The constructions on another colony ship have started. This thread will
keep all future space colonists up to date, thus you are requested to
follow this thread.
We have established a large cylinder, and work right now on the
illumination of the inside habitat. In opposition to another colony ship
(chief designer: Mr. Mike Horvath), our colony ship has a long
construction along its middle axis, which features an artificial fusion
sun system, that rotates just slightly slower than the cylinder habitat,
thus achieving a real day and night phase for the colonists.
At the present stage, the habitat has a radius of 1500 meters (diameter:
3 km), and a length of 5 km. While the lights in the center are almost
white, the lights towards the side transform from peachy sunset colors
to dark purple early night colors.
The central construction, in which there is no gravity, contains the
lights and beside rapid transport tubes, also our oxygen production
(using a light-emitting porous tissue through which air is moving, with
genetically modified cyano bacterias on the surface of that porous tissue.
This cylinder is one of four, counter-spinning cylinders of the colony ship.
Our next step is the addition of air into the habitat. We will keep you
posted.
Download 'sl - colony ship i.png' (20 KB)
Preview of image 'sl - colony ship i.png'
I am cogitating a habitat similar to Greg Bear's in his novel, Eon.
https://en.wikipedia.org/wiki/Eon_%28novel%29#The_Stone
When I've sorted out a few minor technical problems. I will start.
Regards
Interesting. That was one of my first thoughts, too - to place the
habitat inside an asteroid. But I came off that idea, for this time. :-)
Yes, go ahead then, I want to see your colony ship, too. Make an own
thread about it. So we soon have here an entire fleet of colony ships in
this forum. :-D
> this forum. :-D
As I said, there are one or two problems. Once they are sorted out. I
will be able to start rendering from the moment I thought of the idea. :-)
Causality, don't ya know.
Regards
Am 07.02.2016 um 16:37 schrieb Sven Littkowski:
In effect, it'll probably be more like a bright sunny day vs. an
overcast day, due to light being reflected from the day side to the
"night" side. The "night" side may also receive tinted light, depending
on the overall colour of structures on the day side.
You may want to rethink placing any living organisms near the central
light source. It might get pretty hot, and certainly blindingly bright.
I was thinking of placing a hang glider near the lamp in my scene, but I
couldn't find a POV equivalent, and don't want to install the additional
tools needed to import a model file in another format.
Mike
I am also having trouble finding materials on "spinning" space stations
that are not shaped like a wheel. I think someone here already said that
a long cylinder is not very stable and will tend to wobble compared to a
wheel.
Mike
> wheel.
Space wheels are so 2001. [Cue the Blue Danube. :-) ]
Regards
Yes, I d. I really do. :-)
That "backbone" (construction along the middle axis) is actually having
a diameter of 500 meters, and the oxygen chambers are integrated into
the inside and walls, where the immense light (mounted on the outside of
the backbone) is reaching just in parts, indirectly, forwarded only
through the light-transporting ability of that artificial tissue. I
might have to make,maybe, a sketch, to give a better idea about the layout.
When we speak or even think about such things, we must not do this by
imaging the materials we are using today. I agree, the bigger an object,
the more fragile it is.
I personally believe, as our knowledge and skills expand steadily
through the decades and centuries (and millennia), we will have very
exotic and very stable materials in the future. Already today, we are
able to process and also to manipulate materials on the nano level, even
molecular.
For some of the space vessels of my Space Ark, to give an example, I
imagined an out material of industrially grown (or even 3D-printed)
diamond, with integrated circuits and sensors and all such, all grown on
a molecular level.
Same here: for such a hypothetical vast construction like this habitat
cylinder, the children of our children would use materials that overcome
the weaknesses of today's materials.
But beside: I am also stating clearly, that I believe, such habitat
cylinders will never be build. Before that happens, our progenies will
found ways to simulate gravity through something in the ship floors. The
attributes of matter are responsible for gravity. They will find ways,
as we always have found. I think, I even would take some bet on that.
I just render my own cylindrical habitat, because Mike Horvath's habitat
inspired me, I admit. :-)
My architects continued on our artificial light. See here the day
colors, the night, and the light colors in between. I made sure, the
evenings are full of beautiful colors.
But what about the morning light? At the moment, it is identical to our
sunset light. But in real life, ti is not. If you like, propose your own
colors for the morning light. For that purpose, I have attached my
self-developed POV-Ray color mixer. And below, see the existing Sunset code.
