POV-Ray : Newsgroups : povray.binaries.images : RSoCP by UberPOV Server Time
10 Oct 2026 18:26:35 EDT (-0400)
  RSoCP by UberPOV (Message 1 to 50 of 59)
Goto Latest 50 Messages Next 9 Messages >>>
Subject: RSoCP by UberPOV
Date: 25 Jun 2015 10:44:41
Message: <558c13d9@news.povray.org>
Following the discussion in povray.off-topic on Physically Based
Rendering (PBR)
http://news.povray.org/povray.off-topic/thread/%3Cop.x0kk32qvufxv4h%40xena%3E/
and the /rules/ given by Clipka, this is an RSoCP following the said
rules and rendered with UberPOV.
Scene file can be found in povray.binaries.scene-files.
Download 'rsocp_uber.png' (273 KB)
Preview of image 'rsocp_uber.png'
Subject: Re: RSoCP by UberPOV
Date: 25 Jun 2015 16:38:36
Message: <558c66cc$1@news.povray.org>
Am 25.06.2015 um 16:44 schrieb Thomas de Groot:
> Rendering (PBR)
I think you're doing /something/ wrong there.
Date: 25 Jun 2015 16:50:44
Message: <558c69a4$1@news.povray.org>
> Rendering (PBR)
Um... you're /not/ following the rules /at all/:
	sphere {
	  <0,0,0>, 1.00
	    pigment {srgb <0.8, 0.7, 0.7>*0.5 }
	    finish {
	      diffuse albedo 0.8
	      brilliance 3, 3
	      reflection {
	        0.0, 1.0
	        //roughness 0.001
	        //fresnel on
	        //metallic on
	      fresnel on
	      metallic on
	  interior { ior 1.5 }
	  scale <1,1,1>  rotate <0,0,0>  translate <0,1.35,0>
You're using "metallic on" in the entire finish block, but not in the
reflection block. That's bad bractice. /Very/ bad practice.
Also, "fresnel on" has no effect (or at least shouldn't have) when used
together with "metallic on". And as I'm already at it, always use
"fresnel on" in the reflection block when you use it in the entire
finish block. It doesn't carry through to the reflection automatically.
Furthermore, I'll probably need to add more rules:
- Do not use "diffuse" for metallic materials (or, more specifically,
use "diffuse 0.0" to override the non-zero default). Use specular
reflection with a very high roughness instead. To also add crisper
highlights to the mix, use complex textures.
Date: 26 Jun 2015 03:03:40
Message: <558cf94c$1@news.povray.org>
Why am I not surprised? ;-)
Date: 26 Jun 2015 03:40:59
Message: <558d020b@news.povray.org>
>> Rendering (PBR)
>      sphere {
>        <0,0,0>, 1.00
>        texture {
>          finish {
>            diffuse albedo 0.8
>            brilliance 3, 3
>            reflection {
>              0.0, 1.0
>              //roughness 0.001
>              //fresnel on
>              //metallic on
>            fresnel on
>            metallic on
Ah! Yes, I don't know why I switched it off. I had a reason initially
which I have forgotten now :-/
I had not paid enough attention to the (mutual) exclusion of fresnel and
metallic (RTFRules!). Forgot also to add conserve_energy.
Good one about diffuse and complex textures. My scene is simple because
I wanted to start from the 'basic scene' in the Insert Menu.
Four images are attached with variations in the parameter use (see their
corresponding titles).
sphere {
   <0,0,0>, 1.00
     finish {
       diffuse albedo 0.0
       specular albedo 0.5
       roughness 0.001
       brilliance 3, 3
       reflection {
         0.0, 1.0
         roughness 0.001
         fresnel on
         metallic off
       fresnel on
       metallic off
Download 'rsocp_uber_fresnel.png' (327 KB) Download 'rsocp_uber_fresnel+specular.png' (317 KB) Download 'rsocp_uber_metallic.png' (308 KB) Download 'rsocp_uber_metallic+specular.png' (316 KB)
Preview of image 'rsocp_uber_fresnel.png'
Preview of image 'rsocp_uber_fresnel+specular.png'
Preview of image 'rsocp_uber_metallic.png'
Preview of image 'rsocp_uber_metallic+specular.png'
Date: 26 Jun 2015 08:43:20
Message: <558d48e8$1@news.povray.org>
Am 26.06.2015 um 09:40 schrieb Thomas de Groot:
Don't worry, that's only relevant for transparent objects.
>        specular albedo 0.5
>        roughness 0.001
>        brilliance 3, 3
>        reflection {
>          0.0, 1.0
Now what did I say about the specular and reflection brightness settings?!
Use "specular albedo N" where N is the same as the maximum reflection.
