POV-Ray : Newsgroups : povray.binaries.images : Dragon Lady Server Time
22 Nov 2026 10:53:07 EST (-0500)
  Dragon Lady (Message 1 to 50 of 65)
Goto Latest 50 Messages Next 15 Messages >>>
Subject: Dragon Lady
Date: 6 Aug 2016 13:44:01
Message: <57a621e1@news.povray.org>
I don't know if the book mentions her complexion but emission looks better.
I'm going to redo this from the start using what I've learned.
At the moment getting the positions right is next to impossible. So I
will re-export from Poser and rework it in PoseRay.
Regards
Download 'eastern01a5a_.jpg' (176 KB) Download 'eastern01a5a_f_0000.jpg' (119 KB) Download 'eastern01a5a_s_0000.jpg' (150 KB)
Preview of image 'eastern01a5a_.jpg'
Preview of image 'eastern01a5a_f_0000.jpg'
Preview of image 'eastern01a5a_s_0000.jpg'
Subject: Re: Dragon Lady
Date: 6 Aug 2016 15:45:00
Message: <web.57a63d27e7e0b8f75e7df57c0@news.povray.org>
This looks like a very cool project, and I like the results so far.
Perhaps the dragon may look / show up better if the emission tapered off in a
gradient as it moved away from the camera.   Think of it as a slightly darker
background media for a slightly brighter foreground media.
I think you could just define a z-gradient and rotate it based on the camera
location relative to the origin. If you need that equation, I can dig it up from
one of my scenes.
Date: 6 Aug 2016 16:25:00
Message: <web.57a64799e7e0b8f77a3e03fe0@news.povray.org>
> Regards
>      Stephen
How to make a hologram? All write about proprietary programs.
How do poor people do this? I live in Russia, I have no money.
Date: 6 Aug 2016 17:00:01
Message: <web.57a64fcbe7e0b8f75e7df57c0@news.povray.org>
There's a great channel on YouTube called "Applied Science"
This guy actually builds a working CT scanner in his garage...
I searched for
applied science hologram
I didn't see a video by him, but maybe some of the search results will have
something you can use - especially the cell phone holograms...
Date: 6 Aug 2016 18:28:39
Message: <57a66497$1@news.povray.org>
Thanks, that's good to know. The more I work on it. The more I see what
is wrong with it.
> one of my scenes.
I see what you mean. It is a good suggestion. Although I think that is a
refinement that must come at a later stage.
Thomas and I have a few integration points to discuss. For instance If
we are both using media then we have to use a common scale in Pov units.
And it is often hard to to make one media container inside a larger
media container not obvious. Then there is the problem that I am using a
PovRay modeller that only supports 3.6 syntax. Although I can use 3.7
syntax with a workaround. It will not make reading the SDL easy.
Thomas and I have both used Moray which uses a different coordinate
system to PovRay. It used Z axis is up. Whereas, as you know PovRay is Y
axis is up. We have to see how the scenes fit together first.
(I am just jotting down a few points that come to mind)
Regards
Date: 6 Aug 2016 19:09:19
Message: <57a66e1f$1@news.povray.org>
>> Regards
>>       Stephen
Hi LanuHum, thanks for the interest.
What I am trying to do is to use emissive media using a density file.
I have created a density file for each R, G, B channel by running an
animation in PovRay. That (as Mr Eagle hints is similar in technique to
a CT scan) takes a series of slices of a model (in this case a Poser mesh).
These images in (TGA format) are stitched together using a DOS utility
called tga2df3.exe to create a df3 file.
One additional step is to take each tga file and copy the values of the
used colour to the two other colour channels. (Making something similar
to a greyscale image.) Before running tga2df3.exe. {I forgot to do that
step in this image and will post an updated image tomorrow.}
That is the high level description. :)
Let me know if you get the drift (understand). If not I am happy to try
to explain further.
Regards
Date: 7 Aug 2016 03:10:57
Message: <57a6df01$1@news.povray.org>
She is a black lady indeed :-)
I think this is a fair interpretation of the dragon considering the
problems generated otherwise. Delany clearly wrote the book with an
image in his head, not considering the future problems of modellers ;-)
Date: 7 Aug 2016 03:30:21
Message: <57a6e38d$1@news.povray.org>
> is wrong with it.
