POV-Ray : Newsgroups : povray.binaries.images : The lemon is ready Server Time
22 Nov 2026 11:01:04 EST (-0500)
  The lemon is ready (Message 1 to 34 of 34)
Subject: The lemon is ready
Date: 8 May 2016 15:33:26
Message: <572f9486@news.povray.org>
For the time being, only available in hgpovray.
lemon { P1, R1, P2, R2, R3 ... }
similar to cone { P1, R1, P2, R2 ...} but connected with a lemon (inner circle of a
torus) of radius R3.
Options includes : uv_mapping, open and sturm.
All Rx must be positive or null, and there is a complain with error when R3 is too
small.
The complain gives the minimal value that can be used.
And now that I can sleep a bit, I'm returning to the extension of the ovus.
Download 'lemon.png' (95 KB)
Preview of image 'lemon.png'
Subject: Re: The lemon is ready
Date: 8 May 2016 20:43:38
Message: <572fdd3a$1@news.povray.org>
Am 08.05.2016 um 21:33 schrieb Le_Forgeron:
Not happy at all with the term "lemon" here, because it only fits the
special case R1=R2=0 (which btw is already covered by the torus in 3.7.1)
The term "ogive" would at least be technically fitting for cases where
only one of R1 and R2 is zero; the term "barrel", too, would be fitting
for more cases than "lemon".
Also, I suspect that specifying R3 as the maximum radius may be more
useful for practical purposes -- and am wondering what the uv_mapping
rules might be (I think, ideally they should match those of the "cone"
primitive).
Date: 9 May 2016 01:48:49
Message: <573024c1$1@news.povray.org>
> primitive).
Ah, Ah... very funny. ROTFL and far more. Really the best joke ever.
Even the Green Golf Ball Joke is a bit short on the amount of humour on
that uv_mapping of "cone" primitive.
That wil make my day.
Date: 9 May 2016 02:15:01
Message: <web.57302a2b370a969c7a3e03fe0@news.povray.org>
small.
Hi!
Errors shan't be. The program shall set limit value automatically. But to
report: "WARNING!WARNING!Impossible parameters - are specified to a minimum!"
lemon { 0,0.1,2,2,1 pigment{rgb 1} rotate x*90}
==== [Parsing...] ==========================================================
File '/tmp/Empty.pov' line 15: Possible Parse Error: Inner (last) radius of
 lemon is too small. Minimal would be 2.31012
Fatal error in parser: Uncategorized error.
Render failed
 lemon is too small. Minimal would be 1.76952
Render failed
lemon { 0,0.1,5,0.5,1 pigment{rgb 1} rotate x*90}
 lemon is too small. Minimal would be 4.34513
Render failed
Date: 9 May 2016 11:34:33
Message: <5730ae09$1@news.povray.org>
Am 09.05.2016 um 07:48 schrieb Le_Forgeron:
>> primitive).
I concede I didn't have a closer look at the cone implementation; just
intended to make sure as early as possible in the design process that
the UV mapping isn't inconsistent with stuff we already have.
Obviously, yeah, since we don't seem to have UV mapping for the cone in
the first place, that turned out to be a moot point.
Please don't just grab something randomly out of a bag though. What I
see in your sample image looks like a ratio of 1:3:1 for the three
components of the object; since this is arbitrary anyway, I would
suggest a ratio of 1:2:1 instead. Not only does this slightly simplify
the maths the user will have to do, and also makes those operations
mathematically more stable (a floating-point division by any power of 2
is lossless; a divison by 5 never is) -- much more importantly, it is a
far better fit for standard image sizes commonly used for UV mapping
(which tend to be powers of 2; even where image sizes are multiples of
5, they'll typically also be multiples of 4.)
We should also consider whether we want the UV mapping of the main body
to just use a cylindrical mapping (as seems to be the case in your
sample image, though that might of course be an optical illusion), or
whether we want the mapping to be equidistant along what I presume to be
the V coordinate (essentially boiling down to a variation of toroidal
mapping).
