POV-Ray : Newsgroups : povray.binaries.images : Growing crystals test Server Time
16 Oct 2026 00:24:01 EDT (-0400)
  Growing crystals test (Message 1 to 35 of 35)
Subject: Growing crystals test
Date: 17 Feb 2016 07:18:44
Message: <56c46524@news.povray.org>
The world of POV-Ray crystallography is on fire this week... after the
discovery of Thomasite, now it's the turn of Vivesite. ;)
The crystals are procedurally generated using triangle meshes from the
scratch. A height_field was used to trace the 4 base points, and then
the crystal was grown following the normal at the center point. No area
light nor radiosity this time... but I used photons+dispersion and a
strong focal blur. Render time was a under 2 hours using an AMD FM-6300
(x6).
As the test seems to have given acceptable results, I'm going to use now
an isosurface as the base, and try to use hexagonal crystals... if I can
work it out: working out the maths for a cube basal I already fried one
or two neurons...
jaime
Download 'crystals-04.png' (955 KB)
Preview of image 'crystals-04.png'
Subject: Re: Growing crystals test
Date: 17 Feb 2016 07:20:30
Message: <56c4658e@news.povray.org>
Oops... sorry for the big PNG, I forgot to convert it to JPG for the post.
jaime
Date: 17 Feb 2016 07:29:35
Message: <56c467af$1@news.povray.org>
Jaime Vives Piqueres wrote on 17/02/2016 13.18:
> (x6).
> or two neurons...
> jaime
A very nice result, imho.
Paolo
Date: 17 Feb 2016 12:55:00
Message: <web.56c4b360e00413379c88bb910@news.povray.org>
> (x6).
> or two neurons...
> jaime
Excellent ! Looking forward for the next one. Hope you have some neurons left.
Bruno
Date: 17 Feb 2016 16:35:26
Message: <56c4e79e@news.povray.org>
> (x6).
> or two neurons...
That's incredibly good. :)
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 17 Feb 2016 17:57:12
Message: <56c4fac8$1@news.povray.org>
Am 17.02.2016 um 13:18 schrieb Jaime Vives Piqueres:
Great stuff!
> or two neurons...
I guess it's worth frying a few more ;)
Date: 17 Feb 2016 17:57:35
Message: <56c4fadf@news.povray.org>
First test using an isosurface as base... nice, except for some ugly
artifacts on focal blur, due to a too strong light source.
jaime
Download 'crystals-07.jpg' (88 KB)
Preview of image 'crystals-07.jpg'
Date: 17 Feb 2016 19:05:01
Message: <web.56c509afe0041337fd6b6fe10@news.povray.org>
> jaime
Fantastic.  I've been wanting to know how to do this for years, but good crystal
geometry has been elusive.
How high do you have to set the max_trace_level?
A.D.B.
Date: 17 Feb 2016 19:15:00
Message: <web.56c50c05e004133723c5c5130@news.povray.org>
> jaime
Phantastic!
Good to see something new from you, Jaime.
First I thought, it's hdr lighting, but with this artifacts...
Norbert
Date: 17 Feb 2016 21:57:07
Message: <56c53303$1@news.povray.org>
double wow with a cherry on top.
dik
Date: 18 Feb 2016 03:02:00
Message: <56c57a78$1@news.povray.org>
That's it! One thing maybe to watch out for is the irregular normal
pattern on the sides. I think one should distinguish between the 'growth
pattern' of the crystals and the 'inclusions' within the crystals like
residual liquids. Of course Vivesite is a totally different matter ;-)
Date: 18 Feb 2016 03:43:53
Message: <56c58449$1@news.povray.org>
   Thanks... my solution was in fact very easy. The crystal geometry is
very simple, just 14 triangles for each crystal. The growth orientation
is controlled by the surface normals, and the widths and heights of each
one are just random.
   Only 9... I found increasing it was an overkill.
jaime
Date: 18 Feb 2016 03:47:57
Message: <56c5853d$1@news.povray.org>
El 18/02/16 a las 01:10, Norbert Kern escribió:
> Phantastic!
> Good to see something new from you, Jaime. First I thought, it's hdr
   Thanks... yes, it has an hdr image as background, but it doesn't
contributes to lighting as I'm not using radiosity at the moment. The
lighting is just a single point light at the top, which matches the
lighting on the cave probe from openfootage.net. The problem with the
artifacts is that I used a looks_like object way too bright.
jaime
Date: 18 Feb 2016 03:49:37
Message: <56c585a1@news.povray.org>
   Yes, the normal is tricky... I used a simple "crackle solid" with
turbulence for now.
jaime
Date: 18 Feb 2016 10:03:24
Message: <56c5dd3c@news.povray.org>
This is amazing stuff. I love those mineral pictures!!!
Date: 18 Feb 2016 10:08:01
Message: <56c5de51$1@news.povray.org>
There are so many different types of crystals out there, so I am looking
forward to see a whole lot of new crystal and rock images to come here!
This is really breath-taking.