Ha! How true. It's a curse ;-)
>> off in a
>> darker
>> camera
>> it up from
>> one of my scenes.
We have indeed some issues to discuss not in the least the media scale
used. Also, we may need indeed to test how the nested containers are
going to show up.
I posted an image of Bellona with the bridge and river in place. No
nested containers there as I restricted the atmosphere to just above the
water surface (the water is a media) and just below the clouds container.
The foreground is where I imagine the Scorpions to be and we need to
consider their scale with regards to the environment.
Much to do but exciting!
This may perhaps help already: the media used for the atmosphere:
//start code
#declare AtmosScale = <10, 10, 10>;
#declare Atmosphere =
union {
   //clouds:
   //clouds media here.
   //atmospheric haze:
   difference {
     sphere {0, 490}
     plane {y, -0.749}
     hollow
     material {
       texture {pigment {color rgbt 1}}
       interior {
         media {
           intervals 1
           samples 50
           scattering {5, rgb <1,1,1>*0.03/AtmosScale
             eccentricity 0.4
           density {
             spherical
             colour_map {
               [0 rgb 0]
               [1 rgb 1]
   scale AtmosScale
   rotate 50*z
   scale <5, 1.0, 5>
   rotate 45*y
//end code
Date: 7 Aug 2016 03:52:57
Message: <57a6e8d9@news.povray.org>
>> better.
Good and as long as we don't have a model called Peter we should stay
out of trouble. ;)
This is always a problem, visualising is so much easier as you can
ignore any inconveniences.
I have redone my export from Poser and Rig for creating df3's.
While That is going on, here are a couple of images with the corrected
density files. There is more detail I think
Regards
Download 'eastern01a5d_fr_0000.png' (253 KB) Download 'eastern01a5c_s_0000.png' (320 KB)
Preview of image 'eastern01a5d_fr_0000.png'
Preview of image 'eastern01a5c_s_0000.png'
Date: 7 Aug 2016 05:30:48
Message: <57a6ffc8$1@news.povray.org>
> //start code
What are the dimensions of you atmosphere media container?
Regards
Date: 7 Aug 2016 06:28:51
Message: <57a70d63@news.povray.org>
I think that I have the relative positions of the mesh and the df3
exported correctly.
I wish I had taken the time to give her some pants. The model looks like
someone I once worked with. I'm beginning to feel like a pervy stalker. :(
I've had to change the ratios of the R, G & B channels each time I've
made a new set of df3's.
I'll post the df3 files if anyone wants to play with them.
Regards
Download 'shenlong_02ae_0000.jpg' (156 KB)
Preview of image 'shenlong_02ae_0000.jpg'
Date: 7 Aug 2016 06:35:09
Message: <57a70edd$1@news.povray.org>
povray.binaries.misc
Just under 2Meg
Regards
Date: 7 Aug 2016 07:00:45
Message: <57a714dd$1@news.povray.org>
>> //start code
AtmosScale above: <10, 10, 10>  ;-) and scaled <5, 1.0, 5> This last
does not influence changes too much.
I have been thinking that emissive media are not influenced by the
container scale or are they? I seem to remember that obly scattering is
influenced...
Date: 7 Aug 2016 09:43:04
Message: <57a73ae8@news.povray.org>
>>> //start code
> influenced...
I don't know. I'll find out after I've finished playing Dressing Dolls. ;)
How many Pov units to a meter, in your scene?
I cheated with the clothes. I really need to export the scene from poser
again as a unit.
Regards
Download 'shenlong_02b_0000.png' (490 KB)
Preview of image 'shenlong_02b_0000.png'
Date: 7 Aug 2016 10:50:01
Message: <web.57a7494be7e0b8f75e7df57c0@news.povray.org>
How are you combining the 3 different channels of media?
I tried defining 3 boxes with different colored interiors, and it seems that the
current box seems to "overwrite" the previous box.
Drat this blasted media thing !!!!
You kids and your fancy new-fangled gadgetry.
Never satisfied with the simpler things in life.
When I was a kid, we didn't even have spheres to render with - we had amorphous
rocks with whatever texture was available.  And they were all drab.
And it was good enough for us.  AND we liked it.
"Media."   Harrrumph!
