POV-Ray : Newsgroups : povray.binaries.images : Glass Jar Server Time
28 Nov 2026 23:10:24 EST (-0500)
  Glass Jar (Message 1 to 35 of 35)
Subject: Glass Jar
Date: 1 Jul 2013 14:34:38
Message: <51d1cbbe@news.povray.org>
I'm testing a user contributed fix related to
http://bugs.povray.org/task/287 and thought the image was cool enough to
share. It's a work in progress so I'm not entirely sure where it will
end up.
Oh and I had opportunity for an unexpected extra test. We had a storm
roll through and lost power for a few minutes. My 1st response was CRAP
eight hours down the drain, but the I remembered +C option. Since the
scene has photons I just loaded the already generated photon map instead
of regenerating the map, and then enabled continue trace and she
finished up the last ten minutes of the render without a hitch!
Jim
PS: the fix probably won't make it into 3.7.0 release because of code
freeze.
Download 'work.png' (927 KB)
Preview of image 'work.png'
Subject: Re: Glass Jar
Date: 2 Jul 2013 02:57:07
Message: <51d279c3@news.povray.org>
I love it. Not in the least, the harmony of colours.
Date: 2 Jul 2013 06:52:05
Message: <51d2b0d5$1@news.povray.org>
> end up.
Surely the jar is very good, it seems /real/ (and thanks to the +C option!).
Paolo
Date: 2 Jul 2013 08:51:06
Message: <51d2ccba$1@news.povray.org>
>> end up.
> option!).
> Paolo
Well I can't take credit for the jar:
http://www.blender-models.com/model-downloads/objects/id/decorative-oct-glass-jar-ver-3/
I think I'm going to try to separate the lid from the rest of the jar,
and place it on the ground plane, with a few other objects
Date: 2 Jul 2013 08:57:22
Message: <51d2ce32$1@news.povray.org>
> Thomas
the glass is srgb <0.6875,0.8750,0.8984> the smaller tiles *0.1 ...
they're slightly reflective and picking up nice hue from the hdr map.
amazingly only lit by single area_light
Date: 2 Jul 2013 16:09:23
Message: <51d33373@news.povray.org>
> end up.
> Jim
> freeze.
Very good.
By the way, it's /feature/ freeze. I think that there is still place for
some bug and glitches fixes.
Date: 2 Jul 2013 17:15:01
Message: <web.51d3420b6fab5b2d3dbcff020@news.povray.org>
> >> end up.
> > option!).
> > Paolo
That may improve your still fine image. I would like to see the result.
Best regards,
Michael
Date: 2 Jul 2013 18:45:01
Message: <web.51d3571c6fab5b2dc2d178100@news.povray.org>
Nice doyley, how exactly do you make such an object? The glass jar looks good as
well of course.
The +C option is IMO one of the most important features in POV, especially with
some of my renders that run for several days. Has saved me smashing my
PC/desk/anything else nearby on many an occasion ;-)
Sean
Date: 3 Jul 2013 07:34:41
Message: <51d40c51@news.povray.org>
> well of course.
It's been in my toolbox for sometime now, and I've used it several
times. It found an image of the doily on a black background. In GIMP I
did select by color and was able to get enough of the image to cut then
paste into a new image that I placed on a transparent background then ...
#declare DoilyPattern =
	image_map {
		png "doily.png"
		once
#declare Doily =
box { <0,0,0> <1,1,0.001>
		pigment { DoilyPattern }
		finish { diffuse 0.5 emission 0.01}
	translate <-0.5,-0.5,0>
	rotate x*90
	translate y*0.005
object { Doily scale <5,1,5>
the last translate in y direction helped with the appearance of
thickness as it casts a shadow underneath.
I've attached the image ... hope you can find it useful in one of your
scenes
indeed
Download 'doily.png' (626 KB)
Preview of image 'doily.png'
Date: 3 Jul 2013 07:45:30
Message: <51d40eda$1@news.povray.org>
>> end up.
>> Jim
>> freeze.
> Very good.
Maybe we're talking semantics here. After I cleaned up the users code
,honoring the style already in the source ... "When in Rome do as the
Romans do ... correct? I was asked to hold off submitting the "fix" ...
in other words this wasn't a feature addition. So I'm sticking with
"code" freeze.
