POV-Ray : Newsgroups : povray.binaries.images : Sky simulation Server Time
28 Nov 2026 23:10:24 EST (-0500)
  Sky simulation (Message 1 to 50 of 58)
Goto Latest 50 Messages Next 8 Messages >>>
Subject: Sky simulation
Date: 7 Jun 2013 03:36:29
Message: <51b18d7d@news.povray.org>
I've created a macro called SkySim (I'll post it in p.b.s-f once I've
tidied it up and added comments) that creates a realistic looking sky
pigment in a sky_sphere based on the sun position and the "haziness" of
the sky.
The algorithm used is from this paper:
www.cs.utah.edu/~shirley/papers/sunsky/sunsky.pdf
It is the same algorithm used by the open-source software Stellarium, so
I already had a starting point in code for the POV version.
If you also use "sunpos.inc" to get the sun position then you can create
the correct sky based on just the longitude/latitude and time of day
(this is how I've done it in the test scene).
The renders below are from the test scene with an isosurface ground and
fog, however I've patched my version of POV so that the fog colour
matches the sky_sphere and is not a constant colour. I think this gives
a realistic perception of depth and renders very quickly.
Obviously in a real scene you may want to add clouds, but I hope it's a
useful starting point for a realistic looking sky.
Download 'skysimtestground1.png' (351 KB) Download 'skysimtestground2.png' (237 KB) Download 'skysimtestground3.png' (259 KB) Download 'skysimtestground4.png' (262 KB) Download 'skysimtestground5.png' (301 KB) Download 'skysimtestground6.png' (197 KB) Download 'skysimtestground7.png' (173 KB)
Preview of image 'skysimtestground1.png'
Preview of image 'skysimtestground2.png'
Preview of image 'skysimtestground3.png'
Preview of image 'skysimtestground4.png'
Preview of image 'skysimtestground5.png'
Preview of image 'skysimtestground6.png'
Preview of image 'skysimtestground7.png'
Subject: Re: Sky simulation
Date: 7 Jun 2013 04:04:25
Message: <51b19409$1@news.povray.org>
> the sky.
Interestingly, I use the following code to the same effect. I do not
remember who proposed this code first unfortunately.
//code start
#declare fn_horizon = function {max(y, 0)}
#declare fn_sun =
function {
   pattern {
     spherical
     scale 3
     translate z
     rotate -Al*x
     rotate Az*y
sky_sphere {
     function {pow(fn_horizon(x,y,z)*(1-fn_sun(x,y,z)), 0.400)}
     color_map {
       [0.000 color SunColor]
       [0.426 color srgb <94,  115,  215>/255]
//code end
Al (altitude) and Az (azimuth) are found using sunpos.inc; SunColor with
CIE.inc.
Date: 7 Jun 2013 06:24:26
Message: <51b1b4da$1@news.povray.org>
> the sky.
Not a tool I have in my tool box and one I would like to have. I look
forward to trying your macro.
Bill P.
Date: 7 Jun 2013 11:05:01
Message: <web.51b1f5b959bb636148146bbd0@news.povray.org>
It looks great; I'll have to try it out soon.
Ah, I wish POV-Ray supported that kind of fog! My POV-SDL hack is just too
inflexible to work with things like media clouds. Will you be posting the patch
someday? (In fact, why aren't coders posting more patches? Is everyone waiting
till 3.7 Final or something?)
Sam
Date: 9 Jun 2013 03:44:50
Message: <51b43272$1@news.povray.org>
Question:
For the visible Sun, you give: #local SunRadius = vlength(sp)/214.8;
I seem to remember that Cousin Ricky evaluated the apparent size of the
Sun as to be twice as much, i.e.: #local SunRadius = vlength(sp)*2/214.8;
I don't know who is right or wrong but personally I prefer the larger
size :-) Somehow, it looks more like the natural aspect of the Sun, but
that may very well not be at all objective.
Date: 9 Jun 2013 05:19:24
Message: <51b4489c@news.povray.org>
For my sun radius calculation I used the values from wikipeda, distance
to sun is 1.5e8 and radius of the sun is 6.96e5, dividing those two
gives the 214.8.
IMO it also depends heavily on the angle/focal length of the camera you
are using, you can easily make the sun or moon look way too big or way
too small (IRL and in POV). In Stellarium there's even a toggle to make
the moon 4x realistic size because it just seems more "natural", it may
be a similar reason why Cousin Ricky put in the factor of 2.
