POV-Ray : Newsgroups : povray.binaries.images : Paradise Server Time
15 Oct 2026 20:53:45 EDT (-0400)
  Paradise (Message 1 to 18 of 18)
Subject: Paradise
Date: 11 Feb 2014 23:21:22
Message: <52faf6c2@news.povray.org>
OK ... not what you expected ;-)
Playing around with subsurface
Download 'work.png' (4485 KB)
Preview of image 'work.png'
Subject: Re: Paradise
Date: 12 Feb 2014 01:58:57
Message: <52fb1bb1$1@news.povray.org>
Para-Dice! Nice!
Do not judge my words, judge my actions.
Ce courrier électronique ne contient aucun virus ou logiciel malveillant parce que la
protection avast! Antivirus est active.
http://www.avast.com
Date: 12 Feb 2014 02:05:01
Message: <web.52fb1d0727e1c16dd19b0ec40@news.povray.org>
Nice.
Now add focal blur and radiosity and report back the render time difference.
Mwahahahaaaaaa!!!
Date: 12 Feb 2014 03:24:27
Message: <52fb2fbb$1@news.povray.org>
Nice stuff and the pun is very appropriate indeed :-)
Date: 12 Feb 2014 06:40:23
Message: <52fb5da7$1@news.povray.org>
> Nice.
> Mwahahahaaaaaa!!!
Already done that ... with radiosity 47+ hrs and I didn't like the
results. I used Radiosity_Fast with pretrace_end 0.004, count 256 and
gray_threshold 1 /without/ sslt to gather the rad data. It looked pretty
decent. The 2nd run with gathered rad data and sslt missed the mark :-(
Is pre-gathered rad data a no-no in this case???
This version /tries/ to try to resolve with a 2nd fill light more
reasonable render time ~15hrs
Obviously I still have some work to do!
Date: 12 Feb 2014 06:58:49
Message: <52fb61f9$1@news.povray.org>
I'm suffering from the recent round of corny-ness in off-topic, and
couldn't resist ;-)
Date: 12 Feb 2014 09:54:05
Message: <52fb8b0d$1@news.povray.org>
> couldn't resist ;-)
I have not been there for some considerable time, so...
Date: 12 Feb 2014 12:05:01
Message: <web.52fba92e27e1c16d6d4f68260@news.povray.org>
Looks very nice indeed! =)
Date: 12 Feb 2014 13:35:01
Message: <web.52fbbeab27e1c16de66d855b0@news.povray.org>
Very nice, your dice.
I only wonder about the table. It seems to be of marble, a classic material for
SSLT. I suspect that there is no SSLT on it. But I fear this will prolong the
rendering time a bit.
Best regards,
Michael
Date: 12 Feb 2014 14:12:51
Message: <52fbc7b3$1@news.povray.org>
well I'm calling it a ground plane ... zero thickness box just big
enough to not see the edges with the camera view. It /does/ look like
marble but it done as follows:
#declare GroundPlaneMat =
material {
   #if (Detail)
     planar
     scale 0.5
     turbulence 1 lambda 3
     color_map {
       [0 srgb <0.9570,0.9570,0.8594>]
       [1 srgb <0.9570,0.9570,0.8594>/2] }
     finish {
       specular 0.15
       roughness 1e-1
     normal{
       planar
       scale 0.5
   #else
     pigment { srgb 1 }
the /main/ reason no sslt on ground plane is the scale factor in globals
used to make dice look good did not suit for the ground plane, and as
far as I know you can't have two different scales ... btw: used 15.
Here's the dice material:
#declare DieMaterial_=
#local Color = <0.5500,0.0900,0.0900>;
#local T_val = Color*2.75;
material {
     #if (Detail)
       pigment { srgb Color }
       finish {
         specular 0.5
         roughness 1/80
         reflection { 0, srgb Color*0.125 }
         #if ( Subsurface )
           subsurface { translucency srgb T_val }
     #else
       pigment { srgb 1 }
   interior {
     ior 2.5
Date: 12 Feb 2014 14:15:35
Message: <52fbc857@news.povray.org>
> Para-Dice! Nice!
  you're a poet and didn't even know it ;-)
Date: 12 Feb 2014 14:16:51
Message: <52fbc8a3@news.povray.org>
thanks ... i have a good start but still have some issues to resolve. i
think i can make it look better!
Date: 12 Feb 2014 14:40:18
Message: <52fbce22$1@news.povray.org>
>> Para-Dice! Nice!
I'm a poet and I know (humbly) it, but all my poor tries of poetry are
in french.
Date: 12 Feb 2014 15:36:38
Message: <52fbdb56@news.povray.org>
>>> Para-Dice! Nice!
> in french.
... was remembering an "old" saying that goes something like:
You're a poet and don't even know it, cause your feet show it. They're
longfellows.
Date: 12 Feb 2014 15:44:43
Message: <52fbdd3b$1@news.povray.org>
>>>> Para-Dice! Nice!
>> in french.
> longfellows.
It is the fortuity, some strange encounter. Maybe am I a poet, maybe you
are perspicuous and seer, sir.
Lionel.
Date: 12 Feb 2014 16:25:01
Message: <web.52fbe67727e1c16d6f82630d0@news.povray.org>
> material {
>    texture {
>    #if (Detail)
>      pigment {
>      planar
>      scale 0.5
>      color_map {
>      finish {
>        specular 0.15
>        roughness 1e-1
>      normal{
>        planar
>        scale 0.5
>    #else
>      pigment { srgb 1 }
>    #end
> material {
>    texture {
>      #if (Detail)
>        finish {
>          specular 0.5
>          roughness 1/80
>          #if ( Subsurface )
>          #end
>      #else
>        pigment { srgb 1 }
>      #end
>    interior {
>      ior 2.5
I think I have the solution! Make the floor a two-triangle mesh. Use the mesh
camera to bake an sslt texture for the ground!
I've been playing around with the mesh camera for my tcrtc entry. It's the best
thing since sliced bread!
Date: 24 May 2014 13:13:20
Message: <5380d330@news.povray.org>
Am 12.02.2014 05:16, schrieb James Holsenback:
Coincidently, this pun is /exactly/ what came across my mind when I read
the title :-P
Date: 24 May 2014 13:21:36
Message: <5380d520@news.povray.org>
Am 12.02.2014 20:12, schrieb James Holsenback:
Simple procedure to follow for /all/ sslt imagery:
(1) Figure out how large your scene objects are supposed to be in real
life. Set the scale (mm_per_unit) accordingly.
(2) Do /not/ mess with the scale or the size of your objects from now on.
(3) Tamper with the materials (especially the translucency) until they
look realistic.
