POV-Ray : Newsgroups : povray.binaries.images : Proof of concept: The wind in the reeds Server Time
22 Nov 2026 11:43:10 EST (-0500)
  Proof of concept: The wind in the reeds (Message 1 to 42 of 42)
Subject: Proof of concept: The wind in the reeds
Date: 16 Sep 2014 10:24:28
Message: <5418481c@news.povray.org>
Well, I am interested in modelling wind patterns over a reed field, or a
corn field. What I seem to observe are turbulent wave patterns moving
the stalks back and forward while going over the field.
This is a first approximation. I am not really satisfied yet with the
pattern. What I did is:
1) Make an image_map with a more or less turbulent ripple pattern.
2) Make a height_field based on that image_map.
3) Build a reed stalk with Inverse Kinematic properties (macro with Bend
parameter).
4) Select random locations on the height_field;
4a) calculate the vertical angle between the normal at that location and
a horizontal plane (using: VAngleD(V1,V2));
4b) calculate the horizontal angle between (arbitrarily) the +z-axis
direction (direction of primary bending of the reed stalks) and the
normal of the random location point (using: VRotationD(V1,V2,axis)).
5a) bend the stalk with a proportion of the vertical angle (4a);
5b) orient the bended stalk by rotating through the horizontal angle (4b);
5c) place the reed stalks at the random locations on a flat surface.
The image shows 15000 reed stalks. About 4.5 minutes render time.
suggestions are more than welcome of course.
Download 'hf_pattern_testing.png' (574 KB)
Preview of image 'hf_pattern_testing.png'
Subject: Re: Proof of concept: The wind in the reeds
Date: 16 Sep 2014 12:10:00
Message: <web.541860c7efc765425e7df57c0@news.povray.org>
> the stalks back and forward....
> I am not really satisfied yet with the pattern.
I think the back part might be why you don't like it.
I don't think the wind would make them curve in opposing directions like that.
I'd say that maybe rather than "height", you use the image map as a force-map.
Better yet would be to use the ripple pattern as "real wind" and translate the
infinite pattern through the stationary reed field.
I'm not sharp enough at the moment to suggest exactly how to do that.
maybe grayscale eval_pigment?
Only bend the reed between 0 and the maximum wind deflection.
     Maybe in the advanced version let them spring back less than zero with an
initial absence of wind, with some sort of rapid decay back to zero.
Introduce a random rotation or sideways bend, in the event you'll at some point
animate this.
Very nice so far.  I haven't yet tried my hand with any of the plant macros or
plotting a gazillion objects.
(I'll post my tc-rtc WIP on TINA-CHeP soon...)
>What I did is:
> parameter).
See above.
Use the magnitude of the ripple pattern to directly increase the BEND
Use some arbitrarily determined vector as your (wind) directional vector.
That way you can have it increase and decrease, and change directions like real
wind does, again with an eye toward possible future animation.
> Thomas
Date: 16 Sep 2014 12:55:01
Message: <web.54186a78efc7654299fcef4c0@news.povray.org>
> parameter).
> Thomas
Unfortunatelly I'm not familiar with the macros you use. But your stalks seems
to form a parting, like with hair, close to the right third. The most stalks to
the left of this point are bended to the left the others to the right. So I
wonder about the direction of the wind. I would propose a more simple approach
here. Bend them all in the same direction (with a slight random deviation, due
to the differences in the individual strenght of the stalks). May be you can
model the ground level too, having deeper stalks more straight and bend higher
ones more since they are more influenced by the wind.
Only some short thoughts about the matter,
Best regards,
Micahel
Date: 16 Sep 2014 14:39:53
Message: <541883f9$1@news.povray.org>
Am 16.09.2014 16:24, schrieb Thomas de Groot:
Looks quite promising for a start.
Sure.
It seems to me that you're bending any given reed with a constant radius
along the whole length of the stalk; I suspect that the stalk should
bend most strongly at the base, because of (a) the wind acting not only
on the tip of the stalk, but also on lower portions, so that the wind
force affecting the bending of any given point increases downward along
the stalk, (b) the stalk acting as a lever, further amplifying the
bending force exerted on any given point on the stalk based on how far
it is from the tip, and (c) the wind force acting upon a near-vertical
portion of the stalk being stronger than that acting upon a
near-horizontal portion.
The reeds should bend in a single direction only (albeit at different
amplitudes) - the primary direction of the wind.
As for the waves, I guess they are not from turbulences already present
in the wind, but rather from upright reeds "shadowing" those further
downwind causing them to rise again, while themselves being exposed to
the wind and beginning to move downward; this effect might be initiated
and amplified by the individual reeds also resonating in the wind due to
(c).
