POV-Ray : Newsgroups : povray.binaries.images : unexplained Server Time
10 Oct 2026 20:46:44 EDT (-0400)
  unexplained (Message 1 to 50 of 58)
Goto Latest 50 Messages Next 8 Messages >>>
Subject: unexplained
Date: 12 Aug 2014 11:07:26
Message: <53ea2dae@news.povray.org>
I've been using Sams "Odd Tiles Object' include (get it in
p.b.scene-files) forever and just noticed a problem. The 1st image shows
the problem ... 2nd image is how is supposed to look.
Builds from the latest uber beta, /and/ povray master branches on github
have the problem, povray 3.7 stable (github) and perforce repository are
ok fine.
Download 'otoc1.png' (305 KB) Download 'otoc2.png' (315 KB)
Preview of image 'otoc1.png'
Preview of image 'otoc2.png'
Subject: Re: unexplained
Date: 12 Aug 2014 12:40:18
Message: <53ea4372@news.povray.org>
Am 12.08.2014 17:06, schrieb James Holsenback:
Is that the "OTOc.inc" 3rd version?
> ok fine.
The Sam's test scene (OTOTest.pov) renders fine here with the latest
POV-Ray and UberPOV stuff (Windows versions).
Download 'ototest.png' (300 KB)
Preview of image 'ototest.png'
Date: 12 Aug 2014 13:01:45
Message: <53ea4879$1@news.povray.org>
that's what the file header says ...
>> ok fine.
here's what I'm doing:
#declare Floor =
union {
	object {
		OTO( <-2.5,-2.5,0>, <2.5,2.5,1>, 0.075, texture { BaseTexture scale 1 } )
	box { <-2.5,-2.5,0.075>, <2.5,2.5,0.075> pigment { srgb 1 } finish
{diffuse 0.6 specular 0.15 roughness 1e-5} }
	rotate x*90
	rotate y*0
kind of funny that it works with some versions (perforce/git 3.7 stable)
but not other git repos ... 32 vs 64 bit? compiler?? configure changes???
Date: 12 Aug 2014 13:09:50
Message: <53ea4a5e@news.povray.org>
>>> ok fine.
> #declare Floor =
> union {
>      object {
> scale 1 } )
>      rotate x*90
>      rotate y*0
found OTOTest.pov file laying around in some obscure corner ... here's
results
Download 'ototest.png' (1072 KB)
Date: 12 Aug 2014 13:24:42
Message: <53ea4dda@news.povray.org>
Am 12.08.2014 19:01, schrieb James Holsenback:
> #declare Floor =
> union {
>      object {
> scale 1 } )
>      rotate x*90
>      rotate y*0
With 3.7.1-alpha.7681813 compiled straight from the GitHub code, the
above scene snippet (with standard OTO_Object) gives me this:
Download 'ototest2.png' (13 KB)
Preview of image 'ototest2.png'
Date: 12 Aug 2014 13:34:42
Message: <53ea5032$1@news.povray.org>
>> #declare Floor =
>> union {
>>      object {
>> scale 1 } )
>>      rotate x*90
>>      rotate y*0
I stayed out of my local git repos as I've made some changes ... Instead
downloaded the zip package made available from povray github with the
master filter selected, it has this hash
ad6d545729bbd92800fc2d65fe74dcac86408c27 and has the problem. With
3.7-stable filter set, this hash
39ce8a24e50651904010dda15872d63be15d7c37 tis ok fine
Date: 12 Aug 2014 13:41:18
Message: <53ea51be@news.povray.org>
Am 12.08.2014 19:08, schrieb James Holsenback:
> results
Well, what can I say, other than "I can't reproduce it"?
Unless you can trim down the thing to an extremely minimalistic scene
(say, one or two primitives with one or two textures) that is rendered
differently by the builds you're using, or can nail down exactly what
GitHub commit broke it, I might be able to do some guessing; but until
then, unfortunately it looks like I need you to do more experimenting.
Date: 12 Aug 2014 13:45:02
Message: <53ea529e$1@news.povray.org>
>>> #declare Floor =
>>> union {
>>>      object {
>>> scale 1 } )
>>>      rotate x*90
>>>      rotate y*0
>>> changes???
