Subject: Gancaloon: Old City street new version
Date: 12 Apr 2013 03:46:34
Message: <5167bbda@news.povray.org>
One step further. Some code clean-up and improvements, and, as shown, an
added random texturing of the buildings.
This version of the macros is gradually diverging from the one in
p.b.s-f. I shall see how I can include the new features in the 'public'
version ;-)
Download 'gancaloon_old city street_05.jpg' (133 KB)
Preview of image 'gancaloon_old city street_05.jpg'
Subject: Re: Gancaloon: Old City street new version
Date: 12 Apr 2013 03:54:32
Message: <op.wve38zntufxv4h@xena>
On Fri, 12 Apr 2013 09:46:21 +0200, Thomas de Groot <tho### [at] degroot org>
> version ;-)
> Thomas
I like the new textures :)
-Nekar Xenos-
Date: 12 Apr 2013 07:14:37
Message: <5167ec9d@news.povray.org>
Thanks. The added proximity pattern is giving me some trouble, mainly
because of the geometric form of the buildings. Some roughness of the
walls will probably correct that.
> Thomas
Looking good, the texture appears lighter in several of the corners on the
walls, this is the bit I would expect to appear more dirty/darker, is the
proximity problem you are referring to?
Are you planning on adding more realistic looking doors? Maybe with different
colours if painted (not sure that would fit the scene though).
Sean
> version ;-)
> Thomas
Would be nice to see a radiosity version of this image as well (I assume the
lighting is ambient currently?)
Sean
Strange you say this. This *is* a radiosity version ;-)
Currently:
radiosity {
pretrace_start 0.08
pretrace_end 0.004
count 50, 500
nearest_count 10, 5
error_bound 0.6
recursion_limit 2
low_error_factor .3
gray_threshold 0.0
minimum_reuse 0.010
maximum_reuse 0.1
brightness 1
adc_bailout 0.01/2
normal off
media off
always_sample off
No, the lighter colour of the edges is intentional as dirt is rubbed off
there, or so I imagine. On the other hand, dirt accumulation in angles
and corners is maybe less well treated this way. Room for improvement,
no doubt ;-)
The problem I refer to is the spots near the first floor windows. My
hope is that with a more irregular surface they will mostly disappear.
Oh yes. Once the general issues are solved, more details will be given
to doors and windows, especially in close-up scenes. In overviews they
will be switched off.
> Currently:
> radiosity {
> pretrace_start 0.08
> pretrace_end 0.004
> count 50, 500
> nearest_count 10, 5
> error_bound 0.6
> recursion_limit 2
> low_error_factor .3
> gray_threshold 0.0
> minimum_reuse 0.010
> maximum_reuse 0.1
> brightness 1
> adc_bailout 0.01/2
> normal off
> media off
> always_sample off
> Thomas
Oops.. sorry, I guess looking at the inside of the windows it shows radiosity
effects, I think the shadows of the buildings on the road and to a certain
extent the shadows on the walls in many areas look too consistent, I would
expect them to darken a bit as they get into corners etc..
I assume you have ambient_light set to zero in the scene? (looking at the
darkness inside the windows would point to this being set I guess).
Will look more closely before I comment again ;-)
Sean
> no doubt ;-)
> Thomas
Hi Thomas,
It was not the edge corners I was referring to, I agree these would be lighter
but more the inner angles where as you say dirt tends to accumulate I was
referring to.
Ahh, yes I did think the spots near the windows looked a bit odd, wish I could
offer some useful advice but all my textures are manually tweaked so I have no
experience of using the proximity method.
I look forward to seeing the next installment from this project.
Sean
The radiosity settings are not optimal I think. For a high quality
render of this street, they would have to be improved.
ambient_light is set at default. I fooled you! ;-) The inside of the
windows is a surface with pigment {rgb <0,0,0>} as the inside of the
houses are of no concern. In a later stage, most will get shutters
and/or bars.
No, please do! It helps me to look at coding details I may overlook.
> and/or bars.
