POV-Ray : Newsgroups : povray.binaries.images : several view in one image Server Time
10 Oct 2026 14:54:15 EDT (-0400)
  several view in one image (Message 1 to 12 of 12)
Subject: several view in one image
Date: 6 Jul 2016 12:58:18
Message: <577d38aa@news.povray.org>
wasting some round tuits, as some seems to have a good supply of them,
I added in hgpovray a new camera type: grid.
#declare Camera_0 = camera {  /*ultra_wide_angle*/ angle 10      // front view
                            location  <0.0 , 2.0 ,-40.0>
                            look_at   <0.0 , 2.0 , 0.0>}
#declare Camera_1 = camera {/*ultra_wide_angle*/ angle 10   // diagonal view
                            location  <20.0 , 20.0 ,-20.0>
                            look_at   <1.0 , 2.0 , 0.0>}
#declare Camera_2 = camera {  /*ultra_wide_angle*/ angle 10  //right side view
                            location  <40.0 , 2.0 , 0.0>
#declare Camera_3 = camera {  /*ultra_wide_angle*/ angle 10        // top view
                            location  <0.0 , 40.0 ,0.0>
                            look_at   <0.0 , 1.0 , 0.0>}
camera{ grid 2 Camera_2 Camera_0 Camera_1 Camera_3}
Followed by the number of camera per side, and then that squared number of camera
identifiers, to make a grid of the various view directly for the rendered image.
Download 'grid.png' (212 KB)
Preview of image 'grid.png'
Subject: Re: several view in one image
Date: 6 Jul 2016 16:42:46
Message: <577d6d46$1@news.povray.org>
Am 2016-07-06 12:58, also sprach Le_Forgeron:
Wow. Pretty slick.
Didn't warp have something similar years ago? I recall an anim of
spaceship on a spline from 4 angles at once.
And because I'm a dork, I'll add
"yeah, but you should support video wipe" (position the dividers between
cameras). :)
dik
Date: 6 Jul 2016 20:30:06
Message: <web.577da1bbfe79c8895e7df57c0@news.povray.org>
That, sir, is wicked cool and very useful and convenient.
An excellent job!   :)
Date: 7 Jul 2016 01:58:30
Message: <577def86$1@news.povray.org>
> Wow. Pretty slick.
> Didn't warp have something similar years ago? I recall an anim of spaceship on a
Any link ?
> "yeah, but you should support video wipe" (position the dividers between cameras).
Give a man a fish, and he will ask for a comfortable table and seat, with a fresh
bottle of white wine and a dedicated team of waitresses, free of charge.
"You can position the dividers anywhere, as long as it's 1/n and you have n*n
cameras".
(in the mood of Ford :"you can have the car in any colour you want, as long as it is
black.")
More seriously, if you can come up with a simple and clear syntax to describes a
layout of rectangles that have the same ratio than the final picture, I might consider
another extension.
But beware, HTML tried that with table, and that turns in a nightmare and ambiguous
descriptions (some engines render differently some complex tables).
Date: 7 Jul 2016 05:19:13
Message: <577e1e91$1@news.povray.org>
>> >Wow. Pretty slick.
> Any link ?
IIRC It was using megapov and quite a while ago.
I cannot find a link.
Regards
Date: 7 Jul 2016 09:31:34
Message: <577e59b6$1@news.povray.org>
Am 06.07.2016 um 18:58 schrieb Le_Forgeron:
Why not provide two parameters, so that we can have arbitrary arrays of
NxM cameras?
That, btw, would obviously provide a reasonably simple way to generate
side-by-side stereographic images.
Date: 7 Jul 2016 10:05:15
Message: <577e619b$1@news.povray.org>
> NxM cameras?
Because I did not mess with image_height & image_width, which could be used in
(sub)camera computation.
And I already have side-by-side stereographic camera
http://wiki.povray.org/content/User:Le_Forgeron#Stereoscopic_camera
Date: 8 Jul 2016 07:42:05
Message: <577f918d$1@news.povray.org>
Am 07.07.2016 um 16:05 schrieb Le_Forgeron:
>> NxM cameras?
They could be used to compute the aspect ratio, but they also could be
used to compute other stuff, so they're "broken" anyway if interpreted
as a per-camera value.
Also, if you develop a scene using a grid camera, you presumably know
what grid size you're using, so you can apply correction factors to
account for the mismatch between camera aspect ratio and image aspect ratio.
Date: 9 Jul 2016 05:23:49
Message: <5780c2a5@news.povray.org>
>>> NxM cameras?
ok... Granted evolution. Just do not blame me when the aspect ratio are not correct.
Instead of 2 paramaters, the parameter is now a vector, interpreted as 2D-vector.
                            right     x*image_width/image_height*2/3
#declare Camera_1 = camera {/*ultra_wide_angle*/ angle 20   // diagonal view
                            right     2*x*image_width/image_height
                            sky +z
                            direction -y
                            up +z
#declare GridT = camera { grid 1 Camera_1 }
#declare GridB = camera { grid <3,1> Camera_2 Camera_3 Camera_0 }
camera{ grid <1,2> GridT GridB }
Download 'grid.png' (172 KB)
Date: 12 Jul 2016 18:02:58
Message: <57856912$1@news.povray.org>
MegaPOV actually had a camera_view pigment.
So you could use one rendered view and use it to texture e.g.
a picture frame. Or of course apply it to 2 x 2 boxes for a grid.
http://megapov.inetart.net/features.html
Date: 12 Jul 2016 18:04:09
Message: <57856959$1@news.povray.org>
Direct link:
http://megapov.inetart.net/manual-1.2.1/megapov0121.html#camera_view
Date: 13 Jul 2016 01:39:35
Message: <5785d417@news.povray.org>
> Direct link:
Thanks.