Download 'stephen_dragon.png' (46 KB)
Preview of image 'stephen_dragon.png'
Date: 7 Aug 2016 11:13:32
Message: <57a7501c@news.povray.org>
> "Media."   Harrrumph!
The youth of today. :P
They say a picture is worth a thousand lines of code. Well at least I do.
I use three media in one interior.
I would post the code but it is messy. I have to overwrite the code
Bishop3d exports with the code modified to run direct from Pov.
Both Bishop3d and Moray export a pov file for each frame and it takes
PovRay 16 seconds to save the scene. Creating the tga files to make the
df3's would take Bishop3d about an hour and a half to export 100 frames
times 3 for each channel.
Regards
Download 'image6.jpg' (43 KB)
Preview of image 'image6.jpg'
Date: 7 Aug 2016 11:15:19
Message: <57a75087$1@news.povray.org>
What's up with her left forearm?  It looks seriously fractured.
Date: 7 Aug 2016 11:28:42
Message: <57a753aa@news.povray.org>
I had better mention that I need to use a multiplier for each media to
balance the colours.
E.g.
//------- Box0 Raw Script Begin -------
#declare Emission_Factor_R = 10.0 ;
#declare Emission_Factor_G = 3.0 ;
#declare Emission_Factor_B = 15.0 ;
#declare df3_Scarab_ =
material{
       color rgbft <1.000,0.000,0.000,0.000,1.000>
   interior{
     ior                 1.000
     caustics            0.000
     dispersion          1.000
     dispersion_samples  7.000
     fade_power          0.000
     fade_distance       0.000
     fade_color          rgb <0.000,0.000,0.000>
     media {
       method     3
       intervals  20
       samples    3, 6
       confidence 0.900
       variance   0.008
       absorption rgb <0.000,0.000,0.000>
       emission   rgb <1.000,0.000,0.000>  * Emission_Factor_R
       aa_threshold 0.100
       aa_level    4
       density {
         density_file df3 "F:\Graphics\B3D
Data\Scenes\Dahlgren\Eastern\B\Shenlong_01A_R_.df3"
         interpolate 2
     media {
       method     3
       intervals  20
       samples    3, 6
       confidence 0.900
       variance   0.008
       ratio      0.900
          emission   rgb <0.000,1.000,0.000> * Emission_Factor_G
       aa_threshold 0.100
       aa_level    4
       density {
Data\Scenes\Dahlgren\Eastern\B\Shenlong_01A_G_.df3"
         interpolate 2
     media {
       method     3
       intervals  20
       samples    3, 6
       confidence 0.900
       variance   0.008
       ratio      0.900
       emission   rgb <0.000,0.000,1.000> * Emission_Factor_B
       aa_threshold 0.100
       aa_level    4
       density {
Data\Scenes\Dahlgren\Eastern\B\Shenlong_01A_B_.df3"
         interpolate 2
   translate <-0.500,-0.500,-0.500>
//------- Box0 Raw Script End ---------
Regards
Date: 7 Aug 2016 11:39:26
Message: <57a7562e$1@news.povray.org>
>> better.
Ah! I did not notice that until about an hour ago.
I think that it was caused by the left arm having the Inverse Kinematics
flag set in Poser when I applied the standard pose. It can cause
discontinuities. I will correct it when I next go into Poser to do a
final export.
And if I remember I will remove that setting from the defaults. <Grrr>
Regards
Date: 7 Aug 2016 11:50:01
Message: <web.57a757f4e7e0b8f7b549e89b0@news.povray.org>
A woman. I made an woman, too.
Download '00.png' (1082 KB)
Preview of image '00.png'
Date: 7 Aug 2016 12:12:15
Message: <57a75ddf$1@news.povray.org>
I used Sculptris a few years ago. And I think there has been a lot work
put into you model.
Nice one. :)
Regards
Date: 7 Aug 2016 14:47:38
Message: <57a7824a$1@news.povray.org>
>>> //start code
> influenced...
If you scale the container with the media, then, that scaling will
affect any media contained. Emissive media will become brighter,
absorbing media may become totally opaque.
If you want the media effect to remain unchanged, then you always need
to adjust the density of the media by the inverse of the scaling. Scale
up by 10, reduce the density or base colour by 10.
Date: 7 Aug 2016 14:51:51
Message: <57a78347$1@news.povray.org>
> "Media."   Harrrumph!