Date: 9 May 2016 12:40:58
Message: <5730bd9a$1@news.povray.org>
>>> primitive).
I have no experience with image used for uv mapping, so I will trust you on that.
Initially (a code nobody have seen), I used a 10% for each end, but changed it
for a 20%, based on current VAT.
Updating for 25% is not a problem, it just seems a waste of pixels when
most of them get squeeze near the centre of the disc.
Let's listen to other's opinions first.
> mapping).
Yep, cylindrical mapping so far for the torus part. I'm just dreaming of the
rocket on the cover (and inside) the "Destination moon" of Tintin (by Hergé).
And it was the easiest to code.
If we want the toroidal mapping, the code would need to store the uv with the
intersection as I have a feeling that the computation could be painful to revert.
Yet, it would be a waste of cycles when uv is not used.
Date: 12 May 2016 12:18:26
Message: <5734acd2$1@news.povray.org>
small.
> Hi!
Please try the new version.
(Bad input get a PossibleError instead, and object is replaced )
I also changed the uv-mapping to 25%.
Date: 12 May 2016 14:10:01
Message: <web.5734c639370a969c7a3e03fe0@news.povray.org>
There are no errors. :)
But, in the Blender the lemon is unprofitable to be used.
Any this form is created by lathe.
But, I can construct Lathe in a 3D-view, but a lemon I can't.
Download 'lemon.jpg' (63 KB)
Preview of image 'lemon.jpg'
Date: 14 May 2016 13:06:57
Message: <57375b31@news.povray.org>
4 lemon, 3 discs, 3 spheres, a bit of cut and voilà.
Download 'fusee.png' (50 KB)
Preview of image 'fusee.png'
Date: 15 May 2016 02:49:55
Message: <57381c13$1@news.povray.org>
Merci Hergé :-)
Date: 17 May 2016 12:04:22
Message: <573b4106$1@news.povray.org>
Am 14.05.2016 um 19:06 schrieb Le_Forgeron:
I love it!
Date: 17 May 2016 12:06:03
Message: <573b416b$1@news.povray.org>
Am 12.05.2016 um 20:06 schrieb LanuHum:
You can't create this exact shape with lathe. All you can get is an
approximation.
Date: 18 May 2016 00:18:05
Message: <573becfd$1@news.povray.org>
Am 2016-05-08 20:43, also sprach clipka:
I don't like lemon either; it seems too specific (although I don't know
why).  I prefer barrel.  Just my humble opinion.
dik
Date: 18 May 2016 14:30:01
Message: <web.573cb381370a969c7a3e03fe0@news.povray.org>
I won't argue. Accuracy of computation of Bezier curves has enough for creation
of a body of the car.
But, as the exact form of a lemon allows to place on its surface objects for
csg.
Task:
To place five spheres so that centers of spheres lay on a lemon surface.
difference{
lemon{}
sphere{??}
sphere{??}
sphere{??}
sphere{??}
sphere{??}
Look attachment
Download 'lemon.jpg' (119 KB)
Date: 18 May 2016 19:45:47
Message: <573cfeab$1@news.povray.org>
Am 18.05.2016 um 20:25 schrieb LanuHum:
I doubt the designers of car bodies use Bezier splines -- their weapon
of choice are NURBS (non-uniform rational B-splines); AFAIK those do
have the capacity to precisely represent circular arcs.
Date: 19 May 2016 10:15:00
Message: <web.573dc93c370a969c7a3e03fe0@news.povray.org>
https://en.wikipedia.org/wiki/B%C3%A9zier_curve
> The mathematical basis for Bézier curves — the Bernstein polynomial — has been >
known since 1912, but its applicabil
ity to graphics was not realized for
> another half century. Bézier curves were widely publicized in 1962 by the
> French engineer Pierre Bézier, who used them to design automobile bodies at
> Renault. The study of these curves was however first developed in 1959 by
> mathematician Paul de Casteljau using de Casteljau's algorithm, a numerically
> stable method to evaluate Bézier curves at Citroën, another French automaker.
