POV-Ray : Newsgroups : povray.binaries.images : Colony ship Server Time
16 Oct 2026 01:18:03 EDT (-0400)
  Colony ship (Message 1 to 50 of 92)
Goto Latest 50 Messages Next 42 Messages >>>
Subject: Colony ship
Date: 5 Jan 2016 23:31:20
Message: <568c9898@news.povray.org>
I decided to dust off this old scene and work on a few more bits.
I finalized how the docking bay and engine are going to be laid out, and
I am happy with them.
I also split the habitation area into two counter-rotating sections. I'm
thinking of making the end caps concave, like the bottom of a soda can.
A note about the cone in front. It's supposed to be a mesh of copper or
gold wires that are electrically charged to keep dust from coming in
contact with the ship. Kind of the opposite of a solar sail. I need to
work on the wires a bit more to make them apparent.
Enjoy!
Mike
Download 'gh_scene_spinner_cutaway.png' (693 KB)
Preview of image 'gh_scene_spinner_cutaway.png'
Subject: Re: Colony ship
Date: 6 Jan 2016 09:03:22
Message: <568d1eaa$1@news.povray.org>
I don't know. I like the effect you have now.
Regards
Date: 6 Jan 2016 12:27:54
Message: <568d4e9a$1@news.povray.org>
Your project is promising, please continue with it and keep us updated. :-)
Date: 6 Jan 2016 13:50:01
Message: <568d61d9$1@news.povray.org>
Another thing I worry about is the weak spine of the ship. I need to
create struts around the circumference of the ship so the ship does not
break in half when applying thrust! Aircraft and spacecraft IRL tend not
to have spines, but rather a hollow frame.
Date: 6 Jan 2016 16:05:11
Message: <568d8187$1@news.povray.org>
> Enjoy!
> Mike
Given the size of that ship, the wires won't be individualy visible
unless they are very thick, like around 1m thick...
The part of the spine inside the living section is OK as it don't seem
to have a real structural function. But, going aft, it does indeed look
flimsy.
Date: 7 Jan 2016 05:25:37
Message: <568e3d21@news.povray.org>
Several changes.
Mike
Download 'gh_scene_spinner_cutaway_24.png' (643 KB)
Preview of image 'gh_scene_spinner_cutaway_24.png'
Date: 9 Jan 2016 18:38:57
Message: <56919a11@news.povray.org>
I decided to use an array of spheres for the spiral lamp light instead
of a single object since it's a lot easier to control.
I also tweaked the parabolic nose shield. I am very unhappy with the
texture however. It's supposed to simulate a wire mesh, not a solid
surface, but I don't think it's working. Here is the texture:
#declare thin_wire_material = material
	#switch (TexQual)
		#case (-1)
			texture {lowqual_pig(Seed)}
		#break
		#case (0)
			texture {pigment {gamma_color_adjust(<0.70, 0.25, 0.15, 0.00, 0.90>)}}
		#break
		#case (1)
		#case (2)
			// needs an interior too I think
			texture
				finish
				    ambient		0.15
				    brilliance	5
				    diffuse		0.6
				    metallic
				    specular	0.80
				    roughness	1/100
				    reflection	0.65
		#break
Download 'gh_scene_spinner_cutaway_27.png' (847 KB)
Preview of image 'gh_scene_spinner_cutaway_27.png'
Date: 9 Jan 2016 19:08:00
Message: <5691a0e0$1@news.povray.org>
Am 10.01.2016 um 00:38 schrieb Mike Horvath:
No that indeed doesn't work at all.
You'll want "micronormals", i.e. some "normal {...}" statement with a
pattern scaled so small that it is no longer visible in the image.
Ideally the structure of the pattern should match the structure of
whatever material you intend to simulate.
Make sure you don't get moiree effects from it though; anti-aliasing
might do the trick, otherwise I'd recommend using a tiny bit of focal
blur, or use UberPOV's anti-aliasing mode 3. Or you might just choose a
random pattern, which won't be as close to the real deal but will not
cause any moiree at all.
Speaking of UberPOV, if you go down that route another alternative would
be to just use highly blurred reflections.
Date: 9 Jan 2016 19:48:06
Message: <5691aa46@news.povray.org>
How would I create the pattern? The radial part is easy, but how do I
get the ribbed portion? Which function do I use?
f_paraboloid(x,y,z, P0)
Or something else?