Date: 3 Jul 2013 07:53:17
Message: <51d410ad@news.povray.org>
>>>> end up.
>>> option!).
>>> Paolo
> Best regards,
> Michael
I'd like to work something in that I can use SSLT ... something organic
like a fruit, vegetable, flower to offset the symmetry and hard angles
of the jar and ground plane.
Date: 3 Jul 2013 18:40:02
Message: <web.51d4a7166fab5b2d6454fc670@news.povray.org>
Nice image, James!
Just in case you didn't already know, in Blender it is easy to separate
disconnected geometry from meshes:
1) In edit mode, select one vertex of the jar's lid and press Ctrl+L to
automatically select all connected vertices.
2) Press P to separate it from the mesh. This will create a new object.
Of course, this will only work if the lid is truly a separate object...
otherwise you have quite the job ahead of you :)
Sam
Date: 3 Jul 2013 19:35:37
Message: <51d4b549$1@news.povray.org>
On 07/03/2013 06:35 PM, Samuel Benge wrote:
> Nice image, James!
> Sam
Thanks twice ... I successfully separated the object into container,
lid, and top decoration.
Date: 3 Jul 2013 20:05:01
Message: <web.51d4bbf06fab5b2da79a3c300@news.povray.org>
NP. Are you planning to make a boolean union of the lid and top decoration? I've
found that Blender's boolean modifier can be dodgy at times, especially if the
base mesh hasn't been triangulated.
Date: 4 Jul 2013 02:15:01
Message: <web.51d512d36fab5b2dc2d178100@news.povray.org>
> It's been in my toolbox for sometime now..
Thanks for providing the code/image. That was the only way I could think of
making such an object but did not think it would work as well as your example
does. The raising it slightly to produce the shadow works really well as I would
never have guessed it was an image map.
Sean
Date: 4 Jul 2013 06:53:12
Message: <51d55418$1@news.povray.org>
Haven't even noticed the union modifier ... I /was/ going to just use
Join in object mode. I'll have a look!
Date: 4 Jul 2013 13:00:01
Message: <web.51d5a8e46fab5b2d4f79afa40@news.povray.org>
Blender's funny like that: certain things are only available as modifiers. I was
scratching my head for the longest time one day trying to figure out how to find
a happy medium between flat shading and smooth... you know, to break the smooth
shading along only the sharp edges of a mesh. The one solution was found where?
The modifiers tab, of course (Add Modifier->Generate->Edge Split) ;P
It's a very confusing program when just jumping in, but it's really not as
poorly designed as it seems at first glance. I've been especially impressed by
its modeling capabilities. And by using modifiers, you can keep your mesh design
as simple as possible until it's time to export it.
Date: 20 Jul 2013 08:48:11
Message: <51ea870b@news.povray.org>
>>> end up.
>> option!).
>> Paolo
well i managed to get the lid separated from the jar ... and the
additional objects started out as jelly beans, but traditional jb colors
just didn't seem to go with the rest of the objects, i went to pastels
colors. now i think they look like jordan almonds. i like the
subsurface, so i think i'll probably end up making the candies more
almond shaped.
Download 'work.png' (841 KB)
Date: 20 Jul 2013 12:44:45
Message: <51eabe7d$1@news.povray.org>
>>>> enough to
>>>> end up.
>>> option!).
>>> Paolo
> almond shaped.
I'd like to see the gelly beans version.
A question:
Why does the grout between the tiles protude above them?
Date: 20 Jul 2013 13:19:04
Message: <51eac688$1@news.povray.org>
Am 20.07.2013 14:47, schrieb James Holsenback:
> almond shaped.
Nice one; but it looks quite artificially placed; maybe move the doily a
deal to the top left, to make it look more like the jar had toppled over?
And then, of course, the candies call for the Bullet Physics Playground...
Date: 20 Jul 2013 13:31:39
Message: <51eac97b@news.povray.org>
>>>>> enough to
>>>>> end up.
>>>> option!).
>>>> Paolo
>> almond shaped.
> A question:
the grout a normal (tiling pattern slope map) ... this version used
radiosity and i'm considering using a fill light instead. the shadows
look kind of flat-ish around some of the candies as well. maybe that's
contributing to what you're seeing.