Note that if you increase the size artificially and are using the sun
sphere as an accurate light source for radiosity (or mcpov) you probably
want to reduce the emission value accordingly (if making the radius 2x
bigger the area will be 4x bigger, so reduce the emission by a factor 4).
Date: 9 Jun 2013 07:23:36
Message: <51b465b8$1@news.povray.org>
> gives the 214.8.
It is probably an unconscious tendency to 'see' the Sun (or Moon) bigger
than they really are.
True.
Date: 9 Jun 2013 09:12:44
Message: <51b47f4c$1@news.povray.org>
actually I seem to recall the license / source code comments did not
allow the publishing of modified sources for beta versions. Not sure if
that also holds for release candidates.
Date: 9 Jun 2013 09:49:36
Message: <51b487f0$1@news.povray.org>
> gives the 214.8.
Yes, that is the correct value known since antiquity (the ratio is
simply the sine of the apparent angle that is readily observable). It
was the figuring out the actual distances/ radii that took longer ;)
http://en.wikipedia.org/wiki/Aristarchus_of_Samos
Regarding the Sun at least we rarely see the actual disk as it is lost
in the glare, and this has a larger size. And at sunset when we see it
we perceive it as larger than we would overhead:
Overhead, we tend to assume an object is not so far away (maybe typical
cloud distance). On the horizon an object is perceived to be very far
away. So the same angular size is interpreted as a larger object. This
effect persists even when no objects are available for comparison, so
that often heard explanation is an urban myth.
The thing here is that the angular size of the sun is fixed, but the
angular size of other objects in the scene depends on the distance. And
in a photo or render the distance is not readily apparent, we need to
estimate it from the scale of objects.
As an extreme example suppose you simulate a telescopic view with angle
1 degree on a house on the horizon. Now the image contains a house of
reasonable size with a sun filling half the image behind it, so it looks
way to big. But if we were smarter we would judge scale from the Sun and
conclude the house is either a tiny model or very far away).
Date: 9 Jun 2013 10:05:01
Message: <web.51b48ac359bb6361e52a27db0@news.povray.org>
> the sky.
These look great, I am struggling with creating a realistic sky colour at the
moment so would look forward to giving this a try.
Sean
Date: 9 Jun 2013 10:38:46
Message: <51b49376$1@news.povray.org>
Thanks Christian. Very comprehensive.
Date: 9 Jun 2013 13:15:02
Message: <web.51b4b7e759bb636144b5561b0@news.povray.org>
> the sky.
Very nice. I'll definitely be using this!
Bill
Date: 9 Jun 2013 13:30:00
Message: <web.51b4bace59bb636178641e0c0@news.povray.org>
> Question:
He is correct.  The formula you attribute to me is for the /diameter/ of the
Sun, not the radius.  (References to celestial objects tend to give diameters
instead of radii.  Another possibility is that the original conversation was
about area_lights.)
Date: 10 Jun 2013 03:07:39
Message: <51b57b3b@news.povray.org>
> about area_lights.)
I stand corrected! The original discussion was /indeed/ about area lights.
I mixed up radius and diameter subsequently.
How little things may wreak havoc in the celestial clockwork ;-)
Date: 17 Jun 2013 04:41:18
Message: <51becbae@news.povray.org>
I wonder at your scene settings.
With you test scene, I get the following image. Sun at 12:00 hours. Way
too dark overall.
Using for all my scenes version 3.7RC7, with assumed_gamma=1 and
Display_Gamma=sRGB.
Download 'skysimtestground.png' (148 KB)
Preview of image 'skysimtestground.png'
Date: 17 Jun 2013 05:34:51
Message: <51bed83b$1@news.povray.org>
> too dark overall.
You can adjust the EXP variable in the test scene to control the
brightness of the sky (it controls how the physical brightness values
calculated are converted to POV units). Try increasing it from 4e-5 to
6e-5 or even higher.
I have no idea what the bright yellow patches on the ground are - I
didn't get those on mine???
Date: 17 Jun 2013 07:37:27
Message: <51bef4f7$1@news.povray.org>
Yes I did that indeed, but somehow the scene never comes close to the
aspect of a regular light and sky_sphere.
I added radiosity, and they seem to come from that. Without radiosity
the landscape remains totally dark whatever the value for EXP and the
hour of the day.
