POV-Ray : Newsgroups : povray.binaries.images : concentric blobs clouds Server Time
15 Oct 2026 23:19:10 EDT (-0400)
  concentric blobs clouds (Message 1 to 50 of 66)
Goto Latest 50 Messages Next 16 Messages >>>
Subject: concentric blobs clouds
Date: 26 Apr 2016 08:47:12
Message: <571f6350@news.povray.org>
I was going to add some cumulus to my sea scene, but the ones I had from
the project tierra where not very convincing, so... I started another
experiment.
The approach is similar to that of my previous cumulus include, but with
a trick to make softer media. As the method involved the object pattern,
the media was a bit sharp with just 0 or 1 in the density map.
The trick is to create an array of blob components positions and radius,
then use that to create 4 blobs with concentric shapes and use them on
an averaged density map. The results are surprisingly fast... this one
took "only" 47 min.
jaime
Download 'blob-clouds-test-03d.jpg' (52 KB)
Preview of image 'blob-clouds-test-03d.jpg'
Subject: Re: concentric blobs clouds
Date: 26 Apr 2016 09:05:01
Message: <web.571f66e85193772e670f6e990@news.povray.org>
> took "only" 47 min.
Nice and fluffy as it should be.
The method of averaging object patterns will be of further use - at least I hope
so...
Norbert
Date: 26 Apr 2016 09:45:00
Message: <web.571f70925193772eff125f370@news.povray.org>
> experiment.
> took "only" 47 min.
> jaime
Here is a resource about the simulation on cloud phenomenon which I know.
http://wiki.flightgear.org/Atmospheric_light_scattering
Date: 26 Apr 2016 09:52:49
Message: <571f72b1$1@news.povray.org>
> experiment.
> took "only" 47 min.
> jaime
Impressive - though am I correct there are some artifacts in the right
part of the center top plume? Was it run with AA ?
Asking mostly because of my continuing look into blob related bugs.Those
spots look like other issues I have seen related to media and blobs at
the blob(s) boundary.
Bill P.
Date: 26 Apr 2016 12:39:55
Message: <571f99db$1@news.povray.org>
   Thanks... perhaps too fluffy, tough.
> so...
  Well, it's nothing fancy, just the average pattern. The real trick is
that the averaged blobs are concentric (with diminishing radius and the
same threshold):
   interior{
     media{
       method 3 intervals 1 samples Cloud_Samples
       scattering{2,.01}
       absorption .005
       density{
         average
         density_map{
           [1
             object{
               cloud_a
               color rgb 0
               color rgb .25
             warp{turbulence .5}
             scale 2 warp{turbulence .67} scale 1/2
             scale 4 warp{turbulence 1} scale 1/4
           [1
             object{
               cloud_b
               color rgb 0
               color rgb .5
             warp{turbulence .5}
           [1
             object{
               cloud_c
               color rgb 0
               color rgb .75
             warp{turbulence .5}
           [1
             object{
               cloud_d
               color rgb 0
               color rgb 1
             warp{turbulence .5}
jaime
Date: 26 Apr 2016 12:45:55
Message: <571f9b43@news.povray.org>
> know.
   Well, fortunately POV-Ray media scattering type 2 takes care of all
that... what I'm really looking for is some method to create convincing
cumulus shapes. Right now they are just a bunch of blob spheres filling
a random conical shape, but I've got some ideas to try from this paper:
   https://hal.inria.fr/inria-00537462/file/BN04_clouds.pdf
   I will try to start with a base blob with just a few big components
and then trace a lot of smaller ones on the surface of it.
jaime
Date: 26 Apr 2016 12:56:13
Message: <571f9dad@news.povray.org>
> right part of the center top plume? Was it run with AA ?
   You have a good eye... I had to zoom several times to see them! Yes,
it was run without AA, and the artifacts are likely due to the media
container (another blob, BTW... I forgot to mention this).
> bugs.Those spots look like other issues I have seen related to media
> and blobs at the blob(s) boundary.
   Yes, that's likely the problem: see the attached test. The inner solid
blob is the object used on the density pattern, and the transparent
outer blob is the media container: you can clearly see the artifacts are
coincident with a blob boundary.
jaime
Download 'blob-clouds-test-03d-containers.jpg' (74 KB)
Preview of image 'blob-clouds-test-03d-containers.jpg'
Date: 26 Apr 2016 12:58:16
Message: <571f9e28@news.povray.org>
Another one using the exact same clouds but with a sunset lighting.
jaime
Download 'blob-clouds-test-03e.jpg' (49 KB)
Preview of image 'blob-clouds-test-03e.jpg'
Date: 26 Apr 2016 13:20:00
Message: <web.571fa3065193772e670f6e990@news.povray.org>
> > so...
