Subject: POVEarth: Tristan da Cunha: gaps between mesh2 triangles
Date: 30 Jun 2013 15:00:40
Message: <51d08058@news.povray.org>
Hi(gh)!
Meanwhile, I managed to produce some first crude ground based views of
Tristan da Cunha (from Inaccessible Island towards the main island) at
"pedestrian height". i. e. 1.7 metres above the ground. The ocean
currently is a simple dark blue global sphere (to be replaced by some
semi-transparent basic water texture later on), the sky a simple
sky_sphere with a gradient aligning with the local normal vector (to
replaced either by Bruno Cabasson's or Christoph Hormann's atmosphere
model), also the terrain texture soon will be replaced by a Blue Marble
satellite mosaic texture (scaled from originally 240 x 240 to 3601 x
3601 pixels, as this is the original data resolution of the underlying
ASTER DEMs.
But now a problem shows up which I faced already some years before: gaps
between the single mesh2 triangles! I remember having dealt with this as
early as 2004 and, with help from Mike Williams, also satisfactorily
solved: just by translating the center of the Earth (and thus the mesh2)
by an amount which places the mesh2 vectors at coordinates of relatively
small orders of magnitude (i. e. not millions but rather thousands or
even only hundreds of POV units). Back then it worked fine (as you can
see with my "Flight over Afghan mountains" animation:
https://www.youtube.com/watch?v=abgq4Zo_nOw ) - but now it doesn't anymore!
Regardless which overall scaling factor I use (in the attached image
sequence from 1 down to 0.0001), the gaps never completely disappear...
instead, at very small values, increasingly portions of the mesh are
shadowed which should be illuminated.
Can be anything done about this - or is this an inaccuracy of POV-Ray
which is entirely unavoidable?
See you in Khyberspace!
Yadgar
Download '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 2.jpg' (38 KB)
Download '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 3 (scaling factor 0.1).jpg' (46 KB)
Download '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 4 (scaling factor 0.01).jpg' (44 KB)
Download '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 5 (scaling factor 0.001).jpg' (40 KB)
Download '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 9 (scaling factor 0.0009).jpg' (47 KB)
Download '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 8 (scaling factor 0.0008).jpg' (46 KB)
Download '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 7 (scaling factor 0.0005).jpg' (32 KB)
Download '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 6 (scaling factor 0.0001).jpg' (24 KB)
Preview of image '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 2.jpg'
Preview of image '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 3 (scaling factor 0.1).jpg'
Preview of image '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 4 (scaling factor 0.01).jpg'
Preview of image '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 5 (scaling factor 0.001).jpg'
Preview of image '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 9 (scaling factor 0.0009).jpg'
Preview of image '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 8 (scaling factor 0.0008).jpg'
Preview of image '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 7 (scaling factor 0.0005).jpg'
Preview of image '2013-06-30 tristan da cunha from inaccessible island, pedestrian view, take 6 (scaling factor 0.0001).jpg'
Subject: Re: POVEarth: Tristan da Cunha: gaps between mesh2 triangles
Date: 30 Jun 2013 15:28:37
Message: <51d086e5$1@news.povray.org>
Just a short in the dark, Jorg.
Blender has the functionality to fill a hole in a mesh with faces.
http://wiki.blender.org/index.php/Doc:2.4/Tutorials/Modeling/Meshes/Fill_Faces
It might help and it is free. ;-)
Regards
Date: 30 Jun 2013 16:09:10
Message: <51d09066@news.povray.org>
Hi(gh)!
Yes, I heard of Blender (and sometimes even used it) - but this is
probably not the solution, as "technically", the mesh is complete, i. e.
no triangles are missing. It must be an accuracy or epsilon problem...
Yadgar
Date: 30 Jun 2013 16:25:10
Message: <51d09426@news.povray.org>
On 30/06/2013 9:09 PM, Jörg 'Yadgar' Bleimann wrote:
> Hi(gh)!
> Yadgar
As I said. It was a shot in the dark.
Regards
Date: 1 Jul 2013 03:03:12
Message: <51d129b0@news.povray.org>
It seems to me that the triangle are floating, the vertices not being
joint properly together. If that is true, the solution is simple: load
the mesh2 into Poseray, go to Groups, push the button labelled Weld
vertices, save as mesh2 again.
Additionally, beware indeed of epsilon issues. Put the camera a little
bit higher from the ground.
Date: 1 Jul 2013 04:56:21
Message: <51d14435$1@news.povray.org>
Hi(gh)!