Date: 16 Sep 2014 22:15:10
Message: <5418eeae$1@news.povray.org>
> Sure.
> (c).
In a field, the wind can't affect the stalks near the base because the
other stalks up wind will shield those downwind. So, the wind only
affect the top part as soon as you are a few meters from the wind facing
edge.
The stalks tend to be slightly broader near the base, making them stiffer.
In most cases, there is some sort of flowering or grapes of seeds near
the top, increasing the surface exposed to wind and adding some height
neat the tips.
This combine in making the stalks bend in a smooth way with the maximum
curvature somewhere near mid height.
Date: 16 Sep 2014 23:25:01
Message: <web.5418fe3eefc765425e7df57c0@news.povray.org>
> the stalk,
I would say that it decreases as you approach the ground.  See Alain's comments,
although I would say that the maximum force/curvature would be near the top.
There is the shielding effect, the tapering effect, the higher surface area due
to flowering, and also the laminar flow issues.
> it is from the tip
True, but it's all to easy to "reason in reverse" and come up with exactly the
opposite conclusion.   Can't tell you how many times I've done that.  :\
?  Not sure what you meant by that.
True, but often there is some asymmetry to the stalk - they might be elliptic in
cross-section, and sometimes IIRC they are almost tear-shaped, with a thin rigid
rib at the thinnest portion.  Depending upon the orientation of that and the
direction of the wind, that could give rise to a twisting effect.
I suppose searching for some IRL video would be in order.
> (c).
I'm not quite sure exactly what the waves are a result of, but anyone who's done
and has studied long-range ballistics knows that wind speed and direction can be
all over the place between you and what you're looking at 400 yards away.
What's going on where you are, what's going on at where you're looking, and
what's going on at various places in between can vary and even be in complete
opposition.
Consider a tornado, where on one side the air is moving North, and on the other
side it's moving South.  Ditto East & West.
The same kind of thing can happen in vertical strata as well.
I think Thomas needs funding to study the issue....    ;)
Date: 17 Sep 2014 03:52:30
Message: <54193dbe@news.povray.org>
That back bending is simply unrealistic. Just changing the bending
direction already improves things. What I did was add 180 degrees to all
negative rotations.
Thanks for all the suggestions.
@ Bald Eagle: I do indeed use the image_map as a kind of force map,
through the height_field stage and then using the properties of the
normals. Basically, I think that is identical to what you suggest? The
rate of bending is proportional to the normal: pointing upward => no
bending; increased bending with increasing normal angle towards the
horizontal.
@ MichaelJF: Yes, that parting was killing the effect and came from my
concept of rebounding of the stalks. In any case, this was far to strong
here. I presently dropped this effect for the time being.
@ clipka: the bending angle is uniform over the whole length as a first
approximation. In reality, I expect bending to increase towards the top,
due to the different effects already mentioned by Alain and Bald Eagle.
Most important in my view are the thickness/rigidity of the stalks
towards the base and the damping effect of surrounding stalks. The
former is easy to implement, the latter is more difficult, especially if
one also wants to consider collision effects. At present, I do not know
how to tread that path.
Something I still believe not right is the wave length of the effect. I
think it should be larger.
Also note in the present image that all stalks start from the same
initial orientation/scale. I need to introduce more randomness /and/ add
different types of stalks.
Download 'hf_pattern_testing.png' (576 KB)
Date: 17 Sep 2014 05:35:33
Message: <541955e5@news.povray.org>
Thomas de Groot wrote on 16/09/2014 16.24:
It looks promising and somehow organic (why it remembers me the seaweed
salad?).
A nice technique,
Paolo
Date: 17 Sep 2014 07:30:45
Message: <541970e5@news.povray.org>
Thanks Paolo.
As a bonus, this image with randomisation of scale and initial vertical
rotation. Also, bending diminishes downwards.
Download 'hf_pattern_testing.png' (449 KB)
Date: 17 Sep 2014 11:54:55
Message: <5419aecf$1@news.povray.org>
Am 17.09.2014 13:30, schrieb Thomas de Groot:
> Thanks Paolo.
I concede that it looks good this way.
Date: 17 Sep 2014 16:35:01
Message: <web.5419f038efc7654280290e640@news.povray.org>
> negative rotations.
> horizontal.
> Thomas
Looks very much better in my eyes. In fact I'm working on a somewhat similiar
issue at the moment. That is why I came up with suggestions to control the
bending and length of the straws depending on the position (and the normal
provided by the trace()-command). I'm trying to give a certain model a special
hair-style. (Stephen will recognize the source of my inspiration most likely.) I
admit, there is room to improvement...
