![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi everyone
Here's my latest Lego render. I've used focal blur in this scene but I
think I need to use motion blur. Is motion blur available in latest
version of POV-Ray or do I have to use MegaPov (or another patched
version or POV-Ray)?
Bye for now
Reuben
Download 3D Lego models and other resources from:
http://www.pearse.co.uk/lego
Download 'superman.png' (380 KB)
Preview of image 'superman.png'
![superman.png](/povray.binaries.images/attachment/%3C5096685b%40news.povray.org%3E/superman.png?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> version of POV-Ray
no, but you can simulate it by rendering an animation moving the
object in "sub-exposure" steps and then averaging the frames. This
also gives you the artistic freedom to give more weight to the final
frame if you want a more comic-like asymmetric blur for this scene.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> version of POV-Ray
Thanks for the info. Can you point me to any websites or tutorials that
explain this technique in more detail? Some example POV code would be
useful.
Reuben
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Lego Superman - Man of Steel
Date: 4 Nov 2012 10:10:24
Message: <50968560@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> useful.
Mostly I just remembered the thread "motion blur test" in these groups:
http://news.povray.org/povray.binaries.animations/thread/%3Cweb.4cdc16a1920b620ecaa39c860%40news.povray.org%3E/?mtop=352976
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> version of POV-Ray
Ah! A little trick I might need. The animation ng is not regularly open
on my system, but I should give it a look once in a while :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
cool!
> >> version of POV-Ray
> useful.
Here's the scene I use when averaging a number of pre-rendered frames:
#version 3.7;
global_settings{assumed_gamma 1.0}
#default{finish{ambient 1}}
camera{
orthographic
right x up y
location -z
#declare n_frames = 80;
#declare image_name_ = "superman"
#macro image_type_() png #end
plane{z,0
pigment{
average
pigment_map{
#for(V, 1, n_frames)
[1
#declare image_name = concat(image_name_, str(V, -(log(n_frames)/log(10) +
1), 0))
image_map{image_type_() image_name}
translate -(x+y)/2
Memory requirements can become pretty high when using large numbers of images,
especially if they are in the HDR format (but they work really well, especially
when rendering star fields).
Sam
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hm, I'm not quite sure, if this alone solves the issue of having motion blur
with POV 3.7. Should this wonderful superman not having decreasing transparency
during the flight? If you only average pictures of the flight, you will probably
get more blur than expected, since POV doesn't know the sequence of the
pictures. May be, proper weights in the average map will help. But you are still
limited to 256 entries. An other approach is to have copies of the blurred
object with decreasing transparency in the scene. But to find the correct
positions and transparencies is the hard job. Christian Froeschlin gave an
example with his entry "glocken" at the IRTC april 2006, which shows the idea
but the difficulties likewise (rendered at a higher resolution then the original
entry).
Best regards,
Michael
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Thomas
Ah! That is why I get no comment from you to my first (very technically) entry
there. And I value your comments very much ;-)
Best regards,
Michael
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> entry).
> Best regards,
> Michael
For the comicks like decreased transparency.
In this sample scene, all frames have the same weight, but it can be
changed:
[V // the weight goes from 1 to n_frames.
1), 0))
translate -(x+y)/2
By replacing the [1 by [V, the first image have a weight of 1, the
second a weight of 2,...
You can also use V/n_frames if you want to keep the weight parameter no
larger than 1.
You can increase the last image further in a few ways:
Add some number to the last image's weight.
Use pow(V,2) or pow(V/n_frames,2) for the weight. You can use a power of
3, 4 or some intermediate value if you want.
This assume that each frame is created in the direction of the movement
and that you want the last frame to dominate.
The limit of 256 entries is not a problem unless you have a very long
motion blur trail. If you use decreasing transparency, it's even less of
a problem, even with rather long trails.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > entry).
> > Best regards,
> > Michael
> changed:
> 1), 0))
> translate -(x+y)/2
> #end
> larger than 1.
> Alain
Yes, your proposal is much more detailed than mine. In fact I only mentioned the
general idea that simply averaging pictures of a flight will not yield a motion
blurred picture and proper weights are needed. But I think you have to play
around a lot with the weights and the number of images to find a proper image.
Best regards,
Michael
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
