POV-Ray : Newsgroups : povray.binaries.images : Urbex - wip 12 Server Time
16 Oct 2026 04:12:05 EDT (-0400)
  Urbex - wip 12 (Message 1 to 31 of 31)
Subject: Urbex - wip 12
Date: 8 Aug 2014 08:10:11
Message: <53e4be23@news.povray.org>
Getting nearer a final render. A large one to be able to assess the details.
Output render in exr format; postprocessed in IC for luminosity balance;
this copy as jpg.
Now as Cathy's World #13.
Download 'urbex_12.jpg' (487 KB)
Preview of image 'urbex_12.jpg'
Subject: Re: Urbex - wip 12
Date: 8 Aug 2014 10:10:40
Message: <53e4da60@news.povray.org>
What do you think? This is a jpg copy of the original exr render,
without post-processing. Somehow, I prefer this although it is a bit too
dark.
Download 'urbex_12.jpg' (314 KB)
Date: 8 Aug 2014 10:26:48
Message: <53e4de28$1@news.povray.org>
Am 08.08.2014 16:10, schrieb Thomas de Groot:
> dark.
I prefer this one, too. I love images that play with light & darkness.
Date: 8 Aug 2014 19:38:08
Message: <53e55f60$1@news.povray.org>
> dark.
> Thomas
The very dark areas make the bright areas look brighter and beter, even
if I need to push the brightness of my monitor to the max. I think that
it beter show the often oppresive feeling you may have in this kind of
settin.
Date: 9 Aug 2014 03:10:19
Message: <53e5c95b$1@news.povray.org>
>> dark.
Yes, me too. Additionally, the post processing flattens out the colour
contrast. I shall play a bit more with that last aspect but just as an
experiment not towards a 'final' image.
Date: 9 Aug 2014 03:10:48
Message: <53e5c978$1@news.povray.org>
>> dark.
>> Thomas
> settin.
Yes, I agree.
Date: 9 Aug 2014 04:40:26
Message: <53e5de7a$1@news.povray.org>
>>> dark.
I would be tempted to use a fill light on the stairs just to bring out
some detail. I would not know how to do that with radiosity. Would using
a diffuse reflective object do it. The way that photographers would use
a white sheet in RL?
Regards
Date: 9 Aug 2014 07:16:33
Message: <53e60311$1@news.povray.org>
During testing I have used a shadowless light over the stairs. I am
thinking about a couple of things: a diffuse reflective screen is one
but may be too 'diffuse' to be effective; a skylight high in the wall
above the stairs is another. I am not too willing to use a direct light,
even an area one, as that would be counter to the state of the building ;-)
Date: 10 Aug 2014 10:01:14
Message: <53e77b2a@news.povray.org>
I believe I have a nice compromise now. I added a screen, simulating a
skylight in the upper wall of the staircase. With a bit of emission.
Download 'urbex_final3.jpg' (336 KB)
Preview of image 'urbex_final3.jpg'
Date: 11 Aug 2014 00:33:19
Message: <53e8478f$1@news.povray.org>
> dark.
> Thomas
Hmm. Haven't commented on this prior, but.. the walls are too
artificial. While its a good look, walls don't peel quite like that,
which I think if the problem. There would be color differences in the
paint itself, lighted in "protected" spots, and discolored in others.
Their might be bleed through of texture from individual panels (if wall
board), or other materials, where the same disruptions that peeled the
paint has warped the underlying material. Also, more protected areas may
be less patchy, due to be less exposed to the conditions that caused the
peel, and others might have much bigger patches missing, due to being
more exposed to the same.
It doesn't "look" uniform, but... its too obviously algorithmic. Too
"cleanly" non-uniformly damaged. If you get what I mean.
Its one of the things that bugs me about this stuff, and why I never
dove that far into it over the years, instead of just once in a while.
POVRay textures are good, when you can't see, in the scale, the
repetitiveness of them, but not so good in scenes like this, but.. on
the other hand, I suck even more at "painting" believable details, using
a static, non-generated texture. lol
Commander Vimes: "You take a bunch of people who don't seem any
different from you and me, but when you add them all together you get
this sort of huge raving maniac with national borders and an anthem."
