POV-Ray : Newsgroups : povray.binaries.images : Dragon Lady Server Time
31 Jan 2025 16:50:29 EST (-0500)
  Dragon Lady (Message 1 to 10 of 65)
Subject: Dragon Lady
Date: 6 Aug 2016 13:44:01
Message: <57a621e1@news.povray.org>
I don't know if the book mentions her complexion but emission looks better.
I'm going to redo this from the start using what I've learned.
At the moment getting the positions right is next to impossible. So I
will re-export from Poser and rework it in PoseRay.
Regards
Download 'eastern01a5a_.jpg' (176 KB) Download 'eastern01a5a_f_0000.jpg' (119 KB) Download 'eastern01a5a_s_0000.jpg' (150 KB)
Preview of image 'eastern01a5a_.jpg'
Preview of image 'eastern01a5a_f_0000.jpg'
Preview of image 'eastern01a5a_s_0000.jpg'
Subject: Re: Dragon Lady
Date: 6 Aug 2016 15:45:00
Message: <web.57a63d27e7e0b8f75e7df57c0@news.povray.org>
This looks like a very cool project, and I like the results so far.
Perhaps the dragon may look / show up better if the emission tapered off in a
gradient as it moved away from the camera.   Think of it as a slightly darker
background media for a slightly brighter foreground media.
I think you could just define a z-gradient and rotate it based on the camera
location relative to the origin. If you need that equation, I can dig it up from
one of my scenes.
Date: 6 Aug 2016 16:25:00
Message: <web.57a64799e7e0b8f77a3e03fe0@news.povray.org>
> Regards
>      Stephen
How to make a hologram? All write about proprietary programs.
How do poor people do this? I live in Russia, I have no money.
Date: 6 Aug 2016 17:00:01
Message: <web.57a64fcbe7e0b8f75e7df57c0@news.povray.org>
There's a great channel on YouTube called "Applied Science"
This guy actually builds a working CT scanner in his garage...
I searched for
applied science hologram
I didn't see a video by him, but maybe some of the search results will have
something you can use - especially the cell phone holograms...
Date: 6 Aug 2016 18:28:39
Message: <57a66497$1@news.povray.org>
Thanks, that's good to know. The more I work on it. The more I see what
is wrong with it.
> one of my scenes.
I see what you mean. It is a good suggestion. Although I think that is a
refinement that must come at a later stage.
Thomas and I have a few integration points to discuss. For instance If
we are both using media then we have to use a common scale in Pov units.
And it is often hard to to make one media container inside a larger
media container not obvious. Then there is the problem that I am using a
PovRay modeller that only supports 3.6 syntax. Although I can use 3.7
syntax with a workaround. It will not make reading the SDL easy.
Thomas and I have both used Moray which uses a different coordinate
system to PovRay. It used Z axis is up. Whereas, as you know PovRay is Y
axis is up. We have to see how the scenes fit together first.
(I am just jotting down a few points that come to mind)
Regards
Date: 6 Aug 2016 19:09:19
Message: <57a66e1f$1@news.povray.org>
>> Regards
>>       Stephen
Hi LanuHum, thanks for the interest.
What I am trying to do is to use emissive media using a density file.
I have created a density file for each R, G, B channel by running an
animation in PovRay. That (as Mr Eagle hints is similar in technique to
a CT scan) takes a series of slices of a model (in this case a Poser mesh).
These images in (TGA format) are stitched together using a DOS utility
called tga2df3.exe to create a df3 file.
One additional step is to take each tga file and copy the values of the
used colour to the two other colour channels. (Making something similar
to a greyscale image.) Before running tga2df3.exe. {I forgot to do that
step in this image and will post an updated image tomorrow.}
That is the high level description. :)
Let me know if you get the drift (understand). If not I am happy to try
to explain further.
Regards
Date: 7 Aug 2016 03:10:57
Message: <57a6df01$1@news.povray.org>
She is a black lady indeed :-)
I think this is a fair interpretation of the dragon considering the
problems generated otherwise. Delany clearly wrote the book with an
image in his head, not considering the future problems of modellers ;-)
Date: 7 Aug 2016 03:30:21
Message: <57a6e38d$1@news.povray.org>
> is wrong with it.
Ha! How true. It's a curse ;-)
>> off in a
>> darker
>> camera
>> it up from
>> one of my scenes.
We have indeed some issues to discuss not in the least the media scale
used. Also, we may need indeed to test how the nested containers are
going to show up.
I posted an image of Bellona with the bridge and river in place. No
nested containers there as I restricted the atmosphere to just above the
water surface (the water is a media) and just below the clouds container.
The foreground is where I imagine the Scorpions to be and we need to
consider their scale with regards to the environment.
Much to do but exciting!
This may perhaps help already: the media used for the atmosphere:
//start code
#declare AtmosScale = <10, 10, 10>;
#declare Atmosphere =
union {
   //clouds:
   //clouds media here.
   //atmospheric haze:
   difference {
     sphere {0, 490}
     plane {y, -0.749}
     hollow
     material {
       texture {pigment {color rgbt 1}}
       interior {
         media {
           intervals 1
           samples 50
           scattering {5, rgb <1,1,1>*0.03/AtmosScale
             eccentricity 0.4
           density {
             spherical
             colour_map {
               [0 rgb 0]
               [1 rgb 1]
   scale AtmosScale
   rotate 50*z
   scale <5, 1.0, 5>
   rotate 45*y
//end code
Date: 7 Aug 2016 03:52:57
Message: <57a6e8d9@news.povray.org>
>> better.
Good and as long as we don't have a model called Peter we should stay
out of trouble. ;)
This is always a problem, visualising is so much easier as you can
ignore any inconveniences.
I have redone my export from Poser and Rig for creating df3's.
While That is going on, here are a couple of images with the corrected
density files. There is more detail I think
Regards
Download 'eastern01a5d_fr_0000.png' (253 KB) Download 'eastern01a5c_s_0000.png' (320 KB)
Preview of image 'eastern01a5d_fr_0000.png'
Preview of image 'eastern01a5c_s_0000.png'
Date: 7 Aug 2016 05:30:48
Message: <57a6ffc8$1@news.povray.org>
> //start code
What are the dimensions of you atmosphere media container?
Regards