POV-Ray 3.7.1-alpha.7681813.unofficial
Date: 12 Aug 2014 13:48:26
Message: <53ea536a$1@news.povray.org>
Am 12.08.2014 19:34, schrieb James Holsenback:
That's 3.7.1-alpha.7681813, so same version as I used.
> With 3.7-stable filter set, this hash
That's the genuine 3.7.0 release proper, aka "3.7.0 stable".
Date: 12 Aug 2014 13:53:37
Message: <53ea54a1$1@news.povray.org>
>> results
well it's after 3.7-stable for sure ... OTOc.inc sources math.inc dunno
if that could be a clue.
Date: 12 Aug 2014 14:42:39
Message: <53ea601f$1@news.povray.org>
Am 12.08.2014 19:53, schrieb James Holsenback:
>>> results
Thanks for the help, you just narrowed it down to a meagre 120-130
commits :-)
I hadn't thought of include files, and it would seem a tempting
explanation, as I'm not regularly updating my installed set of those;
but a quick check reveals that I'm already using the newest; which is
not too surprising, giving that only three changes have been made within
the include directory since 3.7-stable so far, and none of them seems
anywhere close to being a plausible candidate. (And no, math.inc hasn't
been changed at all.)
Date: 12 Aug 2014 14:55:50
Message: <53ea6336$1@news.povray.org>
>>>> results
> commits :-)
narrowed a bit further ... this hash works fine:
9a278c7f02003b7e6d6d0665c37695351cb23a27 so something after that!!!!
Date: 12 Aug 2014 15:53:08
Message: <53ea70a4@news.povray.org>
>>>>> results
>> commits :-)
ok so at hash 54b283a0d39c637ce9d4ab16512a364e993c58c5 its busted so I
think that's considerable less territory to cover.
Date: 13 Aug 2014 03:16:22
Message: <53eb10c6$1@news.povray.org>
Yet another compiler issue ?
Is there a full-scene available for download and test ?
Just because nobody complains does not mean all parachutes are perfect.
Date: 13 Aug 2014 04:26:57
Message: <53eb2151$1@news.povray.org>
I'm having my suspicions that is what's going on ...
Yep ... the OTOTest.pov file that comes with the OTOc.inc package (over
in p.b.scene-files
Date: 13 Aug 2014 06:11:38
Message: <53eb39da$1@news.povray.org>
>>>>>> here's
>>>>>> results
>>> commits :-)
this hash ac564f7231f2b05b461a3a03fe6b9ed21b845c5a is the last working
commit (compiles and runs OTOTest.pov properly)
broken @ cf1c3fbedb33802bd431acac43ce41db55fa87b8 ... doesn't even
compile ./base/safemath.h is belching errors all over the place
In file included from base/image/image.cpp:57:0:
./base/safemath.h: In function ‘T pov_base::SafeUnsignedProduct(T1, T2,
T3, T4)’:
./base/safemath.h:51:2: error: ‘numeric_limits’ was not declared in this
scope
./base/safemath.h:51:2: note: suggested alternative:
/usr/include/c++/4.6/limits:304:12: note:   ‘std::numeric_limits’
./base/safemath.h:51:2: error: expected primary-expression before ‘>’ token
./base/safemath.h:51:2: error: ‘::is_integer’ has not been declared
./base/safemath.h:52:2: error: expected primary-expression before ‘>’ token
./base/safemath.h:52:2: error: ‘::is_integer’ has not been declared
./base/safemath.h:53:2: error: expected primary-expression before ‘>’ token
./base/safemath.h:53:2: error: ‘::is_integer’ has not been declared
./base/safemath.h:54:2: error: expected primary-expression before ‘>’ token
./base/safemath.h:54:2: error: ‘::is_integer’ has not been declared
./base/safemath.h:55:2: error: expected primary-expression before ‘>’ token
./base/safemath.h:55:2: error: ‘::is_integer’ has not been declared
./base/safemath.h:61:26: error: expected primary-expression before ‘>’ token
./base/safemath.h:61:33: error: no matching function for call to ‘max()’
./base/safemath.h:61:33: note: candidates are:
/usr/include/c++/4.6/bits/stl_algobase.h:254:5: note: template<class
_Tp, class _Compare> const _Tp& std::max(const _Tp&, const _Tp&, _Compare)
/usr/include/c++/4.6/bits/stl_algobase.h:210:5: note: template<class
_Tp> const _Tp& std::max(const _Tp&, const _Tp&)
make[2]: *** [base/image/image.o] Error 1
Date: 13 Aug 2014 07:28:26
Message: <53eb4bda$1@news.povray.org>
Am 13.08.2014 12:11, schrieb James Holsenback:
Ah, yes, that one... that's part of GitHub issue #29. It'll need
replacing of "numeric_limits" with "std::numeric_limits" (and then
probably some more fixes).