Date: 11 Aug 2014 03:28:36
Message: <53e870a4$1@news.povray.org>
Compare to the original photograph:
http://www.daanoe.nl/en/photos#.U-htPGPJAQg
I partly agree with you but the intention was to try to approach as much
as possible real life. I think I got close :-)
Otoh though, real life is /not/ the ultimate goal in my work ;-)
Date: 11 Aug 2014 10:52:02
Message: <53e8d892@news.povray.org>
Following Patrick's comments I have been thinking about a couple of more
'sophisticated' applications of my peeling paint macro (see p.b.s-f).
In this image, the superellipsoid uses a classic granite pattern; the
ovus uses a pigment_pattern based on a granite pattern function; the
julia fractal uses the latter in combination with a proximity pattern.
Download 'peeling_test.png' (379 KB)
Preview of image 'peeling_test.png'
Date: 11 Aug 2014 18:27:58
Message: <53e9436e$1@news.povray.org>
> Thomas
Hmm. Yeah, can see that. I would, based on the original, if the goal
"was" to match it, "A good start". But, yeah, the one obvious thing
missing is the "hanging" bits, where its still peeling, for one. Your
version, I suppose, looks more like what someone might get is being real
careful about scraping those bits off, to leave a smooth surface. I was
right about the greater variations of discoloration though. ;)
For me, frankly, it would be. A lot of the stuff I do right now (and
there just isn't a lot of practical ways to help it with POVRay) is for
Second Life, when I do any at all. And, I seriously hate the lack of
realism in so much of the stuff on there, especially when contrasted
with stuff that "is" being done with high realism. :p
Date: 12 Aug 2014 03:12:39
Message: <53e9be67$1@news.povray.org>
Ah! the hanging bits! That was my first concern (and my last). At
present, I see no elegant way out of that issue. I tried to write a
simulation macro but the results were horrible. Just as for peeling wall
paper, I am afraid that needs to be modelled separately :-(
Discolouration is another brain cracker. I use a texture_map but
obviously that is not the same at all.
That explains your comments :-)
Date: 12 Aug 2014 11:40:01
Message: <web.53ea344d7572c76885de7b680@news.povray.org>
This was discussed a while back, and no good solution was found.
Date: 12 Aug 2014 16:55:01
Message: <web.53ea7f017572c768d19b0ec40@news.povray.org>
There are still people on Second Life? (although there are people saying the
same thing about Povray!).
Do you have examples of what you're talking about in Second Life?
Also, I find this amusing: https://www.youtube.com/watch?v=OrAHBk4ZAeQ
Date: 13 Aug 2014 01:57:29
Message: <53eafe49$1@news.povray.org>
Hmm. Well, some of the best stuff I have seen are from people like these:
https://marketplace.secondlife.com/stores/24073
They try for high realism, or as high as possible, but with the addition
of funky elements, like having one chair leg repaired oddly, or other
"ghostly" effects.
These guys do some real good stuff too.
https://marketplace.secondlife.com/stores/4427
A lot of things have taken off do to allowing mesh now, and some insane
stuff was, and still is, done with "prim torture", also known as
displacement mapping (or sculpties).
Also, the places made by "some" of the residents, and almost always by
Linden themselves, can be just insanely detailed and amazing. One major
part of the area I roleplay in is being remodeled (but not yet
"public"), with all the new lighting systems, mesh, texture support,
etc. in them. These people are.. still a bit out of my league, to say
the least. lol
Date: 13 Aug 2014 02:02:39
Message: <53eaff7f$1@news.povray.org>
Oh, and yeah, because a) all the others out there have either failed,
been found to be stealing, or allowing stealing, or just flat suck (and
many of them are based on the open source version of Second Life).
Also, apparently Linden has gotten the clue that a lot of their original
design was.. problematic, and needs to be reworked, to continue
improving things, so a Second Life 2.0 is in the works. About damn time
too.. If they had waited too much longer "someone" might have actually
managed to blow their current system out of the water. There are..
interesting things coming out, but, mostly in the "pure game" market,
and without the versatility that SL provided in terms of pure ability to
build what ever you wanted in it.