Date: 18 Feb 2016 11:32:33
Message: <56c5f221@news.povray.org>
   Thanks, but I think there is no need to fry neurons anymore: I was
doing it too complicated by creating the geometry AFTER the tracing on
to the surface. Now I'm creating the geometry at the origin and using
transforms.inc macros later... as I should have done from the start.
Typical of me, anyhow. :(
jaime
Date: 19 Feb 2016 06:20:00
Message: <web.56c6f9bbe0041337234a01ef0@news.povray.org>
> jaime
I really have to unlurk for this!
This kind of thing got me into ray-tracing to begin with.
Beautiful!
Can I ask, in broad strokes, how you did this? I tend to render distances, and
haven't done much in the way of upclose and detailed work like this. Looking at
these two images I think I would like to try.
Simon.
Date: 19 Feb 2016 06:30:00
Message: <web.56c6fbdee0041337234a01ef0@news.povray.org>
OK, ignore that! I was so busy admiring the images that I missed this:
> strong focal blur.
I'll just go back to lurking!
Simon.
Date: 19 Feb 2016 06:36:21
Message: <56c6fe35@news.povray.org>
El 19/02/16 a las 12:17, Simon J. Cambridge escribió:
> Beautiful!
    Thanks!
    I will publish the code this weekend, but it's really easy. Just old
& good trace() function and simple triangle geometry, placed with the
help of Reorient_Trans(). The texture is a bit tricky, but nothing too
complex really. Here is attached a test with the geometry updated to
hexagonal prisms, which look much more credible.
jaime
Download 'crystals-10.jpg' (51 KB)
Preview of image 'crystals-10.jpg'
Date: 19 Feb 2016 07:32:38
Message: <56c70b66@news.povray.org>
First try at colored crystal using color on the texture and interior
media (just a test: no aa).
jaime
Download 'crystals-12.jpg' (47 KB)
Preview of image 'crystals-12.jpg'
Date: 19 Feb 2016 11:20:01
Message: <web.56c74099e00413375b7d07940@news.povray.org>
This is lovely work. Prelude to a Crystal of the Week page?
btw, why media and not sslt?
Bill
Date: 19 Feb 2016 11:36:04
Message: <56c74474$1@news.povray.org>
   Thanks!
   The variety on the world of natural crystals is awesome, so, yes... it
could well be a source for a COTW page on my site. Thanks for the idea!
   TBH, mostly due to sticking to what I know and can type from memory.
But I also seem to remember having done a few tests and finding sslt was
slower for some simple effects like this one... but maybe I'm wrong.
jaime
Date: 19 Feb 2016 11:50:00
Message: <web.56c74725e00413375b7d07940@news.povray.org>
Excellent, shall keep my eyes open for it :)
Honestly, I don't use either of them often enough to do anything quickly, or to
know which works best in any given scenario... was just curious!
Date: 19 Feb 2016 12:10:01
Message: <web.56c74b3fe0041337adb2e4f80@news.povray.org>
Really an amazing Result, Jamie!
Your talent is still unbeaten unique.
Date: 19 Feb 2016 13:46:43
Message: <56c76313$1@news.povray.org>
On Fri, 19 Feb 2016 12:36:22 +0100, Jaime Vives Piqueres wrote:
> Here is attached a test with the geometry updated to hexagonal prisms,
Incredible. :)  Nice work.
Jim
Date: 19 Feb 2016 21:31:13
Message: <56c7cff1$1@news.povray.org>
Welcome, Simon, to this amazing group!
Date: 19 Feb 2016 21:32:26
Message: <56c7d03a$1@news.povray.org>
Wow, that is an interesting turn! Thanks from my side, too! I will
experiment with different backgrounds.
Date: 19 Feb 2016 21:35:55
Message: <56c7d10b$1@news.povray.org>
Wooooooooowwwwww!!!!!!!!!
Date: 19 Feb 2016 22:00:01
Message: <web.56c7d633e00413376e89f5aa0@news.povray.org>
I really love those crystals, very nice and realistic !
Date: 20 Feb 2016 10:30:00
Message: <web.56c88564e004133788d74dab0@news.povray.org>
Thank you, Sven. I think I said this in my other posting (Here be monsters...)
that I have lurked for a long while. I didn't really want to contribute until I
had something to contribute, so to speak.
Date: 20 Feb 2016 20:39:40
Message: <56c9155c$1@news.povray.org>
Would you make the source code available for us? That would be
wonderful. Just, if you want.
Date: 21 Feb 2016 03:44:59
Message: <56c9790b$1@news.povray.org>
   I already said I would do so... and the code is on p.b.scene-files
since yesterday.
jaime
Date: 27 Feb 2016 01:40:55
Message: <56d144f7$1@news.povray.org>
Hey, thanks a lot! :-D
> since yesterday.
Date: 3 Mar 2016 16:05:02
Message: <web.56d8a686e0041337adb2e4f80@news.povray.org>
Thats the advantage from POV-Ray to those modellers out there.
Just a little change of a little number ...
Download 'crystals_02.png' (1474 KB)
Preview of image 'crystals_02.png'