That's what I said.
Need a hearing aid, hm? :P
Date: 26 Jun 2015 10:36:09
Message: <558d6359$1@news.povray.org>
>>        specular albedo 0.5
>>        roughness 0.001
>>        brilliance 3, 3
>>        reflection {
>>          0.0, 1.0
> That's what I said.
What did you say? I don't hear you! ;-)
The thing is, I read what you write and it just doesn't impact where it
should: "Use "specular albedo N" where N is the maximum reflection
intensity"; clear enough one should say, except for me of course.
Oh, well...
Date: 26 Jun 2015 11:33:55
Message: <558d70e3$1@news.povray.org>
Am 26.06.2015 um 16:36 schrieb Thomas de Groot:
>> settings?!
>> That's what I said.
> Oh, well...
I'm pondering adding a mode where POV-Ray will automatically issue a
warning whenever it finds inconsistencies in the settings.
I guess I'll start every such warning message with "Thomas, I told
you..." :P
Date: 27 Jun 2015 08:12:30
Message: <558e932e@news.povray.org>
>>> settings?!
>>> That's what I said.
>> Oh, well...
> you..." :P
Good idea! ;-)
I have a problem reading from screen. Reason I never use e-books for
example.
Date: 27 Jun 2015 10:19:06
Message: <558eb0da$1@news.povray.org>
Am 27.06.2015 um 14:12 schrieb Thomas de Groot:
>> you..." :P
> Good idea! ;-)
> example.
Then I'll have to make it an audible warning? :P
Date: 27 Jun 2015 10:42:01
Message: <558eb639$1@news.povray.org>
>        diffuse albedo 0.0
>        specular albedo 0.5
>        roughness 0.001
>        brilliance 3, 3
oh, btw, did I mention that brilliance has no effect if diffuse is set
to zero? :P
Date: 27 Jun 2015 11:18:00
Message: <558ebea8@news.povray.org>
>>        diffuse albedo 0.0
>>        specular albedo 0.5
>>        roughness 0.001
>>        brilliance 3, 3
> to zero? :P
By the bye. We love the way the documentation is being handled, live. ;-)
Regards
Date: 27 Jun 2015 19:32:38
Message: <558f3296@news.povray.org>
>>        diffuse albedo 0.0
>>        specular albedo 0.5
>>        roughness 0.001
>>        brilliance 3, 3
> to zero? :P
diffuse 0 mean that no light get diffused. brilliance controll how the
light get diffused. No light diffused = brilliance have no effect.
To me, it's self evident.
Date: 28 Jun 2015 02:58:10
Message: <558f9b02$1@news.povray.org>
>>> you..." :P
>> Good idea! ;-)
>> example.
That would be better; add sirens because I don't hear too well :-)
Date: 28 Jun 2015 03:02:07
Message: <558f9bef$1@news.povray.org>
>>        diffuse albedo 0.0
>>        specular albedo 0.5
>>        roughness 0.001
>>        brilliance 3, 3
> to zero? :P
As a matter of fact, you didn't.
I add it to the rules, as for somebody not familiar with physical
properties this is not evident.
Date: 28 Jun 2015 03:04:20
Message: <558f9c74$1@news.povray.org>
>>>        diffuse albedo 0.0
>>>        specular albedo 0.5
>>>        roughness 0.001
>>>        brilliance 3, 3
>> to zero? :P
Not to me. Like many, I am a moron were physical properties are
concerned, hence the need for comprehensive rules. ;-)
Date: 28 Jun 2015 03:08:07
Message: <558f9d57$1@news.povray.org>
>>>        diffuse albedo 0.0
>>>        specular albedo 0.5
>>>        roughness 0.001
>>>        brilliance 3, 3
>> to zero? :P
You mean like in a boxing ring? :-P
I think the documentation will get better as a result. I am compiling a
document from what Christoph is mumbling about; then I shall let him
read it and shall expect a bucket full of comments :-)
Date: 28 Jun 2015 06:22:36
Message: <558fcaec$1@news.povray.org>
>>>> you..." :P
>>> Good idea! ;-)
>>> example.
Blinking text?
Regards
Date: 28 Jun 2015 06:27:02
Message: <558fcbf6$1@news.povray.org>
No, like a dripping tap. One drop at a time. :-)
Is Jim Holsenback still looking after the documentation? I've not seen
him post for a while.
Regards
Date: 28 Jun 2015 13:35:30
Message: <55903062@news.povray.org>
On 06/28/2015 06:22 AM, Stephen wrote:
> Blinking text?
No, no, NO!  I will quit POV-Ray forever if Christoph does that!