Date: 17 Jun 2013 07:47:08
Message: <51bef73c@news.povray.org>
I think I found the culprit: Your original SunPos() is divided by 1000!
Date: 17 Jun 2013 10:21:15
Message: <51bf1b5b$1@news.povray.org>
It looks like it's because the sun is so bright and so small, the
radiosity algorithm won't pick it up very often. This would explain the
bright yellow patches, they're radiosity samples that just happened to
pick up the sun - most of the samples didn't. I'm not experienced enough
with radiosity to know a way around this (I use mcpov for most renders,
which allows for such small very bright objects ok).
Could you ever get a similar scene with a realistically sized and bright
sun to render with radiosity corerctly? The pigment of the sky_sphere
should only make a very minor difference when a bright sun is in the sky.
> hour of the day.
There was a light_source in my demo scene file I posted, that should
illuminate the ground - unless you've uncommented the sun sphere that
happens to be in exactly the same place :-)
That shouldn't make a difference, because the sun radius is determined
from the distance. The reason I did that is because SunPos.inc returns a
massive distance for the sun vector which causes problems in some
scenes, in reality it only needs to be a few orders of magnitude further
away than everything else in your scene.
Date: 17 Jun 2013 10:39:03
Message: <51bf1f87@news.povray.org>
And yet, *that* is exactly the trouble maker. Without, the scene renders
perfectly, like the example (with radiosity added again) shows. Also in
any other of my scenes the results are correct. Exp at 4e-5 again here.
Download 'skysimtestground.png' (160 KB)
Date: 17 Jun 2013 10:41:30
Message: <51bf201a$1@news.povray.org>
> hour of the day.
Thinking about, you can have light_sources and still use radiosity can't
you? In that case I don't see any benefit to using a sphere for the sun
over using a light_source (even an area_light if you want realistic soft
shadows).
The only reason I left the sphere object in there is because in mcpov
you can't use light_sources, you are forced to model a sun as a very
bright sphere.
Date: 17 Jun 2013 10:45:07
Message: <51bf20f3@news.povray.org>
If you want to post your two scene files (the one that renders correctly
and the one that has the bright blobs) then I'll take a look and see if
I can figure out what's going on.
Date: 17 Jun 2013 11:06:05
Message: <51bf25dd$1@news.povray.org>
It is very simple: the only thing to do is to comment out the /1000 at
the end of the SunPos() declaration in your scene file. You may want to
add the radiosity code (below).
As radiosity I use:
   radiosity {
     pretrace_start 0.08
     pretrace_end   0.004
     count 50, 1000
     nearest_count 10, 5
     error_bound 1
     recursion_limit 2
     low_error_factor .3
     gray_threshold 0.0
     minimum_reuse 0.015
     maximum_reuse 0.1
     brightness 1
     adc_bailout 0.01/2
     normal off
     media off
     always_sample off
     //max_sample 1.0
Note that without the divisor, the sun sphere (when switched on) becomes
invisible somehow.
Date: 17 Jun 2013 11:10:43
Message: <51bf26f3$1@news.povray.org>
> shadows).
Your scene uses a light_source, therefore the visibility switch should
switch on the looks_like code there.
Date: 17 Jun 2013 13:20:57
Message: <51bf4579@news.povray.org>
> invisible somehow.
It also becomes invisible to the whole radiosity algorithm... Try it
with the sphere commented out - I get exactly the same image with and
without the sphere when the /1000 divisor is deleted.
If you look at sunpos.inc near the bottom you see this line:
    #declare SolarPosition=vrotate(<0,0,1000000000>,<-Al,Az,0>);
That 1000000000 is simply too big - accuracy errors prevent an object at
that distance rendering properly, even directly or from the radiosity code.
Anyway, the splotchiness is because the sun is too small, so the
radiosity algorithm doesn't always pick it up. By taking out the /1000
you are effectively removing the sun sphere from the scene so the
splotchiness goes away (along with any radiosity effect from the sun).
To test this simply make your sun sphere much bigger (and reduce the
emission so the amount of light stays constant), here I made it 50x bigger:
#local SunRadius = vlength(sp)/214.8 * 50;
sphere{ sp,SunRadius pigment{color rgb 1} finish{emission 1.6e9 * EXP /
50/50 }}
That makes it 50 times bigger and it renders fine (no bright splotches)
with your radiosity settings - see attached.
