POV-Ray : Newsgroups : povray.binaries.images : POVEarth: I just don't get it... Server Time
28 Nov 2026 23:10:24 EST (-0500)
  POVEarth: I just don't get it... (Message 1 to 7 of 7)
Subject: POVEarth: I just don't get it...
Date: 28 Jun 2013 17:40:17
Message: <51ce02c1@news.povray.org>
Hi(gh)!
After a longer retreat from active POVing (and, instead, collecting
elevation data for my POVEarth project), I started to generate
heightfields from ASTER GeoTIFFs (3601 x 3601 data points per degree)
and, subsequently, curved mesh2s (following the curvature of Earth's
surface) from these heightfields.
But whatever I try, all I get is an empty black scene... I tried
tweaking the distance of the sun (Earth's center is at the origin), the
illumination direction, correctly applying rotations of mesh2, camera
position and camera direction, but no effect at all.
The scene should show a bird's view of the Tristan da Cunha archipelago
in the southern Atlantic Ocean from about 10000 metres (currently only
the bare relief with a simple green texture, no ocean or realistic
satellite mosaic texture yet)...
Here is the code:
// Begin of code
#include "functions.inc"
#declare sf=0.001; // scaling factor to avoid epsilon problems
#declare os=0; // 0: Linux, 1: Windows
#switch (os)
   #case (0)
     #declare path="";
   #break
   #case (1)
     #declare path="../SRTM/png_patched/";
   #break
global_settings
   assumed_gamma 2
#declare xdim=3601;
#declare ydim=3601;
#declare deadsea=422;
#declare everest=8848;
#declare rng=deadsea+everest;
#declare rd=6378140;
#declare latstart=-37;   // meshes are calculated from
#declare longstart=-13;  // the northwestern to southeastern corner of
the original DEM tile
#declare res=3601;
#declare map=
pigment
   image_map
     png concat(path, "s38w013_corrected.png")
#declare Cam_Azi=-89.99999;
#declare Cam_Dir=0;
#declare Cam_Lat=-37.5;
#declare Cam_Long=-12.5;
#declare Cam_Height=10000;
#declare Earth_Pos=0;
#declare Earth_Tilt=0; // 23.439281;
#declare Earth_Rot=0;
#declare Earth_Slice=
mesh2
   vertex_vectors
     xdim*ydim
     #declare row=0;
     #while (row<ydim)
       #declare col=0;
       #while (col<xdim)
         #declare clrvect=eval_pigment(map, <1/(xdim*2)+col/xdim,
1-(1/(ydim*2)+row/ydim), 1>);
         #declare hval=clrvect.red*256+clrvect.green;
         #declare hval=-deadsea+rng/65535*hval;
rd+hval*<sin(radians(-longstart-col/xdim))*cos(radians(latstart-row/ydim)),
                  sin(radians(latstart-row/ydim)),
cos(radians(-longstart-col/xdim))*cos(radians(latstart-row/ydim))>*sf
         #if (!(row=ydim-1 & col=xdim-1)) // no comma after last vector
         #declare col=col+1;
       #declare row=row+1;
   face_indices
     (xdim-1)*(ydim-1)*2
     #declare r=0;
     #while (r<ydim-1)
       #declare c=0;
       #while (c<xdim-1)
         <r*xdim+c, r*xdim+c+1, (r+1)*xdim+c>,
         <r*xdim+c+1, (r+1)*xdim+c+1, (r+1)*xdim+c>
         #if (!(r=ydim-2 & c=xdim-2)) // no comma after last vector
         #declare c=c+1;
       #declare r=r+1;
   texture
     pigment { color rgb <0, 0.8, 0> }
     finish { ambient 0.1 diffuse 1 brilliance 0.4 }
   double_illuminate
#declare Cam_surfpos=trace(Earth_Slice, Earth_Pos,
2*rd*<sin(radians(-Cam_Long))*cos(radians(Cam_Lat)),
sin(radians(Cam_Lat)), cos(radians(-Cam_Long))*cos(radians(Cam_Lat))>);
#declare Cam_Pos=Cam_surfpos+vnormalize(Cam_surfpos)*Cam_Height;
#declare Cam_Pos=vrotate(Cam_Pos, <0, Earth_Rot, 0>);
#declare Cam_Pos=vrotate(Cam_Pos, <Earth_Tilt, 0, 0>);
#declare Cam_Look=<sin(radians(Cam_Dir))*cos(radians(Cam_Azi)),
sin(radians(Cam_Azi)), cos(radians(Cam_Dir))*cos(radians(Cam_Azi))>;
#declare Cam_Look=vrotate(Cam_Look, <90-Cam_Lat, -Cam_Long, 0>);
#declare Cam_Look=vrotate(Cam_Look, <0, Earth_Rot, 0>);
#declare Cam_Look=vrotate(Cam_Look, <Earth_Tilt, 0, 0>);
#declare Cam_Look=Cam_Pos+Cam_Look;
#declare Cam_Sky=<0, 1, 0>;
#declare Cam_Sky=vrotate(Cam_Sky, <90-Cam_Lat, -Cam_Long, 0>);
#declare Cam_Sky=vrotate(Cam_Sky, <0, Earth_Rot, 0>);
#declare Cam_Sky=vrotate(Cam_Sky, <Earth_Tilt, 0, 0>);
object
   Earth_Slice
   rotate <Earth_Tilt, 0, 0>
   rotate <0, Earth_Rot, 0>
/* sphere
   0, rd
   texture
     pigment { color rgb <0, 0, 0.4> }
     finish { ambient 0.1 diffuse 1 brilliance 0.6 }
camera
   location Cam_Pos*sf
   look_at Cam_Look*sf
   sky Cam_Sky
   angle 40
/* camera
   location <20000000, -20000000, 20000000>*sf
   look_at 0
   angle 60
light_source
   <149600000000, 0, 0>*sf*sf
   color rgb 1
// end of code
I also attached the heightfield generated from the original ASTER
GeoTIFF tile.