If you're using POV-Ray 3.7, then ambient_light is automatically set to zero
whenever radiosity is used.
(In 3.6, I preferred to set #default { finish { ambient 0 } } rather than mess
around with ambient_light, as glowing objects are impossible with the latter.)
True. In fact, I have never bothered about ambient_light for years ;-)
>> Currently:
>> radiosity {
>> pretrace_start 0.08
>> pretrace_end 0.004
>> count 50, 500
>> nearest_count 10, 5
>> error_bound 0.6
>> recursion_limit 2
>> low_error_factor .3
>> gray_threshold 0.0
>> minimum_reuse 0.010
>> maximum_reuse 0.1
>> brightness 1
>> adc_bailout 0.01/2
>> normal off
>> media off
>> always_sample off
>> Thomas
> Sean
Rendered with version 3.7, so, ambient get automativaly turned OFF as
soon as radiosity is activated.
You can tell it use version 3.7 when you see double values after count
and nearest_count, as well as the presance of maximum_reuse.
> >> Currently:
> >> radiosity {
> >> pretrace_start 0.08
> >> pretrace_end 0.004
> >> count 50, 500
> >> nearest_count 10, 5
> >> error_bound 0.6
> >> recursion_limit 2
> >> low_error_factor .3
> >> gray_threshold 0.0
> >> minimum_reuse 0.010
> >> maximum_reuse 0.1
> >> brightness 1
> >> adc_bailout 0.01/2
> >> normal off
> >> media off
> >> always_sample off
> >> Thomas
> > Sean
> Alain
If you have heard the saying ignorance is bliss, then I must be very happy ;-)
I have not tried the new double values on 3.7 do they make much difference to
performance? (always looking for ways to speed up a render).
Sean
>> Alain
<grin> Keep it that way. ;-)
I have not experimented much I confess, and am not sure I entirely
understand their use, so I am not sure.
> version ;-)
> Thomas
Even and even better.
Perhaps the walls on the ground floor of the homes with the "towers"
need to be reinforced in order to sustain the weight of the construction
(I think that at the time in Gancaloon were used stones or mud and wood
for constructions).
Paolo
>>>> Currently:
>>>> radiosity {
>>>> pretrace_start 0.08
>>>> pretrace_end 0.004
>>>> count 50, 500
>>>> nearest_count 10, 5
>>>> error_bound 0.6
>>>> recursion_limit 2
>>>> low_error_factor .3
>>>> gray_threshold 0.0
>>>> minimum_reuse 0.010
>>>> maximum_reuse 0.1
>>>> brightness 1
>>>> adc_bailout 0.01/2
>>>> normal off
>>>> media off
>>>> always_sample off
>>>> Thomas
>>> Sean
>> Alain
> Sean
The second value for count set a larger direction pool for the radiosity
sampling. It should not have any important effect on the speed, but can
affect the quality. In some cases, it allow you to use a smaller count
value, making the render faster. If used, it MUST be larger than the
first value. Those who use it seems to tend to use a value at least 10
times larger than the first one.
The double nearest_count can affect the quality and the speed. The first
value set the maximum bound to be used in areas where the samples have
more variation. The second value is the minimal value to be used in
areas where everything is prety uniform, like a large, plain wall.
maximim_reuse set the largest distance any sample can be reused. It's
grosly a ratio of the width ov the scene.
If you use a smaller pretrace_end value, you often can do with more
relaxed settings elsewhere. The default of 0.04 is often much to large,
I usualy use 0.01 or 0.005. low_error_factor also play a large role in
reducing the sampling done during the final trace and a small value can
greatly reduce artefacts on multi-core systems. Keep it at or under the
default value of 0.5.