Date: 19 May 2016 11:04:06
Message: <573dd5e6$1@news.povray.org>
Am 19.05.2016 um 16:10 schrieb LanuHum:
[quote from Wikipedia, not clipka]
>> known since 1912, but its applicability to graphics was not realized for
Yes, the /invention/ of Bezier curves was driven by the French
automotive industry.
But as the article also notes, that was around _1960_.
Car body quality requirements have increased quite a lot since then.
Note how the "Applications" section in that article lists computer
graphics, animation and fonts, but /not/ [contemporary] automotive design.
Date: 19 May 2016 11:50:00
Message: <web.573ddf71370a969c7a3e03fe0@news.povray.org>
We distracted, but the task remained unresolved.
Task:
difference{
lemon{}
sphere{??}
sphere{??}
sphere{??}
sphere{??}
sphere{??}
http://news.povray.org/povray.binaries.images/attachment/%3Cweb.573cb381370a969c7a3e03fe0%40news.povray.org%3E/lemon.jp
g
WRITTEN_FOR="LANUHUM"
use_bezier_lathe = False
use_lemon = True
#macro Calculate_points_coords_lemon_surface(number_x,number_y,number_z)
//bla-bla-bla...
replace, please, //bla-bla-bla... with the working source code
If it isn't in documentation, then I don't know how to the rocket to attach
wings
Date: 19 May 2016 12:31:40
Message: <573dea6c$1@news.povray.org>
> Task:
> difference{
> lemon{}
> sphere{??}
> sphere{??}
> sphere{??}
> sphere{??}
> sphere{??}
> g
> use_lemon = True
> //bla-bla-bla...
> wings
The code below uses the new spindle torus & not the lemon, but is
something like this what you are after?
#declare Torus00=torus { 0.25, 0.5 intersection scale <1,2,1> }
#declare Norm=<0,0,0>;
difference {
     object { Torus00 }
     sphere { trace(Torus00, <1,0,0>,    <-1,0,0>, Norm) , 0.15 }
     sphere { trace(Torus00, <1,0.5,0>,  <-1,0,0>, Norm) , 0.15 }
     sphere { trace(Torus00, <1,-0.5,0>, <-1,0,0>, Norm) , 0.15 }
     pigment { color Niagara }
Bill P.
Date: 19 May 2016 12:33:26
Message: <573dead6$1@news.povray.org>
> Task:
> difference{
> lemon{}
> sphere{??}
> sphere{??}
> sphere{??}
> sphere{??}
> sphere{??}
For lemon { 0, 0, H*y, 0, R }
The 2D circle (of radius R) of the lemon is centred at <-V, H/2>, with
V^2 = R^2 - ((H^2)/4)
easily solved as V = sqrt( R^2 - ((H^2)/4) ).
Assuming you want the spheres in the z=0,x+ demi plane, you just have to satisfy for
< A, B, C> as the centre:
C = 0
R^2 = (B-(H/2))^2 + (A+V)^2
0 <= B <= H
As I'm tired of equations solving, I let it to wolframalpha solver :
A is sqrt(-2 B^2+2 B H-H^2+4 R^2+sqrt(H^2-4 R^2) sqrt(4 B^2-4 B H+H^2-4 R^2))/sqrt(2)
Have a nice sleep.
Date: 26 May 2016 07:31:16
Message: <5746de84$1@news.povray.org>
small.
In working with this new object I came across this case:
// P1, R1, P2, R2, R3
#declare LemonLeft  = lemon {
    <-1.2,-0.5,0>, 0.0, <-1.2,0.5,0>, 0.0, 0.499999
#declare LemonCenter = lemon {
    <0,-0.5,0>, 0.0, <0,0.5,0>, 0.0, 0.50
#declare LemonRight  = lemon {
    <1.2,-0.5,0>, 0.0, <1.2,0.5,0>, 0.0, 0.500001
Where the LemonLeft generates this warning message:
File 'lemon.pov' line 176: Possible Parse Error: Inner (last) radius of
lemon is too small. Minimal would be 0.5. Subtituing a sphere to lemon
recommending the code used in LemonCenter. However the result for
LemonCenter is quite noisy. An 'epsilon' above is OK.
