Hi everyone
Here's my latest Lego render. I've used focal blur in this scene but I
think I need to use motion blur. Is motion blur available in latest
version of POV-Ray or do I have to use MegaPov (or another patched
version or POV-Ray)?
Bye for now
Reuben
Download 3D Lego models and other resources from:
http://www.pearse.co.uk/lego
Download 'superman.png' (380 KB)
Preview of image 'superman.png'
> version of POV-Ray
no, but you can simulate it by rendering an animation moving the
object in "sub-exposure" steps and then averaging the frames. This
also gives you the artistic freedom to give more weight to the final
frame if you want a more comic-like asymmetric blur for this scene.
>> version of POV-Ray
Thanks for the info. Can you point me to any websites or tutorials that
explain this technique in more detail? Some example POV code would be
useful.
Reuben
Subject: Re: Lego Superman - Man of Steel
Date: 4 Nov 2012 10:10:24
Message: <50968560@news.povray.org>
> useful.
Mostly I just remembered the thread "motion blur test" in these groups:
http://news.povray.org/povray.binaries.animations/thread/%3Cweb.4cdc16a1920b620ecaa39c860%40news.povray.org%3E/?mtop=352976
>> version of POV-Ray
Ah! A little trick I might need. The animation ng is not regularly open
on my system, but I should give it a look once in a while :-)
cool!
> >> version of POV-Ray
> useful.
Here's the scene I use when averaging a number of pre-rendered frames:
#version 3.7;
global_settings{assumed_gamma 1.0}
#default{finish{ambient 1}}
camera{
orthographic
right x up y
location -z
#declare n_frames = 80;
#declare image_name_ = "superman"
#macro image_type_() png #end
plane{z,0
pigment{
average
pigment_map{
#for(V, 1, n_frames)
[1
#declare image_name = concat(image_name_, str(V, -(log(n_frames)/log(10) +
1), 0))
image_map{image_type_() image_name}
translate -(x+y)/2
Memory requirements can become pretty high when using large numbers of images,
especially if they are in the HDR format (but they work really well, especially
when rendering star fields).
Sam
Hm, I'm not quite sure, if this alone solves the issue of having motion blur
with POV 3.7. Should this wonderful superman not having decreasing transparency
during the flight? If you only average pictures of the flight, you will probably
get more blur than expected, since POV doesn't know the sequence of the
pictures. May be, proper weights in the average map will help. But you are still
limited to 256 entries. An other approach is to have copies of the blurred
object with decreasing transparency in the scene. But to find the correct
positions and transparencies is the hard job. Christian Froeschlin gave an
example with his entry "glocken" at the IRTC april 2006, which shows the idea
but the difficulties likewise (rendered at a higher resolution then the original
entry).
Best regards,
Michael
> Thomas
Ah! That is why I get no comment from you to my first (very technically) entry
there. And I value your comments very much ;-)
Best regards,
Michael
> entry).
> Best regards,
> Michael
For the comicks like decreased transparency.
In this sample scene, all frames have the same weight, but it can be
changed:
[V // the weight goes from 1 to n_frames.
1), 0))
translate -(x+y)/2
By replacing the [1 by [V, the first image have a weight of 1, the
second a weight of 2,...
You can also use V/n_frames if you want to keep the weight parameter no
larger than 1.
You can increase the last image further in a few ways:
Add some number to the last image's weight.
Use pow(V,2) or pow(V/n_frames,2) for the weight. You can use a power of
3, 4 or some intermediate value if you want.
This assume that each frame is created in the direction of the movement
and that you want the last frame to dominate.
The limit of 256 entries is not a problem unless you have a very long
motion blur trail. If you use decreasing transparency, it's even less of
a problem, even with rather long trails.
> > entry).
> > Best regards,
> > Michael
> changed:
> 1), 0))
> translate -(x+y)/2
> #end
> larger than 1.