Date: 13 Aug 2014 16:07:10
Message: <53ebc56e@news.povray.org>
>>>> Instead
Identify your compiler ?
mine is gcc 4.8.2 (ubuntu) and testing with
ad6d545729bbd92800fc2d65fe74dcac86408c27 (head of master), it works ok here.
(from OTOC... )
(I did not reinstall the include files, so changes in such files might
not be reflected)
> in p.b.scene-files
Thanks.
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Date: 13 Aug 2014 18:24:52
Message: <53ebe5b4@news.povray.org>
>>>>> Instead
gcc (SUSE Linux) 4.6.2
> (from OTOC... )
> not be reflected)
>> in p.b.scene-files
> Thanks.
Date: 14 Aug 2014 15:24:37
Message: <53ed0cf5@news.povray.org>
went to #af80da48a650b51039d23318a73b583493d81200 (last of #29 issue)
and now it builds clean, but the wall from the OTO test scene is incomplete
Date: 16 Aug 2014 06:49:34
Message: <53ef373e@news.povray.org>
have you been able to (or are you even going to) look into why the
implementation (re-factoring???) of this construct isn't compatible with
my compiler (that's what appears to be happening) since you can't
confirm on your end.
it /really/ appears that this (OTOTest file) got broken @
cf1c3fbedb33802bd431acac43ce41db55fa87b8 and that the issue #29 commits
just cleaned up the implementation so i could at least compile.
Date: 16 Aug 2014 08:00:19
Message: <53ef47d3@news.povray.org>
following up on the notion that it's compiler/configure related, I did a
comparison of configure output the buildbot server and my system!
This 1st output is from the buildbot server ...
gcc (Ubuntu/Linaro 4.8.1-10ubuntu9) 4.8.1:
Just a few entries of interest here /not/ all of them ... compare them
with below output!
Language constructs and functions
checking size of int... 4
checking size of long int... 8
checking size of size_t... 8
checking size of float... 4
Floating Point Features
checking limits usability... yes
checking limits presence... yes
checking for limits... yes
checking whether NaNs are supported... yes
checking cmath usability... yes
checking cmath presence... yes
checking for cmath... yes
checking whether NaNs can be identified using std::isnan()... no
checking whether NaNs can be identified using global isnan()... no
checking whether NaNs can be identified by comparison to themselves... no
checking whether infinite values are supported... yes
checking for cmath... (cached) yes
checking whether infinities can be identified using std::isinf()... no
checking whether infinities can be identified using global isinf()... no
checking whether infinities can be identified by comparison to the
maximum value... yes
This output is from my system ...
gcc (SUSE Linux) 4.6.2:
Compare to above buildbot output ...
checking size of long int... 4
checking size of size_t... 4
Did /not/ even have "Floating Point Features" section on my system!!!
The plot thickens? mkl?
Date: 16 Aug 2014 10:17:28
Message: <53ef67f8$1@news.povray.org>
Am 16.08.2014 12:49, schrieb James Holsenback:
The "numeric_limits" in the global namespace (i.e. without "std::")
isn't compatible with your compiler because it's not ISO C++. MS Visual
C++ does support it, but other compilers (or, more precisely, the
respective <limits> header file) may not.