#declare LightSectionHalf = union
light_source { < 0.0, LightDistance, 0.0 > rgb < 1.00000, 0.98824,
0.88235 > * MyLightMultiplicator*25 spotlight point_at < 000.0, -1500.0,
0.0 > radius 10 tightness 10 falloff 20 rotate < 0.0, 0.0, 2.5 > }
0.88235 > * MyLightMultiplicator*25 spotlight point_at < 050.0, -1350.0,
0.88235 > * MyLightMultiplicator*25 spotlight point_at < 100.0, -0950.0,
0.88235 > * MyLightMultiplicator*25 spotlight point_at < 150.0, -0700.0,
0.88235 > * MyLightMultiplicator*18 spotlight point_at < 175.0, -0600.0,
0.0 > radius MyRadius tightness MyTightness falloff MyFalloff rotate <
0.0, 0.0, 5.0 > }
light_source { < 0.0, LightDistance, 0.0 > rgb < 1.00000, 0.88627,
0.50196 > * MyLightMultiplicator*15 spotlight point_at < 200.0, -0550.0,
0.0, 0.0, 7.5 > }
light_source { < 0.0, LightDistance, 0.0 > rgb < 1.00000, 0.69412,
0.28235 > * MyLightMultiplicator*12 spotlight point_at < 225.0, -0500.0,
0.0, 0.0, 10.0 > }
light_source { < 0.0, LightDistance, 0.0 > rgb < 0.99608, 0.35686,
0.08627 > * MyLightMultiplicator*09 spotlight point_at < 250.0, -0450.0,
0.0, 0.0, 12.5 > }
light_source { < 0.0, LightDistance, 0.0 > rgb < 0.76863, 0.27059,
0.05882 > * MyLightMultiplicator*06 spotlight point_at < 275.0, -0400.0,
0.0, 0.0, 15.0 > }
light_source { < 0.0, LightDistance, 0.0 > rgb < 0.54902, 0.10980,
0.10980 > * MyLightMultiplicator*04 spotlight point_at < 300.0, -0350.0,
0.0, 0.0, 17.5 > }
light_source { < 0.0, LightDistance, 0.0 > rgb < 0.43922, 0.09412,
0.16078 > * MyLightMultiplicator*02 spotlight point_at < 325.0, -0300.0,
0.0, 0.0, 20.0 > }
light_source { < 0.0, LightDistance, 0.0 > rgb < 0.31373, 0.07843,
0.14902 > * MyLightMultiplicator*00 spotlight point_at < 350.0, -0250.0,
0.0, 0.0, 22.5 > }
light_source { < 0.0, LightDistance, 0.0 > rgb < 0.15294, 0.04706,
0.10588 > * MyLightMultiplicator*00 spotlight point_at < 375.0, -0200.0,
0.0, 0.0, 25.0 > }
Download 'sl - colony ship i.png' (42 KB)
Download 'povcolors.exe.dat' (418 KB)
I didn't mean so much the substances used in the construction of the
habitat. Rather, that it's hard to keep a long cylinder from wobbling
out of control.
Mike
Yes, point taken. :-)
My landscapers seeded the habitat.
But for now, only pigments used, not yet any real texture.
Download 'sl - colony ship i.png' (54 KB)
Another view, taken from a location closer to the ground. I still have
to adjust the colors.
But I am wondering, if I should have a landscape with lakes in between
as it is now, or if I should have on the one end an "ocean" and from the
middle to the other end a landscape of hills, slowly raising towards the
end, where the ring-shaped town could be.
What do you think, would be most logical?
Download 'sl - colony ship i.png' (43 KB)
New view, close to the gently hilled ground, now with highest quality
and radiosity.
Still, I am thinking about a re-design of the landscape: on the one
cylinder's end a ring ocean, then gently rising hills, and on the other
cylinder's end a ring town. What do you think?
Download 'sl - colony ship i.png' (45 KB)
Am 08.02.2016 um 09:53 schrieb Sven Littkowski:
You should render the scene with radiosity, just to get an idea of how
much the sunny side will illuminate the dark side.
> and radiosity.
I've tried generating terrain textures in the past with unsatisfactory
results.
Mike
PLEASE PARTICIPATE
You see here the colors for the sunset part of the light. But what about
sunset light. But in real life, it is not.