> >>>> Currently:
> >>>> radiosity {
> >>>> pretrace_start 0.08
> >>>> pretrace_end 0.004
> >>>> count 50, 500
> >>>> nearest_count 10, 5
> >>>> error_bound 0.6
> >>>> recursion_limit 2
> >>>> low_error_factor .3
> >>>> gray_threshold 0.0
> >>>> minimum_reuse 0.010
> >>>> maximum_reuse 0.1
> >>>> brightness 1
> >>>> adc_bailout 0.01/2
> >>>> normal off
> >>>> media off
> >>>> always_sample off
> >>>> Thomas
> >>> Sean
> >> Alain
> > Sean
> Alain
Wow, thanks Alain, you have just supercharged the radiosity gathering stage of
my renders. I need to do a comparisson for quality, I usually run a no focal
blur/AA render to gather the radiosity data then reload this data with pretrace
set to 1. The radiosity render was running at about 5 hours and with these
settings is now taking about 7 minutes!
Will run the final high quality trace now to see if it looks as good as my 5
hour trace. Oh the hours I have wasted ;-)
Sean
>> version ;-)
>> Thomas
Thank you, Paolo :-)
> for constructions).
That's an idea, and easy to implement.
> version ;-)
> Thomas
I like the textures, except that the stones in the street look too clean and
evenly worn for it to be an "Old" city.
The things that jar my sensibilities are the 2-1/2 foot drop from the bottom
step of the second house on the right, the perfectly clean lines of the
buildings and the grade of the street from one side to the other.
Just a suggestion, but you might consider making the street more level, if you
can. I understand that it's all one height field, but maybe you can find some
way to deform it - say you were to take a spline of the street and flatten the
pixels within a certain distance on either side, not necessarily perfectly
level, but more level than it is.
I don't know how your macro would handle the adjustment to the terrain.
I really love the concept.
A.D.B.
Of course. Be aware that this is all in some kind of beta state. The end
product will show a very different street surface texture.
<grin> Most of this has been solved at this moment, except for the clean
lines of the buildings. Some degrading has still to be done on them.
This has been solved. For the close-up views a separate street surface
is generated, following the height_field but level cross-streetwise.
This is not an automatic process but modelled separately. Not so
difficult to do as I use a high-resolution mesh copy of the local
height_field for modelling purposes.
Simply by making a union of the street surface object and the
height_field before trace()
A new street view is being rendered.
Thank you indeed. I have not finished exploring the possibilities.
Subject: Re: Gancaloon: Old City street new version 2
Date: 17 Apr 2013 03:26:43
Message: <516e4eb3@news.povray.org>
The same street after some improvements.
- a level street surface object is added.
- code influencing the buildings along the street boundaries has been
fine-tuned.
- doors, shutters, and bars have been added (not all visible here though).
Download 'gancaloon_old city street_07.jpg' (133 KB)
Preview of image 'gancaloon_old city street_07.jpg'
> Sean
Ahh.. thought that was too good to be true, the quality was not so good, still
with a few tweaks I now have almost identical quality with a 2 hour radiosity
gathering stage so still a big improvement.
Thanks
Sean
> fine-tuned.
> Thomas
Hi Thomas,
Looking better, I think adding some open shutters and mabe the odd door at a
random angle would be good.
Sean
Date: 17 Apr 2013 09:51:52
Message: <516ea8f8@news.povray.org>
Yes, I could indeed open some shutters. At this moment one of the two
available doors is ajar, but unfortunately it is not one of the doors
shown here :-) I could probably automate opening and shutting the doors
randomly. On my ToDo list.
Subject: Re: Gancaloon: Old City street new version 2b
Date: 17 Apr 2013 09:53:40
Message: <516ea964@news.povray.org>
An update of the Old City overview. State-of-the-art.
Download 'gancaloon_old city overview_03.jpg' (222 KB)
Preview of image 'gancaloon_old city overview_03.jpg'
Date: 17 Apr 2013 10:06:21
Message: <516eac5d$1@news.povray.org>
From the number of houses (single and double floored) I guestimate that
the population lies between 25000 and 30000 in this part of the city. :-)
Am 15.04.2013 23:46, schrieb Alain:
No, not exactly.