Date: 20 Jul 2013 13:37:33
Message: <51eacadd$1@news.povray.org>
>> almond shaped.
lol ... yes my in-house critic mentioned that as well
yes that's what i used and i wasn't 100% happy. i was hasty with how
they were clustered together, before dropping them. i also need to come
up with a better color distribution method ... currently it's a pretty
basic odd/even
Date: 20 Jul 2013 17:07:34
Message: <51eafc16@news.povray.org>
doh ... think i found the problem. i used rad_def.inc:
Rad_Settings(Radiosity_Normal, off, off)
Date: 22 Jul 2013 16:35:40
Message: <51ed979c@news.povray.org>
If I decide to go with jelly beans, I think the jar needs to be clear.
It's a toggle, so I can go back to jordan almonds easy enough. I messed
with the physics a bit and found that math.random (6) returns an integer
from 1 to 6 which helped distribute the colors better. I'm not all that
crazy about the pattern, what I think I should really do is fill a
container with the beans and tip it over.
Download 'work.png' (834 KB)
Date: 22 Jul 2013 17:55:56
Message: <51edaa6c$1@news.povray.org>
   IIRC, for the pills pot image
(http://www.ignorancia.org/uploads/images/take-your-meds/wips/prescription-05.jpg)
my solution was to let the pills fall just in front of the pot, which
was already tipped over and empty: a few pills entered into the pot, so
it ended looking as if it was tipped over while filled with pills.
Jaime
Date: 24 Jul 2013 11:03:33
Message: <51efecc5@news.povray.org>
> Jaime
Good idea ... I like this distribution much better! I'm not sure what
happened to the sslt on a couple of the candies. Maybe I should not have
done a separate photon run, then picked up he sslt later.
Download 'work.png' (920 KB)
Date: 24 Jul 2013 20:14:50
Message: <51f06dfa$1@news.povray.org>
>> Jaime
Nice.
To enhence the impression that the jar was toppled over, I'd place the
lid upside down and relocate it in front of the jar's oppening.
It still look as if the grout is casting shadows on the tiles. Have you
tried negating your bormals or bump papping?
Date: 24 Jul 2013 20:28:11
Message: <51f0711b$1@news.povray.org>
>>> Jaime
> Nice.
Yep ... I was considering that, but have resisted since I like the
detail on the top of the lid. Maybe photons will show some of that on
the ground plane ... OK you convinced me!
OK /now/ I get what you were talking about. I think it's a color_map
issue. I /was/ trying to do some transition shading. I'll have to double
my settings.
Date: 26 Jul 2013 07:13:05
Message: <51f259c1@news.povray.org>
Thanks for the ideas etc ... I think I'm getting close
Download 'work.png' (843 KB)
Date: 26 Jul 2013 07:24:48
Message: <51f25c80$1@news.povray.org>
Absolutely.
Date: 28 Jul 2013 17:10:33
Message: <51f588c9$1@news.povray.org>
I totaly agree :)
Now, add a few translucent jelly beans mixed with those mints...
Date: 2 Aug 2013 16:37:40
Message: <51fc1894@news.povray.org>
On 07/01/2013 02:33 PM, James Holsenback wrote:
> <snip> and thought the image was cool enough to
> end up.
Well I'm calling this one final (except for the image size) ... photons,
area_light and subsurface (jelly beans) took 27hr 40min 45 sec. I was
using the system off and on so probably not a fair benchmark.
Thanks y'all for the feedback, I'm happy how it turned out!
Download 'work.png' (771 KB)
Date: 2 Aug 2013 17:32:23
Message: <51fc2567$1@news.povray.org>
That is very, very good. But could you do something about the jelly
beans all being perfectly balanced, in  the same plane?
Regards
Date: 3 Aug 2013 07:15:40
Message: <51fce65c$1@news.povray.org>
I dropped them vertical (points up and down) and that's how they settled
... they even oscillated back and forth before they settling. I had to
play around with mass and friction settings to keep them from scattering
all over the place. I suppose I could change the mass of /some/ of them
and maybe get a few to pile on top of the others, but I'm not sure the
shape (basically round) would behave that way naturally.
Date: 3 Aug 2013 07:41:06
Message: <51fcec52$1@news.povray.org>
I've not tried bullet-physics-playground, yet. It is definitely on my to
do list. I agree about the shape, can you offset the centre of gravity,
inside the bean?
Regards