Prior to that change, there was a statement "using namespace std;" which
effectively says, "everything in namespace std should also be available
in the current namespace", or, in other words, "std:: can be omitted
everywhere". It had to be dropped because with some compilers it caused
name conflicts between implementations of the shared_ptr class from
different sources (boost, tr1 and C++11).
I wouldn't expect the issue #29 commits to do anything else. They're
just there to use less ambiguous language constructs to satisfy some
compilers that are less forgiving than MS Visual C++.
If I understand you correctly, you're saying that with issue #29 fixes
in place commit 7502593 works while cf1c3fb doesn't. Is that right?
Date: 16 Aug 2014 10:24:39
Message: <53ef69a7@news.povray.org>
Am 16.08.2014 14:00, schrieb James Holsenback:
Does the buildbot-generated binary render the scene ok?
> with below output!
That's typical for a 64-bit machine.
That's typical for g++ with floating-point optimizations enabled.
That's typical for a 32-bit machine.
That's perfectly normal for any version prior to commit f1699ea.
No plot-thickening yet.
Date: 17 Aug 2014 04:47:59
Message: <53f06c3f@news.povray.org>
ac564f7 was the last time I was able to compile and run OTOTest file
correctly ... cf1c3fb wouldn't even compile. jumped to af80da4 (the last
issue #29) commit and it compiled fine but OTOTest file problem showed
up again
Date: 18 Aug 2014 08:18:51
Message: <53f1ef2b$1@news.povray.org>
Am 17.08.2014 10:47, schrieb James Holsenback:
> up again
Please note that the Git version history isn't linear: It has different
branches that split and merge; and while ac564f7 is the last commit
before cf1c3fb, it was done on a different branch, and so the immediate
predecessor of cf1c3fb is the earlier commit 7502593. (Likewise, the
later commit 914fff1 is a direct successor of ac564f7 but not of
cf1c3fb, and is therefore likely to both compile and run OTOTest file.)
The following commits are still suspects for having broken OTOTest (in
reverse chronological order):
     cf1c3fb
     7502593
     2a2d1a8
     2a41f04
7502593 is comparatively unlikely to be the culprit, as it just merges
bugfix cc24c62, which was also merged into the other branch leading to
ac564f7 and apparently didn't do any damage there.
2a2d1a8 is about as hot a candidate as cf1c3fb - probably even more so,
as it is all about vectors and therefore relative position of items,
while cf1c3fb is about blend maps (colour maps, pigment maps, normal
maps etc.), which do not have any intrinsic relative positional
component to them.
2a41f04 is a hot candidate for having caused GitHub issue #29, but
shouldn't have brought about any functional changes, so I suspect it
will run fine with the issue #29 fixes applied.
Date: 18 Aug 2014 08:20:56
Message: <53f1efa8@news.povray.org>
Am 16.08.2014 16:24, schrieb clipka:
Did you have time to test this by now?
Date: 18 Aug 2014 09:35:09
Message: <53f2010d$1@news.povray.org>
no I haven't ... didn't catch that previously. probably not today ...
maybe tomorrow.
Date: 18 Aug 2014 09:43:01
Message: <53f202e5$1@news.povray.org>
>> up again
>      cf1c3fb
>      7502593
>      2a2d1a8
>      2a41f04
> component to them.
OK ... this goes to some of my confusion. I'd suspected as much. Thanks
for the sanity check!
When I downloaded source(s) I used the "clone" url, so I was pulling a
snapshot of the entire branch (not just individual changes) at that
commit, then doing separate builds for each. Give me some time to
further narrow it down.
Appreciate your indulgence.
Date: 18 Aug 2014 10:13:50
Message: <53f20a1e@news.povray.org>
>> #declare Floor =
>> union {
>>      object {
>> scale 1 } )
>>      rotate x*90
>>      rotate y*0
> results
I've got some good news: While I'm still unable to reproduce the error,
I /am/ now able to exactly reproduce the output you're seeing (see
attached image), by changing the OTO_FMask function
     #local OTO_FMask = function{ pattern{ pigment_pattern{
         checker 0, 1 warp{planar} } } }
to something that never returns 1; so it would seem that the error
scrambles one of the statements in this function definition.