Best regards,
Michael
Download 'mudmaid_veryfirstwip.jpg' (11 KB)
Preview of image 'mudmaid_veryfirstwip.jpg'
Date: 17 Sep 2014 19:42:36
Message: <541a1c6c$1@news.povray.org>
Hi(gh)!
On 17.09.2014 13:30, Thomas de Groot wrote:
> Thanks Paolo.
> Thomas
And they do not intersect each other? That in fact would be stunning!
See you in Khyberspace!
Yadgar
Now playing: Hearts (Jon Anderson)
Date: 18 Sep 2014 01:30:00
Message: <web.541a6ce7efc7654257a8c4650@news.povray.org>
> parameter).
> Thomas
Wow, like a painting.
What are the povray objects you use?
Date: 18 Sep 2014 03:25:57
Message: <541a8905@news.povray.org>
Ah yes, I can see the similarities indeed. Interesting hair model!
There is great potential in using the normal. In my case length control
does not make really sense, derived from the normal - except if I were
using /another/ image_map for controlling reed height in determined
areas; evalpig would be my friend in that case.
Date: 18 Sep 2014 03:28:40
Message: <541a89a8@news.povray.org>
Alas! There is no collision control available. However, intersections
are probably only visible to the really discerning eye ;-)
Date: 18 Sep 2014 03:34:11
Message: <541a8af3@news.povray.org>
Thanks. Mesh2 objects, modelled in Silo. This one still has a couple of
small issues that need correction. When finished, I shall upload
everything to p.b.s-f.
Date: 18 Sep 2014 04:10:00
Message: <web.541a9306efc7654234a6c6f50@news.povray.org>
Hi Thomas,
This is looking really great, I pobably am missing some step but how exactly can
you bend a mesh2 object in pov?
Thanks
Sean
Date: 18 Sep 2014 07:27:15
Message: <541ac193$1@news.povray.org>
On 18-9-2014 10:08, s.day wrote:
> Hi Thomas,
I shall upload the model soon, when I have finished some corrections.
In the mean time, you need to build the model following inverse
kinematic principles. This means that the model subdivided in discrete
elements and articulated at their juncture, but not in a haphazardly
way. Here follows the construction of the reed stalk as I use it. You
can already study its inner workings:
#macro Reed(Bend)
//random rotation for the whole stalk:
#local Rot = RRand(-180, 180, R);
//construction of the Inverse kinematic stalk:
#local Bend1 = Bend+((2*Bend)/10);
#local Plume =
union {
   object {ReedMesh_03_ik_Reed01_plume_ material{Reed01_plume_} hollow
translate -10.40*y rotate Rot*y rotate Bend1*x translate (10.40-10.18)*y }
   object {ReedMesh_03_ik_Reed01_11_  material{Reed01_11_} hollow
translate -10.18*y rotate Rot*y}
#local Bend2 = Bend+(Bend/10);
#local Top =
union {
   object {Plume rotate Bend2*x translate (10.18-9.86)*y}
   object {ReedMesh_03_ik_Reed01_10_  material{Reed01_10_} hollow
translate -9.86*y rotate Rot*y}
#local Stem9 =
union {
   object {Top rotate Bend*x translate (9.86-9.54)*y}
   object{ReedMesh_03_ik_Reed01_9_  material{Reed01_9_} hollow translate
-9.54*y rotate Rot*y}
#local Bend = Bend-(Bend/20);
#local Stem8 =
union {
   object {Stem9 rotate Bend*x translate (9.54-9.165)*y}
   object{ReedMesh_03_ik_Reed01_8_  material{Reed01_8_} hollow translate
-9.165*y rotate Rot*y}
#local Stem7 =
union {
   object {Stem8 rotate Bend*x translate (9.165-8.79)*y}
   object{ReedMesh_03_ik_Reed01_7_  material{Reed01_7_} hollow translate
-8.79*y rotate Rot*y}
#local Stem6 =
union {
   object {Stem7 rotate Bend*x translate (8.79-7.72)*y}
   object{ReedMesh_03_ik_Reed01_6_  material{Reed01_6_} hollow translate
-7.72*y rotate Rot*y}
#local Stem5 =
union {
   object {Stem6 rotate Bend*x translate (7.72-6.20)*y}
   object{ReedMesh_03_ik_Reed01_5_  material{Reed01_5_} hollow translate
-6.20*y rotate Rot*y}
#local Stem4 =
union {
   object {Stem5 rotate Bend*x translate (6.20-4.65)*y}
   object{ReedMesh_03_ik_Reed01_4_  material{Reed01_4_} hollow translate
-4.65*y rotate Rot*y}
#local Stem3 =
union {
   object {Stem4 rotate Bend*x translate (4.65-3.10)*y}
   object{ReedMesh_03_ik_Reed01_3_  material{Reed01_3_} hollow translate
-3.10*y rotate Rot*y}
#local Stem2 =
union {
   object {Stem3 rotate Bend*x translate (3.10-1.55)*y}
   object{ReedMesh_03_ik_Reed01_2_  material{Reed01_2_} hollow translate
-1.55*y rotate Rot*y}
#declare ReedMesh_03 =
union {
   object {Stem2 rotate Bend*x translate 1.55*y}
   object{ReedMesh_03_ik_Reed01_1_  material{Reed01_1_} hollow rotate Rot*y}
#end  //macro
As you can see, the construction starts at the top of the stalk and
gradually incorporates adjacent elements until the base is reached. Note
that /only/ rotations can be used as transformations inside the IK
model. All other transformations must be applied to the /complete/ model
or not at all. Note also that /all/ internal rotations of the model are
applied *at the origin*.