If you like, propose your own colors for the morning light. For that
purpose, I have attached my self-developed POV-Ray color mixer. And
0.0, 0.0, 5.0 > }
0.0, 0.0, 7.5 > }
0.0, 0.0, 10.0 > }
0.0, 0.0, 12.5 > }
0.0, 0.0, 15.0 > }
0.0, 0.0, 17.5 > }
0.0, 0.0, 20.0 > }
0.0, 0.0, 22.5 > }
0.0, 0.0, 25.0 > }
Download 'sl - colony ship ib.png' (42 KB)
Preview of image 'sl - colony ship ib.png'
Here is the small Windows program I developed. It is a color picker for
POV-Ray. It is free, and please use it (if you like) for the sunrise
colors. Thanks for helping me.
Download 'povcolors.rar.dat' (174 KB)
At the moment, I am using around 2,000 light sources for my ship inside.
This is, to simulate a long stripe of light (5 km long) and with a white
inside and sunset colors to the side.
But I am considering to make the central cylinder along the middle axis
much thicker, and to put an .hdr image around it, emitting light. This
might MAYBE save me a lot of computing time.
Right now, I have to try to find out, how to create such an .hdr file.
The wise Internet will tell me...
Hmmm, maybe making an .hdr image is too difficult. Basically, what I
need is an image with a color flow from black through the sunrise colors
to white, and from white through the sunset colors to black. Then using
emission 1.0 or more. Maybe I can do this with a regular image, not
sure. Let's see.
Am 11.02.2016 um 22:28 schrieb Sven Littkowski:
I wouldn't expect that to speed up rendering; this would require the
first "bounce" of light to be computed via radiosity, which is primarily
designed for computing light coming from all around, but performs rather
poorly (read: exhibits artifacts unless you invest a lot of rendering
time) for light coming predominantly from a comparatively small region
of the surroundings.
My personal suggestion would be to use a long 1-dimensional area light
(or a number thereof) with area_illumination active, wrapped in a
filtering cylinder.
Am 11.02.2016 um 22:44 schrieb Sven Littkowski:
> sure. Let's see.
Why not simply use a patterned pigment? I think there is some pattern
that does the trick out of the box, but if not, a cylindrical warp
should get you there.
Yes, absolutely right. And that is, what I am going to do as a first try
(emission).
But I like your other suggestion (area light, area illuminated,
filtering cylinder), too, and want to have a look into it. Though I
don't understand wrapped things and such. But this is all about seeing
new ways, and learning them. :-)
Is it possible to create various light nuances (from bright white
daylight to sunset colors to night black) this way?
Improved Illumination
Our engineers have installed the new emission-based color_map system
which replaces the previously used 2,000 light sources. This has a vast
reduction in the light bill and a vast increase in render speed.
What's missing now, is the bluish atmosphere.
Download 'sl - colony ship i.png' (96 KB)
UPDATE
Habitat was filled with air.
Problem:
while it looks acceptably good on the daytime side, the sunset side
misses a lot of those colors, and the nighttime side is also wrong.
Please have a try on your own and help, if you got some ideas. Thanks.
Scene Code ---------------------------------------------------------
#version 3.7;
#include "macros.inc"
#include "shapes.inc"
#declare MyRadiosity = on; // on or off
#declare MediumRadiosity = on;
#declare FastRadiosity = off;
#declare CameraDaytime = on;
#declare CameraSunset = off; // Problem: doesn't look like sunset
#declare CameraNighttime = off; // Problem: doesn't look like sunset
#declare CameraOutside = off;
global_settings
