Since my last image on metal monsters, I have been experimenting with
sunsets in which the background sky remains blue. It is something I
often see from my RL window at a particular hour of the evening. I have
put the background sky into a separate light_group illuminated by a noon
sun, all the rest is illuminated by a sunset sun (both from CIE.inc btw).
The clouds are a scattering light grey media within a hollow spherical
shell of a certain thickness.
This view is attractive I believe and a reminder of more southern climes.
Download 'sundown_test.png' (350 KB)
Preview of image 'sundown_test.png'
> Thomas
That's a great looking cloud formation you have there. I very much like the way
you have the varying colors in different portions of the cloud mass, and the way
the light strikes them from that "underneath" angle.
I think you've grasped the essentials of the lighting and the colors, and the
manner that your lighting evokes that - late afternoon illumination of something
near by something so very big but so very far away. If this is a new avenue of
expression, I very much look forward to seeing LOTS more of it :)
Very nice work, Thomas.
Thank you very much indeed. This was the first image I was really
satisfied with after a long series of test that were interesting at
best. It is a very delicate matter with a large number delicate
parameters all influencing each other. For now I am mainly playing with
density variations which - it must be said - do not create really
/realistic/ cloud patterns, but the idea is perfectly applicable of
course on Gilles Tran's MakeCloud objects. However, I am not really
after true realism in general so I am just searching for that one
pattern that attracts me.
This particular pattern is based on a bozo density pattern. Samples are
low in this example but in most cases using other patterns need to be
increased to possibly 100.
Quick-and-dirty:
//---------------start code
#declare AtmosScale = <10, 10, 10>;
#declare Density_in =
density {
//spiral1 4
//marble
//granite
bozo
//spherical
frequency 6
color_map {
[0.30 rgb <0.00, 0.00, 0.00>]
[0.48 rgb 0.9]
[0.52 rgb 0.9]
[0.70 rgb <0.00, 0.00, 0.00>]
scale 5
//rotate 90*x //when using spirals; either here or:
scale 50
warp {turbulence <2, 4, 2>*1}
scale 1/50
//rotate 90*x //when using spirals; here
#declare Density_out =
density {
//spherical
//color_map {
/*[1.0*/ rgb <0.00, 0.00, 0.00>//]
#declare Atmosphere =
difference {
sphere {0, 1000}
sphere {0, 600}
hollow
material {
texture {pigment {color rgbt 1} finish {ambient 0 diffuse 0}}
interior {
media {
// (---general values---)
intervals 1
samples 5
scattering {1, rgb <1,1,1>*0.05/AtmosScale}
// (---method---)
//method 3 // adaptive sampling
//aa_threshold 0.1 // accuracy threshold for method 3 [0.1]
//aa_level 4 // maximum recursion depth for method 3 [4]
//jitter 0.5 // randomness for method 2&3
// (---density---)
density {
spherical
density_map {
[0.1 Density_out]
[0.9 Density_in]
warp {turbulence 0.3}
scale 900
scale AtmosScale
scale <5, 1.0, 5>
rotate 45*y
//---------------end code
Just substituting granite to bozo. Increasing samples will smooth out
the ragged edges.
Download 'sundown_test.png' (567 KB)
A nice one with wrinkles pattern.
Download 'sundown_test_04-wrinkles.png' (446 KB)
Preview of image 'sundown_test_04-wrinkles.png'
This one is for Stephen.
"to wound the autumnal city."
Cityscape macros by Mike Williams.
Download 'dhalgren_01.png' (429 KB)
Preview of image 'dhalgren_01.png'
So howled out for the world to give him a name.
Atmospheric. I like it. Thank you.
(Maybe a bloodier sky with a bloated sun?)
Regards
I intend to work some more on this piece.
Good.
It made me think of doing an image of the kid as a scorpion.
A couple of years ago I made a start on the dress Lanya wore to the big
party.
[Un-sensuous nudity warning]
https://www.youtube.com/watch?v=jvZfbKGbUDs
Regards
> Good.
That would be interesting to do. I have pondered the complex chain
pattern worn by him but that seems far too complicated to model
dynamically in Poser and iirc he wore it under his clothes anyway.