Date: 18 Sep 2014 17:05:00
Message: <web.541b48eaefc7654234a6c6f50@news.povray.org>
Thanks Thomas,
I hadn't thought about having separate sections, I thought you were somehow
bending the acutal mesh (doh!).
Sean
Date: 19 Sep 2014 08:19:18
Message: <541c1f46@news.povray.org>
I have attached my code and the used reed stalk, in p.b.s-f.
Explore and enjoy!
Download 'wind_pattern.png' (662 KB)
Preview of image 'wind_pattern.png'
Date: 20 Sep 2014 13:55:01
Message: <web.541dbeafefc7654267e7dca90@news.povray.org>
"s.day" <s.d### [at] uelacuk> wrote:
> Hi Thomas,
> Thanks
> Sean
If you have a proper inside vector you can bend mesh2 objects with the approach
by Chris Colefax. In this case, mesh2 objects can be handled like other CSG
objects (spheres, boxes and so on). I have done this with my snails
(http://www.tc-rtc.co.uk/imagenewdisplay/stills/index345.html) which consists of
a mesh2 object and a blob with thousands of components. In fact I did not
understood Chris's parameters and wrote an own approach, but very similiar to
Chris, since I judged it easier to implement it by myself than to understand his
parametrisations.
@Thomas: The Mud Maid at the "Lost Gardens of Heligan" (I spend my holydays this
year very close to this garden) is a sculpture consisting of mud, clay, cement,
gras, ivy and moss and she is laying at the left side of her body to the ground,
so no much grass at the left side if standing;-)
Best regards,
Michael
Date: 21 Sep 2014 03:21:36
Message: <541e7c80$1@news.povray.org>
> parametrisations.
Not sure, but I think that /bending/ an object will be much slower to
render, especially if there are 15000 of them ;-)
Ah yes, the Lost Gardens! I unfortunately missed those when I stayed in
Penzance many years ago. Only much later I heard about them. I hope
/your/ Mud Maid will make it here or perhaps at the TC-RTC.
Date: 21 Sep 2014 15:45:00
Message: <web.541f29e7efc76542181323a20@news.povray.org>
Yes, indeed, the rendering time is heavily increased with this approach. The
only option to reduce it a little bit is to give proper bounding boxes
(bounded_by) since bounding with csg-differences or -intersections are not
implemented as one would expect in POV. But I think this would be a very hard
job, and so I can understand, that this issue has not been addressed so far.
> Thomas
I really hope that this WIP will make it to the contest. At the moment I have no
idea to link my imagined image to the topic. May be the Men-An-Tol as a stargate
at the background, just to keep it cornish.
Best regards,
Michael
Date: 22 Sep 2014 03:19:37
Message: <541fcd89$1@news.povray.org>
Thomas de Groot wrote on 19/09/2014 14.18:
> Explore and enjoy!
> Thomas
This one is very credible! It needs only some animals, now.
Are you starting a new image for the POV-Ray Hall of Fame?
Paolo
Date: 22 Sep 2014 03:29:20
Message: <541fcfd0$1@news.povray.org>
> Paolo
Thanks Paolo, I am quite satisfied too :-) But it is far from HoF
quality and I guess my work in general generally falls short of that
too. It is not my aim (as if it were me to decide ;-) )
Date: 22 Sep 2014 04:30:45
Message: <541FDE25.1020807@gmail.com>
> Explore and enjoy!
> Thomas
Much better than my attempt of (my god, i'm getting old) seven years
ago. I didn't dare to choose a close camera point at the time.