> same threshold):
>    interior{
>      media{
>        scattering{2,.01}
>        absorption .005
>        density{
>          average
>          density_map{
>            [1
>              object{
>                cloud_a
>                color rgb 0
>                color rgb .25
>              warp{turbulence .5}
>            [1
>              object{
>                cloud_b
>                color rgb 0
>                color rgb .5
>              warp{turbulence .5}
>            [1
>              object{
>                cloud_c
>                color rgb 0
>                color rgb .75
>              warp{turbulence .5}
>            [1
>              object{
>                cloud_d
>                color rgb 0
>                color rgb 1
>              warp{turbulence .5}
> jaime
Thank you for the code snippet.
Concentric is clear, otherwise it would be similar to proximity patterns.
But, who knows...
Norbert
Date: 26 Apr 2016 15:27:14
Message: <571fc112@news.povray.org>
Am 26.04.2016 um 18:58 schrieb Jaime Vives Piqueres:
You folks are amazing!
Date: 27 Apr 2016 02:56:54
Message: <572062b6$1@news.povray.org>
Very nice indeed Jaime. How does this method relate to the df3 one used
by Gilles Tran? I am familiar with that; I also used blobs for making
smoke (Chris Huff or Michael Carneholm macros) but they are pretty slow.
Date: 27 Apr 2016 03:08:47
Message: <5720657f@news.povray.org>
Jaime Vives Piqueres wrote on 26/04/2016 14.47:
> experiment.
> took "only" 47 min.
> jaime
I like a lot this one!
Paolo
Date: 27 Apr 2016 03:15:01
Message: <web.572065ff5193772e6e89f5aa0@news.povray.org>
Gorgeous !
I find them an impressionism touch...
Can't wait to see the composition with the sea.
> experiment.
> took "only" 47 min.
> jaime
Date: 27 Apr 2016 03:35:01
Message: <web.57206aae5193772e5b7d07940@news.povray.org>
This is excellent. Whenever I've tried to use this type of technique before, I
can never get the media settings right - my clouds either end up
not-really-opaque, i.e. I can see other stuff through even the densest regions,
or so dense that they saturate to black underneath.
Your code looks very straightforward - I must play with it!
Bill
Date: 27 Apr 2016 03:38:33
Message: <57206c79$1@news.povray.org>
> used by Gilles Tran? I am familiar with that;
   Well, in fact I started first trying df3 clouds: I did my own
"makecloud" using ARRAYS_WriteDF3() to write the cloud files, sampling
the same blobs I'm using now. It worked fine, but it was slow to
generate clouds with decent resolution, and the look was too fluffy.
Also, I found no way to make the clouds less turbulent at bottom.
> I also used blobs for making smoke (Chris Huff or Michael Carneholm
   Well, I'm using another blob as container, and perhaps that's making
them faster, because I find them not much slower than the df3 ones.
jaime
Date: 27 Apr 2016 04:05:24
Message: <572072c4$1@news.povray.org>
Ah yes, the cloud bottom was a problem indeed.
That's interesting. Thanks!
Date: 27 Apr 2016 06:22:58
Message: <57209302$1@news.povray.org>
   Thanks!
jaime
Date: 27 Apr 2016 06:28:50
Message: <57209462@news.povray.org>
El 27/04/16 a las 09:10, BayashiPascal escribió:
> Gorgeous ! I find them an impressionism touch...
   Thanks. The "impressionism" touch is nice, but to be frank is only the
result of not being realistic enough... :(
   I still have some things to try with the clouds, but I will let it
render this evening, as I've to leave for some hours... will post tonight.
jaime
Date: 27 Apr 2016 06:34:59
Message: <572095d3$1@news.povray.org>
> jaime
Thanks for checking Jaime. The image is also helpful for understanding
your cloud technique.
Let me add my apologies for the many times I've no doubt mistyped your
name. I typed again this morning - Jamie - but saw it this time.
Many days, my eyes & brain fail to see in the moment the scrambled
things my fingers type!