Without upping the count to silly levels I don't know how else to get an
emissive sun of a realistic size to show up with radiosity. You'd be
better off sticking with an area_light IMHO.
Download 'bigsun.png' (145 KB)
Preview of image 'bigsun.png'
Date: 18 Jun 2013 03:01:49
Message: <51c005dd$1@news.povray.org>
Re-reading my own post, I find it totally confusing :-)
What I mean is that instead of a sphere, you could add the looks_like
code to the light_source.
Date: 18 Jun 2013 04:05:39
Message: <51c014d3@news.povray.org>
There is a much better solution.
//start code
#local sp = SunPos(2013, 6, 6, 17, 0, 0, 52.206507, 0.12165);
light_source {
   sp
   color rgb <1,1,0.9>*(17334 * EXP)
#local SunRadius = vlength(sp/1000)/214.8;
sphere {sp/1000, SunRadius pigment{color rgb 1} finish{emission 1}
no_shadow}
//end code
The scene does not need the *emission* of the *visible* sphere as a
light source. It only needs the light source itself. So, the solution is
to put the sunlight at the standard SunPos position, and the *visible*
sphere and its radius at sp/1000. In addition, just make emission of the
sphere equal to 1.
See attached image.
Download 'skysimtestground.png' (207 KB)
Date: 18 Jun 2013 04:52:13
Message: <51c01fbd$1@news.povray.org>
> light source.
As I said before, there isn't any need to try this for radiosity, it
will just cause problems like you experienced. It's only in the code as
it is needed for mcpov (where is works fine).
I don't know if there are any accuracy issues related to having a
light_source a very large distance away, I expect it may cause some
shadow artifacts? The length of the vector from SunPos is quite
arbitrary, so in every scene you just need to find the max distance it
works at, then I'd probably divide by 10 or 100 just to be sure you're
not near the accuracy limit.
> sphere equal to 1.
The problem with that is the sun will look unrealistically dim compared
to the sky when visible in any reflections, especially darker low-level
reflections (eg a black car). You could set emission to 0 and ambient to
the original physically correct 1.6e9 * EXP, but I think that would
still influence the radiosity algorithm and give you back the bright
splotches again.
At this point I usually fire up mcpov :-)
Date: 18 Jun 2013 05:30:40
Message: <51c028c0$1@news.povray.org>
>> light source.
But mcpov has other problems of its own, as Clipka explained some time ago.
I have never met any problems or artefacts when using SunPos so, imho,
there is no need to divide.
>> sphere equal to 1.
> splotches again.
Maybe, but those are special cases needing special solutions.
<grin>
Date: 19 Jun 2013 10:24:56
Message: <51c1bf38$1@news.povray.org>
The only major one is the diffuse values are out by a factor of 2, I
usually use a macro for setting the finish which outputs either the
vanilla POV syntax (for testing the scene) or the mcpov syntax (for
final render). Incorporating the factor of 2 correction is easy in the
macro.
That's just because you never tried to put a sphere at that position
before :-) Also I haven't done a thorough investigation, but the
accuracy issues you run into seem to depend on the size of other objects
in your scene (and maybe the camera setup?). Whilst the /1000 factor for
placing the sphere might work in this particular scene, it may become
invisible again in a different scene (or work fine without the /1000).
I suppose the ultimate solution would be to incorporate the sun in the
sky_sphere pigment at the physically correct brightness (which would
save having to use any arbitrary values for "very far away"), and for
the POV team to implement something similar to the sky importance
sampling in mcpov for the radiosity algorithm (so you don't need a
really high count to reliably pick up the bright sun).
I never thought I'd hear a glossy reflective surface being called a
"special case" in a raytracing forum - what next, a checkered plane is
also a special case? :-O
> <grin>
Bring on mcpov merged into POV 3.7 !! If I had the time I'd definitely
give it a shot.
Date: 19 Jun 2013 10:49:40
Message: <51c1c504$1@news.povray.org>
Oh yes, I did! ;-) However, I only use SunPos for my main light source.
I hardly use a visible sun.
That would be a good idea.
LOL good point. I admit that I was talking from a strictly personal
point of view...
> give it a shot.
I am too happy with 3.7 for the things I do. ;-)
Subject: Re: Sky simulation: what is wrong with this particular code?
