Been some time since my last image from Gancaloon. Steady changes and
steady progress since then. Main development being the replacement of
the city blocks by 'real' geometry. Progress still under way and only as
first version without doors and windows. Potentially however, I have now
the possibility to make any street scene I want, wherever in the city.
Further, I make extensively use of Edouard Poor's proximity pattern
macro which is the one I prefer at this moment. Sam Benge's comes as
close second ;-)
Download 'gancaloon_river harbour3_05.jpg' (284 KB)
Preview of image 'gancaloon_river harbour3_05.jpg'
> close second ;-)
> Thomas
Hi Thomas,
a nice view of Gancaloon again. Two nitpicks: You should consider the use of the
occulsion map baking for the statue and a higher camera position to see the
water between the paths.
Best regards,
Michael
You should have a website for this series. (As if you need any more
demands on your time.) :-)
I don't agree with Michael about a higher camera position. Then you
would not get the handrail view. And I think that you have spent a lot
of time, refurbishing that boat. :-)
Regards
Subject: Re: A new view from Gancaloon's harbour
Date: 19 Feb 2013 16:01:09
Message: <5123e815@news.povray.org>
great view from the ship!
The two right-most figures appear a bit "headless" to me ;)
Likely an effect of dark head against dark background.
Also I wonder if the water lanes should be wider? From economy
of building I'd expect they should fit two ships side by side.
> close second ;-)
And you are probably very fond of the effects you can create
with this, but don't overdo it. I would hope a prestigous statue
in a shiny harbour could be a little better maintained ;)
I agree that the statue's texture is a bit extreme. I still need to come
up with a better overall texture and, in particular, make better use of
the proximity pattern. Baking the occlusion map is a next option indeed.
About the camera position, I shall see. I don't want to loose the
contact with the ship ;-)
Indeed for both points ;-) I have no plans in that direction however.
Yes, that might be the problem indeed. However, I shall consider the
possibilities.
You don't want to know /how much/ time that is, and still not finished.
About nothing is left of the original geometry/textures and many have
been added.
Date: 20 Feb 2013 03:35:45
Message: <51248ae1@news.povray.org>
Thanks!
Ah yes! Just a matter of contrast indeed.
Believe it or not, there is ample room for two ships side by side in
most if not all of the docks! Perspective is playing a bad trick here.
>> close second ;-)
Oh well.... the intention is indeed bad maintenance and age. I agree
with you however and shall work a bit more towards a more believable
aspect ;-)
Date: 20 Feb 2013 03:53:29
Message: <51248f09@news.povray.org>
So I am proved a liar ;-)
Somehow I have not paid attention to some proportions and sizes and
shall have to reconsider.
I remember that my original intention was to have docks for all kind of
vessels, large but also small. This might need proper attention...
Download 'gancaloon.png' (557 KB)
Preview of image 'gancaloon.png'
Not too bad. The most narrow docks are 5m wide. Considering that on the
river there are a score of small vessels, from the pirogue-scale
upwards, those would be reserved for them.
No real need for rebuilding ;-)
Am 20.02.2013 13:33, schrieb Thomas de Groot:
5m wide = max. 1.5m width per ship.
I doubt that such small ships would be moored directly sideways to a
solid stone quay. After all, what heavy or bulky load could they
possibly carry? And how would they get out of the ships at low tide?
More likely you'd have narrow wooden walkways for such small vessels,
floating on pontoons; and you'd moor multiple vessels side by side to those.
Nice scene.
Remember, in ancient times they had these huge wheel cranes on some locations at
the harbor. Inside the wheel were humans, and the movement of that huge wheel
was used to move the crane's top, or to lift and lower the fright from the
crane's top. Those cranes could rotate, too. And most harbors had also some
large fires burning at the entrance towers, to make it possible for the ships to
find it by night.
There were three books published in the USA, showing some of my works in the
field of maritime archaeology. The author is Stephen M. Miller.
Date: 21 Feb 2013 03:23:45
Message: <5125d991@news.povray.org>
Yeah... it is a bit of a squeeze, I admit. But for the pirogue-class
that's all right ;-)
Seriously, I may have to reconsider the layout. Sloppy architect.
Not much tide in the Mediterranean. Small ships, even pirogues crowd in
to the daily markets with fish and fruit, I imagine.
There probably is some kind of buffer (hides) either on the quay or the
ships to protect from the stone. Also need something to moor to.