Bill P.
Date: 27 Apr 2016 06:35:20
Message: <572095e8$1@news.povray.org>
> before, I can never get the media settings right - my clouds either
> end up not-really-opaque, i.e. I can see other stuff through even the
> densest regions, or so dense that they saturate to black underneath.
   Yeah... POV-Ray media isn't easy to setup. In fact it can drive you
crazy most of the time. It's happening to me now as I'm trying to add
another media for the haze (I was using a ground fog until now). But it
looks gorgeous when you find the right setup for your scene...
jaime
Date: 27 Apr 2016 06:47:21
Message: <572098b9$1@news.povray.org>
> understanding your cloud technique.
   What you don't see on the image is the other 3 concentric blobs inside
the solid one: they use the same components placement but with
increasingly smaller radius.
> your name. I typed again this morning - Jamie - but saw it this
> time.
   Don't worry... I'm already used to being called Jamie. In fact I
rarely notice it: as long as all the characters are there, it looks right.
jaime
Date: 27 Apr 2016 17:49:07
Message: <572133d3@news.povray.org>
   Well, lots of artifacts and no AA, but looks promising...
jaime
Download 'ocean-18.jpg' (55 KB)
Preview of image 'ocean-18.jpg'
Date: 27 Apr 2016 22:24:36
Message: <57217464@news.povray.org>
> jaime
It's a UFO!
=:o
________________________________________
-Nekar Xenos-
Date: 28 Apr 2016 03:25:01
Message: <web.5721ba445193772e5b7d07940@news.povray.org>
Awesome. I look forward to this time next year when the full size version
finishes rendering!
Date: 28 Apr 2016 03:49:28
Message: <5721c088$1@news.povray.org>
El 28/04/16 a las 04:24, Nekar Xenos escribió:
> It's a UFO!
   Good idea: if I cannot get ride of the artifacts, I could pass it for
a UFO trying to hide on the clouds using some invisibility trick... :)
jaime
Date: 28 Apr 2016 03:55:02
Message: <5721c1d6@news.povray.org>
> version finishes rendering!
   Thanks, but it's not that slow... that test took just 29 min, and the
one attached here, using +a, took 1h45m using only 4 out of 6 cores. I
guess the full render at 1600x900 will take about 4 hours with 6 cores.
The idea of using a blob as container, instead a box or sphere, works
pretty well... it's just a shame it generates some artifacts. :(
jaime
Download 'ocean-18b.jpg' (84 KB)
Preview of image 'ocean-18b.jpg'
Date: 28 Apr 2016 06:59:54
Message: <5721ed2a$1@news.povray.org>
   BTW, I've just found a way to avoid the "bottom" problem with df3
clouds: do not use the df3 directly on the density, but declare it first
as a pigment, then use it on a "gradient y" density map with a less
turbulent version at the bottom. Works nicely...
       density{
         gradient y
         density_map{
           [0 pigment_pattern{p_df3}
             ...little turbulence at bottom...
           [1 pigment_pattern{p_df3}
             ...full turbulence at the top...
jaime
Date: 28 Apr 2016 07:10:00
Message: <web.5721ee5b5193772e5b7d07940@news.povray.org>
I guess the blob containers makes for fewer media calculations - that's a decent
time for such a render.
What causes the artifacts, is it something about the way blobs are implemented?
How about using a merge of the blob component spheres instead?
Date: 28 Apr 2016 07:15:01
Message: <web.5721f04c5193772eb3cc20420@news.povray.org>
> jaime
I feel for you concerning the artifacts. I have tried all kinds of tricks to get
rid of them and usually end up in a worse place than I began with. Blasted
container objects! May they be for ever confined to the ninth circle of hell
(the one reserved for treachery)!
I ended up using a single containing object (box or plane) and then filling it
with a skewed y-gradient density to get a flat bottom and then adding a mixture
of wrinkles, bozo and crackle (form<1, 0, 0>) to try to approximate fluffy tops.
Some of my images over at www.landofthefirst.com were created using this. I am
still not 100% happy with them.
I think your idea much better (and I love the results). More ideas to play with.
Date: 28 Apr 2016 07:22:25
Message: <5721f271$1@news.povray.org>
Thanks! Shall try!
Date: 28 Apr 2016 07:39:06
Message: <5721f65a$1@news.povray.org>
> implemented? How about using a merge of the blob component spheres
> instead?