Date: 28 Jun 2015 14:03:44
Message: <55903700$1@news.povray.org>
>> Blinking text?
Thank you, thank you. :-)
I could only dream of that response. ;-)
Regards
Date: 28 Jun 2015 17:53:02
Message: <55906cbe$1@news.povray.org>
>> Blinking text?
OK then. Make it blink for 5 seconds, then use a markee. ;P
Date: 29 Jun 2015 07:35:59
Message: <55912d9f@news.povray.org>
Right. This should be it I guess:
sphere {
   <0,0,0>, 1.00
     finish {
       diffuse albedo 0.5  //note: should be 0.0 when metallic on
       specular albedo 0.4
       roughness 0.001
       brilliance 3, 3
       reflection {
         0.0, 0.4
         roughness 0.001
         fresnel on
         metallic off
       fresnel on
       metallic off
       conserve_energy
   interior {ior 1.5}
   scale <1,1,1>  rotate <0,0,0>  translate <-1.35, 1.35, 0>
sphere {
   <0,0,0>, 1.00
     finish {
       diffuse albedo 0.0  //note: should be 0.0 when metallic on
       specular albedo 0.4
       roughness 0.001
       //brilliance 3, 3
       reflection {
         0.0, 0.4
         roughness 0.001
         fresnel off
         metallic on
       fresnel off
       metallic on
       conserve_energy
   interior {ior 1.5}
   scale <1,1,1>  rotate <0,0,0>  translate <1.35, 1.35, 0>
As I am still unsure about the looks_like object, in the case of a
/sun-like/ object, this is the code I used although, to tell the truth,
it could be left out in the present scene.
#declare SunPosition = <-3000, 3000, -3000>;
//apparent size of the Sun (courtesy Cousin Ricky)
#declare SunDis      = vlength(SunPosition)*2/215;
light_source {
     SunPosition
     color rgb <1, 1, 1>*10
     area_light
     SunDis*x, SunDis*z,
     5, 5
     adaptive 2
     jitter
     circular
     orient
     parallel
     point_at <0, 0, 0>
     looks_like {
       sphere {
         0, SunDis
         pigment {color rgb <1,1,1>*10000}
         //finish {emission 1}
         no_radiosity
         no_reflection
     //fade_power 2
     //fade_distance SunDis/2
     //area_illumination
Download 'rsocp_uber.png' (231 KB)
Date: 29 Jun 2015 09:07:20
Message: <55914308$1@news.povray.org>
Am 28.06.2015 um 23:53 schrieb Alain:
>>> Blinking text?
I'll use animated GIFs then. A *lot* of them. Mwahahahaha! }:>
Date: 29 Jun 2015 09:12:58
Message: <5591445a$1@news.povray.org>
Am 29.06.2015 um 13:35 schrieb Thomas de Groot:
Now look at that! I /love/ the material shown on the left!
Now you need to do something about the plane, because it /really/ breaks
the scene.
>      looks_like {
>        sphere {
>          0, SunDis
>          no_radiosity
>          no_reflection
With no_radiosity and no_reflection, it's pretty simple: If the sun is
directly visible in the image, use it. If it's only visible in
reflections, you're perfetly fine without the looks_like.
Date: 30 Jun 2015 02:59:20
Message: <55923e48$1@news.povray.org>
> the scene.
It does. Maybe I shall do that...
[snip]
You confirm my conclusion :-)
Date: 30 Jun 2015 08:06:57
Message: <55928661@news.povray.org>
>> the scene.
For instance this.
Download 'rsocp_uber.png' (378 KB)
Date: 30 Jun 2015 08:15:44
Message: <55928870$1@news.povray.org>
Am 30.06.2015 um 14:06 schrieb Thomas de Groot:
>>> the scene.
> For instance this.
Well, it's a bit of an improvement.
A bit.
Date: 30 Jun 2015 11:29:51
Message: <5592b5ef$1@news.povray.org>
On 6/30/2015 1:06 PM, Thomas de Groot wrote:
> For instance this.
Nice! Now replace the plane with a large torus. :-)
Regards
Date: 30 Jun 2015 12:09:18
Message: <5592bf2e$1@news.povray.org>
Am 30.06.2015 um 17:29 schrieb Stephen:
>> For instance this.
You're not planning to make Tom jump through a hoop, are you? ;)
Date: 30 Jun 2015 13:59:16
Message: <5592d8f4$1@news.povray.org>
>>> For instance this.
No, I just want a smiley face for a new logo. :)
Regards
Date: 1 Jul 2015 02:55:18
Message: <55938ed6@news.povray.org>
>>>> breaks
>>>> the scene.
>> For instance this.
> A bit.
Well, I am not going any further. It is going beyond my initial
experimental intentions and I prefer to turn to other things.
