Time for a little wip.
Following this thread:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.52c1498885bcdecd90cbcd420@news.povray.org%3E/
I let myself be inspired by the photograph by Bill's daughter and the
engraving by MC Escher.
Height_field entirely based on a GIMP image; Red Oak leaves scanned from
RL in the neighbourhood.
The challenge for me is now to get the positioning of the leaves better
in relation to the height_field and - where overlapping - with each
other. Not sure yet how I am going to solve that...
Download 'puddle_02.jpg' (227 KB)
Preview of image 'puddle_02.jpg'
> Thomas
Hi Thomas,
what Kind of object are the leaves? The sand is an height_field I understood,
are the leaves meshes or height_fields too? A possible way may be to convert the
height_fields into meshes. Most likely you must modify the macros be Rune
(shapes.inc) to meet your needs. IIRC the meshes can be converted to OBJ with
PoseRay. Then the dressing room in Poser may help. Just a silly idea, never done
this before. But I would give it a try. I know you have all this resources.
Best regards,
Michael
On 23-12-2014 20:59, MichaelJF wrote:
> Hi Thomas,
The leaves are meshes (Silo uvmapped>>obj>>Poseray>>mesh2). The problem
is not there. It is in the fact that ideally I need several trace()
points per leave and choose the highest for its position, then - if
necessary - reposition the leaf according to the other points.
Especially where tracks are present, height differences are substantial
within a small circle.
Looks great!
> Thomas
Looks good so far, if you are trying to be more like the Escher image I think a
brighter sky and less ripples on the water are required the ground/sand looks
really great though.
I agree that the leaves are probably the weakest part of the image currently
especially where they overlap the ground.
Sean
Thanks Sean. No, I do not want an 'Escher' ;-) I just draw my
inspiration from different sectors. However, the sky could certainly be
brighter and is on my todo list. Concerning the ripples, I looked at the
photograph and thought that 'shivering' aspect of the water really neat.
I will need to scale down the effect still more however.
The leaves are a challenge and not trivial. I am working on a solution
using two trace points per leaf (for a start) and see how it goes. I
need also to concern myself with the collision aspect. I shall dig
through my collection of third party code as I remember a couple of
examples from the past.
On 24-12-2014 16:29, jhu wrote:
> Looks great!
Thanks!
> Thomas
Nice start, and happy Christmas.
Lionel
<b>Do not judge my words, judge my actions.</b>
Ce courrier électronique ne contient aucun virus ou logiciel malveillant parce que la
protection avast! Antivirus est active.
http://www.avast.com
Better but still not perfect. The control of the leaf orientation is
tricky especially were there are sudden jumps in the height_field. For
trace() I use a more basic/smooth height_field and calculate the
orientation from two points but still the transformations are not equal
for all leaves.
Download 'puddle_03.jpg' (176 KB)
Preview of image 'puddle_03.jpg'
Another variation (better?).
Download 'puddle_04.jpg' (238 KB)
Preview of image 'puddle_04.jpg'
That's looking really good, Thomas.
I think that having some of the leaves partially covered in water or sand adds a
degree of realism, especially since the tire tracks imply disturbed ground.
Have you thought about placing your leaves like a tripod, using a 3-point
orientation method? That might help get them to lay correctly.
> for all leaves.
> Thomas
For the few leaves that still intersect with the ground, it looks
somewhat like there are holes/breakages in them, whitch is normal and
add some credibility.
Thank you indeed.
Yes, that was also my judgement :-)
Out of laziness I must confess I did not use three point, only two and I
agree that I should do that. In addition to a few other things that is
going to be my next step.
Indeed. I am not too concerned about them presently. Still, I shall seek
some improvements.
Now, with a couple of additions, the meaning of the scene completely
changes.
Download 'puddle_06.jpg' (226 KB)
Preview of image 'puddle_06.jpg'
> changes.
Clever idea & neatly done! I'll have to let my daughter know her puddle
snapshot has led to another Pov-Ray image. :-)
Bill P.