See attached image.
Bill P.
Download 'lemonissue.jpg' (75 KB)
Preview of image 'lemonissue.jpg'
Date: 26 May 2016 07:50:44
Message: <5746e314$1@news.povray.org>
> See attached image.
> Bill P.
can you try to add "sturm" to LemonCenter ? (I'm away from my hgpovray)
     <0,-0.5,0>, 0.0, <0,0.5,0>, 0.0, 0.50 sturm
Date: 26 May 2016 09:24:35
Message: <5746f913@news.povray.org>
Using sturm as follows is less noisy, but still noisy :
    <1.2,-0.5,0>, 0.0, <1.2,0.5,0>, 0.0, 0.500001 sturm
On my first attempt I did the following:
    <-1.2,-0.5,0>, 0.0, <-1.2,0.5,0>, 0.0, 0.499999 sturm
which gave me this parse error :
File 'lemon.pov' line 175: Parse Error: Keyword 'sturm' cannot be used
with this object.
So, I assumed you'd not yet set sturm up for the lemon! Wondering now if
the code creating the inner radius warning for LemonLeft is itself
creating the error for sturm use in that case?
Bill P.
Date: 26 May 2016 10:15:18
Message: <574704f6$1@news.povray.org>
> with this object.
> Bill P.
On LemonLeft, parsing occurs up to the inner radius, then the message is
written and the object so far get replaced with a sphere.
Then parsing continue and find sturm, which is not supported by a sphere.
Notice that the same issue would occurs with current ovus (when the top
radius is more than twice the bottom radius).
For lemon, I could replace with another object which would support
sturm, but is it really needed ? or even wanted ?
(My first approach was to stop with an error instead of a warning, was
it better ?)
Date: 26 May 2016 12:12:39
Message: <57472077@news.povray.org>
> it better ?)
Suppose if someone is doing an animation or sequence of images, it might
be convenient to transition into a sphere then continue to shrink that
sphere.
If so, we are not really doing that today as we seem to be at a 0.5
radius and then jump to a radius of 0.499999/2 where we'd need to not
have a discontinuity in result for inner radius moving from 0.5 to
0.499999.
Changing from the current discontinuous behavior and moving to say a
polynomial (See attached image) :
// #declare LemonLeft  = lemon {
//    <-1.2,-0.5,0>, 0.0, <-1.2,0.5,0>, 0.0, 0.499999
    #declare LemonLeft  = polynomial { 2,
      xyz(2,0,0):1,
      xyz(0,2,0):1,
      xyz(0,0,2):1,
      xyz(1,0,0):-2*-1.2,
      xyz(0,0,0):pow(-1.2,2)-pow(0.49999,2)
      sturm
allows sturm - but then not open... I suspect if we want this smooth
transition into a sphere we might be stuck filtering whatever keywords
the lemon supports but our substitute object does not.
If we are going to jump to the 0.499999/2 radius on substitution as we
do today, I vote we go back to an error message.
Bill P.
Download 'lemonissue2.jpg' (103 KB)
Preview of image 'lemonissue2.jpg'
Date: 29 May 2016 13:33:01
Message: <574b27cd$1@news.povray.org>
>> it better ?)
> Suppose if someone is doing an animation or sequence of images, it might be
convenient to transition into a sphere then continue to shrink that sphere.
> If so, we are not really doing that today as we seem to be at a 0.5 radius and then
jump to a radius of 0.499999/2 where we'd need to not have a discontinuity in result
for inner radius moving from 0.5 to 0.499999.
Thanks you for your input, on that point as well as the noisy surface when radius is
exactly the minimal one.
It should be corrected with the new (and hopefully last) change on the lemon.
