POV-Ray : Newsgroups : povray.binaries.images : Perfect Polish Server Time
10 Jun 2026 15:43:14 EDT (-0400)
  Perfect Polish (Message 1 to 10 of 10)
Subject: Perfect Polish
Date: 22 Jul 2014 21:32:16
Message: <53cf10a0@news.povray.org>
... no, not the language ;-)
The spheres on the left and right have a subtle advantage over the
middle one: While the latter uses the fresnel formula only for variable
reflection, the former also use it to vary the diffuse term accordingly,
reducing it at shallow angles.
This effect is applied not only for the viewing angle, but also for the
incoming light angle, for perfect physical realism.
(Besides, the outer spheres also use the fresnel formula for highlights,
but it doesn't show here because the highlights are too bright.)
Download 'highlight_fresnel.png' (221 KB)
Preview of image 'highlight_fresnel.png'
Subject: Re: Perfect Polish
Date: 23 Jul 2014 03:37:11
Message: <53cf6627$1@news.povray.org>
Better & better!
Date: 23 Jul 2014 04:27:51
Message: <53cf7207$1@news.povray.org>
Am 23.07.2014 09:37, schrieb Thomas de Groot:
> Better & better!
Thanks; I'm quite happy with the last two days' work myself, too.
As this wraps up my efforts to improve the realism of the finish
properties, Unix jockeys can now get their share of it on
https://github.com/POV-Ray/povray/tree/master. (Yes, that's right - I
consider this essential enough to push it directly into POV-Ray proper.)
Date: 23 Jul 2014 07:04:20
Message: <53cf96b4$1@news.povray.org>
>> Better & better!
...and the poor Win users?
Date: 23 Jul 2014 08:41:14
Message: <53cfad6a@news.povray.org>
>> Better & better!
compiled just fine, however noticed a different warning is showing up
all over the place, here's the last occurrence:
../source/base/colour.h:117:72: warning: friend declaration
‘pov_base::GenericRGBColour<T> pov_base::ToRGBColour(const
pov_base::GenericColour<T>&)’ declares a non-template function
[-Wnon-template-friend]
../source/base/colour.h:117:72: note: (if this is not what you intended,
make sure the function template has already been declared and add <>
after the function name here)
only briefly followed threads you posted working up to this release and
it looks like it might be related to some of your recent work ... dunno
if it's worth looking into tho
Date: 23 Jul 2014 14:32:18
Message: <53cfffb2$1@news.povray.org>
Am 23.07.2014 14:41, schrieb James Holsenback:
>>> Better & better!
> .../source/base/colour.h:117:72: warning: friend declaration
> .../source/base/colour.h:117:72: note: (if this is not what you
> intended, make sure the function template has already been declared and
> add <> after the function name here)
Those warnings are nothing to worry about; according to my research, the
standard language construct we're using there had a different
(non-standard) meaning in older g++ versions, and the warning is only
there to alert of this potentially breaking change.
I've already prepared a change to configure.ac to set
"-Wno-non-template-friend" when compiling with g++, but it hasn't found
its way into the repo yet.
Date: 23 Jul 2014 14:44:23
Message: <53d00287$1@news.povray.org>
Am 23.07.2014 13:04, schrieb Thomas de Groot:
>>> Better & better!
> ....and the poor Win users?
They are poor old sods, yes :-P
Give me a bit of time to prepare something release-ish; I've just gotten
round to merging this fancy stuff into UberPOV ;-)
As a matter of fact I'm inclined to not do a semi-official Windows build
of POV-Ray for these features, and refer Windows users to the next
UberPOV beta instead, which I'm about to prepare any moment now.
Date: 23 Jul 2014 23:57:53
Message: <53d08441@news.povray.org>
Am 23.07.2014 20:44, schrieb clipka:
Now available at the following location:
https://github.com/UberPOV/UberPOV/releases/tag/v1.37.0.0-beta.6
Date: 24 Jul 2014 03:15:52
Message: <53d0b2a8$1@news.povray.org>
Perfect! Thank you.
Date: 25 Jul 2014 13:55:01
Message: <web.53d299496be55426bd5ee0540@news.povray.org>
> > Better & better!
It's a good work.