I think they should, as this is the code for the mesh2:
#declare Earth_Slice=
mesh2
vertex_vectors
xdim*ydim
#declare row=0;
#while (row<ydim)
#declare col=0;
#while (col<xdim)
#declare clrvect=eval_pigment(map, <1/(xdim*2)+col/xdim,
1-(1/(ydim*2)+row/ydim), 1>);
// #warning concat("<",vstr(3, clrvect, ",",7,2),">")
// #warning concat(str(col,2,0)," ",str(row,2,0))
#declare hval=clrvect.red*65280+clrvect.green*255;
#declare hval=-deadsea+rng/65535*hval;
// #warning str(hval, 1, 2)
(rd+hval)*<sin(radians(-longstart-col/xdim))*cos(radians(latstart-row/ydim)),
sin(radians(latstart-row/ydim)),
cos(radians(-longstart-col/xdim))*cos(radians(latstart-row/ydim))>*sf
#if (!(row=ydim-1 & col=xdim-1)) // no comma after last vector
#declare col=col+1;
#declare row=row+1;
face_indices
(xdim-1)*(ydim-1)*2
#declare r=0;
#while (r<ydim-1)
#declare c=0;
#while (c<xdim-1)
<r*xdim+c, r*xdim+c+1, (r+1)*xdim+c>,
<r*xdim+c+1, (r+1)*xdim+c+1, (r+1)*xdim+c>
#if (!(r=ydim-2 & c=xdim-2)) // no comma after last vector
#declare c=c+1;
#declare r=r+1;
texture
pigment { color rgb <0, 0.8, 0> }
finish { ambient 0.1 diffuse 1 brilliance 0.4 }
double_illuminate
translate ApproxLook*sf
Poseray? Is it free?
In my current scene, the camera is placed at "pedestrian eye's height",
i. e. 1.7 metres above ground. But the problem remains with any camera
height - the gaps then show up as black dots on the terrain!
Yadgar
Now playing: Master of Sensation (Eloy)
Date: 1 Jul 2013 05:57:56
Message: <51d152a4$1@news.povray.org>
Yes, it is an excellent program
https://sites.google.com/site/poseray/
Regards
Date: 1 Jul 2013 07:19:33
Message: <51d165c5$1@news.povray.org>
> mesh2
> vertex_vectors
> xdim*ydim
> #declare row=0;
> #while (row<ydim)
> #declare col=0;
> #while (col<xdim)
I cannot read that ;-)
Thinking a bit more about this, meshes with loose triangles at least
have their vertices at the /same/ locations; here there seems to be a
gap. Either, this is already present in the original DEMs, or the math
above for the conversion has some errors... Difficult to say.
Poseray is free indeed and it is worth a try. If it does not solve the
issue, then other solutions have to be found. In Poseray, the tolerance
for welding vertices can be adapted. Start with the default; if
necessary increase the value gradually.
Date: 1 Jul 2013 08:05:27
Message: <51d17087@news.povray.org>
> mesh2
> vertex_vectors
> xdim*ydim
> #declare row=0;
> #while (row<ydim)
> #declare col=0;
> #while (col<xdim)
I would put something very simple like this for debug purposes:
<row,col,hval>
> face_indices
> (xdim-1)*(ydim-1)*2
> #declare r=0;
> #while (r<ydim-1)
> #declare c=0;
> #while (c<xdim-1)
That looks fine to me.
Put your camera in a suitable location for the above debug mesh to show
up, and put a constant coloured background so that you can see the
difference between shadowed areas and areas not rendered properly.
Assuming the above test works then I would gradually build back up to
your equations (maybe first changing the scale to match, then
introducing the trig) to see what causes the problems.
My guess is accuracy because you are dealing with a huge dynamic range
of dimensions.
Date: 1 Jul 2013 08:20:39
Message: <51d17417$1@news.povray.org>
>> vertex_vectors
>> xdim*ydim
>> #declare row=0;
>> #while (row<ydim)
>> #declare col=0;
>> #while (col<xdim)
Even if it has errors it shouldn't introduce gaps as he is using
face_indices to reference the vertices (all 6 triangles using that
vertex will have exactly the same value, even if it is an incorrect value).
Date: 1 Jul 2013 15:40:03
Message: <op.wzj58xdxufxv4h@xena>
I would love to visit Tristan da Cunha one day :)
There are so many beautiful and interesting features on this island. My
first impression on Google Earth was "dead, dry and boring" until I took a
closer look.
-Nekar Xenos-
Date: 2 Jul 2013 01:39:32
Message: <51d26794@news.povray.org>
Hi(gh)!
Same with me... but it is, at least from Europe, even further away and
more difficult to reach than Afghanistan! And there are many more
interesting islands in the southern temperate and subantarctic zone...
ever heard of Amsterdam Island? It's somehow Tristan da Cunha's
counterpart in the Indian Ocean!
All these islands appear interesting to render within my megalomaniac
POVEarth project... especially when it comes to vegetation and fauna
(any albatross model ready?)!
Yadgar