#if(MyRadiosity)
radiosity
media on
pretrace_start 0.08
#if(FastRadiosity)
pretrace_end 0.015
#elseif(MediumRadiosity)
pretrace_end 0.008
#else
pretrace_end 0.001
count 400
error_bound 0.75
recursion_limit 1
adc_bailout 0.0039
ambient_light rgb < 1.000, 1.000, 1.000 >
assumed_gamma 1.000
irid_wavelength rgb < 0.250, 0.180, 0.140 >
max_trace_level 5
number_of_waves 10
noise_generator 3
charset ascii
#default { pigment { rgb 1.0 } finish { ambient 0.0 specular 1.0 } }
#if(CameraDaytime)
camera // Daytime Position Inside
location < 0.0, -1400.0, 100.0 >
look_at < 0.0, -1400.0, 200.0 >
right 1.77*x
#elseif(CameraSunset)
camera // Sunset Position Inside
location < 1400.0, 0.0, 100.0 >
look_at < 1400.0, 0.0, 200.0 >
right 1.77*x
#elseif(CameraNighttime)
camera // Nighttime Position Inside
location < 0.0, 1400.0, 100.0 >
look_at < 0.0, 1400.0, 200.0 >
right 1.77*x
#elseif(CameraOutside)
camera // Outside
location < -5000.0, 5000.0, -5000.0 >
look_at < 0.0, 0.0, 0.0 >
right 1.77*x
#declare Seed=seed(441);
#if(CameraOutside)
light_source
< -10000.0, 10000.0, 10000.0 >
color rgb < 1.0, 1.0, 1.0 >
#declare LightDistance = -253.1;
#declare LightWidth = 50.0;
#declare MyRadius = 5;
#declare MyTightness = 50;
#declare MyFalloff = 80;
#declare MyLightMultiplicator = 0.007;
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 000.0, -1500.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 050.0, -1350.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 100.0, -0950.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 150.0, -0700.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 175.0, -0600.0,
0.0, 0.0, 5.0 > }
0.50196 > * MyLightMultiplicator*05 spotlight point_at < 200.0, -0550.0,
0.0, 0.0, 7.5 > }
0.28235 > * MyLightMultiplicator*04 spotlight point_at < 225.0, -0500.0,
0.0, 0.0, 10.0 > }
0.08627 > * MyLightMultiplicator*04 spotlight point_at < 250.0, -0450.0,
0.0, 0.0, 12.5 > }
0.05882 > * MyLightMultiplicator*04 spotlight point_at < 275.0, -0400.0,
0.0, 0.0, 15.0 > }
0.10980 > * MyLightMultiplicator*03 spotlight point_at < 300.0, -0350.0,
0.0, 0.0, 17.5 > }
0.16078 > * MyLightMultiplicator*03 spotlight point_at < 325.0, -0300.0,
0.0, 0.0, 20.0 > }
0.14902 > * MyLightMultiplicator*02 spotlight point_at < 350.0, -0250.0,
0.0, 0.0, 22.5 > }
0.10588 > * MyLightMultiplicator*02 spotlight point_at < 375.0, -0200.0,
0.0, 0.0, 25.0 > }
#declare LightSection = union
object { LightSectionHalf scale < 1.0, 1.0, 1.0 > }
object { LightSectionHalf scale < -1.0, 1.0, 1.0 > }
#declare RundeLight = 50.0;
#while(RundeLight<4950.0)
object { LightSection translate < 0.0, 0.0, RundeLight > }
#declare RundeLight = RundeLight+50.0;
#macro
RoundCilinderSegment(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Bevel,BevelHeight,MaxLength)
#local Start=y*(StartHeight+Bevel);
#local Eind=y*(EindHeight-Bevel);
#local Start2=y*StartHeight;
#local Eind2=y*EindHeight;
#local StartHoek2=StartHoek+degrees(Bevel/Radius);
#local EindHoek2=EindHoek-degrees(Bevel/Radius);
#local TotaleLengte=radians(EindHoek-StartHoek)*(Radius+BevelHeight);
#local Aantal=max(int(TotaleLengte/MaxLength),1);
#local Tel=0;
mesh {
triangle {
vrotate(<Radius,StartHeight,0>,y*StartHoek),
vrotate(<Radius,EindHeight,0>,y*StartHoek),
vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*StartHoek2)
triangle {
vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*StartHoek2),
triangle {
vrotate(<Radius,EindHeight,0>,y*StartHoek2),
triangle {
vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*StartHoek2),
vrotate(<Radius,StartHeight,0>,y*StartHoek2)
triangle {
vrotate(<Radius,StartHeight,0>,y*EindHoek),