Use a single container, a box in your case, and give it 3 medias.
Using 3 boxes is bound to give you severe coincident surfaces artefacts:
For each individual pixels, there is no way to know which box will be
used and you get a noisy mess.
Date: 7 Aug 2016 15:05:00
Message: <web.57a78531e7e0b8f75e7df57c0@news.povray.org>
Changed my code - that seems to work for me now.
Seems messy and time consuming.
"Frame"?  Is that one of the "slices" to make the DF3?
That seems insane.
There has to be a better way / workflow.
I had an idea last night -
I did a quick experiment with the Stanford Dragon mesh:
defined the object
used #declare Variable = VRand_In_Obj(object {StanfordDragon}, Stream);
to get the coordinates of 10,000 spheres, and placed them, made a copy of that
and overlaid it with a "skin", plus rendered a jade textured mesh beside it - in
51 seconds.
I'm thinking that it may be well worth your while to either ditch media and use
an alternate scheme, or use POV-Ray to scan through a full-color solid object
and make a point-cloud right in SDL
http://paulbourke.net/miscellaneous/povexamples/
I think there must be a way to export the full RGB data in a single DF3, and
then maybe overlay the real mesh with a highly-transparent texture.
Can you make the mesh object filled with a media directly?
I don't play with these things very often, so I'm just brainstorming.
Download 'fillobjecttest.png' (158 KB)
Preview of image 'fillobjecttest.png'
Date: 7 Aug 2016 15:11:57
Message: <57a787fd$1@news.povray.org>
> E.g.
> material{
>   texture {
>     pigment {
>   interior{
>     ior                 1.000
>     caustics            0.000
>     dispersion          1.000
>     fade_power          0.000
>     fade_distance       0.000
You shopuld remove the 7 lines above. They are useless and may introduce
some problems.
>     media {
>       method     3
>       intervals  20
Using intervals larger than 1 HUGELY increase the rendering time and can
cause artefacts.
NEVER use anything else that intervals 1 with method 3.
>       samples    3//, 6
Instead of increasing intervals, increase samples. samples 100 is *much*
faster that intervals 20 samples 3 (for 60 total samples) for a finer
result.
The ", 6 " is totally useless and silently ignored.
>       confidence 0.900
>       variance   0.008
confidence and variance are used ONLY with method 1 and 2. With method
3, they are meaningless and better left out.
>       aa_threshold 0.100 // default value
>       aa_level    4 //default value = not needed
>       density {
>         interpolate 2
>     media {
>       method     3
>      // intervals  20
>       samples    80
>      // confidence 0.900
>     //  variance   0.008
>      // ratio      0.900
ratio is also useless, and ignored, with method 3.
>       aa_threshold 0.100
>       aa_level    4
>       density {
>         interpolate 2
>     media {
>       method     3
>       samples    80
>       aa_threshold 0.100
>       aa_level    4
>       density {
>         interpolate 2
In method 1 and 2, confidence, variance and ratio are used to control
how many samples are to be used in the different intervals depending on
the density and illumination in the various intervals. With method 3,
using more that a single interval is highly counterproductive.
I've done my tests with intervals and the negative impact they have on
the performance is astounding.
I demonstrated that samples 100 is way faster than intervals 10 samples
1 for greatly better results.
Date: 7 Aug 2016 15:16:28
Message: <57a7890c@news.povray.org>
> That seems insane.
> defined the object
> 51 seconds.
Sory, it's just not possible. DF3 support 1, 2 or 3 bytes per voxel, but
always in a single channel gray levels.
Date: 7 Aug 2016 15:31:16
Message: <57a78c84$1@news.povray.org>
Thanks Alain, I knew I would get it in the neck for posting that code. :)
Except for the intervals/samples thing. The other things you mention are
Bishop3D defaults and there is not a lot that I can do about what is
exported except go through the code afterwards. But I have a relatively
fast machine, so I don't.
I seem to have a blind spot for samples vs intervals. Thomas, amongst
others, is forever mentioning it.
I use media so seldom that I have to relearn it whenever I want to use
it. :(
So it is not ignorance but stupidity on my part. :(
Regards
Date: 7 Aug 2016 16:21:47
Message: <57a7985b$1@news.povray.org>
Good, good.
