POV-Ray : Newsgroups : povray.binaries.images : Hair/beard growing - a Poseray problem? Server Time
12 Jul 2025 21:30:40 EDT (-0400)
  Hair/beard growing - a Poseray problem? (Message 1 to 7 of 7)
Subject: Hair/beard growing - a Poseray problem?
Date: 9 Feb 2016 07:42:51
Message: <56b9decb@news.povray.org>
You may remember that in early 2014 I experimented with growing hair
using POV-Ray code (see image attached). I remember now that I did this
out of frustration with an apparent problem to convert Poser-generated
lines to tubes in Poseray's latest build. I need to investigate further
if this is: (1) a Poser problem (I currently am using Poser Pro 2014);
(2) an export problem from Poser to an .obj file; (3) a particular
Poseray problem. In the past, I did successfully convert Poser-generated
lines into tubes, so it must be a later issue.
Does anybody here possibly has met with identical problems? please let
me know.
Download 'hairplanting_test.png' (358 KB)
Preview of image 'hairplanting_test.png'
Subject: Re: Hair/beard growing - a Poseray problem?
Date: 10 Feb 2016 03:43:28
Message: <56baf830$1@news.povray.org>
Testing different Poseray versions with a beard/line test model from
2011 I know did work correctly, it appears that the /latest/ Poseray
version correctly converting lines to tubes is version 3_12_2, and
possibly 3_13_15_beta (there was a file loading problem but creating a
tubes conversion seems to work). Neither version 3_13_19 nor 3_13_23 do
any conversion. Those are the versions in my possession.
Date: 11 Feb 2016 03:22:11
Message: <56bc44b3$1@news.povray.org>
Further careful testing shows me definitely that Poseray does not
convert correctly from lines to tubes.
I shall contact FlyerX.
Date: 25 Feb 2016 17:40:00
Message: <web.56cf826497e15030efa0f190@news.povray.org>
> Thomas
Thanks to the bug report from Thomas, the issue should be fixed now. You can
download the new version from PoseRay's site:
https://sites.google.com/site/poseray/
It has some other small updates too.
regards,
FlyerX
Date: 25 Feb 2016 18:31:13
Message: <56cf8ec1$1@news.povray.org>
I'm curious what you expected it to look like.  It looks very dollish,
but what was the desired effect?
Date: 25 Feb 2016 21:15:00
Message: <web.56cfb41997e15030efa0f190@news.povray.org>
I general I recommend against using dynamic hair with POV-Ray. It rarely looks
good. Trans-mapped hair looks fine but dynamic strand hair needs many more hairs
which need to be converted to tubes increasing the poly count massively. POV-Ray
also needs a better handling of the specular for strands to look better.
Date: 26 Feb 2016 02:41:40
Message: <56d001b4$1@news.povray.org>
I think there is latitude for experimentation here. The one example
where dynamic hair from Poser works rather well is with beards, if they
are short. Otherwise, I agree with FlyerX that it is better to use
trans-mapped hair for the time being.