> those.
Yep. And as this is visibly going to be a multi-purpose harbour, all
kind of possibilities need to be kept open indeed.
Note: While using historical elements, these scenes are not intended as
scientifically accurate views. We stay in the realm of the imagination ;-)
Wow! Both of your images show the tremendous amount of detailed work you've put
into this scene.
The view from on-board the boat is a keeper; I do like the image's composition,
with the railing in the foreground.
I would suggest some 'dirtying down' of some of the stone surfaces: on the main
court, and on the vertical walls near the water (those would probably have years
of green grime dripping down, from the moisture.) Does the court get much human
or animal traffic? Or is it supposed to be 'clean and austere' and off-limits to
the populace, like China's Forbidden City used to be?
On 21-2-2013 1:28, Sven Littkowski wrote:
> Nice scene.
Thanks.
> find it by night.
The cranes are an option indeed, but they will probably not be present
in this harbour (possibly in the one on the sea side, which will be the
military harbour as far as I know presently).
Hmm...
> into this scene.
Thanks! And still only in wip mode ;-)
Well, there already is some but that could certainly be made more
obvious. I have to consider, if I can find time of course ;-)
However, being in a Mediterranean/North African climate means less slime
(except at water's edge) than what we are used to up North.
Oh no, everything is open and free and often used for other purposes
than those for which they were created in the first place. The court is
a market during early day hours when the temperature is not too high and
often also at night (different purposes...).
> Thomas
hey, that sea demands a bit more ripples :)
Oh dear! Was I expecting that ? ;-)
Waves are not really the problem, when time comes to implement them, but
what I find difficult is the way they will behave on the coastline
(except for a foam line like in the Terra project of Jaime) and when
coming into the estuary, how they will be damped. This is truly beyond
my capacities at present...
I am concentrating on the town (and its population if time permits). The
rest of the world is there to give an idea of what it will/ should look
like.
But you are right. Sooner or later I shall have to confront this problem.
Am 25.02.2013 09:20, schrieb Thomas de Groot:
Why not use a wave tank simulator? POV-Ray can do that :-)
news://news.povray.org:119/4a812162@news.povray.org
I think I still have the SDL code somewhere on my computer.
woa, I was just talking about some more pronounced normals :)
Yes, but... the code in that thread is your Game of Life? Not really
waves meseems... ;-)
Is there wave tank simulator code somewhere?
Am 25.02.2013 13:44, schrieb Thomas de Groot:
Posted to p.b.scene-files.
Have Fun!
> Have Fun!
Thanks! Visibly the same flavour as Game of Life ;-)
However... except for a series of white images with some "obstacles" I
see no wave pattern forming.
Changed version to 3.7 and ambient to emission but that is obviously not
the problem.
any ideas?
Am 26.02.2013 09:31, schrieb Thomas de Groot:
>> Have Fun!
> the problem.
> any ideas?
Um... no, not really. It's been years since I touched that code. Maybe
check the all the gamma tweakables?
Well, assumed_gamma 1.0 of course, everything else equal to all my other
scenes.
Attached is a ninth iteration as an example. In the series the images
get brighter and brighter.
Download 'wavetank9.exr.dat' (4 KB)
Am 26.02.2013 14:22, schrieb Thomas de Groot:
> scenes.
You might need to set "gamma 1.0" on the .png input file.
> scenes.
If you want to go that way, Tim Nikias’s Liquid-Surface-Simulation-Macros
http://www.nolights.de/downloads.html#lssm
Work quite well.
But you have IIRC a big sea. ;-)
I forgot that one indeed, but no change.
> Work quite well.
For the time being, it is curiosity (which kills the cat of course) ;-)
But yes, I probably shall have look into that too.
My sea is very large indeed: a sphere of 10e5 radius.
>> scenes.
> Work quite well.
That's a simulation for standing water over a mostly flat bottom.
In the Gancaloon scene, you have a river going into the sea. That mean
some current. Then, there is the problem of that flowing water
encountering the mostly static sea water. Add a realy uneven bottom with
possibly some abrupt depth changes.
The simulator may work well, but the current model is likely to cause it
to fail.
> to fail.
Reasons why I left this for (much) later. ;-)
Except for the island offshore, the sea and river bottoms are flat, but
the meeting of the two water bodies is challenging. At least I solved
the water colour mixing of the two (with some help of the community) a
couple of years ago.
