POV-Ray : Newsgroups : povray.binaries.images : (WIP) Mono-plug ~41kb - plug_scene.jpg Server Time
23 Oct 2026 15:30:20 EDT (-0400)
  (WIP) Mono-plug ~41kb - plug_scene.jpg (Message 1 to 14 of 14)
Subject: (WIP) Mono-plug ~41kb - plug_scene.jpg
Date: 10 Jun 2001 02:56:33
Message: <4sg6itgu6p26dlbov37i842dimqnpujh4b@4ax.com>
Any ideas what else should be in the scene?....comments welcome too.
Oldstench................
Download 'plug_scene.jpg' (41 KB)
Preview of image 'plug_scene.jpg'
Subject: Re: (WIP) Mono-plug ~41kb - plug_scene.jpg
Date: 10 Jun 2001 04:32:55
Message: <3B2330CB.19611D4E@ibras.dk>
A guitar and an amp, perhaps...
Nice plug, though. The red part looks like rubber, is that intended?
/Ib
Date: 10 Jun 2001 06:46:47
Message: <3b235017@news.povray.org>
"Oldstench" <sor### [at] butnocom> wrote in message
news:4sg6itgu6p26dlbov37i842dimqnpujh4b@4ax.com...
        How about a Gibson plectrum?
         Nice plug, bang on apart from the bend nearest the plug.
         I don't think it would do that in reality?
       ~Steve~
Date: 10 Jun 2001 07:04:14
Message: <3B235536.4EC33910@home.com>
It could do that bend but half the timr you have that it means that some
of the wires are broken
>        ~Steve~
Date: 10 Jun 2001 07:20:09
Message: <3b2357e9@news.povray.org>
"Psychomech" <psy### [at] homecom> wrote in message
news:3B235536.4EC33910@home.com...
    lol. True!  The amount of times that I've tried to repair mine.... ;)
     ~Steve~
> >        ~Steve~
Date: 10 Jun 2001 07:22:11
Message: <3B235860.58FA5CF2@videotron.ca>
Very good.  I can almost hear the hum of the amplifier...
I think the metallic pin looks more like grey plastic.  Try modifying
the highlight and putting radial microscopic scratches resulting from
the manufacturing process.  As thers have mentioned, the kink in the
wire is a bit too severe.
Francois Labreque | It is by caffeine alone I set my mind in motion, it
    flabreque     | is by the beans of Java that thoughts acquire speed,
        @         | the hands acquire shaking, the shaking becomes a
   videotron.ca   | warning, it is by caffeine alone I set my mind in
                  | motion.
                               - Stolen from Badger's .sig file
Date: 10 Jun 2001 07:33:23
Message: <slrn9i6i5e.9bl.steve@zero-pps.localdomain>
I like the cable, how did you do it?
The metal part of the plug looks very old and tarnished, so on that
table you need coffe stains, some ash strewen about, an old casset
tape in bits etc.
The reason I never get anything done is because I keep getting new
ideas, what an inspirational lot you all are:-)
 11:11am  up 128 days, 12:01,  2 users,  load average: 1.02, 1.04, 1.00
Date: 10 Jun 2001 07:53:46
Message: <3b235fca$1@news.povray.org>
    Hmm... the radius of the bend in the wire makes it look like either the
wire is -much- softer than it should be, or that the plug is -much- larger
than it should be.
    Otherwise the modeling is great. Comparing it to what I have here, it is
almost perfect in dimensions and textures.
Date: 10 Jun 2001 14:10:19
Message: <4ho7it471hdspslc7ennnvhltshv6ecgli@4ax.com>
>Nice plug, though.
Thank you...
Plastic is what I was going for...needs some more work I suppose....
Date: 10 Jun 2001 14:11:00
Message: <bjo7itsf9d6ufmaue0ntg0jbqm6n91vd6t@4ax.com>
Ok...it will be fixed
Date: 10 Jun 2001 14:11:31
Message: <8ko7it0n5dth3589dmjiuftllmhsededd2@4ax.com>
Thank you
Ok...will give it a try
Date: 10 Jun 2001 14:13:07
Message: <mlo7itccru60q9lont6rsj0ibb3e8hv2e6@4ax.com>
Thank you...all modelling was done in Rhino, imported into Moray and
textured there.. The wire is a spline with a pipe extruded around it.
>tape in bits etc.
I like the idea about a tape...shall try that next
Date: 10 Jun 2001 14:13:46
Message: <foo7itsls3k671i9gp12e9of2r749l1i31@4ax.com>
>than it should be.
I am sensing a pattern....
Thanks
Date: 11 Jun 2001 23:30:08
Message: <3b258cc0$1@news.povray.org>
Looks nice!  My only complaint is that the metal looks too "foggy".  If you
make it a little more reflective, that should do the trick!
-Ian
