POV-Ray : Newsgroups : povray.binaries.images : unexplained Server Time
11 Apr 2026 05:17:04 EDT (-0400)
  unexplained (Message 1 to 10 of 58)
Subject: unexplained
Date: 12 Aug 2014 11:07:26
Message: <53ea2dae@news.povray.org>
I've been using Sams "Odd Tiles Object' include (get it in
p.b.scene-files) forever and just noticed a problem. The 1st image shows
the problem ... 2nd image is how is supposed to look.
Builds from the latest uber beta, /and/ povray master branches on github
have the problem, povray 3.7 stable (github) and perforce repository are
ok fine.
Download 'otoc1.png' (305 KB) Download 'otoc2.png' (315 KB)
Preview of image 'otoc1.png'
Preview of image 'otoc2.png'
Subject: Re: unexplained
Date: 12 Aug 2014 12:40:18
Message: <53ea4372@news.povray.org>
Am 12.08.2014 17:06, schrieb James Holsenback:
Is that the "OTOc.inc" 3rd version?
> ok fine.
The Sam's test scene (OTOTest.pov) renders fine here with the latest
POV-Ray and UberPOV stuff (Windows versions).
Download 'ototest.png' (300 KB)
Preview of image 'ototest.png'
Date: 12 Aug 2014 13:01:45
Message: <53ea4879$1@news.povray.org>
that's what the file header says ...
>> ok fine.
here's what I'm doing:
#declare Floor =
union {
	object {
		OTO( <-2.5,-2.5,0>, <2.5,2.5,1>, 0.075, texture { BaseTexture scale 1 } )
	box { <-2.5,-2.5,0.075>, <2.5,2.5,0.075> pigment { srgb 1 } finish
{diffuse 0.6 specular 0.15 roughness 1e-5} }
	rotate x*90
	rotate y*0
kind of funny that it works with some versions (perforce/git 3.7 stable)
but not other git repos ... 32 vs 64 bit? compiler?? configure changes???
Date: 12 Aug 2014 13:09:50
Message: <53ea4a5e@news.povray.org>
>>> ok fine.
> #declare Floor =
> union {
>      object {
> scale 1 } )
>      rotate x*90
>      rotate y*0
found OTOTest.pov file laying around in some obscure corner ... here's
results
Download 'ototest.png' (1072 KB)
Date: 12 Aug 2014 13:24:42
Message: <53ea4dda@news.povray.org>
Am 12.08.2014 19:01, schrieb James Holsenback:
> #declare Floor =
> union {
>      object {
> scale 1 } )
>      rotate x*90
>      rotate y*0
With 3.7.1-alpha.7681813 compiled straight from the GitHub code, the
above scene snippet (with standard OTO_Object) gives me this:
Download 'ototest2.png' (13 KB)
Preview of image 'ototest2.png'
Date: 12 Aug 2014 13:34:42
Message: <53ea5032$1@news.povray.org>
>> #declare Floor =
>> union {
>>      object {
>> scale 1 } )
>>      rotate x*90
>>      rotate y*0
I stayed out of my local git repos as I've made some changes ... Instead
downloaded the zip package made available from povray github with the
master filter selected, it has this hash
ad6d545729bbd92800fc2d65fe74dcac86408c27 and has the problem. With
3.7-stable filter set, this hash
39ce8a24e50651904010dda15872d63be15d7c37 tis ok fine
Date: 12 Aug 2014 13:41:18
Message: <53ea51be@news.povray.org>
Am 12.08.2014 19:08, schrieb James Holsenback:
> results
Well, what can I say, other than "I can't reproduce it"?
Unless you can trim down the thing to an extremely minimalistic scene
(say, one or two primitives with one or two textures) that is rendered
differently by the builds you're using, or can nail down exactly what
GitHub commit broke it, I might be able to do some guessing; but until
then, unfortunately it looks like I need you to do more experimenting.
Date: 12 Aug 2014 13:45:02
Message: <53ea529e$1@news.povray.org>
>>> #declare Floor =
>>> union {
>>>      object {
>>> scale 1 } )
>>>      rotate x*90
>>>      rotate y*0
>>> changes???
POV-Ray 3.7.1-alpha.7681813.unofficial
Date: 12 Aug 2014 13:48:26
Message: <53ea536a$1@news.povray.org>
Am 12.08.2014 19:34, schrieb James Holsenback:
That's 3.7.1-alpha.7681813, so same version as I used.
> With 3.7-stable filter set, this hash
That's the genuine 3.7.0 release proper, aka "3.7.0 stable".
Date: 12 Aug 2014 13:53:37
Message: <53ea54a1$1@news.povray.org>
>> results
well it's after 3.7-stable for sure ... OTOc.inc sources math.inc dunno
if that could be a clue.