vrotate(<Radius,EindHeight,0>,y*EindHoek),
vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*EindHoek2)
triangle {
vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*EindHoek2),
triangle {
vrotate(<Radius,EindHeight,0>,y*EindHoek2),
triangle {
vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*EindHoek2),
vrotate(<Radius,StartHeight,0>,y*EindHoek2)
#while (Tel<Aantal)
#local H1=StartHoek2+(EindHoek2-StartHoek2)*(Tel/Aantal);
#local H2=StartHoek2+(EindHoek2-StartHoek2)*((Tel+1)/Aantal);
#local P1=vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*H1);
#local P2=vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*H1);
#local P3=vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*H2);
#local P4=vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*H2);
#local N1=vrotate(x,y*H1);
#local N2=vrotate(x,y*H2);
smooth_triangle {P1,N1,P2,N1,P4,N2}
smooth_triangle {P2,N1,P3,N2,P4,N2}
//triangle {P1,P2,P4}
//triangle {P2,P3,P4}
#local P2B=vrotate(<Radius,EindHeight,0>,y*H1);
#local P3B=vrotate(<Radius,EindHeight,0>,y*H2);
triangle {P2,P2B,P3}
triangle {P2B,P3B,P3}
#local P2B=vrotate(<Radius,StartHeight,0>,y*H2);
#local P3B=vrotate(<Radius,StartHeight,0>,y*H1);
triangle {P2B,P1,P3B}
triangle {P1,P4,P2B}
#local Tel=Tel+1;
#macro Verlaag(X)
#local R=X-(1+rand(Seed)*2.5);
R
#macro
CilinderGreeble(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Bevel,BevelHeight,MaxLength,Detail)
#local Start=(StartHeight+Bevel);
#local Eind=(EindHeight-Bevel);
#local StartH=StartHoek+degrees(Bevel/Radius);
#local EindH=EindHoek-degrees(Bevel/Radius);
//cilindertjes:
#local Aantal=rand(Seed)*Detail;
#while (Aantal>0)
#local Size=(Bevel*.01)+rand(Seed)*Bevel*.99*2;
#local Hoek=StartH+(EindH-StartH)*rand(Seed);
#local Hoogte=Start+(Eind-Start)*rand(Seed);
#local Depth=BevelHeight/2+rand(Seed)*BevelHeight/2;
superellipsoid {<1,.1+rand(Seed)*.3> rotate y*90 scale
<Depth,Size,Size> translate x*Radius rotate y*Hoek translate y*Hoogte}
#local Aantal=Aantal-1;
//vakjes:
#while (Aantal>0)
#local S=Start+(Eind-Start)*rand(Seed);
#local E=S+(Eind-S)*rand(Seed);
#local SH=StartH+(EindH-StartH)*rand(Seed);
#local EH=SH+(EindH-SH)*rand(Seed);
#local H=BevelHeight/2+rand(Seed)*BevelHeight/2;
RoundCilinderSegment(S,E,Radius,SH,EH,Bevel/2,H,AantalStapjes)
//verticale buisjes
#while (Aantal>0)
//#local EH=SH+(EindH-SH)*rand(Seed);
#local H=(BevelHeight/2+rand(Seed)*BevelHeight/2)/2;
//RoundCilinderSegment(S,E,Radius,SH,EH,Bevel/2,H,AantalStapjes)
cylinder {y*S,y*E,H translate x*Radius rotate y*SH}
sphere {y*S,H translate x*Radius rotate y*SH}
sphere {y*E,H translate x*Radius rotate y*SH}
//horizontale buisjes simuleren, toruskes zouden wsl te traag gaan
#while (Aantal>0)
#local H=min((Eind-S),H*2)/2;
#local E=S+H*2;
RoundCilinderSegment(S,E,Radius,SH,EH,H,H,AantalStapjes)
#macro
VerdeelCilinder(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Diepte,Bevel,BevelHeight)
#if (Diepte<0)
#ifndef(Detail) #local Detail=5; #end
#local H=rand(Seed)*BevelHeight;
#ifndef(MaxSegmentLength) #local AantalStapjes=Bevel; //(eigenlijk de
maximale lengte van een segment)
#else #local AantalStapjes= MaxSegmentLength; #end
RoundCilinderSegment(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Bevel,H,AantalStapjes)
CilinderGreeble(StartHeight,EindHeight,Radius+H,StartHoek,EindHoek,Bevel,H,AantalStapjes,Detail)
#else
// eerst es checken of 't nie onvoorstelbaar ongelijk verdeeld is:
#local Lengte=radians(EindHoek-StartHoek)*Radius;
#local Hoogte=EindHeight-StartHeight;
#local PercentageU=.5+(rand(Seed)-rand(Seed))*.5*.9;
#local PercentageV=.5+(rand(Seed)-rand(Seed))*.5*.9;
#local MidHeight=StartHeight+(EindHeight-StartHeight)*PercentageU;