Date: 5 Jul 2013 08:36:04
Message: <51d6bdb4@news.povray.org>
Consider the following scene code:
//start code
#version 3.7;
global_settings {assumed_gamma 1.0}
   location  <0, 5, -40>
   sky       y
   up        y
   direction z*1.7
   angle     70
   look_at   <0, 5, 100>
#include "sunpos.inc"
#declare MySun  = SunPos(2012, 3, 5, 13, 10, 0, 31.7625, 25.0888);
#declare EXP = 8e-5;
// SkySim
#include "SkySim.inc"
SkySim( SolarPosition,
      y,
      5,
      EXP
#declare SunColor = rgb 1;
light_source {
   MySun
   color    SunColor*(17334 * EXP)
   //parallel
   //point_at <0, 5, 100>
plane {y, -5 pigment {rgb 1}}
cylinder {<0,-5,10>, <0,6,10>, 1 pigment {rgb <1,0,0>}}
//end code
It renders well (see image: SkySim_SolarPosition) also with parallel and
point_at in the light_source uncommented.
Now, switch SolarPosition in the SkySim macro call, by MySun. I get
image SkySim_MySun.
Now, uncomment parrale and point_at in the light_source. I get image
SkySim_MySun parallel.
So, what is wrong here? All goes well in the original test scene.
Download 'skysim_solarposition.png' (15 KB) Download 'skysim_mysun.png' (24 KB) Download 'skysim_mysun parallel.png' (15 KB)
Preview of image 'skysim_solarposition.png'
Preview of image 'skysim_mysun.png'
Preview of image 'skysim_mysun parallel.png'
Date: 5 Jul 2013 09:38:01
Message: <51d6cc39$1@news.povray.org>
> //start code
> #version 3.7;
> camera {
>    sky       y
>    up        y
>    direction z*1.7
>    angle     70
>    look_at   <0, 5, 100>
> // SkySim
>       y,
>       5,
>       EXP
> light_source {
>    MySun
>    //parallel
> //end code
> image SkySim_MySun.
Hmmm ok, so apparently I misunderstood the POV syntax, this short piece
of code prints X=9 whereas I assumed it would print X=10. Not sure if
this is intended behaviour or not.
// start code
#macro A(B)
#local B = B - 1;
#declare X = 10;
A(X)
#warning concat("X = ",str(X,0,0))
// end code
Will fix the macro and post and update... (it's essentially normalizing
your sun position, which you're then using the place the light source).
Date: 5 Jul 2013 10:07:42
Message: <51d6d32e$1@news.povray.org>
Thanks! Glad to be of help (by chance) :-)
Date: 5 Jul 2013 20:17:30
Message: <51d7621a$1@news.povray.org>
> // start code
> #macro A(B)
> #local B = B - 1;
> #end
> #declare X = 10;
> A(X)
> // end code
Your code develop as:
#declare X = 10;
#local X = X - 1;
In this contex, #local and #declare are synonims.
So, yes, it works as expected.
There is a difference when #local is used in an include file. In an
include, any #local variables only exist within the include.
Date: 8 Jul 2013 03:54:52
Message: <51da704c$1@news.povray.org>
> #declare X = 10;
> #local X = X - 1;
It is in an include, sorry in the above example the macro is in another
file. Try this (two files):
// file1.inc
#macro A(B)
#local B = 5;
// file2.pov
#include "file1.inc"
#declare X = 10;
A(X)
X comes out as 5, but I would have expected 10.
Date: 8 Jul 2013 08:18:23
Message: <51daae0f@news.povray.org>
While we're at it this also causes an error (even if the definition for
A is in a different file):
#macro A()
#macro B()
#local A=1;
B()
This one is a bit more serious as it means if any macro in your scene
uses a local variable with the same name as another macro you'll get an
error.
Date: 10 Jul 2013 10:45:00
Message: <web.51dd73032dc5ff1278641e0c0@news.povray.org>
> #macro A()
> #end
> #macro B()
> #local A=1;
> #end
> B()
> error.
This is a known problem, although I do not know that the POV Team perceives it
as a problem.  When I brought it up 5 years ago, I was quoted documentation of
macro names being global in scope, which was just a red herring.  This behavior
breaks the very concept of local variables and makes "black box" modularization
impossible.
You also get an error if you declare a function with an argument that has the
same name as a previously declared variable.
I hope that these (and ALL other cases of scope leakage in POV-Ray) will be
eliminated by version 4.0.