Incidentally, I saw on the web somebody who tattooed the pattern on her
body (why not indeed?). Still, the kid is also on my (long) wish list.
Lets see where that brings us. We always can combine elements into a
grand Delany scene. :-)
> party.
Ah yes, I remember that one. I suppose the dress needed a couple more
subdivisions to move correctly ;-)
>> Good.
Yes, the kid is more your kind of image than mine.
I am more interested in the Projector and trying to get a person inside
an illuminated Scorpion. That will probably something that is better in
the mind than in the flesh.
I've found a free scorpion mesh but it is not articulated. I should be
able to pose it in Blender.
Let's do that. I can't promise I'll get an effect that will be acceptable.
The optical chains remind me of the hippy beads I wore in the early
seventies. The beads were strung together in a chain with brass wire and
itched like hell. :)
All you would need is a loop showing at a cuff or a chest. But I am
getting ahead of myself. :)
>> party.
It was only a proof of concept. It would need a bit more work it it were
to be useful.
It was the first time I had used Poser's Walk Designer as well. And it
shows.
I must say that book made an impression on me. I read it in the late
70's and I remember a lot.
Regards
>>> Good.
It is a thought. I need to read the book again to get the mood again; it
has been a while since last time.
That should be possible indeed.
It must be something like that indeed.
Yes. That would be enough and not too difficult. The kid himself should
be rather straightforward as Poser modelling goes.
>>> party.
> to be useful.
> shows.
Oh yes indeed; disturbing and fascinating at the same time. It has not
lost its attraction either. It was a new way of writing SF at the time
although I don't think it was really part of the 'New Wave' as promoted
by Harlan Ellison at the time, although certainly close in concept.
My paperback is in storage. I have a epub version but it is not the same
as a hardcopy. Especially when the writing gets disjointed and tells
bits of its own story.
We will see...
Thinking about it. Unless you are doing a closeup they won't be visible.
Hang! the chains. ;)
I think that there was new wave and New Wave. One was used to sell books.
Cynical. Moi? :)
Regards
Yes, there is that. I cannot concentrate on digital. I need the touch,
smell and history of the hardcopy. And I need books around me in the house.
> We will see...
Indeed. No matter; the orchid will make a nice addition though.
> Cynical. Moi? :)
Oh, you are absolutely right to be cynical! The percentage of trash did
not change at all before or after ;-)
On the other hand. These old tomes are heavy and bulky. But for some
books you need the smell of foxing. :)
>> We will see...
I don't think the scorpion will work. It would either look stupid
standing on its hind legs or be six feet high and twenty feet long.
I have a dragon with gossamer wings. That should be a challenge.
That is one of the most stupid weapons imagined. Zelazny would have done
better.
>> Cynical. Moi? :)
No but it did raise the standard overall. It seems to have dropped back
a bit now. </ Good old days rant>
Regards
>>>> again; it
>> house.
Who cares, I like the struggling with those old volumes fighting back by
breaking at the spine, refusing to open correctly, showing printing
errors... and I do /not/ mistreat them at all. ;-) Fortunately, my wife
has some book binding skills so the damage can be repaired when necessary.
>>> We will see...
Dragon Lady then. I wonder how the scorpion in the book would show.
> better.
Ha! Yes indeed! It is the most awkward thing imaginable and pretty
useless if you ask me except for keeping in the way when not called for.
>>> books.
>>> Cynical. Moi? :)
That is true. I am a bit out of touch with the post-2000 vintage though.
Fortune, indeed.
I, on the other hand, have gone to the dark side. :)
Now I will need to read the book. :)
I am trying to df3-ise a dragon model but I am running into problems
with the textures in the model. If any of my experiments look
interesting I will post the results.
>> better.
You would need reinforced pockets that's for sure.
Me too.
Regards
>> necessary.
> Fortune, indeed.
tsk tsk...
OK. I am working now on the river and bridge of Bellona. I am going to
diverge from the book description somewhat but it is the mood that is
important. I also would like to include the tree/woman from the ritual
initiation scene (that is how I interpret it somehow).
>>> better.
Not by chance that the kid keeps it dangling from his belt ;-) (pretty
dangerous too)
> Me too.