Can you please dig further in this direction to figure out exactly what
part of this is broken? (I guess this will lead us much faster to the
root cause than knowing exactly which commit introduced it.)
Download 'ototest.png' (275 KB)
Date: 18 Aug 2014 10:22:50
Message: <53f20c3a$1@news.povray.org>
>>> #declare Floor =
>>> union {
>>>      object {
>>> scale 1 } )
>>>      rotate x*90
>>>      rotate y*0
>>> changes???
>> results
yes that IS good news ...
OK
Date: 18 Aug 2014 16:38:45
Message: <53f26455@news.povray.org>
>>> #declare Floor =
>>> union {
>>>      object {
>>> scale 1 } )
>>>      rotate x*90
>>>      rotate y*0
>>> changes???
>> results
Well had some time after all ... I played with the OTO_FMask function,
but hey there's not much to change right? I started looking at the
numbers being passed to OTO_Get_Mask, on line 133 of the attached
include I added a debug. Everything looked legitimate, so I dropped down
a couple of lines and added debugs for the corner finding test. Those
sets of vectors looked like legitimate formed vectors as well, but the
wall is incomplete. Didn't notice that notice that the vectors were ALL
falling into the 1st test until I changed condition to false on line
136. Now the vectors pass through BOTH of the test and the wall in complete.
Download 'us-ascii' (5 KB)
Date: 18 Aug 2014 20:41:44
Message: <53f29d48$1@news.povray.org>
Am 18.08.2014 22:38, schrieb James Holsenback:
> 136.
I... don't think I understand what you're saying.
Yes, the bug seems to be causing the corner finding test to always go to
the same branch (but it's the else-branch according to my observation).
The mystery to be solved is, why is that?
I don't think the test itself ("#if(OTO_Get_Mask(Vec)=1)") is broken;
that would surely affect too many other scenes. Likewise, I can't see
how anything in the OTO_Get_Mask() macro could go wrong without messing
up plenty of scenes as well.
My suspicion is therefore that the function OTO_FMask returns non-1
values where it should return 1, and I was hoping you could do some
toying around with that very function and compare its operation with (a)
a working binary and (b) your broken version.
Something like:
  #macro OTO_Get_Mask(Cell)
   #local CX = Cell.x;
   #local CY = Cell.y;
   #local Result = OTO_FMask(CX,CY,0);
   #debug concat()
   Result
On a properly working binary and with the original OTOTest.pov scene,
this should output:
<-8.00000,-5.00000,0.00000>: 1.00000000000000000000
<-7.00000,-5.00000,0.00000>: 0.00000000000000000000
<-6.00000,-5.00000,0.00000>: 1.00000000000000000000
<-5.00000,-5.00000,0.00000>: 0.00000000000000000000
<-4.00000,-5.00000,0.00000>: 1.00000000000000000000
<-3.00000,-5.00000,0.00000>: 0.00000000000000000000
<-2.00000,-5.00000,0.00000>: 1.00000000000000000000
<-1.00000,-5.00000,0.00000>: 0.00000000000000000000
<0.00000,-5.00000,0.00000>: 1.00000000000000000000
<1.00000,-5.00000,0.00000>: 0.00000000000000000000
<2.00000,-5.00000,0.00000>: 1.00000000000000000000
<3.00000,-5.00000,0.00000>: 0.00000000000000000000
<4.00000,-5.00000,0.00000>: 1.00000000000000000000
<5.00000,-5.00000,0.00000>: 0.00000000000000000000
<6.00000,-5.00000,0.00000>: 1.00000000000000000000
<7.00000,-5.00000,0.00000>: 0.00000000000000000000
<-8.00000,-4.00000,0.00000>: 0.00000000000000000000
<-7.00000,-4.00000,0.00000>: 1.00000000000000000000
<-6.00000,-4.00000,0.00000>: 0.00000000000000000000
<-5.00000,-4.00000,0.00000>: 1.00000000000000000000
<-4.00000,-4.00000,0.00000>: 0.00000000000000000000
<-3.00000,-4.00000,0.00000>: 1.00000000000000000000
<-2.00000,-4.00000,0.00000>: 0.00000000000000000000
<-1.00000,-4.00000,0.00000>: 1.00000000000000000000
<0.00000,-4.00000,0.00000>: 0.00000000000000000000
<1.00000,-4.00000,0.00000>: 1.00000000000000000000
<2.00000,-4.00000,0.00000>: 0.00000000000000000000
<3.00000,-4.00000,0.00000>: 1.00000000000000000000
<4.00000,-4.00000,0.00000>: 0.00000000000000000000
<5.00000,-4.00000,0.00000>: 1.00000000000000000000
<6.00000,-4.00000,0.00000>: 0.00000000000000000000
<7.00000,-4.00000,0.00000>: 1.00000000000000000000
If your broken build outputs the same, the problem must be in the macro
or the comparison after all, but I doubt that, so I suspect that you'll
get something different instead of "1.00000000000000000000".