Date: 9 Jan 2016 19:50:59
Message: <5691aaf3$1@news.povray.org>
I guess I should clarify that what you see in that last image is not a
texture, but a physical array of cylinders and tori. Replacing them with
a proper texture would make the scene render much faster as well.
Mike
Date: 9 Jan 2016 20:48:21
Message: <5691b865$1@news.povray.org>
Am 10.01.2016 um 01:51 schrieb Mike Horvath:
Ah, I guess we have a misunderstanding there. I thought you wanted the
semi-transparent paraboloid sheet to look more like a fine mesh, but now
my understanding is that it is the visible support structure of that
paraboloid that you want to look more like a mesh.
Well, my guess there is that it doesn't look like wires because they're
not really the size of wires, and also because the "longitudinal" and
"latitudinal" structures simply intersect. Maybe if they just touched
each other, possibly in an alternating "weaving" fashion, and maybe
connected with some "clamps", it might look better.
Also I wouldn't use copper. It's expensive, heavy, and you only need it
if there are high currents involved. Presuming the shield is primarily
based on static voltage, metals with higher resistance should work just
as fine.
Aluminum might make for a great alternative, too.
Date: 9 Jan 2016 22:50:56
Message: <5691d520$1@news.povray.org>
> as fine.
No, you were right. I want to make the paraboloid sheet to look like a
mesh. The solid ribs take too long to render.
I will also switch the material to look the same as the engine nozzle.
Mike
Date: 10 Jan 2016 00:15:35
Message: <5691e8f7@news.povray.org>
> as fine.
Here's the code I use for the paraboloid, by the way. Whatever i end up
doing, it has to match up with that.
#local glass_cone = difference
	object
		Paraboloid_Z
		scale nose_cone_radius
		translate -z * ext_glass_thick/2
	object
		Paraboloid_Z
		translate +z * ext_glass_thick/2
Date: 11 Jan 2016 17:49:42
Message: <56943186@news.povray.org>
> Enjoy!
> Mike
I changed the texture of the nose cone. I'm pretty happy with it. I
think I got all the things done on my checklist. I will put the project
back on the shelf until some later time when I come up with new ideas.
For now I am done.
Mike
Download 'gh_scene_spinner_cutaway_28_small.png' (1035 KB)
Preview of image 'gh_scene_spinner_cutaway_28_small.png'
Date: 11 Jan 2016 19:29:40
Message: <569448f4$1@news.povray.org>
> For now I am done.
> Mike
I created a youtube video showing how the model has changed over time.
https://www.youtube.com/watch?v=ajeZkwBuzIU
Enjoy!
Mike
Date: 12 Jan 2016 09:57:21
Message: <MPG.30fede481e62b2eb989697@news.povray.org>
In article <569448f4$1@news.povray.org>, mik### [at] gmailcom says...
> Enjoy!
Very cool.  I like the first generation where the solar panels circle
the ship, at 0:53.
Date: 12 Jan 2016 15:04:45
Message: <56955c5d$1@news.povray.org>
> Mike
I tried creating a texture, and while it does look good, it is actually
slower to render than creating the 3D cylindrical ribs.
Mike
Date: 13 Jan 2016 20:11:52
Message: <5696f5d8$1@news.povray.org>
>> Enjoy!
>> Mike
> For now I am done.
> Mike
Do the fuel tanks in back of the space craft appear too small? I was
aiming for nuclear propulsion, but might switch to something else.
Mike
Date: 16 Jan 2016 14:05:58
Message: <569a9496@news.povray.org>
Just got done rendering the attached image. It took 15 hours, and I
haven't even enabled finishes or interiors yet. :(
Mike
Download 'gh_scene_spinner_cutaway_e_method_c_14.45.17.png' (1088 KB)
Preview of image 'gh_scene_spinner_cutaway_e_method_c_14.45.17.png'
Date: 16 Jan 2016 14:35:19
Message: <569a9b77@news.povray.org>
> Mike
I have a rendering that racked about 800 times as much and is currently
just over 50% done...
Ok, it have multiple imbedded spheres and use blured reflection,
refraction, dispersion, photons, irid,...
I get a *LOT* of total internal reflections in those spheres.
Date: 16 Jan 2016 18:59:30
Message: <569ad962$1@news.povray.org>
>> Mike
I don't have the patience to wait *that* long. Maybe if I had a second
computer dedicated to POV-Ray. But I doubt it.
Mike
Date: 18 Jan 2016 20:48:36
Message: <569d95f4@news.povray.org>
Here's my latest (incomplete) render. However, I don't understand why
the planet in the background is so bright compared to the last render.
