POV-Ray : Newsgroups : povray.binaries.images : Again SSLT Server Time
15 Oct 2026 20:53:45 EDT (-0400)
  Again SSLT (Message 1 to 13 of 13)
Subject: Again SSLT
Date: 15 Feb 2014 10:07:12
Message: <52ff82a0@news.povray.org>
Years ago, I made a celadon texture. I was curious to see how it would
appear with SSLT added.
The superellipsoid has James Holsenback's marble texture (see Paradise),
also with SSLT.
Download 'sslt_test.png' (496 KB)
Preview of image 'sslt_test.png'
Subject: Re: Again SSLT
Date: 15 Feb 2014 10:32:00
Message: <52ff8870@news.povray.org>
Or like this.
Download 'sslt_test.png' (474 KB)
Date: 15 Feb 2014 10:47:06
Message: <52ff8bfa@news.povray.org>
Or, finally.
For those interested in the texture:
//-----start code
#declare TdG_Celadon =
material {
       bozo
       pigment_map {
         [0.0 color rgb <0.762025, 0.883775, 0.762025>]
         [0.2 color rgb <0.855688, 0.935979, 0.855688>]
         [0.5 color rgb <0.728519, 0.896481, 0.728519>]
         [0.8 color rgb <0.937467, 1.000000, 0.937467>]
         [1.0 color rgb <0.548054, 0.722746, 0.548054>]
     normal {
       crackle 0.5 solid
       warp {turbulence <0.1, 0.1, 0.1>}
       scale  0.1
     finish {
       diffuse 0.6
       specular 0.5
       roughness 0.005
       conserve_energy
       #if (SS)
         subsurface {translucency <0.45, 0.38,0.33>*0.5}
       reflection {
         0.01 , 0.2
         fresnel  on
         falloff  1.0
         exponent 1.0
   interior {ior 1.5}
//-----end code
Download 'sslt_test.png' (444 KB)
Date: 15 Feb 2014 11:58:59
Message: <52ff9cd3$1@news.povray.org>
> also with SSLT.
haha, cool ... nice job!
Date: 16 Feb 2014 05:28:04
Message: <53009290.3040800@gmail.com>
> also with SSLT.
> Thomas
Where did you learn to get your china so thin. I was never able to get
it less then 1 mm and have it survive. Though to be fair I normally use
standard clay. (my website
http://bytehouwer.nl/visitekaart/en/ceramics.html needs urgently an update)
Everytime the IT department forbids something that a researcher deems
necessary for her work there will be another hole in the firewall.
Date: 16 Feb 2014 07:03:50
Message: <5300a926$1@news.povray.org>
A well kept secret ;-) Although, looking at your examples, the (white)
compound vases come close to my bowl.
Date: 16 Feb 2014 15:35:30
Message: <530120EC.8030801@gmail.com>
>> update)
Raku fired, not celadon glazing. Both ancient asian techniques, but
rather different.
Date: 17 Feb 2014 03:30:32
Message: <5301c8a8@news.povray.org>
> rather different.
I saw a few other raku ceramics on your site if I am not mistaken. One
of my favourite techniques. I am not a ceramist myself but I highly
appreciate the work.
Date: 17 Feb 2014 08:45:01
Message: <web.530212104322838716086ed00@news.povray.org>
> Or, finally.
> //-----start code
> material {
>    texture {
>      pigment {
>        bozo
>        pigment_map {
>      normal {
>        crackle 0.5 solid
>        scale  0.1
>      finish {
>        diffuse 0.6
>        specular 0.5
>        roughness 0.005
>        conserve_energy
>        #if (SS)
>        #end
>        reflection {
>          0.01 , 0.2
>          fresnel  on
>          falloff  1.0
>          exponent 1.0
>    interior {ior 1.5}
> //-----end code
> Thomas
Nice! do you mind if I use it as a basis for one of the materials shared at the
below link?
http://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/Render/POV-Ray/Sample_Materials
Date: 17 Feb 2014 10:15:46
Message: <530227a2$1@news.povray.org>
On 17-2-2014 14:43, Mr wrote:
>> Or, finally.
>> //-----start code
>> material {
>>     texture {
>>       pigment {
>>         bozo
>>         pigment_map {
>>       normal {
>>         crackle 0.5 solid
>>         scale  0.1
>>       finish {
>>         diffuse 0.6
>>         specular 0.5
>>         roughness 0.005
>>         conserve_energy
>>         #if (SS)
>>         #end
>>         reflection {
>>           0.01 , 0.2
>>           fresnel  on
>>           falloff  1.0
>>           exponent 1.0
>>     interior {ior 1.5}
>> //-----end code
>> Thomas
> below link?
You have my permission :-) You may even change rgb to srgb in the
pigment. Makes the colour a bit fuller. However, Celadon comes in
several hues.
Date: 17 Feb 2014 17:18:22
Message: <53028A97.1040806@gmail.com>
>> rather different.
It is an interesting technique. Problem is that after you reduced the
oxides during firing, they start oxidising slowly during the months
after that.
I made also another set of compound vases (using a 3D printer to create
a mold) those colors are totally different (mostly greens and red) even
if I used more or less the same pigments.
Mainly fired my recent work in a more traditional way. I might return to
japanese techniques when I have objects that are suitable for that.
Perhaps another set of larger compound vases?
Date: 18 Feb 2014 03:17:25
Message: <53031715$1@news.povray.org>
>>> rather different.
> after that.
That's interesting. I didn't know that but seems logical indeed. So you
never know what to expect in the end. I think I like that :-)
Slight variations in temperatures? in burning times?
This is going a bit OT but... As raku, I particularly like the rougher,
simple objects. They are only simple at a superficial glance though.
Date: 18 Feb 2014 06:54:34
Message: <530349fa@news.povray.org>
An important hurdle is the Dragon Test :-)
Download 'sslt_test.png' (463 KB)