Date: 13 Aug 2014 12:21:05
Message: <53eb9071$1@news.povray.org>
Had a thought on this.. Modifying the texture so you have, basically, a
white line that produces a hard transition to a height field, right
along the point of delineation between the peeled and non-peeled parts
would give you at least a start point, right? You would then have a sort
of "punch through" effect, where there is a ridge of material, all
around the point of transition. The problem then is doing something else
to the resulting height field so that its not a solid outline, but has a
more random "hang" and gaps in it, then... texturing gets a bit funky, I
admit, since you have to somehow get it to apply the right "underside"
coloration to the inside of this punch out, and the paint color, and
other variances, to the "outside". But, yeah, that is a tough one, since
I am not even sure how to get past the, "Use a modded version of the
texture to get a height field.", part. lol
Date: 13 Aug 2014 12:23:56
Message: <53eb911c$1@news.povray.org>
On the other hand.. Nah, that would be too thin and create possible
coincident surfaces. Was thinking to make the height field "wider" than
the hanging bit needs to be, then use difference to apply the texture to
the inside and outside parts, and to get the right material thickness.
Would, in theory, work, but, again, the material is so thin...
Date: 13 Aug 2014 18:07:59
Message: <53ebe1bf$1@news.povray.org>
To me that is much better, I can see the cat now. ;-)
IMO these images with deep shadows and bright sunlight need a compromise
as our eyes adjust in RL. But cannot do that on an image.
Don't you think that there should be some dust in the air?
Regards
Date: 14 Aug 2014 03:20:33
Message: <53ec6341@news.povray.org>
Those are a couple of interesting ideas... I'll shelf them for the time
being to let the brain cells time to adjust :-)
Date: 14 Aug 2014 03:25:40
Message: <53ec6474$1@news.povray.org>
Yes, and the compromising is delicate as the notion of 'acceptable'
tends to vary from person to person in this case. In the present case a
bit lighter or darker would also be possible. ;-)
Some dust. Yes indeed. Totally forgot that.
Some images are never finished. There are a lot of things I could still
tweak, add, move, etc in this one :-)
Date: 15 Aug 2014 12:46:01
Message: <53ee3949$1@news.povray.org>
It is IMO a tricky shot to call but I think that you have got it right
with this one.
You might be house proud I am not. :-)
That is so true.
Regards
Date: 15 Aug 2014 13:55:16
Message: <53ee4984@news.povray.org>
Am 14.08.2014 09:25, schrieb Thomas de Groot:
Not only does the notion of "acceptable" vary from person to person, but
-- I guess even more importantly -- it also varies from display to
display. Experience in these newsgroups has shown over and over again
that people complaining about images being too dark tend to change their
mind once they have been coaxed to calibrate their display properly.
Date: 15 Aug 2014 16:35:00
Message: <web.53ee6ea27572c768d19b0ec40@news.povray.org>
Nonsense. They just need to increase/decrease the number and density of
rods/cones in their eyes.
Date: 15 Aug 2014 17:00:38
Message: <53ee74f6$1@news.povray.org>
Old CRT I had before.. something must have overloaded the damn caps in
it, or something, at some point. It was so dark that even if you turned
up the gamma in games, or the like, it was still "darker" than it should
be. Never realized it was that bad, at all, until I decided to go with a
whole new system, with wide screen LCD, then.. Holy... lol
Date: 15 Aug 2014 17:36:47
Message: <53ee7d6f$1@news.povray.org>
LOL
A nice trick if you can do it. :-)
Regards
Date: 15 Aug 2014 18:52:25
Message: <53ee8f29@news.povray.org>
Am 15.08.2014 22:33, schrieb jhu:
That actually wouldn't do the trick. Turning off any other light sources
in the room might though, if the problem is reflection glare.
For wearers of corrective eyegear like me, cleaning the glasses from
time to time might also help ;-)
(And yes, dusting off the display may also helpful.)
Date: 16 Aug 2014 01:52:19
Message: <53eef193@news.povray.org>
+1
Top tips :-)
Regards
Date: 16 Aug 2014 07:30:48
Message: <53ef40e8$1@news.povray.org>
> with this one.
Yes, I believe so too. Now, I dearly need Bill's isosurface trick :-)
Neither am I!
Only this morning I took a little time to clear away the dust that had
accumulated on the less-used parts of my desk over the last 8 months ;-)
> That is so true.
And especially when different scenes are being worked on at the same time...