Can anyone explain this? Is it the area light causing this or the
reflections? I'm using the same area light as in the last render and I
don't understand why the planet appears to be extra lit. Thanks.
Mike
Download 'gh_spinner_test_02.png' (359 KB)
Preview of image 'gh_spinner_test_02.png'
Date: 18 Jan 2016 21:30:44
Message: <569d9fd4@news.povray.org>
The preview window may not accurately reflect what's in the image file.
  Strange but true.
Date: 19 Jan 2016 01:25:30
Message: <569dd6da$1@news.povray.org>
>   Strange but true.
None of the other objects in the scene appear brighter. It's just the
planet as seen through the window.
Mike
Date: 19 Jan 2016 11:08:19
Message: <569e5f73$1@news.povray.org>
Am 19.01.2016 um 02:48 schrieb Mike Horvath:
Did you make sure that the light properly falls off with distance?
Date: 19 Jan 2016 13:31:49
Message: <569e8115$1@news.povray.org>
No, I didn't. But wouldn't that be noticeable in both images? In the
previous image the planet looked okay. I am using the same light source
in both.
Mike
Date: 24 Jan 2016 19:17:35
Message: <56a5699f@news.povray.org>
Here's the latest render from inside the ship. Way too much glare! I
will explore ways to reduce the glare but I'm not sure what will be
effective.
Mike
Download 'gh_scene_spinner_cutaway_e_method_c_khdsf.png' (1354 KB)
Preview of image 'gh_scene_spinner_cutaway_e_method_c_khdsf.png'
Date: 24 Jan 2016 21:27:20
Message: <56a58808$1@news.povray.org>
What values would you recommend? It is a linear area light.
Mike
Date: 25 Jan 2016 04:01:46
Message: <56a5e47a$1@news.povray.org>
Nice inside landscaping. Shouldn't all building be of the same shape, in
regards to ensure all over the cylinder is the same mass distribution?
Otherwise, mass unbalance might cause problems while spinning. I don't
mean the shape of buildings from back to front, but beside each other.
Date: 25 Jan 2016 04:02:32
Message: <56a5e4a8$1@news.povray.org>
How did you make the trees? I could use that technology for some of my
scenes, too. :-)
Date: 25 Jan 2016 07:38:28
Message: <56a61744$1@news.povray.org>
> scenes, too. :-)
Looks like POV-Tree...
Date: 25 Jan 2016 07:44:08
Message: <56a61898$1@news.povray.org>
> scenes, too. :-)
Looks like POV-Tree:
http://web.archive.org/web/20071101052625/propro.ru/go/Wshop/povtree/download.html
Date: 25 Jan 2016 09:05:01
Message: <web.56a62b09ed6e77c8ad6fa18f0@news.povray.org>
Presuming the area light is supposed to simulate a structure somewhat akin to a
long cylinder, I would set fade_distance to the radius of that structure; to get
the proper behaviour along the length of the area light, I would suggest using
area_illumination.
For realism, fade_power should always be 2. Note that you may have to
significantly increase the light source's brightness.
Date: 25 Jan 2016 14:26:40
Message: <56a676f0$1@news.povray.org>
You just need the building to be similar across the axis. Side by side,
it don't mather.
Also, you can have a small building containing huigh mass cargo, and
large ones used by peoples that have about the same overall mass.
Finaly, there is probably a network of balast "underground" to help
balancing the whole thing.
Date: 25 Jan 2016 14:50:51
Message: <56a67c9b$1@news.povray.org>
I think the scene would look less interesting if the buildings are the
same. Anyway, if I were to make changes, I would go in the *other*
direction. I.e. make the scene look even *more* organic.
Mike
Date: 25 Jan 2016 14:52:28
Message: <56a67cfc$1@news.povray.org>
> area_illumination.
I experimented with fade_distance by setting it to the radius of the
lamp object, but it makes the scene too dark.
Good tip, thanks.
Mike
Date: 25 Jan 2016 14:57:19
Message: <56a67e1f$1@news.povray.org>
> scenes, too. :-)
It may be TomTree.
http://tkgate.sourcearchive.com/documentation/2.0~b8/TOMTREE_8inc-source.html
I don't recall for sure.
Mike
Date: 25 Jan 2016 15:25:00
Message: <web.56a6837ded6e77c8566b73360@news.povray.org>
> > area_illumination.
