POV-Ray : Newsgroups : povray.binaries.images : Anamorphic images for mirrored cylinder. Server Time
25 Oct 2025 16:49:55 EDT (-0400)
  Anamorphic images for mirrored cylinder. (Message 1 to 5 of 5)
Subject: Anamorphic images for mirrored cylinder.
Date: 8 Dec 2015 16:43:48
Message: <56674f14@news.povray.org>
In answer to a question to povray.general yesterday on how to do this in
POV-Ray I worked up the following code to both create and visualize the
distorted image from any input image.
// POV-Ray code to render both result and distorted image
// I used png formatted square image. Camera00 renders
// both distorted image and its reflection off cylinder.
// Camera01 renders just the distorted image for the table
// top. Of course, endless variations possible.
#version 3.7;
global_settings {
     assumed_gamma 1
     ambient_light srgb <1,1,1>
#declare Grey50 = srgbft <0.5,0.5,0.5,0,0>;
#declare White = srgbft <1,1,1,0,0>;
background {
     color Grey50
   //color White   // Likely use this with Camera01
#declare Camera00 = camera {
     perspective
     location <1.2,1.2,-1.2>
     sky <0,1,0>
     angle 35
     right x*(image_width/image_height)
     look_at <0,0,0>
#declare Camera01 = camera {
     orthographic
     location <0,1,0>
     direction <0,-1,0>
     right x*(2)
     up <0,0,2>
#declare Light00 = light_source {
     <50,150,-250>, White
#declare Red = srgbft <1,0,0,0,0>;
#declare CylinderX = cylinder {
     <-1,0,0>, <1,0,0>, 0.01
     pigment { color Red }
#declare Green = srgbft <0,1,0,0,0>;
#declare CylinderY = cylinder {
     <0,-1,0>, <0,1,0>, 0.01
     pigment { color Green }
#declare Blue = srgbft <0,0,1,0,0>;
#declare CylinderZ = cylinder {
     <0,0,-1>, <0,0,1>, 0.01
     pigment { color Blue }
#declare CylinderM = cylinder {
     <0,0,0>, <0,0.5,0>, 0.1
#declare Cyan = srgbft <0,1,1,0,0>;
#declare CylinderB = cylinder {
     <0,-0.01,0>, <0,0,0>, 0.11
     pigment { color Cyan }
#declare Magenta = srgbft <1,0,1,0,0>;
#declare CylinderT = cylinder {
     <0,0.5,0>, <0,0.51,0>, 0.11
     pigment { color Magenta }
#declare BoxTableTop = box {
     <-1,-0.001,-1>,<1,0.001,1>
#declare Pigm = pigment {
     image_map { "example.png" once map_type 0 }
     rotate x*90
     translate <0,0,0.3>  // Moving image up some
     warp {
         cylindrical
         orientation z
#include "finish.inc"
#declare Ttabletop = texture {
     pigment { Pigm }
     finish { Luminous }
     scale 0.7            // Shrink partly due translate up
     scale <-1,1,-1>
     rotate y*45
#declare Tcylinder = texture {
     pigment { color White }
     finish { Mirror }
#declare ObjCylinder = object {
     object { CylinderM }
     texture { Tcylinder }
#declare ObjTableTop = object {
     object { BoxTableTop }
     texture { Ttabletop }
    camera { Camera00 }  // Use to see final result
// camera { Camera01 }  // Use to create distorted image.
light_source { Light00 }
    object { CylinderX } // Axis & cyl top bottom shapes as aids
    object { CylinderY } // Normally comment when using Camera01
    object { CylinderZ }
    object { CylinderB }
    object { CylinderT }
object { ObjCylinder }
object { ObjTableTop }
Bill P.
Download 'camera00.jpg' (93 KB) Download 'camera01.jpg' (63 KB)
Preview of image 'camera00.jpg'
Preview of image 'camera01.jpg'
Subject: Re: Anamorphic images for mirrored cylinder.
Date: 14 Dec 2015 05:50:58
Message: <566e9f12$1@news.povray.org>
William F Pokorny wrote on 08/12/2015 22.43:
> Bill P.
An interesting work! Anamorphic images are always fascinating.
Paolo
Date: 14 Dec 2015 07:24:45
Message: <566eb50d@news.povray.org>
Paolo reminds me that I forgot to thank you for this code. Fascinating,
and can become useful one day :-)
Date: 23 Apr 2019 14:10:05
Message: <web.5cbf54d89d797d254eec112d0@news.povray.org>
Is there a way to use this to "undo" the reflection of a normal scene in a
cylindrical surface?
So let's say there is a mirror-finish cylinder along axis y.
One renders an HDRI light probe surrounding it, and you see the reflection all
smooshed in the cylinder.
Can one now take this render (assuming this is all you have to start with, so
you have to start ab initio) and undistort the reflection in the cylinder to get
a clear look at what it's reflecting?
What's the best way to do this?
A user-defined camera looking at the image_map of the render?
A camera looking through the appropriate type of lens at the image_map of the
render?
Somehow just stretching the image_map out based on a function?
Date: 24 Apr 2019 10:05:00
Message: <web.5cc06c679d797d25968d6dc0@news.povray.org>
hi,
is the stuff discussed in the 'Skewness (long)' thread not solving the same (v
similar) problem?
http://news.povray.org/povray.advanced-users/thread/%3C5bb67852%40news.povray.org%3E/
(completely out of my depth.  :-))
regards, jr.
