I think I have reached the final version of this image.
What do you think?
Download 'elements of geology3_final.jpg' (273 KB)
Preview of image 'elements of geology3_final.jpg'
> What do you think?
Pretty good. :-D
A little nitpick. Does the Poser model have hair?
Regards
On 10-6-2013 13:18, Stephen wrote:
> Pretty good. :-D
Thanks!
LOL Yes it has, although close cropped. ;-)
Now that you have found the weak spot of the image, I am obliged to add
some 19th century /coiffure/...
This is probably more to your liking ;-)
Added a white collar too.
Download 'elements of geology3.jpg' (5 KB)
Preview of image 'elements of geology3.jpg'
Just some fuzz at the back and sideburns would do, I think.
Regards
Indeed it is. :-D
Regards
The sideburns would be nice indeed for a close up. I need to model that
separately...
> separately...
> Thomas
I thought he was bald
>> separately...
>> Thomas
Oh no. Not at all. A simple follicle. :-)
Size and shadow of the hat rim made it invisible. However, I had delayed
proper attention to the hair until later. The problem with the
combination of hair and hat is that you have to tweak both until nothing
is poking through and still look acceptable.
> What do you think?
I really like it. The clouds are very effective, the birds add life, and the
landscape is spectacular. I honestly didn't spot the issue with the facial
furniture :)
Bill
> What do you think?
I think it is great, I cannot really suggest anything to improve it.
I like the fact I can make out something behind the tree to the left, looks like
a rock or crevice but I cannot see exactly what it is which I think it is a good
thing to have in an image, it keeps your mind wondering and makes you look in
more detail at the image. Although with this one I had the 'dis'advantage of
looking back at the original to see what it was ;-).
Sean
>> What do you think?
Thanks indeed Sean. I shall leave it at that.
Yes, that is always an interesting feature with (groups of) trees. And
easy to achieve. Interesting things like this can also be achieved with
buildings, providing little peep holes into otherwise hidden areas. More
difficult to achieve, certainly, as they need to look casual.
>> What do you think?
> furniture :)
Thanks indeed Bill. In a much later stage I may revisit this scene as
there are a couple of little ideas floating in my mind.
> What do you think?
I think this is looking really nice Thomas, I love all the detail that you've
added to the foreground :)
Cheers,
Rob
> What do you think?
> Thomas
"Feel like a sir"
B. Gimeno
Thanks Robert.
On 13-6-2013 6:52, B. Gimeno wrote:
> "Feel like a sir"
Thank you my dear chap.
> What do you think?
> Thomas
The light on the grass is simply fantastic!
Paolo
Indeed? I would need to test how it looks back-lighted. What I did now
to the - basically - Poser textures, is add some transparency and a
small amount of back light diffuse. I did this also for the tree leaves
in the background.
> in the background.
> Thomas
The effect is of wet grass illuminated by the sun, and I like the
contrast with the shadow zone.
If you have time to waste, you can try to add a path.
Paolo
> What do you think?
> Thomas
Oh yes, great image, nice foam and foreground this time ;)
> What do you think?
> Thomas
Beautiful. I am such a hack in comparison....
May I ask some technical questions?
The mountains in the distance (love the layers) -- How did you do that? It
doesn't look like a simple heightfield; maybe a hightfield on another? (or a
heightfield turned sideways towards the viewer?)
The trees (or vegitation) on the mountain foothills -- they look more 3d than
textured on it. Did you loop a trace() and place green objects there? What
sort of objects?
Similar question about the far trees across the misty valley -- how detailed did
you make them to have them come out looking like that? (Obviously, you don't
need to model them to the leaf level at this distance).
And the close grass -- I've tried to make it with a bunch of triangles. They
were all the same color, though. How do you get all the colors? You don't
model them individually, do you?
Thanks!
Tom A.
>> What do you think?
>> Thomas
The author probably used some isosurface. Add to that some clever
texturing. Add a bit of turbulance to break the regularity of the base
pattern.
> sort of objects?
Not textures nut actual objects, probably some mesh.
Mesh are very effecient: One mesh can be placed thousands of times and
only reside in memory once. Add some random rotation, slight uneven
scalling mean that only 2 or 3 meshes can make a very beleivable forest.
Those don't need much detail. Some low triangle count meshes can do the
trick.
You can create grass patches as mesh proceduraly. Have a ground with
varying colouring, apply some pattern to the grass colour, maybe use
some short grass patches and some longer ones.
> Thanks!
> Tom A.
Of course.
The mountains consist of one single height_field made in GeoControl. It
is mirrored and copied a number of times to fill the panorama. The
layers are produced by a texture using a slope/altitude pattern.
> sort of objects?
The trees are one single POV-Tree object exported as mesh{}. There are
200,000 of them from the far background to the middle foreground. They
are traced on the combined heigh_fields and randomly rotated, scaled,
and textured to different green hues. Obviously, I first saved a file
with trace positions. You only have to do that once as it takes some
time to calculate; then you only need to include the file and read the
locations which is very fast.
Same tree, one single bunch of trees over the whole image ;-) As they
are instanced from one single mesh there is very little memory needed.
Individual grass patches are originally Poser props. There are eight of
them, textured and uv-mapped and exported as mesh2. Using the same
technique as for the trees, they are randomly chosen, rotated, scaled on
the foreground heigh_field. The latter has a basic slope pattern texture
to put some green under and between the grass patches.
> Of course.
> Thomas
Thank you Thomas and Alain
Tom A.