   Damn... that was so obvious and easy! Indeed it works great, thanks!
Currently rendering with your solution the exact same clouds for comparison.
jaime
Date: 28 Apr 2016 07:41:08
Message: <5721f6d4$1@news.povray.org>
   The ones at Othil Homtoh look very nice...
jaime
Date: 28 Apr 2016 08:32:18
Message: <572202d2$1@news.povray.org>
Answering without going back to refresh my old brain cells...
When Gail Shaw hit this issue back in 2005. At that time Slime wrote:
This is probably just a problem with the accuracy of the blob solver; I
think it's not noticing the second (backside) surface near the edges, so
it thinks there's a long distance of media and makes it very bright as a
result. (In 3.5 this may have been diminished by anti-aliasing.)
A suggestion: Use a small box as your media container instead of a blob,
and then use a density{} in the media with the object pattern with the
blob, so that all points outside of the blob have no media.
- Slime
In my digging I've found blob surfaces are actually a bit noisy
especially as the rays hit the surface in a more tangential way - so I
think Slime's thinking as to the cause is probably right.
Things that tend to help:
1) Try running with sturm off.
2) Lower the blob threshold - start extreme with 0.0001 say - though you
may of course lose the blob effect you want, but perhaps in the case of
these clouds this would be OK?
3) The code change I have been working to verify against blob problem
cases from years past tends to help a little with bright artifacts -
more with dark artifacts. Specifically the change in blob.cpp is changing:
const DBL DEPTH_TOLERANCE = 1.0e-2;
to:
const DBL DEPTH_TOLERANCE = 1.0e-4;
4) AA sometimes helps - and sometimes not - depending on how tangential
the super samples themselves are I guess.
5) What the other Bill P suggested should help too - if the merge
eliminates internal blob surfaces causing the artifacts.
Hope one or more things here enough to get this cloud method working
generally.
Bill P.
Date: 28 Apr 2016 08:44:57
Message: <572205c9@news.povray.org>
> generally.
   Thanks for the detailed explanation, but in this case the best
solution was the one the other Bill P. suggested. A merge of spheres
with same radius and placement did work pretty well, and in this case it
doesn't matter as it is an invisible container. It still does the job of
being a close container, and the speed up provided is even a little
better too.
jaime
Download 'ocean-18c.jpg' (130 KB)
Preview of image 'ocean-18c.jpg'
Date: 28 Apr 2016 09:08:59
Message: <57220b6b$1@news.povray.org>
>> generally.
> better too.
> jaime
Great! At least it was one of the Bill P's helped out... :-)
Perhaps I missed it, but are these renders with 3.7.0 or that latest
3.7.1 ?
Asking because Christoph made media related fixes in 3.7.1 which in my
few experiences help both performance and result.
Bill P.
Date: 28 Apr 2016 10:20:27
Message: <57221c2b$1@news.povray.org>
> 3.7.1 ?
   3.7.1, latest alpha...
   I didn't know, but yes, that must have helped too...
jaime
Date: 28 Apr 2016 10:55:01
Message: <web.572223a55193772e63ecef950@news.povray.org>
> jaime
Here is the code:
    #macro SkyShell(minAlt, maxAlt, Int)
        difference
            sphere {<0, 0, 0> 1000000+maxAlt}
            sphere {<0, 0, 0> 1000000+minAlt}
            hollow
            texture {pigment {color rgbf 1}}
            interior {Int}
            translate <0, -1000000, 0>
    SkyShell(4000, 5000,
        interior {
            media {
                method 3
                samples 20
                scattering {2, color rgb 0.0075 extinction 1}
                density
                    wrinkles
                    scale <4000, 1000, 4000>
                    warp { turbulence 2 }
                    lambda 4
                    color_map
                        [0.00 color rgb 1.0]
                        [0.50 color rgb 0.8]
                        [0.55 color rgb 0.0]
                        [1.00 color rgb 0.0]
                    translate <-4000, 0, -1000>
                density
                    gradient y
                    scale 1000
                    color_map
                        [0.0  color rgb 0.00]
                        [0.4  color rgb 1.00]
                        [0.9  color rgb 1.00]
                        [1.0  color rgb 0.00]
I lied. It was concentric spheres!
And nice solution for the artifacts! One to remember.
Date: 28 Apr 2016 13:48:41
Message: <57224cf9$1@news.povray.org>
>> least I hope
>> so...
