sep 2016 08:44:46
Message: <57d6a33e$1@news.povray.org>
Is this even possible? Isn't there a limit on how bright you can make
something?
Mike
Date: 12 Sep 2016 09:04:27
Message: <57d6a7db$1@news.povray.org>
Am 12.09.2016 um 14:44 schrieb Mike Horvath:
>> looks_like
> something?
Yes, absolutely: Brightness values cannot exceed 3.4e+38 ;)
Date: 13 Sep 2016 17:15:15
Message: <57d86c63$1@news.povray.org>
Do I apply this to the pigment or the finish emission?
Date: 13 Sep 2016 18:11:42
Message: <57d8799e$1@news.povray.org>
Am 13.09.2016 um 23:15 schrieb Mike Horvath:
>> looks_like
That's up to you, but personally I'd recommend the finish emission. The
pigment is also used in the other finish features, which are related to
reflection of light from somewhere else, where values above 1 make no
physical sense. But when it comes to emitting light on its own, there's
no limit for an object's material.
Date: 13 Sep 2016 18:58:39
Message: <57d8849f$1@news.povray.org>
>>> looks_like
So, like this?
	texture
		pigment {color srgb light_color}
		finish
			emission	pi/0.00006
			ambient		0
			diffuse		0
Date: 14 Sep 2016 05:05:00
Message: <web.57d9125be29f651c369d5640@news.povray.org>
> >>> looks_like
> So, like this?
>  texture
>   finish
>    emission pi/0.00006
>    ambient  0
>    diffuse  0
That should work.
Date: 14 Sep 2016 10:10:00
Message: <web.57d95a2be29f651b488d9aa0@news.povray.org>
The
> physical sense.
Does that include fluorescence, such as the widespread use of optical
brighteners in laundry detergents and printer paper?
(I'm not trying to claim that the actual reflected light intensity would exceed
the incident light in practice, in those two examples, but in theory I suppose
it might be possible?
Date: 14 Sep 2016 10:38:30
Message: <57d960e6@news.povray.org>
Le 14/09/2016 à 16:09, Bald Eagle a écrit :
> clipka <ano### [at] anonymousorg> wrote:
> The
>> physical sense.
Azurant... convert UV-radiation (invisible) into visible spectrum
(usually by doubling the wavelength). Black light is using the same system.
IMHO, you would need a non-diagonal matrix as pigment instead of a
vector to model such things (one column/row per wavelength) and a wider
vector for the light itself... and at the end, the camera collapse the
wider vector into the RGB value for the picture format.
Our traditional pigment would just be a pure diagonal matrix (everything
out of the main diagonal is 0).
Date: 14 Sep 2016 10:38:40
Message: <57d960f0$1@news.povray.org>
Am 14.09.2016 um 16:09 schrieb Bald Eagle:
> The
>> physical sense.
Even with fluorescence, technically values above 1 make no sense. But to
model this, colours would have to be matrices rather than vectors, and
one of the channels will be UV light, which doesn't show up in the image.