Normally, during pretrace the whole image is scanned over and over again
with ever increasing resolution, as specified by the pretrace_start and
pretrace_end parameters. In each pass, for each individual location
probed it is checked whether the nearest_count condition is satisfied,
and if not, another sample is added there.
This is rather inefficient, as in regions where the individual locations
probed already did satisfy the nearest_count location, it is unlikely to
find individual locations that don't satisfy that condition yet.
If you specify a second parameter to nearest_count, regions where the
/average/ sample density satisfies this second condition in one pass are
skipped in any further pretrace passes.
Thus, the second parameter to nearest_count can be considered an average
sample density to aim for, while the first parameter can be considered a
local maximum sample density.
Date: 18 Apr 2013 07:46:23
Message: <516fdd0f$1@news.povray.org>
> Thomas
Both the last views of Gancaloon are magnificent!
Paolo
> version ;-)
> Thomas
I can't be the first one to ask if you've seen "Marwencol." Just in case, I'd
strongly suggest watching it if you haven't.
-Shay
You are indeed the first to mention Marwencol, Shay, and I had not been
aware of it until now. Thanks for pointing it out to me. Fascinating
stuff. Very familiar.
I can readily appreciate the similarities in purpose, although no brain
damage in my case - as far as I know ;-) but the compulsion to create
one's own world is there and I have felt it strongly my whole life.
"Thomas de Groot" <tho### [at] degroot org> wrote in message
news:51948a54$1@news.povray.org...
Ha!
I had no intention to imply /THAT/ similarity. What you might not have
gotten from the (I guess you watched it) trailer is that Mark is very
talented in addition to being a little "off". "Pictures of dolls" is a
semi-popular and dishwater-dull contemporary-art genre (at least in
Houston), but Mark is a gifted photographer and able to make it interesting.
-Shay
> interesting.
The trailer is not enough for a correct appreciation, but stills from
his work give a good idea of his talent. I know how difficult it is to
do this kind of photographic work well /and/ make it interesting, having
explored the same premisses a bit way back in the seventies. Mark is
very talented indeed. I shall have to dig a bit further into his work. I
find it quite fascinating.
Date: 27 May 2013 10:58:03
Message: <51a3747b$1@news.povray.org>
Hi(gh)!
Same with me... it started quite early in my childhood days - anybody
who gave 9-year-old Jörg Bleimann some paper, pencils and felt pens soon
saw him drawing colorful topographic maps of imaginary places... back
then, I day-dreamed together an entire planet, M 720 or Jörgiania, a
world populated by immortal, hyper-intelligent children but also at
constant war with a Darth Vader-like oppressor...
Unfortunately, none of these countless maps (there were physical as well
as thematic maps, also city maps) survived until today, as my parents
back then were quite uneasy about my vivid imagination, so they threw
away all those maps I had drawn between 1977 and 1983.
At 21, a fellow student who studied linguistics and started a
collaborative Tolkien-ish fantasy project, inspired me to re-create M
720 (now to be called "Ilthanalg" - "planet of the Sacred Number") and
even to develop an own language for its people; so I drew several global
maps (physical, political, temperatures, precipitation and vegetation.
I scanned those maps when my computer equipment became sophisticated
enough during the 1990s... but then lost them all to a catastrophic
Windows crash. But nevertheless, I think I'm still able to re-draw them
from memory... and I also have written a lengthy introduction to
Ilthanalg, currently only in German, but I hope to get it translated in
the not-too-distant future.
See you in Khyberspace!
Yadgar
On 27-5-2013 16:58, Jörg 'Yadgar' Bleimann wrote:
> Hi(gh)!
Yes, I can imagine that. I was less map-oriented though ;-)
Oh, that's sad indeed.
Nothing like memory and imagination. Although with POV-Ray I really
approximate what I see in my mind, still the mind vistas are grander.
Smells, noises, variations of shades, throngs of people...