#local MidHoek=StartHoek+(EindHoek-StartHoek)*PercentageV;
// als't 2 keer zo hoog als breed is (of nog hoger), dan ff enkel in
de hoogte bijsnijden:
#if ((Hoogte>(Lengte*2))&(rand(Seed)>.125))
VerdeelCilinder(StartHeight,MidHeight,Radius,StartHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(MidHeight,EindHeight,Radius,StartHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
// als't 2 keer lager dan breed is (of nog lager), dan ff enkel in de
breedte bijsnijden:
#else
#if (((Hoogte*2)<Lengte)&(rand(Seed)>.125))
VerdeelCilinder(StartHeight,EindHeight,Radius,StartHoek,MidHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(StartHeight,EindHeight,Radius,MidHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
#else
VerdeelCilinder(StartHeight,MidHeight,Radius,StartHoek,MidHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(MidHeight,EindHeight,Radius,StartHoek,MidHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(StartHeight,MidHeight,Radius,MidHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(MidHeight,EindHeight,Radius,MidHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
//#include "textures.inc"
#declare HabitatOutside = union
#declare Detail=5;
#declare MaxSegmentLength=.1;
VerdeelCilinder(-3,3,1,0,360,10,.002,.0075)
cylinder {-3*y,3*y,1}
//Metaal()
rotate < 90.0, 0.0, 0.0 >
translate < 0.0, 0.0, 3.0 >
scale < 1.0*1600.0, 1.0*1600.0, (1.0/6.0)*5200.0 >
translate < 0.0, 0.0, -100.0 >
#declare Backbone = union
#declare Detail=5;
//Metaal()
scale < 750.0, 750.0, (1.0/6.0)*5000.0 >
translate < 0.0, 0.0, 0.0 >
#declare MyLight = difference // Backbone Light
cylinder { < 0.0, 0.0, 0.0 > < 0.0, 0.0, 5000.0 > 760.0 }
box { < -760.1, 0.0, -0.1 > < 760.1, 760.1, 5000.1 > }
pigment
gradient x
color_map
[ 0.00 rgb < 0.00000, 0.00000, 0.00000 > * 1 ]
[ 0.05 rgb < 0.15294, 0.04706, 0.10588 > * 1 ]
[ 0.10 rgb < 0.31373, 0.07843, 0.14902 > * 1 ]
[ 0.30 rgb < 1.00000, 0.69412, 0.28235 > * 1 ]
[ 0.425 rgb < 1.00000, 0.98824, 0.88235 >* 2 ]
[ 0.575 rgb < 1.00000, 0.98824, 0.88235 >* 2 ]
[ 0.70 rgb < 1.00000, 0.69412, 0.28235 > * 1 ]
[ 0.90 rgb < 0.31373, 0.07843, 0.14902 > * 1 ]
[ 0.95 rgb < 0.15294, 0.04706, 0.10588 > * 1 ]
[ 1.00 rgb < 0.00000, 0.00000, 0.00000 > * 1 ]
translate < -0.5, 0.0, 0.0 >
scale < 1520.0, 1.0, 1.0 >
finish { emission 1.0 }
translate < 0.0, -10.0, 0.0 >
#declare MyAtmosphere = cylinder // Air
< 0.0, 0.0, 0.0 > < 0.0, 0.0, 5000.0 > 1500.0
pigment { rgbt < 1.0, 1.0, 1.0, 1.0 > }
hollow
interior
fade_colour < 0.4, 0.66, 0.9 >
fade_distance 5000.0
fade_power 1001
media
emission 0.0005
density
gradient y
density_map
[ 0.0 rgb < 0.5, 0.7, 1.0 > * 0.1 ]
[ 0.4 rgb < 0.5, 0.7, 1.0 > ]
[ 0.5 rgb < 0.5, 0.7, 1.0 > ]
[ 1.0 rgb < 0.0, 0.0, 0.0 > ]
translate < 0.0, -0.5, 0.0 >
scale < 3000.0, 3000.0, 1.0 >
// absorption 1000.0
/* scattering
1
< 0.5, 0.7, 1.0 >
extinction 1.0
#declare Fn_1 = function(x,y,z)
1-(-f_snoise3d(x*5,y*3,z*5)*0.8)
#declare TheLandscape = object
HF_Cylinder( Fn_1, // Function,
0, // UseUVheight: 0 or 1
1, // UseUVtexture: 0 or 1
<50,50>, // Resolution,
1, // Smooth: 0 or 1
"", // FileName, ""=no file,
<0,0,0>, // EndA,
<0,1.5,0>, // EndB
1.60 ,// Radius
0.05 // Depth
scale < 0.58, 0.67, 0.58 >
scale < 1500.0, 1500.0, 2500.0 >
#declare MyLandscape = union
object { TheLandscape scale < 1.0, 1.0, 1.0 > translate < 0.0, 0.0,
0000.0 > }
object { TheLandscape scale < 1.0, 1.0, -1.0 > translate < 0.0, 0.0,
5000.0 > }
pigment { rgb < 0.05, 0.25, 0.0 > }
finish { emission 0.0 }
#declare MyWaterLevel = 1440.0;
#declare fn_pattern = function
pattern { bozo scale 0.15 }
#declare fn_water = function
z - fn_pattern(x, y, 0)*0.25
