POV-Ray : Newsgroups : povray.binaries.images : Ship's Wheel Server Time
24 Oct 2025 17:58:23 EDT (-0400)
  Ship's Wheel (Message 1 to 7 of 7)
Subject: Ship's Wheel
Date: 4 May 2016 08:41:56
Message: <5729ee14@news.povray.org>
Hi
thought I'd post my latest amusement. (keeps me off the streets)
Started life as a a wheel on a pirate ship, but looks more like the
wheel from a luxury cruiser. So decided to make it a "recycled" wheel
sometime in the future when humanity has merged with robots to enable
space exploration.
Thoughts appreciated
Alternate name for the ship ??
Download 'v2a_1600x900.jpg' (370 KB)
Preview of image 'v2a_1600x900.jpg'
Subject: Re: Ship's Wheel
Date: 4 May 2016 09:08:22
Message: <5729f446$1@news.povray.org>
Am 04.05.2016 um 14:41 schrieb Bob Frew:
"USS Arcade"
for the buttons on the left-hand side of the consoles? ;)
Date: 5 May 2016 05:50:01
Message: <web.572b15c32b6b48ac33c457550@news.povray.org>
Love the wheel; the robot looks cool, too.
One suggestion I would offer would be to give the wheel's various parts a
different 'orientation' of the wood grain... the 'inner' circle, the outer
circle, and the handles. And maybe some kind of small-scaled normals(?). As-is,
the wood looks a bit plastic-like (or, to put a better way: as if it was cast as
one piece, out of a single material from a mold.)
Nevertheless, it looks nice.
Radiosity would definitely give the scene (especially the cool robot) a more
life-like quality. Your scene looks made for it. ;-)
Date: 5 May 2016 12:17:21
Message: <572b7211$1@news.povray.org>
I must agree on that one. The wheel and it's base have exactly the same
grain.
I'd use one kind of wood for the base. A second kind for the rim and hub
of the wheel, and a third, similar to the second, for the handles and
spokes, the later been oriented radialy for each spoke.
Date: 6 May 2016 05:59:17
Message: <572c6af5@news.povray.org>
On 04/05/2016 13:41, Bob Frew wrote:
> Hi
> space exploration.
> Bob
many thanks for input.  I know you are right.
Although I've been playing for years, there is quite a long list of POV
features where my knowledge is abysmal.
Textures and lighting are two of them. There is only a single white
light source in my scene.
I was originally thinking of a wheel cut from one block, but as you say
it would more likely be "constructed" and possibly stronger in consequence.
Have found a tutorial on radiosity on POV-Wiki so will move outside the
"comfort zone" and give it another try.
			cheers   .. Bob
Date: 6 May 2016 07:26:53
Message: <572c7f7d$1@news.povray.org>
>> outer
>> normals(?). As-is,
>> was cast as
> grain.
Following up on that, I would build the wheel rim itself in different
cylinder sections (at least for the textures) not from one piece.
Date: 6 May 2016 07:40:00
Message: <web.572c81742b6b48ac5e7df57c0@news.povray.org>
Bob Frew <bob### [at] ntlworldcom> wrote:
> Hi,
Join the club.   ;)   There's just _too much_!
There's always something new to discover, and always someone who comes out of
left-field with a new twist on implementing it.
Check out these links - I know there are other good ones out there too, but I'm
on my way out the door to work soon.
http://www.f-lohmueller.de/pov_tut/camera_light/camlit_e1.htm
http://xahlee.info/3d/povray-lighting.html
Google Warp's tutorial on wood flooring - he's got some good things to say about
matching up the wood pigment pattern with normals, etc.
You might also check out "isowood" that makes great wooden objects using
isosurfaces.
Also, I've found that making some slight imperfections in the object ,ake it
look less plasticky. Small translations and rotations, some interesting things
thrown into the color map, slight shifts or misfits in the parts of something -
perhaps with the gaps filled in with a black "glue" to give it some character.
Something to really bring out the texture and shadows.
One could really spend an entire week or more (probably more) doing nothing but
learning how to put together wood textures.
Having gone down that road, I can tell you that the results are well worth the
time and effort you spend getting radiosity to work in your scene.
And once you just bite the bullet and do it, you'll see that it's a LOT simpler
to do than one might make it out to be (even the two-step method), and you'll be
wondering why you procrastinated for so long.
Good luck - it's coming along well!