(The image is of course an illustarion of the glycocalyx, although I
don't expect many of you are familiar with that. It is the layer of long
proteins on the inside of bloodvessels that for a sort of gel and
protect the bloodcells from colliding with the walls.)
Everytime the IT department forbids something that a researcher deems
necessary for her work there will be another hole in the firewall.
Download 'glycowcalyx.jpg' (564 KB)
Preview of image 'glycowcalyx.jpg'
Date: 22 Sep 2014 06:15:31
Message: <541ff6c3$1@news.povray.org>
>> Explore and enjoy!
>> Thomas
LOL
Well done.
Friesian cows I assume. But why?
Regards
Date: 22 Sep 2014 07:19:02
Message: <542005a6@news.povray.org>
>> Explore and enjoy!
>> Thomas
Oh! I remember that one! A humoristic approach to Waterland indeed. ;-)
Date: 22 Sep 2014 07:19:40
Message: <542005cc$1@news.povray.org>
On 22-9-2014 12:15, Stephen wrote:
> LOL
> Well done.
Why not? ;-)
Date: 22 Sep 2014 08:11:13
Message: <542011D4.1080606@gmail.com>
>>> Explore and enjoy!
>>> Thomas
> LOL
> Well done.
to emphasize that the scene in the glass container is in fact microscopic.
Date: 22 Sep 2014 09:45:47
Message: <5420280b@news.povray.org>
>> LOL
>> Well done.
> Why not? ;-)
Why not indeed?
Do you take a proprietorial interest?
Regards
Date: 22 Sep 2014 09:55:07
Message: <54202a3b$1@news.povray.org>
On 22/09/2014 13:11, andrel wrote:
>> LOL
>> Well done.
Ah! of course I get it now.
The spelling of glycocalyx is a pointer as well, I believe.
I really like that image. It tickles my fancy.
Regards
Date: 22 Sep 2014 10:29:49
Message: <5420325d$1@news.povray.org>
On 22-9-2014 15:45, Stephen wrote:
> Why not indeed?
LOL
Oh no, not at all!
What I find so fascinating in this image is its play with micro- and
macroscopic, where the two worlds indeed are able to merge perfectly. As
I see it, the islands with cows are an exact representation of a certain
landscape in NL: Waterland, North of Amsterdam, and at the same time the
waterways are the microscopic representations of blood vessels. Very
smart indeed.
Date: 22 Sep 2014 10:48:59
Message: <542036db$1@news.povray.org>
Am 22.09.2014 16:29, schrieb Thomas de Groot:
> smart indeed.
I particularly like the rubber boat blood cells :-)
Date: 22 Sep 2014 11:42:40
Message: <54204370$1@news.povray.org>
> smart indeed.
Deeply symbolic with a touch of surrealism. An good to look at too.
+1010
Regards
Date: 22 Sep 2014 11:44:02
Message: <542043c2$1@news.povray.org>
"And" I need a new k/board.
Regards
Date: 22 Sep 2014 22:20:01
Message: <web.5420d81defc76542d19b0ec40@news.povray.org>
> Explore and enjoy!
> Thomas
That looks really nice. Water could use some work though.
Date: 23 Sep 2014 02:59:32
Message: <54211a54$1@news.povray.org>
Water has never been the subject of this proof of concept :-D
Date: 23 Sep 2014 03:29:28
Message: <54210538.1050106@gmail.com>
>> smart indeed.
> +1010
Thanks, a friend of mine was working on the glococalyx. I know the area
around Waterland well, because I am living close by. So when I connected
the two, I just had to make this image.
Possibly one of the last original images I made. After that I did things
with POV but mainly variations on a theme. I suffered from a sever case
of real life. I should have more time now (for reasons that are
off-topic), so hopefully I get some more inspiration. OTOH even without
a job my time seems completely filled.
Date: 23 Sep 2014 03:43:26
Message: <5421087D.4060301@gmail.com>
>> Why not indeed?
> LOL
> Oh no, not at all!
Thanks
> As I see it, the islands with cows are an exact representation of a certain
indeed that is the area I was refering to
> Very smart indeed.
Thanks again and sorry for hijacking your thread.
Date: 23 Sep 2014 03:51:18
Message: <54212676$1@news.povray.org>
You are welcome. Should happen more often :-)
Date: 2 Oct 2014 10:36:01
Message: <542d62d1@news.povray.org>
You inspired me to follow your steps, especially as I have problems
exporting hair from Poser: program crash as soon as lines are exported
in an .obj format file.
I intend to develop this a bit further of course. In red: the skullcap.
Download 'hairplanting_test.png' (264 KB)
Preview of image 'hairplanting_test.png'