In that case, a next step could be to use an all-1 pigment pattern
instead and see what that does:
   #local OTO_FMask = function { pattern { pigment_pattern {
     colour 1.0 } } }
With an ok binary, this should give:
<-7.00000,-5.00000,0.00000>: 1.00000000000000000000
<-5.00000,-5.00000,0.00000>: 1.00000000000000000000
If your results differ there as well (which I suspect), we can rule out
the warp{planar} and the checker pigment; using an entirely different
pattern instead of pigment_pattern might also give some insight, such as:
   #local OTO_FMask = function{ pattern{ gradient x } }
which gives me:
<-8.00000,-5.00000,0.00000>: 0.00007000000000045858
<-7.00000,-5.00000,0.00000>: 0.00006000000000039307
<-6.00000,-5.00000,0.00000>: 0.00005000000000032756
<-5.00000,-5.00000,0.00000>: 0.00004000000000026205
<-4.00000,-5.00000,0.00000>: 0.00003000000000019654
<-3.00000,-5.00000,0.00000>: 0.00002000000000013102
<-2.00000,-5.00000,0.00000>: 0.00001000000000006551
<0.00000,-5.00000,0.00000>: 0.00000000000000000000
<1.00000,-5.00000,0.00000>: 1.00000000000000000000
<2.00000,-5.00000,0.00000>: 0.00000000000000000000
<4.00000,-5.00000,0.00000>: 0.00000000000000000000
<6.00000,-5.00000,0.00000>: 0.00000000000000000000
Or use checker like this, which should give the same as the original
from OTOc.inc albeit with a much simpler statement:
   #local OTO_FMask = function{ pattern{ checker } }
> complete.
Pardon? You fixed it? How? The OTOc.inc you posted contains no changes
except for the commented-out #debug lines and an additional blank at the
end of the central test condition.
Date: 19 Aug 2014 07:07:48
Message: <53f33004$1@news.povray.org>
>> 136.
> Something like:
>    #local CX = Cell.x;
>    #local CY = Cell.y;
>    #debug concat()
>    Result
>   #end
> this should output:
>      colour 1.0 } } }
> which gives me:
>> complete.
Geez ... I never said I fixed it, and I'm getting rather bored with this
back and forth. There's a problem ... fix it or don't.
Date: 19 Aug 2014 09:14:14
Message: <53f34da6@news.povray.org>
Am 19.08.2014 13:07, schrieb James Holsenback:
I'd really like to fix it, but I need your help to diagnose the problem,
because I really can't reproduce it here, and at present I know of
nobody else who can.
Running the tests I described in my previous post should be a matter of
just a few minutes, and might tell me more about the problem than all
the back and forth so far.
So please help me a bit more with this.
... pretty please?
Date: 20 Aug 2014 08:29:46
Message: <53f494ba$1@news.povray.org>
> ... pretty please?