True but needs must. :) And I need a visual representation of the scene
I am making.
Yes, I use frame_number instead of clock for animations.
> That seems insane.
You are telling me. It is so easy to make a mistake or forget a step.
Very tiresome indeed.
I had forgotten about the Stanford Dragon. It is quite upright at the
front and might be a good object to use. The Stanford Bunny might be a
good model to use as well. If you can imagine a drug smoking violent
Street Gang disguised as bunny.
> defined the object
> 51 seconds.
You are confusing me. You are confusing me with someone who can code. ;)
Basic and PLC (programmable logic controller) are my limits.
I'll have a look at that. Paul is always worth listening to.
Yes you can but in the process of creating a media. PovRay converts the
colour vector into a scalar. That is why I have used different
multipliers in the different colour channels.
> and then maybe overlay the real mesh with a highly-transparent texture.
That is too simple. There must be a catch. :)
If I make sure that the mesh is closed. I don't want my dragon leaking :)
It would negate the problem of a media container inside another media
container being visible.
Keep at it. It is only too easy to pick one direction and stick to it.
Almost all comments are welcome.
Regards
Date: 7 Aug 2016 16:26:25
Message: <57a79971$1@news.povray.org>
>> DF3, and
That is why I filtered the R, G & B values then copied the single colour
to the other colours in an editor. It did not work as well as I hopped.
But some of the detail is there.
Regards
Date: 7 Aug 2016 17:01:19
Message: <57a7a19f$1@news.povray.org>
Just had another thought about that idea.
Poser meshes are not like scanned meshes. They can have internal
structures. For instance eyes are closed meshes part of which is within
the whole body. In the animation below the eyes of the spirit Ariel's
eyes glow. An artefact that did not distract, for once. :)
http://www.tc-rtc.co.uk/image/upload//Stephen/pw-1228515119-Prologue.mpg
Regards
Date: 7 Aug 2016 18:25:41
Message: <57a7b565@news.povray.org>
> it. :(
Here are the default vbalues :
method 3
samples 10
intervals 1 // Don't increase !
The default code from Bishop mostly repeat the actual defaults values.
That effectively make then into "no operation" code.
Even on the fastest machine, using intervals >1 is a serious performance
killer.
Date: 7 Aug 2016 18:55:00
Message: <web.57a7bb41e7e0b8f75e7df57c0@news.povray.org>
So, that's a macro where you give it the object, and a random stream, and it
samples the bounding box until it finds a point that's actually IN the object
itself.  So I just did that with a loop 10,00 times.
And I figured media could be faked with tiny spheres - a real point cloud, but
in the shape of the object
I then took the mesh, and textured it with a see-through texture.
I figured if it was just barely visible, it would have a printed-lampshade
effect with the emissive stuff inside - all the color and detail would be on the
outside "skin", and no color separation would be necessary
Just the regular old POV-ray textured mesh object, for comparison
Teamwork.  ;)
I'm struggling with the crazy camera frustrum thing he has on that page.
Seems like it could rewritten for clarity and completeness.
I will have to think on that.
Yeah - I suck at using filter and transmit, and the result might not be as great
looking as a media.
Try that.
Put a white emissive media in the mesh container, and texture the mesh with a
very highly transparent texture of the original rgb colors
Date: 8 Aug 2016 02:46:32
Message: <57a82ac8$1@news.povray.org>
Ah! Thanks for the reminder. I mostly use scattering media that is why.
Date: 8 Aug 2016 02:51:02
Message: <57a82bd6$1@news.povray.org>
I was away for part of the day, and now I am lost :-)
I have not followed the media discussion in detail and will pick up from
here.
Date: 8 Aug 2016 07:15:00
Message: <web.57a8695be7e0b8f75e7df57c0@news.povray.org>
Given what Stephen resorts to doing, I thought that might be the case.
BUT - I also thought that perhaps if there were a way to recolor the DF3 befor
saving, then the realistic RBG values could be _encoded_ into that false color
in such a way that they could be extracted back out of the gray value.
I need to get going, so I'll just give a quick non-binary example.
Lets say you had a single "gray value that could range from 0-999.
I was thinking that perhaps R could be factors of 100, G of 10, and B of 1.