Multiply the light source's color by (1 + pow (D / R, 2)) / 2, where R is the
fade_distance, and D is the radius of the colony interior.
Date: 25 Jan 2016 17:10:51
Message: <56a69d6b$1@news.povray.org>
Question: Should the density of the gas in the habitat area be
significantly lower around the central axis than toward the outer edges
of the cylinder? Or is it safe to ignore such a gradient?
Mike
Date: 25 Jan 2016 17:18:04
Message: <56a69f1c$1@news.povray.org>
>>> area_illumination.
That worked, thank you!
Mike
Date: 25 Jan 2016 17:28:31
Message: <56a6a18f$1@news.povray.org>
I would say more than probably. On ships and semi-submersible oil rigs.
The balast has to be adjusted whenever the cargo changes.
Regards
Date: 25 Jan 2016 17:31:43
Message: <56a6a24f$1@news.povray.org>
Am 25.01.2016 um 23:11 schrieb Mike Horvath:
Given the comparatively small size of the habitat, it should be negligible.
Presuming both artificial gravitation and ground level air pressure to
be similar to conditions on Earth, you'd also get a somewhat similar
atmospheric density gradient. (It would even be less pronounced than on
Earth, as the artificial gravitation would fall off much faster with
increase in height above ground.)
Date: 26 Jan 2016 03:34:33
Message: <56a72f99$1@news.povray.org>
> effective.
> Mike
I forgot to add that this image took about a week to render. I just
turned on interior media and radiosity and it is rendering at 13ppm (and
will probably drop lower at certain spots). So I estimate it will take
between 1 and 2 months nonstop to fully render.
AMD A8-5600K Trinity Quad-Core 3.6GHz
Date: 26 Jan 2016 03:49:25
Message: <56a73315$1@news.povray.org>
Am 26.01.2016 um 09:34 schrieb Mike Horvath:
You might want to examine whether you're doing something wrong.
While high quality settings are an obvious factor in long renders,
another infamous but often underestimated performance hog is complex
non-union CSG.
Date: 26 Jan 2016 04:51:03
Message: <56a74187$1@news.povray.org>
> non-union CSG.
I added a lot of bounded_by statements to the city objects previously.
If you want to take a look for yourself, you can download the scene here:
http://www.mediafire.com/download/ccp3kv21k3oldvl/GH_LoadingScreen_src_v2_6_0.zip
The file to render is called "gh_scene_spinner_cutaway_e.pov".
Mike
Date: 26 Jan 2016 21:26:58
Message: <56a82af2$1@news.povray.org>
>> effective.
>> Mike
The render speed has actually improved to 75ppm. I am 17 hours into the
render and am at 8% completion of the 1280x720px image! Yay!
Mike
Date: 27 Jan 2016 06:29:31
Message: <56a8aa1b@news.povray.org>
Thanks! :-D
Date: 27 Jan 2016 06:32:49
Message: <56a8aae1$1@news.povray.org>
Same problem here. Just to render a part of the central hull of my
starship, it takes several days. I think, the problem is too many
individual shapes (like boxes and such).
I heard about a plugin for SketchUp, that can export to our POV-Ray
scene description language. As mesh.I am considering to design a number
of elements of my ship in Sketchup as meshes, and then add those meshes
to my POV-Ray scenes. I believe, I will gain render speed by replacing
hundreds of box with one single mesh shape. Could I be right with my
assumption?
Date: 27 Jan 2016 06:35:19
Message: <56a8ab77$1@news.povray.org>
And I am happily rendering my spaceship at 17PPM. If I would render the
entire spaceship, I would expect to watch the finished render image in
somewhere in the 6th millennium AD...
Date: 27 Jan 2016 07:39:03
Message: <56a8ba67$1@news.povray.org>
> assumption?
I have not used SketchUp for some time and was going to say that most of
the models looked very blocky and not very well textured. Then I
rememberd that in the early days of TC-RTC a member used SketchUp with
VRay. The models don't need to be blocky.
Have a look at:
http://www.tc-rtc.co.uk/image/upload//chandan/pw-1250429739-final3.jpg
and his other one
http://www.tc-rtc.co.uk/image/upload//chandan/pw-1245100893-Evidence_2.jpg
But if you are going to learn a new modeller why not give Blender a try?
I know it has a steep learning curve but it is not as bad as it was.
In both PovRay plugins* you can use PovCode for texturing.
* There is an official PovRay exporter and LanuHum's unofficial one.
Regards