I added some debug in OTO_Get_Mask like this:
	#local CX = Cell.x;
   #local CY = Cell.y;
   #debug concat ("OTO_Get_Mask <",vstr(3,Cell,",",2,4),">
Result:",str(Result,2,4),"\n")
   OTO_FMask(CX,CY,0)
and it produced the following output:
OTO_Get_Mask <-8.0000,-5.0000,0.0000> Result:1.0000
else: <-8.08857,-4.96521,0.00000>, <-6.81513, -3.69069, 0.00000>
OTO_Get_Mask <-7.0000,-5.0000,0.0000> Result:0.0000
else: <-6.96521,-4.79876,0.00000>, <-6.19790, -3.81513, 0.00000>
OTO_Get_Mask <-6.0000,-5.0000,0.0000> Result:1.0000
else: <-5.79876,-4.73380,0.00000>, <-4.90749, -4.19790, 0.00000>
OTO_Get_Mask <-5.0000,-5.0000,0.0000> Result:0.0000
else: <-4.73380,-4.96589,0.00000>, <-4.33468, -3.90749, 0.00000>
OTO_Get_Mask <-4.0000,-5.0000,0.0000> Result:1.0000
else: <-3.96589,-5.17163,0.00000>, <-3.41528, -4.33468, 0.00000>
the 1st group shows a "Result" of 1 and it improperly falls into the
else clause (yep got that backwards in previous post ... tired, dyslexia
acting up) ... but notice in the 2nd group that even tho "Result" is 0
(inside the OTO_Get_Mask macro) it /still/ falls into the else clause
I also used:
#local OTO_FMask = function{ pattern{ pigment_pattern{ color 1.0 } } }
with these results:
OTO_Get_Mask <-7.0000,-5.0000,0.0000> Result:1.0000
OTO_Get_Mask <-5.0000,-5.0000,0.0000> Result:1.0000
so it would seem that no matter what OTO_Get_Mask returns, it's /always/
falling into the else clause.
when I change the corner test to: #if(OTO_Get_Mask(Vec)=0)
things appear to go through the corner test properly (albeit reverse
logic) and the image renders correctly without the gaps.
if: <-6.81513,-4.96521,0.00000>, <-5.79876, -4.19790, 0.00000>
if: <-4.90749,-4.73380,0.00000>, <-3.96589, -4.33468, 0.00000>
Date: 20 Aug 2014 09:16:24
Message: <53f49fa8$1@news.povray.org>
Am 20.08.2014 14:29, schrieb James Holsenback:
>      #local CX = Cell.x;
>    #local CY = Cell.y;
>    OTO_FMask(CX,CY,0)
>   #end
Can you repeat this with a much higher precision for the result? 20
digits should be enough. I wouldn't be surprised if this was some kind
of precision issue in the function{pattern{pigment_pattern}} construct,
as it would perfectly explain why it doesn't compare equal to 1.0. (I
consider it unlikely that the comparison with 1.0 itself got broken
somehow, and I think there /is/ a bit of code in the pigment_pattern
that might be subject to rounding errors.)
Date: 20 Aug 2014 09:16:31
Message: <53f49faf$1@news.povray.org>
On a lark I also tried:
#if(OTO_Get_Mask(Vec))
and it works!!!
if: <-7.69069,-5.08857,0.00000>, <-6.96521, -3.81513, 0.00000>
if: <-6.19790,-4.79876,0.00000>, <-4.73380, -3.90749, 0.00000>
if: <-4.33468,-4.96589,0.00000>, <-3.17163, -4.41528, 0.00000>
I'm confused now ... aren't
and
functionally the same?
Date: 20 Aug 2014 09:26:02
Message: <53f4a1ea$1@news.povray.org>
>>      #local CX = Cell.x;
>>    #local CY = Cell.y;
>>    OTO_FMask(CX,CY,0)
>>   #end
OTO_Get_Mask
<-8.00000000000000000000,-5.00000000000000000000,0.0000000000000000
0000> Result:0.99999997764825820923
Hmmm ... OK I think this shows problem the above is output from inside
the OTO_Get_Mask function ... I now see why reversing the logic (and my
"on a lark" test) in corner test works
Date: 20 Aug 2014 09:28:11
Message: <53f4a26b$1@news.povray.org>
Am 20.08.2014 15:16, schrieb James Holsenback:
> and
No,
and
   #if(OTO_Get_Mask(Vec) != 0)
are.
