POV-Ray : Newsgroups : povray.binaries.images : Silentium. A last (?) final Server Time
22 Nov 2026 11:43:09 EST (-0500)
  Silentium. A last (?) final (Message 1 to 27 of 27)
Subject: Silentium. A last (?) final
Date: 23 Sep 2014 04:01:01
Message: <542128bd@news.povray.org>
Never being satisfied, I made some last changes: I added an extra
pigment_pattern normal to the tiled floor /and/ I rendered with
stochastic antialiasing (render time: 9.5 hours). I believe this subtly
improved the scene.
Now I have a question for Clipka!
*Why* is the light source moved when rendered with UberPOV???? See the
small cut-out from a render with POV-Ray 3.7 and compare. Also the
fountain is more lighted using UberPOV...
Using /exactly/ the same scene code.
Download 'silentium_final2.jpg' (259 KB) Download 'silentium_partial.png' (111 KB)
Preview of image 'silentium_final2.jpg'
Preview of image 'silentium_partial.png'
Subject: Re: Silentium. A last (?) final
Date: 23 Sep 2014 04:22:46
Message: <54212dd6$1@news.povray.org>
> improved the scene.
I like this one very much.
Regards
Date: 23 Sep 2014 07:10:40
Message: <54215530@news.povray.org>
Am 23.09.2014 10:00, schrieb Thomas de Groot:
Frankly, I don't have the slightest idea. (*)
You mind posting the relevant portions of the scene? (light source, plus
either the architecture or some information about the dimension thereof?)
(* Well, that's not entirely true; my best bet would be that you're
using area lights and that my stochastic area light handling code is
buggy; but that would most likely cause a sideways offset of the light
source. To me the difference in the images looks more like the light
source is closer to the origin - or as if the POV-Ray 3.7 version used a
parallel light source where the UberPOV version used a point light source.)
Date: 23 Sep 2014 08:00:03
Message: <542160c3$1@news.povray.org>
Am 23.09.2014 13:10, schrieb clipka:
Well, now I do have some that's far from slight; see this thread:
news://news.povray.org:119/web.54214e42b2c0e8b8b6820d7a0@news.povray.org
If you examine the shadows in your scene closely, it hits you like a
hammer (well, at least that's how it hit me): The light source hasn't
budged an inch - it's the shadows of your pillars, arches and ledges
that have vanished /entirely/!
Oh bugger.
Could you do me a favor and post the respective material definitions?
Thanks a lot!
Date: 23 Sep 2014 08:14:48
Message: <54216438$1@news.povray.org>
No area light is used here (I have it available but is not used in this
scene). Light info is:
#declare Sun_alt 			  = 50;
#declare Sun_azm 			  = -80;
#include "CIE.inc"
#declare SunColor     = Blackbody(6500)*2;
#declare SunPosition  = <0, 0, -2>*10e4;
#declare SunPosition  = vrotate(SunPosition, <Sun_alt, Sun_azm, 0>);
   light_source {
     <0, 0, 0>
     color rgb SunColor
     translate SunPosition
     parallel
     point_at <0, 0, 0>
I am trying to get a simplified version of the cloister (only bounding
boxes from Poseray) and put it here as soon as I have made it work...
Date: 23 Sep 2014 10:21:03
Message: <542181cf@news.povray.org>
> Oh bugger.
> Thanks a lot!
Oh gosh, yes, it is a shadow vanishing trick indeed!
I attach the material file of the building. Note that a few elements
have been subjected to a proximity pattern. I shall test if /those/
render differently; if so, you will get them too but I think that will
not be necessary.
Download 'cloister_pievedicadore_pov_mat.inc.txt' (33 KB)
Date: 23 Sep 2014 10:43:40
Message: <5421871c$1@news.povray.org>
> improved the scene.
> Thomas
Well done, you have made some very good jobs actually. I want also to
thank and congratulate you for your reeds_in_the_winds files, very
useful and realistic.
Lionel
Do not judge my words, judge my actions.