Date: 27 May 2013 14:15:20
Message: <op.wxq8zsgeufxv4h@xena>
On Mon, 27 May 2013 16:58:02 +0200, Jörg 'Yadgar' Bleimann
<yaz### [at] gmx de> wrote:
> Hi(gh)!
in
soon
ll
al
m
n
> Yadgar
I find this very inspiring. Makes me want to continue working on my
BueHaria Binary planets :)
-Nekar Xenos-
Date: 27 May 2013 19:10:24
Message: <51a3e7e0@news.povray.org>
Hi(gh)!
BueHaria Binary planets? Sounds interesting... are they co-orbital or in
fact a binary system like Pluto and Charon? Would you tell us more about
them?
Yadgar
Date: 28 May 2013 13:18:51
Message: <op.wxs01k0hufxv4h@xena>
On Tue, 28 May 2013 01:10:26 +0200, Jörg 'Yadgar' Bleimann
> Hi(gh)!
in
ut
> them?
> Yadgar
I started making up this world when I first heard of binary stars and
planets in High-school. I think it must have been something I read in
Scientific American that triggered the idea. Somewhere there was mention
that the Earth and the moon could almost be a binary planet system. So
yes, like Pluto and Charon. Bueharia is a binary planet system consistin
g
of the planets Bu and Har.
Bue is a beautiful blue planet where plants have blue leaves (I think th
is
would require a method other than photosynthesis, but I don't know enoug
h
about biology to come up with an idea for that). Also there is lots of
gold in the soil, so walking on a golden beach would be nothing unnatura
l.
Most animals would have 6 limbs of which 2 are normally wings. The
intelligent beings (Aliel) would have seven slender fingers of which 2 a
re
thumbs, 1 on each side of the hand. There are different races with skin
and hair colours ranging from cyan - blue - magenta - gold. (One could f
or
instance have blue skin and gold hair). Normally they weave their own ha
ir
into clothes - without cutting it, so their hair would be one with their
clothes. The story would start in the forest age of Bue (Similar to our
stone age) where everyone lives in trees. These trees grow a natural
man-sized nest on each branch, so a new couple would search for a small
tree and plan their family according to when new nests have grown. The
atmosphere would be very thick to allow large animals to fly and
Pegasus-like creatures abound.
Har on the other hand is very much like a prison planet and used as one
later on. There is a lot of volcanic activity and the only water comes
from geysers. You can never see the horizon because of all the smoke. A
ny
hair or feathers would be singed off because of the heat, so most life o
n
this planet is reptilian. War is the norm and thus there is very little
life on this planet.
-Nekar Xenos-
> is
> h
Some animals right here on Earth use copper as a base for their oxygen-bearing
protein instead of iron, resulting in blue blood; so I can easily imagine a
photosynthesis that uses a catalyst other than magnesium-based chlorophyll.
Actually, Wikipedia does mention some other photosynthetic pigments, such as
carotenes and xanthophylls, so dream away!
I love this! A great setting for when intelligent life starts space
travel... This reminds me of the good old SF days when space travel and
alien worlds were the norm. Too much Fantasy nowadays... :-(
Date: 29 May 2013 14:06:38
Message: <op.wxuxw9ivufxv4h@xena>
On Wed, 29 May 2013 02:55:37 +0200, Cousin Ricky <rickysttATyahooDOTcom>
>> is
>> h
> oxygen-bearing
> imagine a
> chlorophyll.
> such as
This is getting interesting :)
-Nekar Xenos-
Date: 29 May 2013 14:09:29
Message: <op.wxux100rufxv4h@xena>
On Wed, 29 May 2013 13:29:15 +0200, Thomas de Groot <tho### [at] degroot org>
> Thomas
I saw an article somewhere earlier this year stating that when fringe
ended, it was the last of Science Fiction on TV. Maybe I have to work on
getting Bue-Haria out there :)
-Nekar Xenos-
Who knows. There still is the SciFi Channel on cable...
Bu-Haria would make an interesting series indeed. A wealth of plot
possibilities. It could go from purely Heinlein or 'Doc' Smith (from the
Skylark and Lensman books) to Moorcock or LeGuin I believe...