Date: 20 Aug 2014 09:40:11
Message: <53f4a53b$1@news.povray.org>
Am 20.08.2014 15:26, schrieb James Holsenback:
> OTO_Get_Mask
Bingo!
Okay, you obviously have already figured a way around this problem by
way of modifying OTOc.inc, and I think I now have enough information to
go hunting for the root cause in the codebase.
I might come back to you for testing of some code modifications, if
that's ok for you.
Date: 20 Aug 2014 10:00:43
Message: <53f4aa0b$1@news.povray.org>
> that's ok for you.
ok fine
Date: 20 Aug 2014 16:00:43
Message: <53f4fe6b$1@news.povray.org>
This is /true/ if and only if the result *is* 1 (one)
> and
This is /false/ if and only if the result *is* 0 (zero)
So, not at all *unless* the result can only be zero or one.
Date: 28 Aug 2014 13:41:55
Message: <53ff69e3@news.povray.org>
>> OTO_Get_Mask
> Bingo!
> that's ok for you.
curious if you've had any time to follow up
Date: 28 Aug 2014 14:08:50
Message: <53ff7032$1@news.povray.org>
Am 28.08.2014 19:41, schrieb James Holsenback:
>>> OTO_Get_Mask
>> Bingo!
>> that's ok for you.
Not yet, sorry.
Date: 6 Jan 2015 17:43:00
Message: <54ac64f4$1@news.povray.org>
Am 28.08.2014 um 19:41 schrieb James Holsenback:
>>> OTO_Get_Mask
>> Bingo!
>> that's ok for you.
Now that I've returned from outer space, I have at last; can you please
try the following patch:
At the beginning of source/base/colour.h, around line 95, replace the
following lines:
const float kRedIntensity   = 0.297;
const float kGreenIntensity = 0.589;
const float kBlueIntensity  = 0.114;
with this:
const PreciseColourChannel kRedIntensity   = 0.297;
const PreciseColourChannel kGreenIntensity = 0.589;
const PreciseColourChannel kBlueIntensity  = 0.114;
I /think/ it should fix the issue. The culprit would then have been
change 0ea2da4.
Date: 13 Jan 2015 14:02:09
Message: <54b56bb1$1@news.povray.org>
>>>> OTO_Get_Mask
>>> Bingo!
>>> that's ok for you.
Well my job (10hrs a day 7 days a week) is a black hole ...
> following lines:
> with this:
> change 0ea2da4.
I will do my best, but can't promise any sort of time frame
Date: 14 Jan 2015 03:26:37
Message: <54b6283d$1@news.povray.org>
No kidding? Slavery has been prohibited as far as I know... :-\
Date: 23 Jan 2015 13:25:21
Message: <54c29211@news.povray.org>
>>>> OTO_Get_Mask
>>> Bingo!
>>> that's ok for you.
> following lines:
> with this:
> change 0ea2da4.
I'm unable to get a clean build after beta6 and I don't have time to
troubleshoot. Wooo hoo I'm getting my 1st day off (this coming sunday)
since the 1st of the year, and I'm not inclined to spend that time
trying to unravel. I DID however notice you made a change on the Wiki to
the "Strings" documentation. What time frame are you looking at for a
release? There have been other doc changes since last release and I'd
like to pick up the changes and post the new doc sets if there aren't
any more changes.
Date: 23 Jan 2015 17:04:45
Message: <54c2c57d$1@news.povray.org>
Am 23.01.2015 um 19:25 schrieb James Holsenback:
> troubleshoot.
beta6? Wait, that's UberPOV, isn't it?
It was my understanding that we were talking about fixing POV-Ray proper
for now. Once we have that sorted out, it can be merged into UberPOV.
> trying to unravel.
Can't blame you :D
> any more changes.
As for a full-fledged official release, with installer and all, I guess
you'll have to ask Chris about that one. He had intended to do a build
earlier this month, but it seems like real life interfered.
I've just released a new semi-official development build (see
povray.beta-test), but that's just a drop-in replacement for the binary,
without any docs.