3x8=24, 0 to 23, pow(2, 23) =
8388608
Simplistic, and it all depends on how the gray value gets calculated so that
things don't get irreversibly "mixed" - but I'll bet the 8-bit guys would puzzle
out a clever cryptographic scheme to encode all of Tetris into that little bit
of storage space  ;)
If it's possible, the range of RGB of course will not be as smooth as the
original, but I believe the trade-off in saving Stephen many painful hours of
scene development would be well worth it.
DISCLAIMER:
This is all just a pipe-dream that I'm having on a Monday morning, before
coffee, without inside knowledge of how Moray or Bishop handle data, or how
DF3's get encoded.
Date: 8 Aug 2016 08:11:50
Message: <57a87706$1@news.povray.org>
> Given what Stephen resorts to doing...
It is a bit tedious that's true.
It is also very easy to miss out a step.
We really need a simpler method of creating df3s. IIRC there is a
Proximity Pattern that creates and uses df3s called df3prox-0.95 that
might be worth looking at.
> DISCLAIMER:
> DF3's get encoded.
What's with the before coffee, thing?
Mad I call you. Mad. :)
By the time you get back from work I should have posted some examples of
a media filled mesh. I can get it to work after a fashion.
If you are interested I will upload the obj, mtl and image files so you
can play with them.
Regards
Date: 8 Aug 2016 10:15:01
Message: <web.57a8934be7e0b8f7b488d9aa0@news.povray.org>
Yes.  I am (usually) a big fan of checklists.
I missed the whole proximity pattern phase of interest and development.
No real idea of what they are, what they do, or how they work.
> can play with them.
Most excellent.
obj is ... Bishop?  Poseray?  both?
is mtl a Moray file?
Date: 8 Aug 2016 10:28:55
Message: <57a89727$1@news.povray.org>
Am 08.08.2016 um 16:12 schrieb Bald Eagle:
>> can play with them.
> Most excellent.
The `obj` file format is a standardized file format for exchanging mesh
data between different applications.
The `mtl` file format is a standardized companion file format to carry
material information (the `obj` format can only carry material names).
In the POV-Ray ecosystem, Poseray is probably the best way to convert
these files into POV-Ray format.
Date: 8 Aug 2016 10:36:27
Message: <57a898eb@news.povray.org>
Unless something is going to go bang. I am not, I am afraid.
The idea is to add dirt/staining to edges, junctions of surfaces etc.
You might be interested in this thread.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.4aa83e6a37d8ab92c83e2c410%40news.povray.org%3E/?mtop=323317
>> can play with them.
> Most excellent.
I've zipped the dragon and the Lady. Both files are about 5.5 Meg
I'll find a site that I can upload them to and post the link.
Otherwise I can use a site that will post the via email.
I managed to upload the dragon file to povray.binaries.misc
But the other is too large. (5.5 vs 5.7 meg)
*.obj is the geometry file, *.mtl is the textures referenced by the obj
file. Both are text and human readable.
Use PoseRay to convert them to a Pov.inc file.
I had to reduce the resolution of the images or the file size would have
been > 22 meg.
Regards
Date: 8 Aug 2016 12:15:00
Message: <web.57a8afdce7e0b8f7b488d9aa0@news.povray.org>
For a while, I was using some organoboranes, organoaluminum, and organozinc
reagents that were air-sensitive and spontaneously pyrophoric.
So there was great potential for "pop"  "Whooooooosssssh"   "BANG"
Others were .... less safety conscious - and it showed.
17
Oooh, yes.   That must be the "Edouard Poor" I have heard so much about in
related threads.   I'll definitely have to check those macros out.  They could
add as much or more as radiosity does to a scene.   :)
Got it.  It's been a while.
Date: 8 Aug 2016 12:34:58
Message: <57a8b4b2$1@news.povray.org>
Rather you than me. ;)
I worked on offshore drilling rigs as an electronic engineer for several
years.
Q. How do you tell if it is a driller ordering a round of drinks?
A. He will show the barman all his fingers and say three pints of beer.
(Really hard to tell a visual joke on paper.) :)
> 17
Thomas has used it to good effect. I have used it.
And there are so many TLA (three-letter acronyms) :)
Regards
Date: 8 Aug 2016 13:13:39
Message: <57a8bdc3@news.povray.org>
How can you recolor before saving when the format only support discrete,
single component, scalar values? That's just not possible.