...and I thought I could come up with a surprise rendering of Tristan da
Cunha as an introduction to POVEarth... but, alas, I'm no Christoph
Hormann, so probably the whole thing is several orders of magnitude too
ambitious for me. I should content myself with pixeling nice little flat
heightfields and placing a few trees and buildings on them...
See you in Khyberspace!
Yadgar
Download 's38w013_corrected.png' (253 KB)
Preview of image 's38w013_corrected.png'
Subject: Re: POVEarth: I just don't get it...
Date: 28 Jun 2013 18:10:01
Message: <51ce09b9$1@news.povray.org>
start small ... you seem to assume that the curved mesh itself
is correct which is a very big assumption for a first test with
such a complicated definition. Make a test scene where you render
some spheres at calculated vertex positions for a small subset of
coordinates to get an overview of your geometry.
And then start with a reasonable test sphere of maybe radius 100
for sea level and add elevations between 0.0 and 1.0 for testing.
Also, rendering a planet as high resolution spherical mesh
is admittedly cool but probably overkill. The Earth is pretty
smooth - on scales where the curvature matters you don't really
need true elevated geometry. A sphere with normals might do
the trick just as well.
Date: 28 Jun 2013 18:35:12
Message: <51ce0fa0@news.povray.org>
Does not work either... only the same black void!
That's true, but I want to do animated flights at 5 to 10 kms over
ground, with only those data tiles to be included which actually would
be in the FOV of the camera... and landscapes would not be realistic if
one could see let's say Mt. Everest from central Europe...
Yadgar
Date: 29 Jun 2013 16:44:55
Message: <51cf4747@news.povray.org>
>> the illumination direction, correctly applying rotations of mesh2,
>> camera position and camera direction, but no effect at all.
The main problem seems to be that
which probes for the mesh, always returns zero... why?
Yadgar
Date: 29 Jun 2013 17:28:34
Message: <51cf5182$1@news.povray.org>
> Yadgar
you have:
trace{Object, location, direction}
Apparently, you trace from the center of your Earth. Are you sure that
your direction is actualy toward the slice you are using?
The lenght of the direction vector don't need to be large, you can
remove the "2*rd*".
Maybe doing a test with the camera placed to see the inside of the slice.
Next, make a cylinder like this:
cylinder{Earth_Pos,
2*rd*<sin(radians(-Cam_Long))*cos(radians(Cam_Lat)),sin(radians(Cam_Lat)),
,1
pigment{rgb<1,0,0>}finish{emission 1}
If that cylinder is not directed toward you slice, it mean that your
math need reworking.
You may try this for your direction:
<sin(radians(Cam_Long)), sin(radians(Cam_Lat)),cos(radians(Cam_Long))>
Date: 29 Jun 2013 18:35:01
Message: <web.51cf6018b26e8b56540235480@news.povray.org>
Try adding a 4th parameter:
  #declare Norm = <0, 0, 0>; //dummy assignment
  sin(radians(Cam_Lat)), cos(radians(-Cam_Long))*cos(radians(Cam_Lat))>,
  Norm)
If Norm is <0, 0, 0> after the call to trace(), then the trace has missed the
object entirely.
Date: 30 Jun 2013 02:34:31
Message: <51cfd177$1@news.povray.org>
Hi(gh)!
>    #declare Norm =<0, 0, 0>; //dummy assignment
>    Norm)
> If Norm is<0, 0, 0>  after the call to trace(), then the trace has missed the
> object entirely.
After setting the background to white for better visibility, I found out
that I forget to put the two parts of the scaling factor for the vertex
vectors in brackets - so the mesh2 ended up in a completely different
location than defined by the geographical coordinates!
Originally, it was:
         rd+hval*<vertVect>
with rd being Earth's radius and hval the terrain elevation value gained
from the pixel colour of the heightfield.
Of course it must be:
         (rd+hval)*<vertVect> !
Attached below is what I've got... still at a low test resolution, but
the three main islands, Tristan da Cunha, Inaccessible and Nightingale,
are clearly discernible!
Now let's go for a full-resolution view...
Yadgar
Download '2013-06-30 tristan da cunha, take 1.jpg' (16 KB)
Preview of image '2013-06-30 tristan da cunha, take 1.jpg'