Date: 1 Jul 2015 07:05:01
Message: <web.5593c902f71020816c8c73900@news.povray.org>
> Thomas
It is good to see that you have improved your technique on this topic.
Date: 1 Jul 2015 07:15:52
Message: <5593cbe8$1@news.povray.org>
>> Thomas
Oh yes! Which does not mean I shall follow it strictly from now  on ;-)
I always give priority to artistic licence over real world properties.
Date: 1 Jul 2015 21:15:00
Message: <web.55948f69f7102081876de41a0@news.povray.org>
> >> Thomas
> Thomas
Hmm, I agree that it is not necessary always following it.
Date: 2 Jul 2015 02:59:39
Message: <5594e15b$1@news.povray.org>
>>>> Thomas
>> Thomas
I consider ray-tracing like painting: it is a medium for (artistic)
expression regardless of its life-like possibilities. It also means
however that one needs to know the rules in order to be able to break
them ;-)
Date: 2 Jul 2015 10:00:00
Message: <web.55953ffff7102081876de41a0@news.povray.org>
> >>>> Thomas
> >> Thomas
> them ;-)
> Thomas
Sometimes I have the same idea, but it is come to me that even you don't express
it by a realism lighting, you still do something modeling, arrangement, ... in
an usually framework that express a life-like observation.
There are some other drawing style truly. For me, it is important to have the
ability of rendering realism first.
Date: 2 Jul 2015 10:30:00
Message: <web.55954a73f7102081876de41a0@news.povray.org>
These are some 'other style' pictures I ever enjoyed and downloaded:
http://yurinoboke.blogspot.tw/2011/01/hourou-musuko-wandering-son-episode-1.html
https://desingersinspiration.wordpress.com/tag/pascal-campion/
http://mclelun.deviantart.com/art/football-field-422808127
Date: 2 Jul 2015 11:19:53
Message: <55955699$1@news.povray.org>
>>>>>> Thomas
>>>> Thomas
>> them ;-)
>> Thomas
I think that you are trying to define art. :-)
If you like art. Don't let that become your only goal. If you know what
I mean. :-)
Regards
Date: 3 Jul 2015 03:24:24
Message: <559638a8$1@news.povray.org>
Indeed. I like this style too.
I have less affinity with this I'm afraid.
I am rather traditional in my preferences, as far as realism is concerned:
http://www.abcgallery.com/R/repin/repin.html
http://www.janmankes.nl/
http://www.helmantel.nl/
just to mention a few. Alternatively, I like abstract painting very much ;-)
Date: 3 Jul 2015 07:05:44
Message: <55966c88$1@news.povray.org>
And not to forget photography, like:
http://www.alexandredeschaumes.com/
Date: 3 Jul 2015 08:45:01
Message: <web.55968361f7102081876de41a0@news.povray.org>
> >> them ;-)
> >> Thomas
> I mean. :-)
> Regards
>      Stephen
Hm, thank you. I'm exploring it. And I would like to know what is my feeling
about art.
Date: 3 Jul 2015 13:55:01
Message: <web.5596cbbcf7102081876de41a0@news.povray.org>
I feel that this author deals with so many emotions, thus he\she can bring a
purely sweet style for us.
It's ok. I don't think so much.
This makes me recall the art class at high school.
> Thomas
Thanks for the sharing.
Date: 3 Jul 2015 15:08:15
Message: <5596dd9f$1@news.povray.org>
> And I would like to know what is my feeling about art.
That takes a while and then it changes. ;-)
Regards
Date: 4 Jul 2015 03:03:19
Message: <55978537$1@news.povray.org>
> about art.
Follow your instinct. If you don't like something, leave it for a while
but come back to it later; if you like something, leave it and turn to
something less familiar, more disturbing. To use a hype term: keep out
of your comfort zone.
Date: 4 Jul 2015 03:19:16
Message: <559788f4$1@news.povray.org>
The main problem I have with this though, is that it can drown in pure,
sugar sweet, sentimentalism.
Date: 4 Jul 2015 12:17:20
Message: <55980710$1@news.povray.org>
>> bring a
But to do it with Raytracing?
Regards
Date: 5 Jul 2015 02:45:00
Message: <web.5598d17ff7102081540e59270@news.povray.org>
> Regards
>      Stephen
Uh - huh..
Date: 5 Jul 2015 02:55:01
Message: <web.5598d4aaf7102081540e59270@news.povray.org>
> > about art.
> Thomas
Maybe I will think about it.
Date: 5 Jul 2015 03:00:01
Message: <web.5598d5caf7102081540e59270@news.povray.org>
> Thomas
I like the sweet..^^"