#declare MyWater = difference // Water
cylinder { < 0.0, 0.0, 0.0 > < 0.0, 0.0, 5000.0 > 1500.0 }
cylinder { < 0.0, 0.0, -0.1 > < 0.0, 0.0, 5000.1 > MyWaterLevel }
material
texture
pigment { color rgbt < 0.2, 0.7, 0.3, 0.5 > }
finish
ambient 0.0
diffuse 0.0
emission 0.0
reflection
0.0, 1.0
falloff 5
fresnel on
specular 0.4
roughness 0.003
normal
function { f_ridged_mf(x, y, z, 0.1, 3.0, 7, 0.7, 0.7, 2) } 0.8
scale 0.13
interior
ior 1.3
fade_distance 10
fade_power 1001
fade_color < 0.8, 0.2, 0.2, 0.5 >
media
// absorption < 0.8, 0.6, 1.0, 0.5 >
scattering
3
< 0.5, 0.65, 0.4 >
extinction 1.0
normal
0.8
scale < 0.13, 0.4, 0.13 >
object { HabitatOutside hollow }
object { Backbone hollow }
object { MyLight }
object { MyAtmosphere }
object { MyLandscape }
object { MyWater }
Download 'sl - colony ship i.png' (106 KB)
On 12-2-2016 9:35, Sven Littkowski wrote:
> UPDATE
Your atmosphere and habitat boundaries are exactly overlapping, showing
unwanted artefacts. Make the atmosphere cylinder a tiny bit larger (or
smaller) than the habitat.
IIRC POV-ray has a limit of 128 light sources.
Mike
Am 12.02.2016 um 09:59 schrieb Mike Horvath:
IIRC you're wrong ;)
Am 12.02.2016 um 09:35 schrieb Sven Littkowski:
> UPDATE
> Problem:
As soon as you use media, you really need to use regular light sources.
Hi.
Do you mean the dark parts on the water surface? If so, this may been
caused by the waves.
Indeed, my air cylinder has the same side as the inner walls of the
habitat cylinder, but you cannot see those inner walls, as the landscape
cylinder and water cylinder are smaller and thus cover the habitat
cylinder inside walls all over.
Oh gosh. And an emitting long bar would be soooo good to simulate a long
fluorescent light source. Well, I will keep it for now this way. Who
knows, maybe some smart programmer will add such possibility (media
supporting emitting surfaces) to the next version of POV-Ray..? O:)
UPDATE
Just for now, see here a 10 meter wide four-lane road from just below
the middle axis construction, 100 m above the road, and 1.70m above the
road.
The hills range up to 100 m high.
I am not yet happy with the waves.
After that all has been fixed, I will start to work on the land texture.
Then there will be grass, and trees. Maybe some fields (though most of
the vegetables, fruits, and meat will be grown in vitro). Finally, then
I will work on the buildings.
Download 'sl - colony ship ic.png' (57 KB)
Download 'sl - colony ship id.png' (104 KB)
Download 'sl - colony ship i.png' (63 KB)
Preview of image 'sl - colony ship ic.png'
Preview of image 'sl - colony ship id.png'
On 2/12/2016 2:43 PM, Sven Littkowski wrote:
> UPDATE
I for one cannot see enough detail in your images to comment.
They are too small.
Incidently you really should quote, in your replies, who and what you
are replying to. IMO
Regards
Am 12.02.2016 um 15:37 schrieb Sven Littkowski:
Unlikely.
To UberPOV, maybe, as it would be a lot easier to implement in a
stochastic renderer.
Am 12.02.2016 um 19:26 schrieb Stephen:
I agree with Stephen; a good newsreader will present the thread as a
tree, but even then it is sometimes tedious to trace back what post
you're replying to. On the web interface it is virtually impossible, as
it just gives you a linear list of all the posts.
Is this wiki page wrong?
http://wiki.povray.org/content/Reference:Light_Source
Am 12.02.2016 um 20:13 schrieb Mike Horvath:
>>>> inside.
>>>> white
Yes (though I was, too):
- Yes, there is a hard limit to the number of light sources (which I
wasn't aware of).
- No, the limit is no longer 127(!) light sources as mentioned in the
wiki, but 1024.
