A rather surreal scene, I don't know why...
Almost done, except for the main subject which is being modelled presently.
This time, I returned to the use of isosurfaces (rocks and ground).
Render time about 5.5 hours. Not too bad.
Download 'elements of geology5_06.jpg' (250 KB)
Preview of image 'elements of geology5_06.jpg'
> Thomas
The texture of the rocks is very nice, like in a painting.
Imho the boulder is a bit strange.
Nevertheless a great scene!
Paolo
I like the premise! My rock hammer's an Estwing, so you can bet I'd be sore if I
lost it while out mineral hunting. The guy in your image could very well be me
(except for the fact that I always double-or-triple-check my pack before moving
on). The man in your image really should have a pack, BTW.
I agree with Paolo that there is something amiss with the boulder. To me it
seems a bit out of place... but of course getting loose rocks to match the
landscape has always been a problem, IME.
Could be much better, though. Are you using radiosity? If so, you can actually
get away with a count of 1, provided your surfaces are sufficiently detailed.
I'll try to post something to the TINA CHeP EOG thread later today to show you
what I mean.
Sam
Great minds think alike ;-) My hammer is also an Estwing, and been with
me for the last 50 years. Never lost it happily. It now gets a bit rusty
in places... I am now modelling it for the scene; first a low detail
version, but I intend to make a high resolution one later on for a
projected close up of sorts. The least I can do for its faithful
services :-)
Indeed, the guy could also be me in fact. The pack is a good idea. I
shall work on that too.
Yes, absolutely. I fact I had already decided to throw it out and
replace it with something better integrated in the scene.
> what I mean.
I am curious to see what you mean. I am indeed using radiosity. The
isosurface max_gradient is pretty low, much lower than recommended by
POV but giving the details I intend to get. With a lower count, I may
need to increase the max_gradient though.
Yes, I fully agree. I am going to throw it out and put something else there.
Thanks Paolo!
Btw, you did a great job with your glacier moulin at the TC-RTC. I like
the original idea. One comment though about your second image: the
captions there should be like cardboard cards glued to the model's
surface don't you think? I remember having seen those kind of models in
natural history musea.
Thank you for the suggestion: I will update the image!
Paolo
Some changes.
- Replaced the rock by a new outcrop.
- increased the wave length of the ripple function of the sand.
- switched off the media which washed out the sky and made the render
longer.
This time, render time is 3 hours and 12 minutes.
Download 'elements of geology5_07.jpg' (252 KB)
Preview of image 'elements of geology5_07.jpg'
> Some changes.
> longer.
> Thomas
Hi Thomas,
These are all good improvements, I was going to suggest trying a blue sky to
improve the contrast/make the clouds stand out more. Wish I had done now as it
would make it look like I offered good advice ;-)
Sean
sky to
I knew already that you would say this ;-)
I was not too happy with that media which did not add much to the scene.
However, I might work on a small dust cloud generated by the wind.
Also, to give credit where credit is due: Scott's Skysim is used in
combination with CIE.inc for the sunlight.
>Thomas de Groot on date 10/07/2013 13.08 wrote:
> Some changes.
> longer.
> Thomas
Very good!
But... where is the hammer? Give us some hints!
Paolo
On 10-7-2013 16:49, Paolo Gibellini wrote:
> Very good!
For the time being, it is really lost. The good news is that it is being
modelled and will soon appear in the scene.
> services :-)
Good brand! I've had mine for about 14 years or so now, and it's badly in need
of a second sharpening already. (The ground doesn't dig itself... well sometimes
it does.) I'm looking forward to seeing your model when you finish it!
I'm not sure increasing the max_gradient is necessary, as all that does is fill
in the holes. If anything, you may need to lower the isosurface's accuracy if
you intend to lower the radiosity's count.
One of my isosurface tests has been posted to the TC-EOG-RTC thread:
http://tinachepforum.forumup.co.uk/viewtopic.php?p=3636&mforum=tinachepforum#3636
That image rendered in 5 minutes 39 seconds, which isn't too bad, all things
considered.
Here's the scene's radiosity block:
radiosity{
count 1
error_bound .1
recursion_limit 1
nearest_count 1
normal on
some isosurface settings:
accuracy 0.001
max_gradient 10
and the command line parameters:
+fn +f +a0.3 +am2 +r2 +j0.2
I can post the entire source (with include files) if needed.
An important thing to keep in mind is to always have enough small details on
your surfaces by using things like surface normals and/or and low isosurface
accuracies. Low aa settings help a great deal as far as speeding things up as
well.
Sam
Do you have the pick or shovel model? Mine is a pick model and the point
is fairly rounded now although still able to neatly insert itself in
crevices. The head part is now badly chipped in places but I love it
that way; showing its age and wear & tear ;-) The leather handle is
fairly roughened now. In dry environments it needs a bath from time to
time when the leather rings dry out and contract. Oh well... a bit of
nostalgic talking, don't I? I am not going much places anymore these days...
The hammer model is progressing smoothly.
I am indeed also using a max_gradient of 10 in my scene. THe accuracy
presently is 0. As radiosity count I use the adaptive method, presently
50, 1000. I generally leave it at that, but I probably can lower the
lower end more. I shall test that.
> considered.
Yes, that is very fast.
> well.
Yep.