Date: 10 Jul 2013 12:13:34
Message: <51dd882e$1@news.povray.org>
The documentation also states that "[#local] temporarily override any
identifiers with the same name." IMO a bit more clarification should be
added there, something along the lines of "...unless the identifier name
is already in use as a macro name, or the #local statement is in a macro
definition and the identifier name matches one of the macro parameter
names.".
> This behavior
> impossible.
Exactly, in my relatively simple macro which I doubt very many people
have tried out yet, two people got different namespace clash related
errors with #local's I'd used inside the macro. In future I'll make sure
to make all variable names and parameter names unique (by prefixing with
my name and/or the macro name etc), at which point I might just as well
use #declare!
I can't believe more people haven't come across this "feature" in the
last 5 years.
Date: 16 Jul 2013 22:27:52
Message: <51e60128$1@news.povray.org>
Am 09.06.2013 15:12, schrieb Christian Froeschlin:
The corresponding text is still in all the file headers, so technically
speaking I guess it does.
And yes, I can name at least one person who is holding back various
patches for just that very reason.
Date: 16 Jul 2013 22:33:49
Message: <51e6028d$1@news.povray.org>
Am 17.07.2013 04:27, schrieb clipka:
(of RC7, that is)
Date: 16 Jul 2013 22:50:34
Message: <51e6067a@news.povray.org>
Am 19.06.2013 16:49, schrieb Thomas de Groot:
>> give it a shot.
Believe me, once you get to toy around with blurred reflections you
/will/ want them integrated in 3.7 :-) It's amazing how much more
credibility it brings to textures midway between between dull and shiny
(non-polished metallic surfaces are just the tip of the iceberg in this
regard).
(You /will/ also want a faster computer of course :-P)
Date: 16 Jul 2013 22:52:11
Message: <51e606db$1@news.povray.org>
Am 17.06.2013 16:41, schrieb scott:
> bright sphere.
... which is a huge drawback of MCPOV, if I'm asked. The ideal solution
would be to have the best of both worlds.
Date: 16 Jul 2013 23:03:31
Message: <51e60983$1@news.povray.org>
Am 10.07.2013 16:43, schrieb Cousin Ricky:
>> #macro A()
>> #end
>> #macro B()
>> #local A=1;
>> #end
>> B()
>> error.
> impossible.
The current POV-Ray development team (*) does perceive the whole 3.x
generation SDL parser as one big monolithic problem :-P
(* or "dev team" for short; I guess that's what you mean. There did
exist some group of people called the "POV Team", but they were focused
on user support rather than development.)
Date: 17 Jul 2013 03:09:52
Message: <51e64340$1@news.povray.org>
> regard).
Oh, I do understand that indeed. Let's say that I am not too
demanding... ;-)
Yeah...
Date: 17 Jul 2013 03:52:52
Message: <51e64d54$1@news.povray.org>
>> bright sphere.
Indeed - bring it on! :-)
The other obvious drawback is that you need to run multiple instances of
MCPOV (all started at least 1 second apart as I found out...) to make
good use of modern CPUs, then merge the images afterwards. I've
automated this process but it's still not as good as being able to do it
all in one program and see the results in real time.
Date: 17 Jul 2013 06:38:06
Message: <51e6740e$1@news.povray.org>
Am 17.07.2013 09:52, schrieb scott:
>>> bright sphere.
Guess what: I probably will :-D
Date: 8 Sep 2016 03:00:00
Message: <web.57d10baf59bb6361b05bf450@news.povray.org>
> Thomas
What line number is that at? I am having the same issue.
Mike
Date: 8 Sep 2016 03:14:52
Message: <57d10fec$1@news.povray.org>
>> Thomas
> Mike
Goodness! That was three years ago! ;-)
Without going over the whole discussion again, I guess it is about:
// uncomment the below lines to have a physical sun in the scene with
realistic brightness
// and size (useful if using mcpov or perhaps radiosity?)
  sphere{ sp/1000, SunRadius pigment{color rgb 1} finish{emission 1}
no_shadow}
Forgive me, I do not have the info freshly available in my mind anymore...
Date: 8 Sep 2016 03:22:04
Message: <57d1119c$1@news.povray.org>
>>> Thomas
>> Mike
> no_shadow}
IIRC I think the consensus was that the 1000 factor (used on both lines)
should be tweaked to make the sphere seem "far away" in your specific
scene (but not too far away it causes accuracy issues). I think without
the /1000 the sun is just too far away for the maths to cope when
dealing with normal scenes of the order of a few metres.