Ce courrier électronique ne contient aucun virus ou logiciel malveillant parce que la
protection avast! Antivirus est active.
http://www.avast.com
Date: 23 Sep 2014 10:44:59
Message: <5421876b@news.povray.org>
> not be necessary.
Well, I can now say definitively that the culprits are the elements that
have gone through the proximity pattern mill. However, the strange thing
is that the shadow of the window sill on the first floor also vanishes
although no element with a proximity pattern is present there.
So the problem might be slightly different from what you were fearing.
Info:
- I used Edouard Poor's Proximity Pattern macro.
- You may have them one way or another, but I attach Edouard's files, as
I use them, to be sure.
- The arcs, columns, and the fountain are processed.
- I attach de .df3 and .prox files of these elements.
I think you have everything necessary to test. If not, yell.
Download 'arcs.df3.dat' (82 KB) Download 'windows-1252' (1 KB) Download 'columns.df3.dat' (83 KB) Download 'windows-1252' (1 KB) Download 'fountain.df3.dat' (79 KB) Download 'windows-1252' (1 KB) Download 'windows-1252' (15 KB) Download 'windows-1252' (13 KB)
Date: 23 Sep 2014 10:47:35
Message: <54218807$1@news.povray.org>
Thank you indeed. The pleasure is mine :-)
As far as the reeds are concerned, I guess there are possibilities for
improvement. This is about what I can do, others may come up with some
smart solutions.
Date: 23 Sep 2014 13:54:46
Message: <5421b3e6$1@news.povray.org>
Am 23.09.2014 16:44, schrieb Thomas de Groot:
>> not be necessary.
Can you help me with identifying those textures?
Well, what /was/ I "fearing" then? ;-)
I have no doubt that the Prox Pattern macros are perfectly fine. I
presume that they just happen to make use of a language construct that's
broken, which may also be used in (and therefore affect) other materials.
Say, do the vanished non-proxed objects perchance also make use of a
texture_map?
Date: 24 Sep 2014 03:57:24
Message: <54227964$1@news.povray.org>
Yes of course.
Good point indeed :-)
> texture_map?
I need to plunge into this and see how the textures are built and are
affected. I'll be back.
Date: 24 Sep 2014 08:36:34
Message: <5422bad2$1@news.povray.org>
> texture_map?
Right. This is what I found:
- The proximity pattern textures have the following build-up with
pigment_pattern and a texture_map:
     pigment_pattern {
       average
       pigment_map {
         #if( proximity_pattern_strength != 0 )
           [ proximity_pattern_strength*3 df3_pattern scale 1/texture_scale]
         #if( slope_pattern_strength != 0 )
           [ slope_pattern_strength*0.6 slope { y altitude <0,1,0> }
color_map { [0 rgb 1] [1 rgb 0] } scale 140 * 1/texture_scale ]
         #if( noise_pattern_strength != 0 )
           [ noise_pattern_strength *0.4 bozo color_map { [0 rgb 0] [1
rgb 1] } scale 4 * noise_scale ]
           [ noise_pattern_strength *0.3 bozo color_map { [0 rgb 0] [1
rgb 1] } scale 1 * noise_scale]
           [ noise_pattern_strength *0.2 bozo color_map { [0 rgb 0] [1
rgb 1] } scale 0.33 * noise_scale ]
           [ noise_pattern_strength *0.1 bozo color_map { [0 rgb 0] [1
rgb 1] } scale 0.1 * noise_scale ]
     texture_map { map }
     scale texture_scale
- Consequently, in my image, the fountain, the columns, the arcs, and
the combined ridges, window sills, window arcs, are missing (part of)
their shadows.
- As far as I can tell, all other elements have rendered correctly.
Date: 24 Sep 2014 10:41:46
Message: <5422d82a$1@news.povray.org>
I do too. Especially the subtle graininess left by the stochastic
antialiasing is something I appreciate.
Date: 24 Sep 2014 10:49:37
Message: <5422da01@news.povray.org>
A pointillist version ;-)
I added a tiny transparency to the image_maps involved in the proximity
patterns and that proved to be a good workaround. Thanks Christoph.