> If we are going to jump to the 0.499999/2 radius on substitution as we do today, I
If the vertices are identical, an error message is issued (same as for cylinder/cone)
If the third radius is too small, it is adjusted to the smallest value and a warning
is written, thus allowing sturm and open without problem. So, no more discontinuity,
but no shrinking either.
and for extra benefit, when the third radius is the minimal one, a sphere is used
instead of the torus part, removing the problem of noise on the surface due to
coincident surface.
Date: 30 May 2016 10:42:27
Message: <574c5153$1@news.povray.org>
cylinder/cone)
coincident surface.
Unfortunately, I am still seeing noise at the 0.5 radius with the
following code giving us the three rows in the attached image.
//----- Top set
// #declare LemonLeft  = polynomial { 2,
//   xyz(2,0,0):1,
//   xyz(0,2,0):1,
//   xyz(0,0,2):1,
//   xyz(1,0,0):-2*-1.2,
//   xyz(0,0,0):pow(-1.2,2)-pow(0.50000,2)
//   sturm
// #declare LemonCenter  = polynomial { 2,
//   xyz(2,0,0):1,
//   xyz(0,2,0):1,
//   xyz(0,0,2):1,
//   xyz(0,0,0):-pow(0.50000,2)
//   sturm
//----- Middle set
// #declare LemonCenter = lemon {
//    <0,-0.5,0>, 0.0, <0,0.5,0>, 0.0, 0.50
//----- Bottom set
//----- All sets
Bill P.
Download 'hg_495:52beb76993f0.jpg' (208 KB)
Preview of image 'hg_495:52beb76993f0.jpg'
Date: 30 May 2016 11:57:31
Message: <574c62eb@news.povray.org>
is exactly the minimal one.
cylinder/cone)
warning is written, thus allowing sturm and open without problem. So, no more
discontinuity, but no shrinking either.
coincident surface.
> Unfortunately, I am still seeing noise at the 0.5 radius with the following code
I agree there is still something on the surface, when used with a metallic reflection.
But the coincidence surface seems to not be the cause.
If anyone has a clue, feel welcome to share.
Download 'lo.png' (191 KB) Download 'lo.pov.txt' (2 KB)
Preview of image 'lo.png'
Date: 30 May 2016 12:21:32
Message: <574c688c$1@news.povray.org>
reflection.
seems it is tied to the computation when the sphere is used... Puzzling.
Date: 30 May 2016 12:46:08
Message: <574c6e50$1@news.povray.org>
reflection.
Interesting. Do you think it might be worth porting the lemon into the
current gitgub master branch for a test?
I'm not completely up on the differences compared to the Hg-povray
branch...
Bill P.
Date: 30 May 2016 13:37:58
Message: <574c7a76$1@news.povray.org>
reflection.
> Interesting. Do you think it might be worth porting the lemon into the current
> I'm not completely up on the differences compared to the Hg-povray branch...
> Bill P.
I should understand first why I have such noisy sphere. The master branch has changed
a lot of vector operations (for a better C++ like syntax), but the operations would be
the same. Hg-povray branch is "late", more based on stable 3.7 release.
Date: 30 May 2016 14:13:42
Message: <574c82d6$1@news.povray.org>
reflection.
>> Bill P.
changed a lot of vector operations (for a better C++ like syntax), but the operations
would be the same. Hg-povray branch is "late", more based on stable 3.7 release.
And you are lucky, I found why it was noisy... it needed a test. Committed & pushed,
should be available now.
Hopefully it's the last bug of it :-)
Date: 30 May 2016 14:58:34
Message: <574c8d5a$1@news.povray.org>
>>> Bill P.
Yes indeed! Looks great even without sturm. :-)
Bill P.
Date: 3 Jun 2016 14:08:54
Message: <5751c7b6$1@news.povray.org>
Am 26.05.2016 um 16:15 schrieb Le_Forgeron:
That should never happen. The syntax of an object MUST NOT change
depending on how it is represented internally.
You'll have to stick with an ovus-/lemon-specific parsing code, and just
silently ignore "sturm" if you replace the object.
Maybe a smarter way to approach this would be to first completely
construct an ovus/lemon, and in a "post-processing" step replace it with
a fitting sphere.