Remember that DF3s have no concept of colour at all. It's strictly a
list of 1 dimension values.
Date: 8 Aug 2016 20:10:00
Message: <web.57a91f19e7e0b8f75e7df57c0@news.povray.org>
Let me give a different example -
If there is a grayscale value, then that must have some range or depth - how
many values?
If it's like a pattern{}, then you can give it a color_map{}.
My idea here, is instead of having the grayscale represent a range of gray from
0 to Max with 1-unit intervals, have it represent an RGB scale from 0 to Max
_STEP 3_.  It's a lot rougher, but it encodes full color.
Let's say you've got the usual 0-255 values.
That's 8 bits.
pow(2, 8) = 256
let's use 6 of those bytes, 2 for each color channel
granted, that only gives you 4 levels for each channel, but it's rgb - the data
is there.
The trick is getting more than those 4 levels for each channel squeezed into
those 8 bytes.
But I still think it's a better, faster workflow than what Stephen's currently
doing.
I'm sure some very clever folks have ways that can use 8 bits much more
efficiently to store more data.
There certainly seem to be computer-sciency types who have some ideas:
http://stackoverflow.com/questions/3499444/compress-two-or-more-numbers-into-one-byte
http://mathoverflow.net/questions/69244/encoding-n-natural-numbers-into-one-and-back
https://en.wikipedia.org/wiki/Z-order_curve
https://www.google.com/#q=how+to+encode+data+into+one+number
Date: 8 Aug 2016 21:35:00
Message: <web.57a932bae7e0b8f75e7df57c0@news.povray.org>
It also occurred to me that one probably doesn't even need to cover the whole
range of RGB values - only the range that's being used, or is significant.
If only certain rgb values are being used, then that a smaller range, and those
few subdivisions represented by the bytes the you have to work with now
represent a much finer scale.
It occurs to me on writing this, that it may be more effective to just ditch RGB
altogether and "encode" the colors in HSV.  Throw out S and V, and just assume
they're both 1, and that leaves you with 360 values.
That gives you a "fineness" of 1.41, which I'm sure is perfectly adequate for
the purpose at hand.
We have some very good people who write POV-Ray source code, and so it would be
a wonderful thing to be ahead of everyone else and have a rapid way of rendering
"full-color" df3 voxels.
The only trick then is to figure out how to get the generating software to write
a scaled hue value rather than a greyscale value.
Sound plausible?
Date: 8 Aug 2016 22:05:00
Message: <web.57a939d9e7e0b8f75e7df57c0@news.povray.org>
And then there's THIS:
http://news.povray.org/povray.binaries.utilities/thread/%3C4a2870e2%40news.povray.org%3E/?ttop=398992
Date: 9 Aug 2016 02:42:45
Message: <57a97b65$1@news.povray.org>
There are a couple of methods around the place, Sam Benge, Edouard Poor
for the most notable. Personally, I much prefer Edouard's method and
have used it extensively. I developed a HowTo from it and maybe I can
make you happy with that some day?  :-)
Date: 9 Aug 2016 03:17:08
Message: <57a98374@news.povray.org>
On 8/9/2016 7:42 AM, Thomas de Groot wrote:
> maybe I can make you happy with that some day? :-)
It would save me some time relearning it. :)
Regards
Date: 9 Aug 2016 07:32:41
Message: <57a9bf59@news.povray.org>
I am going to verify if everything is straightforward and then post the
needed files...
[looks for a round tuit under desk...]
Date: 10 Aug 2016 04:01:28
Message: <57aadf58$1@news.povray.org>
> method 3
> samples 10
> killer.
Thanks Alain,
B3D sets the default value for intervals to 10. We must have missed that
during testing.
I have created a default texture in the new scene template which I will
copy instead of creating from the menu.
(Thinking back. This must be the source of many of my problems in the past.)
Regards
Date: 10 Aug 2016 18:55:59
Message: <57abb0ff$1@news.povray.org>
>> method 3
>> samples 10
>> killer.
> Thanks Alain,
> during testing.
> past.)
IIRC, intervals 10 is the default for method 1 and 2. Also, method 1 was
the default before version 3.5.
It's common for pre version 3.5 scenes and include to set intervals to
larger values than that. It's also common for external utilities made
during that time to have similar settings.