Tomorrow I shall render a better final version.
Download 'silentium.png' (1064 KB)
Preview of image 'silentium.png'
Date: 24 Sep 2014 11:02:00
Message: <5422dce8$1@news.povray.org>
> Thomas
This I really like.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 24 Sep 2014 11:34:35
Message: <5422e48b$1@news.povray.org>
>> Thomas
> This I really like.
The graininess adds to the atmosphere.
@Clipka would it be feasible to add a feature to UberPov so that it
takes a snapshot at different stages to see the progress of the render?
It is just a thought as an animation of the building of the picture
might be interesting to see.
Regards
Date: 24 Sep 2014 11:49:08
Message: <5422e7f4$1@news.povray.org>
Am 24.09.2014 17:34, schrieb Stephen:
Such a feature is on my to-do list (has always been, actually), but I'm
waiting for some other changes to happen in POV-Ray proper that will
make it a whole lot easier.
Date: 24 Sep 2014 12:03:27
Message: <5422eb4f$1@news.povray.org>
Excellent!
Regards
Date: 24 Sep 2014 12:56:34
Message: <5422f7c2$1@news.povray.org>
Am 24.09.2014 18:03, schrieb Stephen:
> Excellent!
Did I ever mention that whatever features MCPov has (*) is also on the
to-do list for UberPOV? ;-)
(* uh, wait... MCPov is based on MegaPOV, isn't it? Well, I won't be
able to add all /that/ to UberPOV... not in the one-man show UberPOV
currently is.)
Date: 24 Sep 2014 13:24:48
Message: <5422fe60$1@news.povray.org>
No.
> currently is.)
Do we change the name to UnterPov? ;-)
Or UnterMcPov Hoots!
I've never really used these unofficial versions as I need a modeller.
And neither Moray nor Bishop3D supported them. You are making be
re-evaluate that. Especially considering the way Blender is being developed.
Regards
Date: 24 Sep 2014 13:25:57
Message: <5422fea5$1@news.povray.org>
> currently is.)
And neither Moray nor Bishop3D supported them. You are making me
developed.
Regards
Date: 24 Sep 2014 17:41:45
Message: <54233a99$1@news.povray.org>
Am 24.09.2014 19:25, schrieb Stephen:
> developed.
That's one more design goal of UberPOV: Make it as simple as possible to
make use of the added features from a classic POV-Ray scene.
Date: 25 Sep 2014 00:40:00
Message: <web.54239c9e9e51df15d19b0ec40@news.povray.org>
> Regards
>      Stephen
It's not too difficult. Just model, export to Povray, and then edit the Povray
code to your liking.
Date: 25 Sep 2014 03:21:12
Message: <5423c268$1@news.povray.org>
May I assume that the shadow-dropping issue has been circumscribed
enough for you to find a vaccine?
Date: 25 Sep 2014 03:24:26
Message: <5423c32a$1@news.povray.org>
>> Regards
>>       Stephen
Yes you can and you can use workarounds in the modellers to export hand
written code so that there is less need to edit in Pov.
I am more interested in animations so I generally do not want the long
render times that these quality features take. And I am lazy, I still
use code that Thomas created for Moray for a lot of my materials as a
starting point. So there has not been any point, for me up to now. But I
find the graininess of these images very attractive.
The other point is that Blender is alive and being developed while Moray
and Bishop3D are not. Also the direction that the official Blender
PovRay exporter and LanuHum’s is exciting. His images of how he is
working on the reed stalks looks comparable to what you would do in
Poser, if you could do it.
Regards
Date: 25 Sep 2014 13:42:54
Message: <5424541e$1@news.povray.org>
Am 25.09.2014 09:20, schrieb Thomas de Groot:
It has, indeed. I'll need to do some vivisecting and microscoping, but I
can do that with lab rats - no need for further examination of cases in
the wild.
Date: 1 Oct 2014 04:30:52
Message: <542bbbbc$1@news.povray.org>
Thomas de Groot wrote on 24/09/2014 16.48:
> Thomas
A very particular effect!
Paolo