> same threshold):
maybe i'm misunderstanding ... more complicated than taking the base
blob object and making scaled copies?
Date: 28 Apr 2016 14:23:14
Message: <57225512$1@news.povray.org>
   Just scaling down the copies only works for objects which are
symmetric on all axes. Scaling down an irregular, asymmetric blob makes
some components to be displaced towards the center, thus they get
outside the component on the original copy (and yes, I too though it
would work and tried that first... ;).
jaime
Date: 28 Apr 2016 15:20:00
Message: <web.572261c75193772efa0ec0bd0@news.povray.org>
> > better too.
> Bill P.
Haha, I keep meaning to call this out. Too many Bill Ps! At least you come up as
a William on your account name, that saves huge confusion on the digest page (I
usually use the web view).
Jaime, glad my suggestion worked well. Honestly I nearly didn't say anything, I
thought it was too obvious and that you were bound to have tried it already! I
shall wheel out random suggestions more often in that case :)
Bill (the other P)
Date: 28 Apr 2016 16:25:24
Message: <572271b4@news.povray.org>
   Nothing is too obvious, at least if I'm involved...
jaime
Date: 30 Apr 2016 07:28:11
Message: <572496cb@news.povray.org>
> clouds:
It makes for different types of clouds of course. Left image is the
original use of the df3 files as densities; right used as pigment
patterns and with a gradient y density.
I had to substantially increase samples to eliminate artifacts. While
left I could get away with samples 10, on the right - to keep on the
safe side - I used samples 100. I probably could easily get away with
samples 50 though.
Download 'my_makecloud2_test_day.png' (852 KB)
Preview of image 'my_makecloud2_test_day.png'
Date: 30 Apr 2016 12:26:10
Message: <5724dca2$1@news.povray.org>
> samples 50 though.
   That's strange... I'm getting good results with just 16 samples.
jaime
Date: 30 Apr 2016 12:29:43
Message: <5724dd77@news.povray.org>
Am 30.04.2016 um 18:26 schrieb Jaime Vives Piqueres:
>> samples 50 though.
Different version?
Media sampling method 3 had various bogosities until somewhen between
3.7.0 and today.
Date: 30 Apr 2016 13:10:00
Message: <web.5724e5f85193772e87fca9f40@news.povray.org>
How do you achieve the atmospheric haze effect?
Date: 1 May 2016 02:47:24
Message: <5725a67c$1@news.povray.org>
That is a fog. The scene is Gilles Tran's.
Date: 1 May 2016 02:52:26
Message: <5725a7aa$1@news.povray.org>
This is basically what I do; most other details are Gilles' original
settings (more or less):
   #declare P_cloud2_1 =
   pigment {density_file df3 "cloud2_1.df3"
     lambda 3
     omega 0.6
     interpolate 1
     translate -0.5
     scale <1, -1, 1>
   #declare Cloud1 =
   box {-0.5,0.5
     texture {pigment {Clear} finish {ambient 0 diffuse 0}}
     hollow
     interior {
       media {
         scattering {1, C_Sun*0.006 extinction 0.25}
         intervals 1
         samples 100, 1000
         density {
           gradient y
           density_map {
             [0 pigment_pattern {P_cloud2_1}
                turbulence Turbulence*0.1
             [1 pigment_pattern {P_cloud2_1}
                turbulence Turbulence*2
     scale <4/3,1,1>
Date: 1 May 2016 03:12:57
Message: <5725ac79$1@news.povray.org>
Sorry, forgot to mention: version 3.7.1 alpha (blablabla) +av123
Date: 1 May 2016 03:35:12
Message: <5725b1b0$1@news.povray.org>
   The only notable difference I see is that I'm using scattering type 2
with default extinction.
jaime
Date: 1 May 2016 04:32:04
Message: <5725bf04@news.povray.org>
The solution was straightforward (see also image):
   #declare Cloud1 =
   box {-0.5,0.5
     hollow
     interior {
       media {
         intervals 1
         samples 50, 1000
         density {
           gradient y
           density_map {
                scale 50 warp {turbulence 0.1} scale 1/50
                scale 50 warp {turbulence 2} scale 1/50
     scale <4/3,1,1>
I shall try your scattering now.
Download 'my_makecloud2_test_day_2016.png' (391 KB)
Preview of image 'my_makecloud2_test_day_2016.png'