> Alain
Yes, your proposal is much more detailed than mine. In fact I only mentioned the
general idea that simply averaging pictures of a flight will not yield a motion
blurred picture and proper weights are needed. But I think you have to play
around a lot with the weights and the number of images to find a proper image.
Best regards,
Michael
Am 04.11.2012 20:46, schrieb MichaelJF:
As a matter of fact, for /realistic/ motion blur simple averaging of the
images /is/ the proper method. Whike the "opaque object with transparent
trail" look is a common staple - probably invented to give the
impression of motion while at the same time preserving object detail -
it is outright wrong.
>> Thomas
<blush> I shall have to experiment with this then... ;-)
Thanks, clipka... I knew I wasn't going crazy :) Maybe MJF is confusing motion
blur with tracers?
>> mentioned the
>> a motion
e
t
The "opaque object with transparent trail" is also what you get
with a flash light synced on the rear curtain and a long(ish)
exposure time (if you don't sync on the rear curtain, the "trail"
will be in front of the object, or sometimes on both sides).
For example:
http://www.apnphotographyschool.com/wp-content/uploads/2010/12/358x500xni
Jerome
mailto:jeb### [at] free fr
http://jeberger.free.fr
Jabber: jeb### [at] jabber fr
Download 'us-ascii' (1 KB)
"MichaelJF" <mi-### [at] t-online de> wrote:
> But you are still limited to 256 entries.
Actually, you're not. While it's true that any given _map is limited to 256
entries, you can nest maps to exceed that limitation. You're pretty much
averaging averaged pigments at that point :)
> blur with tracers?
Sorry, I don't know what I mixed up, may be impressions from ads, I took for
photographies or something like Jerome presented. Tracers certainly not, because
I first had to look up the wikipedia what this could be... But is superman very
far away from them?
Yes, as ever clipka is right, as is clear, if one thinks a bit more before
posting...
Best regards,
Michael
> Thomas
No need to blush;-) I only thought that my cheap trick could interest you
regarding your former profession.
Best regards,
Michael
Oh, absolutely. In fact I have been thinking about the contour line
possibilities for a long time without getting very far. So, I see great
possibilities in your technique.
But with regard of the motion blur proper, I have been thinking about
how to use the averaging method (to replace the Megapov application)
without loosing to much (render) time. One thing your comment above made
me think of was (1) to isolate the moving object from the scene proper,
(2) animate it to get motion blur on a transparent background and
average the frames, and finally (3) average the blurred object image
with the scene image.
While more work than with Megapov, I suppose that it might work, and it
probably is the technique used originally by Megapov, but then embedded
into the code.
Thanks, I just investigate if exr-pictures can achieve an improvement after
having reached a certain approximation of the landscape with png.
> into the code.
> Thomas
Sounds great, I think, this is the way to go.
Best regards,
Michael
Second thought: average the images with the transparent background and layer the
result over the original scene only. Otherwise the original scene (background)
has a chance to come into the object in motion. Ok, may be only to a small,
hardly visible amount...
Best regards,
Michael
Am 06.11.2012 20:42, schrieb MichaelJF:
While OpenEXR will give you an improvement, it would still be a
comparatively poor choice, as its absolute precision varies considerably
between dark and bright regions of an image, so you'd have different
quality on high plateaus than in low plains.
For your purposes, any classic file format with a 16-bit color depth
would be better suited, such as 16-bit png.
Am 06.11.2012 21:17, schrieb MichaelJF:
No, you're perfectly right there: averaging is the wrong operation for
this job; you do want an overlay operation.
Many thanks, it's just an experiment. And I see I have still much to learn,
again. But this is one reason I try to make pictures with POV, I learn. By
observation or even by being corrected for errors or misjudgements by this
wonderful community.
Best regards,
Michael
>> layer the
>> (background)
>> small,
Hmm yes. That is true. Not as straightforward as I thought. And if some
element of the scene partly obscures the moving object both techniques
won't work correctly. But otherwise an overlay would do.
We still need a megapov-type piece of code in the software.