>> Very good!
> Thomas
Ok, this is a comforting news ;-)
Paolo
>> does is fill
>> accuracy if
Just a quick note.
I am not correct when I say adaptive /count/. It should be adaptive
/nearest_count/ of course, for which I use the values 10, 5.
After a quick test, I see that I can get away with a much lower count
value. In general, I think I am using too high radiosity settings in my
scenes as I generally leave them at settings I consider as my defaults...
Next, with the hammer and some flying dust.
Download 'elements of geology5_08.jpg' (248 KB)
Preview of image 'elements of geology5_08.jpg'
Nice composition too. It makes me want to shout out to him.
Regards
The pick model, just like the one in your most recent rendering, only less rusty
My brother did happen to find me an old army spade. Great tool; the shovel part
folds back into the wooden handle, so it just barely fits into my backpack. My
prospecting toolkit now has four implements: rock hammer; shovel; flat head
screwdriver; screen (1/4" carpenter's cloth + narrow steel rods for edge
support). All that extra weight means I'm going to need a backpack frame,
though. Don't know if I should buy one or make one yet... I might go with an
Alice pack, like the ones the US military uses.
That's a shame! You've got to get out there sometime :)
Oftentimes I can get away with a max_gradient of 1 or 2. POV-Ray usually
suggests values much higher than those which are really needed.
Makes all the difference in the world. For isosurface scenes I begin with a
count of 1 and work my way up if needed, usually up to 16.
Whats up with importance sampling, BTW? I thought it would allow you to
effectively use a lower count for specified objects in a scene, but my tests
didn't seem to support that notion. It would be nice to force isosurfaces to
render with lower rad counts than other objects.
Nice! I love the irony :)
That reminds me, just this week I was playing with Blender's smoke simulation. I
have now managed to get smoke from Blender to actually render in POV-Ray. (I
think somebody was asking about that very same thing awhile ago in p.general,
but explaining my process is probably going to require a tutorial, and I'm not
up for that right now.)
Sam
Those spades are great indeed. I had one too. It can also be fixed
perpendicular to the handle for shovelling sand rapidly.
I need to model a backpack now...
Oh well. I have done my lot of travelling over the world. Nowadays I am
just content to watch other people going places. ;-)
<grin>
All the more reasons for me to get a grip on Blender. :-)
He won't listen, I know. ;-)
> Thomas
LOL Speaking from experience?
Regards
> Thomas
Goes together. I suppose that you are going to use Poser's cloth room.
Regards
>> Thomas
Yeah... A bit stubborn I guess ;-)
>> Thomas
Possibly. Not sure yet if I make it purely a prop or if I combine that
with the cloth room for the straps.
> >> Thomas
> Thomas
I was thinking of the cloth room for the shape of the pack. In my mind’s eye I
see the backpack as being of the smaller type and either frame less or having an
internal frame.
> internal frame.
Frame-less (or internal indeed). Something like the image. I have used
all sorts of packs, from one-strap canvas side-packs to the old
onion-shaped backpacks, and even thin nylon flimsy packs, not to mention
supermarket carrier bags ;-) It really depends on the project under way.
My preference is for the one shown on the image.
As far as Poser is concerned, the body can be as rigid as necessary
while only the straps need Cloth Room modelling to settle the whole
thing on the back of the figure, or that is how I imagine things presently.
Download 'fjallraven-20l-backpack.jpg' (146 KB)
Preview of image 'fjallraven-20l-backpack.jpg'
> > internal frame.
Yes, your preference would be easier to model. My romantic image is of an onion
type with or without a bullwhip. ;-)
Very important IMO, not to have the straps looking as if they are made of wood.
<grin> Those were hell to carry. Pulling you shoulder out of joint.
Absolutely.
Quick & Dirty: a first /portrait/ of my hammer.
Download 'elements of geology6.png' (270 KB)
Preview of image 'elements of geology6.png'
> Absolutely.
> Thomas
Even this one is nice. The picture is a little bit small to really judge it. I
think the rust stains are a little bit to sharp. And for the backpack in the
original scene, why bother about the straps? The guy is only seen from behind.
If you will not reuse him with other pictures just put the backpack believable
at his back and forget about the cloth room.
Best regards,
Michael
No need to do much traveling, unless you live in a city. Seeing things firsthand
can produce fresh inspiration above and beyond that which is produced by merely
looking at images. The complexity of the natural world never ceases to amaze me.
> > have now managed to get smoke from Blender to actually render in POV-Ray. <snip>
Ain't nothing to it but to do it (c:
Sam
Thanks Michael. There is more work to do on the model indeed as this is
just an in-between render just for showing progress.
Yes, that might be a good idea indeed. I like to make complete models
but in this case I just might get away with your suggestion. I have no
immediate use of a backpack at this moment ;-)
Oh yes! I absolutely agree. I live in the country, with a mixed
landscape of cultivation, woods, and moors. I do a lot of bicycling
around, often with camera, at all times of the year. Having worked on
the geology in this area, I like to peel off the different layers in my
mind and reconstruct former worlds around me :-) Even in a 'flat'
country like NL, the geological past can be quite complex in some
places. No much use of a hammer though, hence the rust. ;-)
> Thomas
A very neat image!
Perhaps needs some crow watching at the scene?
Paolo