Also, it may be interesting to note that the limit is only relevant if
you're using photons or media.
Couldn't it be possible to implement then a stochastic mode to POV-Ray,
so it can do the same things? But I admit, I am not sure what stochastic
means, will try to find out when I have a bit time. I just want to see
our great POV-Ray pushed to its limits (as some of its programmers)... :-D
Hmmm, will have to rethink my own position about that then. For my part,
I always dislike all that quoting. I thought I did a favor to you all
when I always deleted it. But okay, I can easily keep the quotations, no
problem. :-)
OMG! I will have to write this date in my diary. ;-)
Regards
Am 12.02.2016 um 21:07 schrieb Sven Littkowski:
Stochastic means using a lot of randomness, resulting in grainy noise
instead of other (sometimes less obvious) types of artifacts. Goes
pretty much against POV-Ray's philosophy of trying to get reproducible
non-grainy results, but is the weapon of choice in UberPOV (and as a
matter of fact one of the primary reasons I started the UberPOV project
in the first place).
Knowing about UberPov and some other versions, I really think, it would
be nicer not to split the POV-family into more and more children, but to
enable POV-Ray Original to have such modes and capabilities, too.
Imagine, you create a scene that uses the latest features of POV-Ray
3.7, but for one effect you need to use UberPov or another member of the
POV-Ray family, and can't because they are not fully compatible with
their understanding of the scene code because they don't support the
same features.
I personally don't care, if a scene of mine looks on each computer the
same, as long as it is approximately the same. If possible, I would like
such a stochastic mode on demand.
But this is a thread about my colony ship, so I don't want to torture
you with my personal POV-Ray wishes. :-)
> problem. :-)
It is **NOT** a favor!! Your missing context is EXTREMELY annoying! Especially due
to the
frequency of your posts.
-=- Larry -=-
PS. Short quotes only. Just enough to show the context.
The full copy of the previous post that many (lazy) people use is unnecessary and also
irritating.
(Except, as here, when the full text is short.) :-)
Yes, I was going to add this. Don't quote the whole article. You are
usually replying to a specific thought. If it's multiple thoughts,
embed your replies inline with the corresponding thought.
And top-posting is for weenies -- Put your reply at the bottom.
> problem. :-)
You weren't doing us any favors.
Deleting parts of quotes that are not relevant to your response is good
netiquette, but eliminating all the quotes in their entirety leaves the reader
with no context. When you post without quoting, frankly, I have no idea what
you're talking about. In a newsreader, we are forced to look up and down the
thread to see what you are referring to. In the Web interface, it is virtually
impossible.
Kenneth,
See here the image. The twisted real heightfield remains gray as the
original image is, and also does not show any heights. It is just like
an ordinary image texture wrapped along a cylinder.
I also include a down-sized version of the heightfield image (the
original is 10,000x10,000, this one is only 1,000x1,000)
Here's the code:
pigment
image_map { jpeg "Colony Ship I - Heightfield Landscape.jpg" once
interpolate 2 }
// this image needs to be pi-units wide by 1.0 tall, NOT square.
// You can use these two modifiers to 'reverse' the imagery, to see it
// correctly on the INSIDE. HOWEVER, this does not reverse the *depth* of
// the heightfield. The only way to do that (that I know of) is to invert
// the image_map's colors (in Photoshop, for example.)
//scale <-1,1,1>
//translate <1,0,0>
HF_Cylinder(function { Fn_1(x,y*1.7,z).gray }, // *Needs* the function
'wrapper' Fn_1
1, // UseUVheight: 0 or 1
// ON-- IMPORTANT
0, // UseUVtexture: 0 or 1
<int(100*pi),100>, // Resolution.
<0,0,0>, // EndA,
<0,1.7,0>, // EndB-- if this
y-value is different from 1.0,
// change the function's
y-value above to compensate.
0.5, // Radius. Keep this at
.5 for 1:1 reproduction of
// the image_map around
the circumference.
0.1 // Depth
0000.0 > }
5000.0 > }
On 14.02.2016 04:15, Kenneth wrote inside the BUGREPORTS section:
> That's odd. I DO see the green color, using just your code example.
Did you
> combine the 'MyLandscape' object with some other CSG and then apply
another
> different 'gray' texture?
> Yes, post an image there (at the IMAGES section).
Download 'sl - colony ship i.png' (29 KB)
Download 'colony ship i - heightfield landscape 1000px.jpg' (118 KB)
Preview of image 'colony ship i - heightfield landscape 1000px.jpg'
