POV-Ray : Newsgroups : povray.binaries.images : HDR compositing Server Time
28 Nov 2026 22:14:16 EST (-0500)
  HDR compositing (Message 1 to 9 of 9)
Subject: HDR compositing
Date: 26 May 2014 07:43:17
Message: <538328d5@news.povray.org>
Following my question in p.a-u, I searched the web for some free
software. I came across this site:
http://www.techsupportalert.com/best-free-high-dynamic-range-hdr-software.htm
and used the first one proposed (Fusion 1) to try out on a POV scene.
As render set, I used 4 renders of my Urbex scene with varying light
intensities and processed them through Fusion 1, using the Summator as
advised on the site. This is the/a result.
I think this looks quite promising while needing further experimentations.
Download 'urbex_hh_sum.jpg' (177 KB)
Preview of image 'urbex_hh_sum.jpg'
Subject: Re: HDR compositing
Date: 26 May 2014 07:54:17
Message: <53832b69@news.povray.org>
This would be a result using the HDR operator instead of Summation.
Download 'urbex_hh_hdr_mode_1.jpg' (140 KB)
Preview of image 'urbex_hh_hdr_mode_1.jpg'
Date: 26 May 2014 10:20:06
Message: <53834d96$1@news.povray.org>
Le 26/05/2014 13:54, Thomas de Groot nous fit lire :
> Thomas
I knew something was not right.... the old age painter might have done a
dual-tone paint: one below 1m or so, one above... maybe with a
contrasting line between the two. (dark below, lighter above)
And probably a different color for the ceiling... traditional white ? or
egg-like ?
Date: 27 May 2014 04:00:07
Message: <53844607$1@news.povray.org>
>> Thomas
> egg-like ?
I am following closely the original photograph where the whole space is
painted in the same way, walls and ceiling. There is however a wainscot
along the wall and the stairs. I have not yet provided that. Also, in a
later stage, I may diverge from the original of course ;-)
Date: 27 May 2014 04:08:51
Message: <53844813@news.povray.org>
I think I like this one better. It is a bit less extreme and I just left
some of the settings alone. Summation used.
Date: 27 May 2014 04:12:54
Message: <53844906$1@news.povray.org>
Forgot to add: based on four renders with different illumination
intensities.
About Fusion F1:
- the help does not work. However, a htm document is provided with the
program.
- The program also can read png files although this is not mentioned.
Date: 1 Jul 2017 17:25:01
Message: <web.59581262c49953343086cf1c0@news.povray.org>
> Thomas
It looks like the list has changed a bit because it no longer have HDR software
called Fusion 1. And it starts with Luminance. And there also a good tool
https://aurorahdr.com for creating HDR effect.
Date: 2 Jul 2017 02:03:53
Message: <59588cc9$1@news.povray.org>
Am 01.07.2017 um 23:22 schrieb Diane:
>> Thomas
Look at the site again - the first entry is still "Fusion" (not "Fusion
1" though).
Date: 2 Jul 2017 02:51:07
Message: <595897db@news.povray.org>
>>> Thomas
> 1" though).
IIRC, Fusion 1 became Fusion at some point. I have used it recently for
my own photography; /not/ POV-Ray ;-)
